RTEMS 5.2
component_pmc.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_PMC_COMPONENT_
31#define _SAMV71_PMC_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __O uint32_t PMC_SCER;
43 __O uint32_t PMC_SCDR;
44 __I uint32_t PMC_SCSR;
45 __I uint32_t Reserved1[1];
46 __O uint32_t PMC_PCER0;
47 __O uint32_t PMC_PCDR0;
48 __I uint32_t PMC_PCSR0;
49 __IO uint32_t CKGR_UCKR;
50 __IO uint32_t CKGR_MOR;
51 __IO uint32_t CKGR_MCFR;
52 __IO uint32_t CKGR_PLLAR;
53 __I uint32_t Reserved2[1];
54 __IO uint32_t PMC_MCKR;
55 __I uint32_t Reserved3[1];
56 __IO uint32_t PMC_USB;
57 __I uint32_t Reserved4[1];
58 __IO uint32_t PMC_PCK[7];
59 __I uint32_t Reserved5[1];
60 __O uint32_t PMC_IER;
61 __O uint32_t PMC_IDR;
62 __I uint32_t PMC_SR;
63 __I uint32_t PMC_IMR;
64 __IO uint32_t PMC_FSMR;
65 __IO uint32_t PMC_FSPR;
66 __O uint32_t PMC_FOCR;
67 __I uint32_t Reserved6[26];
68 __IO uint32_t PMC_WPMR;
69 __I uint32_t PMC_WPSR;
70 __I uint32_t Reserved7[4];
71 __I uint32_t PMC_VERSION;
72 __O uint32_t PMC_PCER1;
73 __O uint32_t PMC_PCDR1;
74 __I uint32_t PMC_PCSR1;
75 __IO uint32_t PMC_PCR;
76 __IO uint32_t PMC_OCR;
77 __O uint32_t PMC_SLPWK_ER0;
78 __O uint32_t PMC_SLPWK_DR0;
79 __I uint32_t PMC_SLPWK_SR0;
80 __I uint32_t PMC_SLPWK_ASR0;
81 __I uint32_t Reserved8[3];
82 __IO uint32_t PMC_PMMR;
83 __O uint32_t PMC_SLPWK_ER1;
84 __O uint32_t PMC_SLPWK_DR1;
85 __I uint32_t PMC_SLPWK_SR1;
86 __I uint32_t PMC_SLPWK_ASR1;
87 __I uint32_t PMC_SLPWK_AIPR;
88} Pmc;
89#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
90/* -------- PMC_SCER : (PMC Offset: 0x0000) System Clock Enable Register -------- */
91#define PMC_SCER_USBCLK (0x1u << 5)
92#define PMC_SCER_PCK0 (0x1u << 8)
93#define PMC_SCER_PCK1 (0x1u << 9)
94#define PMC_SCER_PCK2 (0x1u << 10)
95#define PMC_SCER_PCK3 (0x1u << 11)
96#define PMC_SCER_PCK4 (0x1u << 12)
97#define PMC_SCER_PCK5 (0x1u << 13)
98#define PMC_SCER_PCK6 (0x1u << 14)
99/* -------- PMC_SCDR : (PMC Offset: 0x0004) System Clock Disable Register -------- */
100#define PMC_SCDR_USBCLK (0x1u << 5)
101#define PMC_SCDR_PCK0 (0x1u << 8)
102#define PMC_SCDR_PCK1 (0x1u << 9)
103#define PMC_SCDR_PCK2 (0x1u << 10)
104#define PMC_SCDR_PCK3 (0x1u << 11)
105#define PMC_SCDR_PCK4 (0x1u << 12)
106#define PMC_SCDR_PCK5 (0x1u << 13)
107#define PMC_SCDR_PCK6 (0x1u << 14)
108/* -------- PMC_SCSR : (PMC Offset: 0x0008) System Clock Status Register -------- */
109#define PMC_SCSR_USBCLK (0x1u << 5)
110#define PMC_SCSR_PCK0 (0x1u << 8)
111#define PMC_SCSR_PCK1 (0x1u << 9)
112#define PMC_SCSR_PCK2 (0x1u << 10)
113#define PMC_SCSR_PCK3 (0x1u << 11)
114#define PMC_SCSR_PCK4 (0x1u << 12)
115#define PMC_SCSR_PCK5 (0x1u << 13)
116#define PMC_SCSR_PCK6 (0x1u << 14)
117/* -------- PMC_PCER0 : (PMC Offset: 0x0010) Peripheral Clock Enable Register 0 -------- */
118#define PMC_PCER0_PID7 (0x1u << 7)
119#define PMC_PCER0_PID8 (0x1u << 8)
120#define PMC_PCER0_PID9 (0x1u << 9)
121#define PMC_PCER0_PID10 (0x1u << 10)
122#define PMC_PCER0_PID11 (0x1u << 11)
123#define PMC_PCER0_PID12 (0x1u << 12)
124#define PMC_PCER0_PID13 (0x1u << 13)
125#define PMC_PCER0_PID14 (0x1u << 14)
126#define PMC_PCER0_PID15 (0x1u << 15)
127#define PMC_PCER0_PID16 (0x1u << 16)
