RTEMS 5.2
serial_mouse.h
1
15/*
16 * COPYRIGHT (c) 1989-2011.
17 * On-Line Applications Research Corporation (OAR).
18 *
19 * The license and distribution terms for this file may be
20 * found in the file LICENSE in this distribution or at
21 * http://www.rtems.org/license/LICENSE.
22 */
23
24#ifndef __SERIAL_MOUSE_h__
25#define __SERIAL_MOUSE_h__
26
27#include <rtems/io.h>
28
29/* functions */
30
36#ifdef __cplusplus
37extern "C" {
38#endif
39
43#define SERIAL_MOUSE_DEVICE_PS2 "/dev/psaux"
44
48#define SERIAL_MOUSE_DRIVER_TABLE_ENTRY \
49 { serial_mouse_initialize, serial_mouse_open, serial_mouse_close, \
50 serial_mouse_read, serial_mouse_write, serial_mouse_control }
51
62 rtems_device_major_number major,
63 rtems_device_minor_number minor,
64 void *arg
65);
66
78 rtems_device_major_number major,
79 rtems_device_minor_number minor,
80 void *arg
81);
82
94 rtems_device_major_number major,
95 rtems_device_minor_number minor,
96 void *arg
97);
98
110 rtems_device_major_number major,
111 rtems_device_minor_number minor,
112 void *arg
113);
114
126 rtems_device_major_number major,
127 rtems_device_minor_number minor,
128 void *arg
129);
130
142 rtems_device_major_number major,
143 rtems_device_minor_number minor,
144 void *arg
145);
146
161 const char **name,
162 const char **type
163);
164
165#ifdef __cplusplus
166}
167#endif
169#endif /* __tty_drv__ */
Classic Input/Output Manager API.
rtems_status_code
Classic API Status.
Definition: status.h:43
rtems_device_driver serial_mouse_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Close device driver entry point for the serial mouse driver.
Definition: serial_mouse.c:132
rtems_device_driver serial_mouse_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Write device driver entry point for the serial mouse driver.
Definition: serial_mouse.c:153
rtems_device_driver serial_mouse_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
IO Control device driver entry point for the serial mouse driver.
Definition: serial_mouse.c:163
bool bsp_get_serial_mouse_device(const char **name, const char **type)
Obtain serial mouse configuration information.
Definition: serial_mouse_config.c:29
rtems_device_driver serial_mouse_read(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Read device driver entry point for the serial mouse driver.
Definition: serial_mouse.c:143
rtems_device_driver serial_mouse_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
The initialization of the serial mouse driver.
Definition: serial_mouse.c:59
rtems_device_driver serial_mouse_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Open device driver entry point for the serial mouse driver.
Definition: serial_mouse.c:80
