RTEMS 5.2
sc16is752-regs.h
1/*
2 * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <info@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef LIBBSP_ARM_ATSAM_SC16IS752_H
16#define LIBBSP_ARM_ATSAM_SC16IS752_H
17
18#ifdef __cplusplus
19extern "C" {
20#endif /* __cplusplus */
21
22/* General register set */
23#define SC16IS752_RHR 0x0
24#define SC16IS752_THR 0x0
25#define SC16IS752_IER 0x1
26#define SC16IS752_FCR 0x2
27#define SC16IS752_IIR 0x2
28#define SC16IS752_LCR 0x3
29#define SC16IS752_MCR 0x4
30#define SC16IS752_LSR 0x5
31#define SC16IS752_MSR 0x6
32#define SC16IS752_TCR 0x6
33#define SC16IS752_SPR 0x7
34#define SC16IS752_TLR 0x7
35#define SC16IS752_TXLVL 0x8
36#define SC16IS752_RXLVL 0x9
37#define SC16IS752_IODIR 0xA
38#define SC16IS752_IOSTATE 0xB
39#define SC16IS752_IOINTENA 0xC
40#define SC16IS752_IOCONTROL 0xE
41#define SC16IS752_EFCR 0xF
42
43/* Special register set */
44#define SC16IS752_DLL 0x0
45#define SC16IS752_DLH 0x1
46
47/* Enhanced register set */
48#define SC16IS752_EFR 0x2
49#define SC16IS752_XON1 0x4
50#define SC16IS752_XON2 0x5
51#define SC16IS752_XOFF1 0x6
52#define SC16IS752_XOFF2 0x7
53
54/* FCR */
55#define SC16IS752_FCR_FIFO_EN 0x01
56#define SC16IS752_FCR_RX_FIFO_RST 0x02
57#define SC16IS752_FCR_TX_FIFO_RST 0x04
58#define SC16IS752_FCR_TX_FIFO_TRG_8 0x00
59#define SC16IS752_FCR_TX_FIFO_TRG_16 0x10
60#define SC16IS752_FCR_TX_FIFO_TRG_32 0x20
61#define SC16IS752_FCR_TX_FIFO_TRG_56 0x30
62#define SC16IS752_FCR_RX_FIFO_TRG_8 0x00
63#define SC16IS752_FCR_RX_FIFO_TRG_16 0x40
64#define SC16IS752_FCR_RX_FIFO_TRG_56 0x80
65#define SC16IS752_FCR_RX_FIFO_TRG_60 0xc0
66
67/* EFCR */
68#define SC16IS752_EFCR_RS485_ENABLE (1u << 0)
69#define SC16IS752_EFCR_RX_DISABLE (1u << 1)
70#define SC16IS752_EFCR_TX_DISABLE (1u << 2)
71#define SC16IS752_EFCR_RTSCON (1u << 4)
72#define SC16IS752_EFCR_RTSINVER (1u << 5)
73
74/* IER */
75#define SC16IS752_IER_RHR (1u << 0)
76#define SC16IS752_IER_THR (1u << 1)
77#define SC16IS752_IER_RECEIVE_LINE_STATUS (1u << 2)
78#define SC16IS752_IER_MODEM_STATUS (1u << 3)
79#define SC16IS752_IER_SLEEP_MODE (1u << 4)
80#define SC16IS752_IER_XOFF (1u << 5)
81#define SC16IS752_IER_RTS (1u << 6)
82#define SC16IS752_IER_CTS (1u << 7)
83
84/* IIR */
85#define SC16IS752_IIR_TX_INTERRUPT (1u << 1)
86#define SC16IS752_IIR_RX_INTERRUPT (1u << 2)
87
88/* LCR */
89#define SC16IS752_LCR_CHRL_5_BIT (0u << 1) | (0u << 0)
90#define SC16IS752_LCR_CHRL_6_BIT (0u << 1) | (1u << 0)
91#define SC16IS752_LCR_CHRL_7_BIT (1u << 1) | (0u << 0)
92#define SC16IS752_LCR_CHRL_8_BIT (1u << 1) | (1u << 0)
93#define SC16IS752_LCR_2_STOP_BIT (1u << 2)
94#define SC16IS752_LCR_SET_PARITY (1u << 3)
95#define SC16IS752_LCR_EVEN_PARITY (1u << 4)
96#define SC16IS752_LCR_BREAK (1u << 5)
97#define SC16IS752_LCR_ENABLE_DIVISOR (1u << 7)
98
99/* LSR */
100#define SC16IS752_LSR_TXEMPTY (1u << 5)
101#define SC16IS752_LSR_RXRDY (1u << 0)
102#define SC16IS752_LSR_ERROR_BITS (7u << 2)
103
104/* MCR */
105#define SC16IS752_MCR_DTR (1u << 0)
106#define SC16IS752_MCR_RTS (1u << 1)
107#define SC16IS752_MCR_TCR_TLR (1u << 2)
108#define SC16IS752_MCR_LOOPBACK (1u << 4)
109#define SC16IS752_MCR_XON_ANY (1u << 5)
110#define SC16IS752_MCR_IRDA_ENABLE (1u << 6)
111#define SC16IS752_MCR_PRESCALE_NEEDED (1u << 7)
112
113/* MSR */
114#define SC16IS752_MSR_dCTS (1u << 0)
115#define SC16IS752_MSR_dDSR (1u << 1)
116#define SC16IS752_MSR_dRI (1u << 2)
117#define SC16IS752_MSR_dCD (1u << 3)
118#define SC16IS752_MSR_CTS (1u << 4)
119#define SC16IS752_MSR_DSR (1u << 5)
120#define SC16IS752_MSR_RI (1u << 6)
121#define SC16IS752_MSR_CD (1u << 7)
122
123/* EFR */
124#define SC16IS752_EFR_ENHANCED_FUNC_ENABLE (1u << 4)
125#define SC16IS752_EFR_SPECIAL_CHAR_DETECT (1u << 5)
126#define SC16IS752_EFR_RTS_FLOW_CTRL_EN (1u << 6)
127#define SC16IS752_EFR_CTS_FLOW_CTRL_EN (1u << 7)
128
129/* IOCONTROL: User accessible. Therefore see sc16is752.h for the defines. */
130
131#define SC16IS752_FIFO_DEPTH 64
132
133#ifdef __cplusplus
134}
135#endif /* __cplusplus */
136
137#endif /* LIBBSP_ARM_ATSAM_SC16IS752_H */