128#define PMC_PCER0_PID17 (0x1u << 17)
129#define PMC_PCER0_PID18 (0x1u << 18)
130#define PMC_PCER0_PID19 (0x1u << 19)
131#define PMC_PCER0_PID20 (0x1u << 20)
132#define PMC_PCER0_PID21 (0x1u << 21)
133#define PMC_PCER0_PID22 (0x1u << 22)
134#define PMC_PCER0_PID23 (0x1u << 23)
135#define PMC_PCER0_PID24 (0x1u << 24)
136#define PMC_PCER0_PID25 (0x1u << 25)
137#define PMC_PCER0_PID26 (0x1u << 26)
138#define PMC_PCER0_PID27 (0x1u << 27)
139#define PMC_PCER0_PID28 (0x1u << 28)
140#define PMC_PCER0_PID29 (0x1u << 29)
141#define PMC_PCER0_PID30 (0x1u << 30)
142#define PMC_PCER0_PID31 (0x1u << 31)
143/* -------- PMC_PCDR0 : (PMC Offset: 0x0014) Peripheral Clock Disable Register 0 -------- */
144#define PMC_PCDR0_PID7 (0x1u << 7)
145#define PMC_PCDR0_PID8 (0x1u << 8)
146#define PMC_PCDR0_PID9 (0x1u << 9)
147#define PMC_PCDR0_PID10 (0x1u << 10)
148#define PMC_PCDR0_PID11 (0x1u << 11)
149#define PMC_PCDR0_PID12 (0x1u << 12)
150#define PMC_PCDR0_PID13 (0x1u << 13)
151#define PMC_PCDR0_PID14 (0x1u << 14)
152#define PMC_PCDR0_PID15 (0x1u << 15)
153#define PMC_PCDR0_PID16 (0x1u << 16)
154#define PMC_PCDR0_PID17 (0x1u << 17)
155#define PMC_PCDR0_PID18 (0x1u << 18)
156#define PMC_PCDR0_PID19 (0x1u << 19)
157#define PMC_PCDR0_PID20 (0x1u << 20)
158#define PMC_PCDR0_PID21 (0x1u << 21)
159#define PMC_PCDR0_PID22 (0x1u << 22)
160#define PMC_PCDR0_PID23 (0x1u << 23)
161#define PMC_PCDR0_PID24 (0x1u << 24)
162#define PMC_PCDR0_PID25 (0x1u << 25)
163#define PMC_PCDR0_PID26 (0x1u << 26)
164#define PMC_PCDR0_PID27 (0x1u << 27)
165#define PMC_PCDR0_PID28 (0x1u << 28)
166#define PMC_PCDR0_PID29 (0x1u << 29)
167#define PMC_PCDR0_PID30 (0x1u << 30)
168#define PMC_PCDR0_PID31 (0x1u << 31)
169/* -------- PMC_PCSR0 : (PMC Offset: 0x0018) Peripheral Clock Status Register 0 -------- */
170#define PMC_PCSR0_PID7 (0x1u << 7)
171#define PMC_PCSR0_PID8 (0x1u << 8)
172#define PMC_PCSR0_PID9 (0x1u << 9)
173#define PMC_PCSR0_PID10 (0x1u << 10)
174#define PMC_PCSR0_PID11 (0x1u << 11)
175#define PMC_PCSR0_PID12 (0x1u << 12)
176#define PMC_PCSR0_PID13 (0x1u << 13)
177#define PMC_PCSR0_PID14 (0x1u << 14)
178#define PMC_PCSR0_PID15 (0x1u << 15)
179#define PMC_PCSR0_PID16 (0x1u << 16)
180#define PMC_PCSR0_PID17 (0x1u << 17)
181#define PMC_PCSR0_PID18 (0x1u << 18)
182#define PMC_PCSR0_PID19 (0x1u << 19)
183#define PMC_PCSR0_PID20 (0x1u << 20)
184#define PMC_PCSR0_PID21 (0x1u << 21)
185#define PMC_PCSR0_PID22 (0x1u << 22)
186#define PMC_PCSR0_PID23 (0x1u << 23)
187#define PMC_PCSR0_PID24 (0x1u << 24)
188#define PMC_PCSR0_PID25 (0x1u << 25)
189#define PMC_PCSR0_PID26 (0x1u << 26)
190#define PMC_PCSR0_PID27 (0x1u << 27)
191#define PMC_PCSR0_PID28 (0x1u << 28)
192#define PMC_PCSR0_PID29 (0x1u << 29)
193#define PMC_PCSR0_PID30 (0x1u << 30)
194#define PMC_PCSR0_PID31 (0x1u << 31)
195/* -------- CKGR_UCKR : (PMC Offset: 0x001C) UTMI Clock Register -------- */
196#define CKGR_UCKR_UPLLEN (0x1u << 16)
197#define CKGR_UCKR_UPLLCOUNT_Pos 20
198#define CKGR_UCKR_UPLLCOUNT_Msk (0xfu << CKGR_UCKR_UPLLCOUNT_Pos)
199#define CKGR_UCKR_UPLLCOUNT(value) ((CKGR_UCKR_UPLLCOUNT_Msk & ((value) << CKGR_UCKR_UPLLCOUNT_Pos)))
200/* -------- CKGR_MOR : (PMC Offset: 0x0020) Main Oscillator Register -------- */
