RTEMS 5.2
sparc64.h
1
11/*
12 * COPYRIGHT (c) 1989-1999. On-Line Applications Research Corporation (OAR).
13 *
14 * This file is based on the SPARC sparc.h file. Modifications are made
15 * to support the SPARC64 processor.
16 * COPYRIGHT (c) 2010. Gedare Bloom.
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _RTEMS_SCORE_SPARC_H
24#define _RTEMS_SCORE_SPARC_H
25
26#ifdef __cplusplus
27extern "C" {
28#endif
29
30/*
31 * This file contains the information required to build
32 * RTEMS for a particular member of the "sparc" family. It does
33 * this by setting variables to indicate which implementation
34 * dependent features are present in a particular member
35 * of the family.
36 *
37 * Currently recognized feature flags:
38 *
39 * + SPARC_HAS_FPU
40 * 0 - no HW FPU
41 * 1 - has HW FPU (assumed to be compatible w/90C602)
42 *
43 * + SPARC_HAS_BITSCAN
44 * 0 - does not have scan instructions
45 * 1 - has scan instruction (not currently implemented)
46 *
47 * + SPARC_NUMBER_OF_REGISTER_WINDOWS
48 * 8 is the most common number supported by SPARC implementations.
49 * SPARC_PSR_CWP_MASK is derived from this value.
50 */
51
52/*
53 * Some higher end SPARCs have a bitscan instructions. It would
54 * be nice to take advantage of them. Right now, there is no
55 * port to a CPU model with this feature and no (untested) code
56 * that is based on this feature flag.
57 */
58
59#define SPARC_HAS_BITSCAN 0
60
61/*
62 * This should be OK until a port to a higher end SPARC processor
63 * is made that has more than 8 register windows. If this cannot
64 * be determined based on multilib settings (v7/v8/v9), then the
65 * cpu_asm.S code that depends on this will have to move to libcpu.
66 *
67 * SPARC v9 supports from 3 to 32 register windows.
68 * N_REG_WINDOWS = 8 on UltraSPARC T1 (impl. dep. #2-V8).
69 */
70
71#define SPARC_NUMBER_OF_REGISTER_WINDOWS 8
72
73/*
74 * This should be determined based on some soft float derived
75 * cpp predefine but gcc does not currently give us that information.
76 */
77
78
79#if defined(_SOFT_FLOAT)
80#define SPARC_HAS_FPU 0
81#else
82#define SPARC_HAS_FPU 1
83#endif
84
85#if SPARC_HAS_FPU
86#define CPU_MODEL_NAME "w/FPU"
87#else
88#define CPU_MODEL_NAME "w/soft-float"
89#endif
90
91/*
92 * Define the name of the CPU family.
93 */
94
95#define CPU_NAME "SPARC"
96
97/*
98 * Miscellaneous constants
99 */
100
101/*
102 * The PSR is deprecated and deleted.
103 *
104 * The following registers represent fields of the PSR:
105 * PIL - Processor Interrupt Level register
106 * CWP - Current Window Pointer register
107 * VER - Version register
108 * CCR - Condition Codes Register
109 * PSTATE - Processor State register
110 */
111
112/*
113 * PSTATE masks and starting bit positions
114 *
115 * NOTE: Reserved bits are ignored.
