RTEMS 5.2
component_rtt.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_RTT_COMPONENT_
31#define _SAMV71_RTT_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __IO uint32_t RTT_MR;
43 __IO uint32_t RTT_AR;
44 __I uint32_t RTT_VR;
45 __I uint32_t RTT_SR;
46} Rtt;
47#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
48/* -------- RTT_MR : (RTT Offset: 0x00) Mode Register -------- */
49#define RTT_MR_RTPRES_Pos 0
50#define RTT_MR_RTPRES_Msk (0xffffu << RTT_MR_RTPRES_Pos)
51#define RTT_MR_RTPRES(value) ((RTT_MR_RTPRES_Msk & ((value) << RTT_MR_RTPRES_Pos)))
52#define RTT_MR_ALMIEN (0x1u << 16)
53#define RTT_MR_RTTINCIEN (0x1u << 17)
54#define RTT_MR_RTTRST (0x1u << 18)
55#define RTT_MR_RTTDIS (0x1u << 20)
56#define RTT_MR_RTC1HZ (0x1u << 24)
57/* -------- RTT_AR : (RTT Offset: 0x04) Alarm Register -------- */
58#define RTT_AR_ALMV_Pos 0
59#define RTT_AR_ALMV_Msk (0xffffffffu << RTT_AR_ALMV_Pos)
60#define RTT_AR_ALMV(value) ((RTT_AR_ALMV_Msk & ((value) << RTT_AR_ALMV_Pos)))
61/* -------- RTT_VR : (RTT Offset: 0x08) Value Register -------- */
62#define RTT_VR_CRTV_Pos 0
63#define RTT_VR_CRTV_Msk (0xffffffffu << RTT_VR_CRTV_Pos)
64/* -------- RTT_SR : (RTT Offset: 0x0C) Status Register -------- */
65#define RTT_SR_ALMS (0x1u << 0)
66#define RTT_SR_RTTINC (0x1u << 1)
69
70
71#endif /* _SAMV71_RTT_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __I
Definition: core_cm7.h:284
Rtt hardware registers.
Definition: component_rtt.h:41