201#define CKGR_MOR_MOSCXTEN (0x1u << 0)
202#define CKGR_MOR_MOSCXTBY (0x1u << 1)
203#define CKGR_MOR_WAITMODE (0x1u << 2)
204#define CKGR_MOR_MOSCRCEN (0x1u << 3)
205#define CKGR_MOR_MOSCRCF_Pos 4
206#define CKGR_MOR_MOSCRCF_Msk (0x7u << CKGR_MOR_MOSCRCF_Pos)
207#define CKGR_MOR_MOSCRCF(value) ((CKGR_MOR_MOSCRCF_Msk & ((value) << CKGR_MOR_MOSCRCF_Pos)))
208#define CKGR_MOR_MOSCRCF_4_MHz (0x0u << 4)
209#define CKGR_MOR_MOSCRCF_8_MHz (0x1u << 4)
210#define CKGR_MOR_MOSCRCF_12_MHz (0x2u << 4)
211#define CKGR_MOR_MOSCXTST_Pos 8
212#define CKGR_MOR_MOSCXTST_Msk (0xffu << CKGR_MOR_MOSCXTST_Pos)
213#define CKGR_MOR_MOSCXTST(value) ((CKGR_MOR_MOSCXTST_Msk & ((value) << CKGR_MOR_MOSCXTST_Pos)))
214#define CKGR_MOR_KEY_Pos 16
215#define CKGR_MOR_KEY_Msk (0xffu << CKGR_MOR_KEY_Pos)
216#define CKGR_MOR_KEY(value) ((CKGR_MOR_KEY_Msk & ((value) << CKGR_MOR_KEY_Pos)))
217#define CKGR_MOR_KEY_PASSWD (0x37u << 16)
218#define CKGR_MOR_MOSCSEL (0x1u << 24)
219#define CKGR_MOR_CFDEN (0x1u << 25)
220#define CKGR_MOR_XT32KFME (0x1u << 26)
221/* -------- CKGR_MCFR : (PMC Offset: 0x0024) Main Clock Frequency Register -------- */
222#define CKGR_MCFR_MAINF_Pos 0
223#define CKGR_MCFR_MAINF_Msk (0xffffu << CKGR_MCFR_MAINF_Pos)
224#define CKGR_MCFR_MAINF(value) ((CKGR_MCFR_MAINF_Msk & ((value) << CKGR_MCFR_MAINF_Pos)))
225#define CKGR_MCFR_MAINFRDY (0x1u << 16)
226#define CKGR_MCFR_RCMEAS (0x1u << 20)
227#define CKGR_MCFR_CCSS (0x1u << 24)
228/* -------- CKGR_PLLAR : (PMC Offset: 0x0028) PLLA Register -------- */
229#define CKGR_PLLAR_DIVA_Pos 0
230#define CKGR_PLLAR_DIVA_Msk (0xffu << CKGR_PLLAR_DIVA_Pos)
231#define CKGR_PLLAR_DIVA(value) ((CKGR_PLLAR_DIVA_Msk & ((value) << CKGR_PLLAR_DIVA_Pos)))
232#define CKGR_PLLAR_DIVA_0 (0x0u << 0)
233#define CKGR_PLLAR_DIVA_BYPASS (0x1u << 0)
234#define CKGR_PLLAR_PLLACOUNT_Pos 8
235#define CKGR_PLLAR_PLLACOUNT_Msk (0x3fu << CKGR_PLLAR_PLLACOUNT_Pos)
236#define CKGR_PLLAR_PLLACOUNT(value) ((CKGR_PLLAR_PLLACOUNT_Msk & ((value) << CKGR_PLLAR_PLLACOUNT_Pos)))
237#define CKGR_PLLAR_MULA_Pos 16
238#define CKGR_PLLAR_MULA_Msk (0x7ffu << CKGR_PLLAR_MULA_Pos)
239#define CKGR_PLLAR_MULA(value) ((CKGR_PLLAR_MULA_Msk & ((value) << CKGR_PLLAR_MULA_Pos)))
240#define CKGR_PLLAR_ONE (0x1u << 29)
241/* -------- PMC_MCKR : (PMC Offset: 0x0030) Master Clock Register -------- */
242#define PMC_MCKR_CSS_Pos 0
243#define PMC_MCKR_CSS_Msk (0x3u << PMC_MCKR_CSS_Pos)
244#define PMC_MCKR_CSS(value) ((PMC_MCKR_CSS_Msk & ((value) << PMC_MCKR_CSS_Pos)))
245#define PMC_MCKR_CSS_SLOW_CLK (0x0u << 0)
246#define PMC_MCKR_CSS_MAIN_CLK (0x1u << 0)
247#define PMC_MCKR_CSS_PLLA_CLK (0x2u << 0)
248#define PMC_MCKR_CSS_UPLL_CLK (0x3u << 0)
249#define PMC_MCKR_PRES_Pos 4
250#define PMC_MCKR_PRES_Msk (0x7u << PMC_MCKR_PRES_Pos)
251#define PMC_MCKR_PRES(value) ((PMC_MCKR_PRES_Msk & ((value) << PMC_MCKR_PRES_Pos)))
252#define PMC_MCKR_PRES_CLK_1 (0x0u << 4)
253#define PMC_MCKR_PRES_CLK_2 (0x1u << 4)
254#define PMC_MCKR_PRES_CLK_4 (0x2u << 4)
255#define PMC_MCKR_PRES_CLK_8 (0x3u << 4)
256#define PMC_MCKR_PRES_CLK_16 (0x4u << 4)
257#define PMC_MCKR_PRES_CLK_32 (0x5u << 4)
258#define PMC_MCKR_PRES_CLK_64 (0x6u << 4)
259#define PMC_MCKR_PRES_CLK_3 (0x7u << 4)