116 */
117
118#define SPARC_PSTATE_AG_MASK 0x00000001 /* bit 0 */
119#define SPARC_PSTATE_IE_MASK 0x00000002 /* bit 1 */
120#define SPARC_PSTATE_PRIV_MASK 0x00000004 /* bit 2 */
121#define SPARC_PSTATE_AM_MASK 0x00000008 /* bit 3 */
122#define SPARC_PSTATE_PEF_MASK 0x00000010 /* bit 4 */
123#define SPARC_PSTATE_MM_MASK 0x00000040 /* bit 6 */
124#define SPARC_PSTATE_TLE_MASK 0x00000100 /* bit 8 */
125#define SPARC_PSTATE_CLE_MASK 0x00000200 /* bit 9 */
126
127#define SPARC_PSTATE_AG_BIT_POSITION 0 /* bit 0 */
128#define SPARC_PSTATE_IE_BIT_POSITION 1 /* bit 1 */
129#define SPARC_PSTATE_PRIV_BIT_POSITION 2 /* bit 2 */
130#define SPARC_PSTATE_AM_BIT_POSITION 3 /* bit 3 */
131#define SPARC_PSTATE_PEF_BIT_POSITION 4 /* bit 4 */
132#define SPARC_PSTATE_MM_BIT_POSITION 6 /* bit 6 */
133#define SPARC_PSTATE_TLE_BIT_POSITION 8 /* bit 8 */
134#define SPARC_PSTATE_CLE_BIT_POSITION 9 /* bit 9 */
135
136#define SPARC_FPRS_FEF_MASK 0x0100 /* bit 2 */
137#define SPARC_FPRS_FEF_BIT_POSITION 2 /* bit 2 */
138
139#define SPARC_TSTATE_IE_MASK 0x00000200 /* bit 9 */
140
141#define SPARC_SOFTINT_TM_MASK 0x00000001 /* bit 0 */
142#define SPARC_SOFTINT_SM_MASK 0x00010000 /* bit 16 */
143#define SPARC_SOFTINT_TM_BIT_POSITION 1 /* bit 0 */
144#define SPARC_SOFTINT_SM_BIT_POSITION 17 /* bit 16 */
145
146#define STACK_BIAS (2047)
147
148#ifdef ASM
149
150/*
151 * To enable the FPU we need to set both PSTATE.pef and FPRS.fef
152 */
153
154#define sparc64_enable_FPU(rtmp1) \
155 rdpr %pstate, rtmp1; \
156 or rtmp1, SPARC_PSTATE_PEF_MASK, rtmp1; \
157 wrpr %g0, rtmp1, %pstate; \
158 rd %fprs, rtmp1; \
159 or rtmp1, SPARC_FPRS_FEF_MASK, rtmp1; \
160 wr %g0, rtmp1, %fprs
161
162
163#endif
164
165#ifndef ASM
166
167/*
168 * Standard nop
169 */
170
171#define nop() \
172 do { \
173 __asm__ volatile ( "nop" ); \
174 } while ( 0 )
175
176/*
177 * Get and set the pstate
178 */
179
180#define sparc64_get_pstate( _pstate ) \
181 do { \
182 (_pstate) = 0; \
183 __asm__ volatile( "rdpr %%pstate, %0" : "=r" (_pstate) : "0" (_pstate) ); \
184 } while ( 0 )
185
186#define sparc64_set_pstate( _pstate ) \
187 do { \
188 __asm__ volatile ( \
189 "wrpr %%g0, %0, %%pstate " : "=r" ((_pstate)) : "0" ((_pstate)) ); \
190 } while ( 0 )
191
192/*
193 * Get and set the PIL
194 */
195
196#define sparc64_get_pil( _pil ) \
197 do { \
198 (_pil) = 0; \
199 __asm__ volatile( "rdpr %%pil, %0" : "=r" (_pil) : "0" (_pil) ); \
200 } while ( 0 )
201
202#define sparc64_set_pil( _pil ) \
203 do { \
204 __asm__ volatile ( "wrpr %%g0, %0, %%pil " : "=r" ((_pil)) : "0" ((_pil)) ); \
205 } while ( 0 )
206
207
208/*
209 * Get and set the TBA
210 */
211
212#define sparc64_get_tba( _tba ) \
213 do { \
214 (_tba) = 0; /* to avoid unitialized warnings */ \
215 __asm__ volatile( "rdpr %%tba, %0" : "=r" (_tba) : "0" (_tba) ); \
216 } while ( 0 )
217
218#define sparc64_set_tba( _tba ) \
219 do { \
220 __asm__ volatile( "wrpr %%g0, %0, %%tba" : "=r" (_tba) : "0" (_tba) ); \
221 } while ( 0 )
222
223/*
224 * Get and set the TL (trap level)
225 */
226
227#define sparc64_get_tl( _tl ) \
228 do { \
229 (_tl) = 0; /* to avoid unitialized warnings */ \
230 __asm__ volatile( "rdpr %%tl, %0" : "=r" (_tl) : "0" (_tl) ); \
231 } while ( 0 )
232
233#define sparc64_set_tl( _tl ) \
234 do { \
235 __asm__ volatile( "wrpr %%g0, %0, %%tl" : "=r" (_tl) : "0" (_tl) ); \
236 } while ( 0 )
237
238
239/*
240 * read the stick register
241 *
242 * Note:
243 * stick asr=24, mnemonic=stick
244 * Note: stick does not appear to be a valid ASR for US3, although it is
245 * implemented in US3i.
