RTEMS 5.2
sdramc.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
36// ---------------------------------------------------------------------------
37// SDRAM
38// ---------------------------------------------------------------------------
40#define EBI_SDRAMC_ADDR (0x70000000u)
41
43#define BOARD_SDRAM_BUSWIDTH 16
44
45
46typedef struct _SSdramc_config {
47 uint32_t dwColumnBits; // Number of Column Bits
48 uint32_t dwRowBits; // Number of Row Bits
49 uint32_t dwBanks; // Number of Banks
50 uint32_t dwCAS; // CAS Latency
51 uint32_t dwDataBusWidth; // Data Bus Width
52 uint32_t dwWriteRecoveryDelay; // Write Recovery Delay
53 uint32_t dwRowCycleDelay_RowRefreshCycle; // Row Cycle Delay and Row Refresh Cycle
54 uint32_t dwRowPrechargeDelay; // Row Precharge Delay
55 uint32_t dwRowColumnDelay; // Row to Column Delay
56 uint32_t dwActivePrechargeDelay; // Active to Precharge Delay
57 uint32_t dwExitSelfRefreshActiveDelay; // Exit Self Refresh to Active Delay
58 uint32_t dwBK1; // bk1 addr
59
61
62typedef struct _SSdramc_Memory {
64
66
67extern void SDRAMC_Configure(SSdramc_Memory *pMemory,
68 uint32_t dwClockFrequency);
void SDRAMC_Configure(SSdramc_Memory *pMemory, uint32_t dwClockFrequency)
Configure and initialize the SDRAM controller.
Definition: sdramc.c:106
Definition: sdramc.h:62
Definition: sdramc.h:46