260#define PMC_MCKR_MDIV_Pos 8
261#define PMC_MCKR_MDIV_Msk (0x3u << PMC_MCKR_MDIV_Pos)
262#define PMC_MCKR_MDIV(value) ((PMC_MCKR_MDIV_Msk & ((value) << PMC_MCKR_MDIV_Pos)))
263#define PMC_MCKR_MDIV_EQ_PCK (0x0u << 8)
264#define PMC_MCKR_MDIV_PCK_DIV2 (0x1u << 8)
265#define PMC_MCKR_MDIV_PCK_DIV4 (0x2u << 8)
266#define PMC_MCKR_MDIV_PCK_DIV3 (0x3u << 8)
267#define PMC_MCKR_UPLLDIV2 (0x1u << 13)
268/* -------- PMC_USB : (PMC Offset: 0x0038) USB Clock Register -------- */
269#define PMC_USB_USBS (0x1u << 0)
270#define PMC_USB_USBDIV_Pos 8
271#define PMC_USB_USBDIV_Msk (0xfu << PMC_USB_USBDIV_Pos)
272#define PMC_USB_USBDIV(value) ((PMC_USB_USBDIV_Msk & ((value) << PMC_USB_USBDIV_Pos)))
273/* -------- PMC_PCK[7] : (PMC Offset: 0x0040) Programmable Clock 0 Register -------- */
274#define PMC_PCK_CSS_Pos 0
275#define PMC_PCK_CSS_Msk (0x7u << PMC_PCK_CSS_Pos)
276#define PMC_PCK_CSS(value) ((PMC_PCK_CSS_Msk & ((value) << PMC_PCK_CSS_Pos)))
277#define PMC_PCK_CSS_SLOW_CLK (0x0u << 0)
278#define PMC_PCK_CSS_MAIN_CLK (0x1u << 0)
279#define PMC_PCK_CSS_PLLA_CLK (0x2u << 0)
280#define PMC_PCK_CSS_UPLL_CLK (0x3u << 0)
281#define PMC_PCK_CSS_MCK (0x4u << 0)
282#define PMC_PCK_PRES_Pos 4
283#define PMC_PCK_PRES_Msk (0xffu << PMC_PCK_PRES_Pos)
284#define PMC_PCK_PRES(value) ((PMC_PCK_PRES_Msk & ((value) << PMC_PCK_PRES_Pos)))
285/* -------- PMC_IER : (PMC Offset: 0x0060) Interrupt Enable Register -------- */
286#define PMC_IER_MOSCXTS (0x1u << 0)
287#define PMC_IER_LOCKA (0x1u << 1)
288#define PMC_IER_MCKRDY (0x1u << 3)
289#define PMC_IER_LOCKU (0x1u << 6)
290#define PMC_IER_PCKRDY0 (0x1u << 8)
291#define PMC_IER_PCKRDY1 (0x1u << 9)
292#define PMC_IER_PCKRDY2 (0x1u << 10)
293#define PMC_IER_PCKRDY3 (0x1u << 11)
294#define PMC_IER_PCKRDY4 (0x1u << 12)
295#define PMC_IER_PCKRDY5 (0x1u << 13)
296#define PMC_IER_PCKRDY6 (0x1u << 14)
297#define PMC_IER_MOSCSELS (0x1u << 16)
298#define PMC_IER_MOSCRCS (0x1u << 17)
299#define PMC_IER_CFDEV (0x1u << 18)
300#define PMC_IER_XT32KERR (0x1u << 21)
301/* -------- PMC_IDR : (PMC Offset: 0x0064) Interrupt Disable Register -------- */
302#define PMC_IDR_MOSCXTS (0x1u << 0)
303#define PMC_IDR_LOCKA (0x1u << 1)
304#define PMC_IDR_MCKRDY (0x1u << 3)
305#define PMC_IDR_LOCKU (0x1u << 6)
306#define PMC_IDR_PCKRDY0 (0x1u << 8)
307#define PMC_IDR_PCKRDY1 (0x1u << 9)
308#define PMC_IDR_PCKRDY2 (0x1u << 10)
309#define PMC_IDR_PCKRDY3 (0x1u << 11)
310#define PMC_IDR_PCKRDY4 (0x1u << 12)
311#define PMC_IDR_PCKRDY5 (0x1u << 13)
312#define PMC_IDR_PCKRDY6 (0x1u << 14)
313#define PMC_IDR_MOSCSELS (0x1u << 16)
314#define PMC_IDR_MOSCRCS (0x1u << 17)
315#define PMC_IDR_CFDEV (0x1u << 18)
316#define PMC_IDR_XT32KERR (0x1u << 21)
317/* -------- PMC_SR : (PMC Offset: 0x0068) Status Register -------- */
318#define PMC_SR_MOSCXTS (0x1u << 0)
319#define PMC_SR_LOCKA (0x1u << 1)
320#define PMC_SR_MCKRDY (0x1u << 3)
321#define PMC_SR_LOCKU (0x1u << 6)
322#define PMC_SR_OSCSELS (0x1u << 7)
323#define PMC_SR_PCKRDY0 (0x1u << 8)
324#define PMC_SR_PCKRDY1 (0x1u << 9)
325#define PMC_SR_PCKRDY2 (0x1u << 10)
326#define PMC_SR_PCKRDY3 (0x1u << 11)
327#define PMC_SR_PCKRDY4 (0x1u << 12)
328#define PMC_SR_PCKRDY5 (0x1u << 13)