246 */
247#define sparc64_read_stick( _stick ) \
248 do { \
249 (_stick) = 0; \
250 __asm__ volatile( "rd %%stick, %0" : "=r" (_stick) : "0" (_stick) ); \
251 } while ( 0 )
252
253/*
254 * write the stick_cmpr register
255 *
256 * Note:
257 * stick_cmpr asr=25, mnemonic=stick_cmpr
258 * Note: stick_cmpr does not appear to be a valid ASR for US3, although it is
259 * implemented in US3i.
260 */
261#define sparc64_write_stick_cmpr( _stick_cmpr ) \
262 do { \
263 __asm__ volatile( "wr %%g0, %0, %%stick_cmpr" : "=r" (_stick_cmpr) \
264 : "0" (_stick_cmpr) ); \
265 } while ( 0 )
266
267/*
268 * read the Tick register
269 */
270#define sparc64_read_tick( _tick ) \
271 do { \
272 (_tick) = 0; \
273 __asm__ volatile( "rd %%tick, %0" : "=r" (_tick) : "0" (_tick) ); \
274 } while ( 0 )
275
276/*
277 * write the tick_cmpr register
278 */
279#define sparc64_write_tick_cmpr( _tick_cmpr ) \
280 do { \
281 __asm__ volatile( "wr %%g0, %0, %%tick_cmpr" : "=r" (_tick_cmpr) \
282 : "0" (_tick_cmpr) ); \
283 } while ( 0 )
284
285/*
286 * Clear the softint register.
287 *
288 * sun4u and sun4v: softint_clr asr = 21, with mnemonic clear_softint
289 */
290#define sparc64_clear_interrupt_bits( _bit_mask ) \
291 do { \
292 __asm__ volatile( "wr %%g0, %0, %%clear_softint" : "=r" (_bit_mask) \
293 : "0" (_bit_mask)); \
294 } while ( 0 )
295
296/************* DEPRECATED ****************/
297/* Note: Although the y register is deprecated, gcc still uses it */
298/*
299 * Get and set the Y
300 */
301
302#define sparc_get_y( _y ) \
303 do { \
304 __asm__ volatile( "rd %%y, %0" : "=r" (_y) : "0" (_y) ); \
305 } while ( 0 )
306
307#define sparc_set_y( _y ) \
308 do { \
309 __asm__ volatile( "wr %0, %%y" : "=r" (_y) : "0" (_y) ); \
310 } while ( 0 )
311
312/************* /DEPRECATED ****************/
313
314/*
315 * Manipulate the interrupt level in the pstate
316 */
317
318uint32_t sparc_disable_interrupts(void);
319void sparc_enable_interrupts(uint32_t);
320
321#define sparc_flash_interrupts( _level ) \
322 do { \
323 uint32_t _ignored; \
324 \
325 sparc_enable_interrupts( (_level) ); \
326 _ignored = sparc_disable_interrupts(); \
327 (void) _ignored; \
328 } while ( 0 )
329
330#define sparc64_get_interrupt_level( _level ) \
331 do { \
332 _level = 0; \
333 sparc64_get_pil( _level ); \
334 } while ( 0 )
335
336#endif /* !ASM */
337
338#ifdef __cplusplus
339}
340#endif
341
342#endif /* _RTEMS_SCORE_SPARC_H */