329#define PMC_SR_PCKRDY6 (0x1u << 14)
330#define PMC_SR_MOSCSELS (0x1u << 16)
331#define PMC_SR_MOSCRCS (0x1u << 17)
332#define PMC_SR_CFDEV (0x1u << 18)
333#define PMC_SR_CFDS (0x1u << 19)
334#define PMC_SR_FOS (0x1u << 20)
335#define PMC_SR_XT32KERR (0x1u << 21)
336/* -------- PMC_IMR : (PMC Offset: 0x006C) Interrupt Mask Register -------- */
337#define PMC_IMR_MOSCXTS (0x1u << 0)
338#define PMC_IMR_LOCKA (0x1u << 1)
339#define PMC_IMR_MCKRDY (0x1u << 3)
340#define PMC_IMR_LOCKU (0x1u << 6)
341#define PMC_IMR_PCKRDY0 (0x1u << 8)
342#define PMC_IMR_PCKRDY1 (0x1u << 9)
343#define PMC_IMR_PCKRDY2 (0x1u << 10)
344#define PMC_IMR_PCKRDY3 (0x1u << 11)
345#define PMC_IMR_PCKRDY4 (0x1u << 12)
346#define PMC_IMR_PCKRDY5 (0x1u << 13)
347#define PMC_IMR_PCKRDY6 (0x1u << 14)
348#define PMC_IMR_MOSCSELS (0x1u << 16)
349#define PMC_IMR_MOSCRCS (0x1u << 17)
350#define PMC_IMR_CFDEV (0x1u << 18)
351#define PMC_IMR_XT32KERR (0x1u << 21)
352/* -------- PMC_FSMR : (PMC Offset: 0x0070) Fast Startup Mode Register -------- */
353#define PMC_FSMR_FSTT0 (0x1u << 0)
354#define PMC_FSMR_FSTT1 (0x1u << 1)
355#define PMC_FSMR_FSTT2 (0x1u << 2)
356#define PMC_FSMR_FSTT3 (0x1u << 3)
357#define PMC_FSMR_FSTT4 (0x1u << 4)
358#define PMC_FSMR_FSTT5 (0x1u << 5)
359#define PMC_FSMR_FSTT6 (0x1u << 6)
360#define PMC_FSMR_FSTT7 (0x1u << 7)
361#define PMC_FSMR_FSTT8 (0x1u << 8)
362#define PMC_FSMR_FSTT9 (0x1u << 9)
363#define PMC_FSMR_FSTT10 (0x1u << 10)
364#define PMC_FSMR_FSTT11 (0x1u << 11)
365#define PMC_FSMR_FSTT12 (0x1u << 12)
366#define PMC_FSMR_FSTT13 (0x1u << 13)
367#define PMC_FSMR_FSTT14 (0x1u << 14)
368#define PMC_FSMR_FSTT15 (0x1u << 15)
369#define PMC_FSMR_RTTAL (0x1u << 16)
370#define PMC_FSMR_RTCAL (0x1u << 17)
371#define PMC_FSMR_USBAL (0x1u << 18)
372#define PMC_FSMR_LPM (0x1u << 20)
373#define PMC_FSMR_FLPM_Pos 21
374#define PMC_FSMR_FLPM_Msk (0x3u << PMC_FSMR_FLPM_Pos)
375#define PMC_FSMR_FLPM(value) ((PMC_FSMR_FLPM_Msk & ((value) << PMC_FSMR_FLPM_Pos)))
376#define PMC_FSMR_FLPM_FLASH_STANDBY (0x0u << 21)
377#define PMC_FSMR_FLPM_FLASH_DEEP_POWERDOWN (0x1u << 21)
378#define PMC_FSMR_FLPM_FLASH_IDLE (0x2u << 21)
379#define PMC_FSMR_FFLPM (0x1u << 23)
380/* -------- PMC_FSPR : (PMC Offset: 0x0074) Fast Startup Polarity Register -------- */
381#define PMC_FSPR_FSTP0 (0x1u << 0)
382#define PMC_FSPR_FSTP1 (0x1u << 1)
383#define PMC_FSPR_FSTP2 (0x1u << 2)
384#define PMC_FSPR_FSTP3 (0x1u << 3)
385#define PMC_FSPR_FSTP4 (0x1u << 4)
386#define PMC_FSPR_FSTP5 (0x1u << 5)
387#define PMC_FSPR_FSTP6 (0x1u << 6)
388#define PMC_FSPR_FSTP7 (0x1u << 7)
389#define PMC_FSPR_FSTP8 (0x1u << 8)
390#define PMC_FSPR_FSTP9 (0x1u << 9)
391#define PMC_FSPR_FSTP10 (0x1u << 10)
392#define PMC_FSPR_FSTP11 (0x1u << 11)
393#define PMC_FSPR_FSTP12 (0x1u << 12)
394#define PMC_FSPR_FSTP13 (0x1u << 13)
395#define PMC_FSPR_FSTP14 (0x1u << 14)
396#define PMC_FSPR_FSTP15 (0x1u << 15)
397/* -------- PMC_FOCR : (PMC Offset: 0x0078) Fault Output Clear Register -------- */
398#define PMC_FOCR_FOCLR (0x1u << 0)
399/* -------- PMC_WPMR : (PMC Offset: 0x00E4) Write Protection Mode Register -------- */
400#define PMC_WPMR_WPEN (0x1u << 0)
401#define PMC_WPMR_WPKEY_Pos 8
402#define PMC_WPMR_WPKEY_Msk (0xffffffu << PMC_WPMR_WPKEY_Pos)
403#define PMC_WPMR_WPKEY(value) ((PMC_WPMR_WPKEY_Msk & ((value) << PMC_WPMR_WPKEY_Pos)))
404#define PMC_WPMR_WPKEY_PASSWD (0x504D43u << 8)
405/* -------- PMC_WPSR : (PMC Offset: 0x00E8) Write Protection Status Register -------- */
406#define PMC_WPSR_WPVS (0x1u << 0)
407#define PMC_WPSR_WPVSRC_Pos 8
408#define PMC_WPSR_WPVSRC_Msk (0xffffu << PMC_WPSR_WPVSRC_Pos)
409/* -------- PMC_VERSION : (PMC Offset: 0x00FC) Version Register -------- */
410#define PMC_VERSION_VERSION_Pos 0
411#define PMC_VERSION_VERSION_Msk (0xfffu << PMC_VERSION_VERSION_Pos)
412#define PMC_VERSION_MFN_Pos 16
413#define PMC_VERSION_MFN_Msk (0x7u << PMC_VERSION_MFN_Pos)
414/* -------- PMC_PCER1 : (PMC Offset: 0x0100) Peripheral Clock Enable Register 1 -------- */
415#define PMC_PCER1_PID32 (0x1u << 0)
416#define PMC_PCER1_PID33 (0x1u << 1)
417#define PMC_PCER1_PID34 (0x1u << 2)
418#define PMC_PCER1_PID35 (0x1u << 3)
419#define PMC_PCER1_PID37 (0x1u << 5)
420#define PMC_PCER1_PID39 (0x1u << 7)
421#define PMC_PCER1_PID40 (0x1u << 8)
422#define PMC_PCER1_PID41 (0x1u << 9)
423#define PMC_PCER1_PID42 (0x1u << 10)
424#define PMC_PCER1_PID43 (0x1u << 11)
425#define PMC_PCER1_PID44 (0x1u << 12)
426#define PMC_PCER1_PID45 (0x1u << 13)
427#define PMC_PCER1_PID46 (0x1u << 14)
428#define PMC_PCER1_PID47 (0x1u << 15)
429#define PMC_PCER1_PID48 (0x1u << 16)
430#define PMC_PCER1_PID49 (0x1u << 17)
431#define PMC_PCER1_PID50 (0x1u << 18)
432#define PMC_PCER1_PID51 (0x1u << 19)
433#define PMC_PCER1_PID52 (0x1u << 20)
434#define PMC_PCER1_PID53 (0x1u << 21)
435#define PMC_PCER1_PID56 (0x1u << 24)
436#define PMC_PCER1_PID57 (0x1u << 25)
437#define PMC_PCER1_PID58 (0x1u << 26)
438#define PMC_PCER1_PID59 (0x1u << 27)
439#define PMC_PCER1_PID60 (0x1u << 28)
440/* -------- PMC_PCDR1 : (PMC Offset: 0x0104) Peripheral Clock Disable Register 1 -------- */
441#define PMC_PCDR1_PID32 (0x1u << 0)
442#define PMC_PCDR1_PID33 (0x1u << 1)
443#define PMC_PCDR1_PID34 (0x1u << 2)
444#define PMC_PCDR1_PID35 (0x1u << 3)
445#define PMC_PCDR1_PID37 (0x1u << 5)
446#define PMC_PCDR1_PID39 (0x1u << 7)
447#define PMC_PCDR1_PID40 (0x1u << 8)
448#define PMC_PCDR1_PID41 (0x1u << 9)
449#define PMC_PCDR1_PID42 (0x1u << 10)
450#define PMC_PCDR1_PID43 (0x1u << 11)
451#define PMC_PCDR1_PID44 (0x1u << 12)
452#define PMC_PCDR1_PID45 (0x1u << 13)
453#define PMC_PCDR1_PID46 (0x1u << 14)
454#define PMC_PCDR1_PID47 (0x1u << 15)
455#define PMC_PCDR1_PID48 (0x1u << 16)
456#define PMC_PCDR1_PID49 (0x1u << 17)
457#define PMC_PCDR1_PID50 (0x1u << 18)
458#define PMC_PCDR1_PID51 (0x1u << 19)
459#define PMC_PCDR1_PID52 (0x1u << 20)
460#define PMC_PCDR1_PID53 (0x1u << 21)
461#define PMC_PCDR1_PID56 (0x1u << 24)
462#define PMC_PCDR1_PID57 (0x1u << 25)
463#define PMC_PCDR1_PID58 (0x1u << 26)
464#define PMC_PCDR1_PID59 (0x1u << 27)
465#define PMC_PCDR1_PID60 (0x1u << 28)
466/* -------- PMC_PCSR1 : (PMC Offset: 0x0108) Peripheral Clock Status Register 1 -------- */
467#define PMC_PCSR1_PID32 (0x1u << 0)
468#define PMC_PCSR1_PID33 (0x1u << 1)
469#define PMC_PCSR1_PID34 (0x1u << 2)
470#define PMC_PCSR1_PID35 (0x1u << 3)
471#define PMC_PCSR1_PID37 (0x1u << 5)
472#define PMC_PCSR1_PID39 (0x1u << 7)
473#define PMC_PCSR1_PID40 (0x1u << 8)
474#define PMC_PCSR1_PID41 (0x1u << 9)
475#define PMC_PCSR1_PID42 (0x1u << 10)
476#define PMC_PCSR1_PID43 (0x1u << 11)
477#define PMC_PCSR1_PID44 (0x1u << 12)
478#define PMC_PCSR1_PID45 (0x1u << 13)
479#define PMC_PCSR1_PID46 (0x1u << 14)
480#define PMC_PCSR1_PID47 (0x1u << 15)
481#define PMC_PCSR1_PID48 (0x1u << 16)
482#define PMC_PCSR1_PID49 (0x1u << 17)
483#define PMC_PCSR1_PID50 (0x1u << 18)
484#define PMC_PCSR1_PID51 (0x1u << 19)
485#define PMC_PCSR1_PID52 (0x1u << 20)
486#define PMC_PCSR1_PID53 (0x1u << 21)
487#define PMC_PCSR1_PID56 (0x1u << 24)
488#define PMC_PCSR1_PID57 (0x1u << 25)
489#define PMC_PCSR1_PID58 (0x1u << 26)
490#define PMC_PCSR1_PID59 (0x1u << 27)
491#define PMC_PCSR1_PID60 (0x1u << 28)
492/* -------- PMC_PCR : (PMC Offset: 0x010C) Peripheral Control Register -------- */
493#define PMC_PCR_PID_Pos 0
494#define PMC_PCR_PID_Msk (0x3fu << PMC_PCR_PID_Pos)
495#define PMC_PCR_PID(value) ((PMC_PCR_PID_Msk & ((value) << PMC_PCR_PID_Pos)))
496#define PMC_PCR_CMD (0x1u << 12)
497#define PMC_PCR_EN (0x1u << 28)
498/* -------- PMC_OCR : (PMC Offset: 0x0110) Oscillator Calibration Register -------- */
499#define PMC_OCR_CAL4_Pos 0
500#define PMC_OCR_CAL4_Msk (0x7fu << PMC_OCR_CAL4_Pos)
501#define PMC_OCR_CAL4(value) ((PMC_OCR_CAL4_Msk & ((value) << PMC_OCR_CAL4_Pos)))
502#define PMC_OCR_SEL4 (0x1u << 7)
503#define PMC_OCR_CAL8_Pos 8
504#define PMC_OCR_CAL8_Msk (0x7fu << PMC_OCR_CAL8_Pos)
505#define PMC_OCR_CAL8(value) ((PMC_OCR_CAL8_Msk & ((value) << PMC_OCR_CAL8_Pos)))
506#define PMC_OCR_SEL8 (0x1u << 15)
507#define PMC_OCR_CAL12_Pos 16
508#define PMC_OCR_CAL12_Msk (0x7fu << PMC_OCR_CAL12_Pos)
509#define PMC_OCR_CAL12(value) ((PMC_OCR_CAL12_Msk & ((value) << PMC_OCR_CAL12_Pos)))
510#define PMC_OCR_SEL12 (0x1u << 23)
511/* -------- PMC_SLPWK_ER0 : (PMC Offset: 0x0114) SleepWalking Enable Register 0 -------- */
512#define PMC_SLPWK_ER0_PID7 (0x1u << 7)
513#define PMC_SLPWK_ER0_PID8 (0x1u << 8)
514#define PMC_SLPWK_ER0_PID9 (0x1u << 9)
515#define PMC_SLPWK_ER0_PID10 (0x1u << 10)
516#define PMC_SLPWK_ER0_PID11 (0x1u << 11)
517#define PMC_SLPWK_ER0_PID12 (0x1u << 12)
518#define PMC_SLPWK_ER0_PID13 (0x1u << 13)
519#define PMC_SLPWK_ER0_PID14 (0x1u << 14)
520#define PMC_SLPWK_ER0_PID15 (0x1u << 15)
521#define PMC_SLPWK_ER0_PID16 (0x1u << 16)
522#define PMC_SLPWK_ER0_PID17 (0x1u << 17)
523#define PMC_SLPWK_ER0_PID18 (0x1u << 18)
524#define PMC_SLPWK_ER0_PID19 (0x1u << 19)
525#define PMC_SLPWK_ER0_PID20 (0x1u << 20)
526#define PMC_SLPWK_ER0_PID21 (0x1u << 21)
527#define PMC_SLPWK_ER0_PID22 (0x1u << 22)
528#define PMC_SLPWK_ER0_PID23 (0x1u << 23)
529#define PMC_SLPWK_ER0_PID24 (0x1u << 24)
530#define PMC_SLPWK_ER0_PID25 (0x1u << 25)
531#define PMC_SLPWK_ER0_PID26 (0x1u << 26)
532#define PMC_SLPWK_ER0_PID27 (0x1u << 27)
533#define PMC_SLPWK_ER0_PID28 (0x1u << 28)
534#define PMC_SLPWK_ER0_PID29 (0x1u << 29)
535#define PMC_SLPWK_ER0_PID30 (0x1u << 30)
536#define PMC_SLPWK_ER0_PID31 (0x1u << 31)
537/* -------- PMC_SLPWK_DR0 : (PMC Offset: 0x0118) SleepWalking Disable Register 0 -------- */
538#define PMC_SLPWK_DR0_PID7 (0x1u << 7)
539#define PMC_SLPWK_DR0_PID8 (0x1u << 8)
540#define PMC_SLPWK_DR0_PID9 (0x1u << 9)
541#define PMC_SLPWK_DR0_PID10 (0x1u << 10)
542#define PMC_SLPWK_DR0_PID11 (0x1u << 11)
543#define PMC_SLPWK_DR0_PID12 (0x1u << 12)
544#define PMC_SLPWK_DR0_PID13 (0x1u << 13)
545#define PMC_SLPWK_DR0_PID14 (0x1u << 14)
546#define PMC_SLPWK_DR0_PID15 (0x1u << 15)
547#define PMC_SLPWK_DR0_PID16 (0x1u << 16)
548#define PMC_SLPWK_DR0_PID17 (0x1u << 17)
549#define PMC_SLPWK_DR0_PID18 (0x1u << 18)
550#define PMC_SLPWK_DR0_PID19 (0x1u << 19)
551#define PMC_SLPWK_DR0_PID20 (0x1u << 20)
552#define PMC_SLPWK_DR0_PID21 (0x1u << 21)
553#define PMC_SLPWK_DR0_PID22 (0x1u << 22)
554#define PMC_SLPWK_DR0_PID23 (0x1u << 23)
555#define PMC_SLPWK_DR0_PID24 (0x1u << 24)
556#define PMC_SLPWK_DR0_PID25 (0x1u << 25)
557#define PMC_SLPWK_DR0_PID26 (0x1u << 26)
558#define PMC_SLPWK_DR0_PID27 (0x1u << 27)
559#define PMC_SLPWK_DR0_PID28 (0x1u << 28)
560#define PMC_SLPWK_DR0_PID29 (0x1u << 29)
561#define PMC_SLPWK_DR0_PID30 (0x1u << 30)
562#define PMC_SLPWK_DR0_PID31 (0x1u << 31)
563/* -------- PMC_SLPWK_SR0 : (PMC Offset: 0x011C) SleepWalking Status Register 0 -------- */
564#define PMC_SLPWK_SR0_PID7 (0x1u << 7)
565#define PMC_SLPWK_SR0_PID8 (0x1u << 8)
566#define PMC_SLPWK_SR0_PID9 (0x1u << 9)
567#define PMC_SLPWK_SR0_PID10 (0x1u << 10)
568#define PMC_SLPWK_SR0_PID11 (0x1u << 11)
569#define PMC_SLPWK_SR0_PID12 (0x1u << 12)
570#define PMC_SLPWK_SR0_PID13 (0x1u << 13)
571#define PMC_SLPWK_SR0_PID14 (0x1u << 14)
572#define PMC_SLPWK_SR0_PID15 (0x1u << 15)
573#define PMC_SLPWK_SR0_PID16 (0x1u << 16)
574#define PMC_SLPWK_SR0_PID17 (0x1u << 17)
575#define PMC_SLPWK_SR0_PID18 (0x1u << 18)
576#define PMC_SLPWK_SR0_PID19 (0x1u << 19)
577#define PMC_SLPWK_SR0_PID20 (0x1u << 20)
578#define PMC_SLPWK_SR0_PID21 (0x1u << 21)
579#define PMC_SLPWK_SR0_PID22 (0x1u << 22)
580#define PMC_SLPWK_SR0_PID23 (0x1u << 23)
581#define PMC_SLPWK_SR0_PID24 (0x1u << 24)
582#define PMC_SLPWK_SR0_PID25 (0x1u << 25)
583#define PMC_SLPWK_SR0_PID26 (0x1u << 26)
584#define PMC_SLPWK_SR0_PID27 (0x1u << 27)
585#define PMC_SLPWK_SR0_PID28 (0x1u << 28)
586#define PMC_SLPWK_SR0_PID29 (0x1u << 29)
587#define PMC_SLPWK_SR0_PID30 (0x1u << 30)
588#define PMC_SLPWK_SR0_PID31 (0x1u << 31)
589/* -------- PMC_SLPWK_ASR0 : (PMC Offset: 0x0120) SleepWalking Activity Status Register 0 -------- */
590#define PMC_SLPWK_ASR0_PID7 (0x1u << 7)
591#define PMC_SLPWK_ASR0_PID8 (0x1u << 8)
592#define PMC_SLPWK_ASR0_PID9 (0x1u << 9)
593#define PMC_SLPWK_ASR0_PID10 (0x1u << 10)
594#define PMC_SLPWK_ASR0_PID11 (0x1u << 11)
595#define PMC_SLPWK_ASR0_PID12 (0x1u << 12)
596#define PMC_SLPWK_ASR0_PID13 (0x1u << 13)
597#define PMC_SLPWK_ASR0_PID14 (0x1u << 14)
598#define PMC_SLPWK_ASR0_PID15 (0x1u << 15)
599#define PMC_SLPWK_ASR0_PID16 (0x1u << 16)
600#define PMC_SLPWK_ASR0_PID17 (0x1u << 17)
601#define PMC_SLPWK_ASR0_PID18 (0x1u << 18)
602#define PMC_SLPWK_ASR0_PID19 (0x1u << 19)
603#define PMC_SLPWK_ASR0_PID20 (0x1u << 20)
604#define PMC_SLPWK_ASR0_PID21 (0x1u << 21)
605#define PMC_SLPWK_ASR0_PID22 (0x1u << 22)
606#define PMC_SLPWK_ASR0_PID23 (0x1u << 23)
607#define PMC_SLPWK_ASR0_PID24 (0x1u << 24)
608#define PMC_SLPWK_ASR0_PID25 (0x1u << 25)
609#define PMC_SLPWK_ASR0_PID26 (0x1u << 26)
610#define PMC_SLPWK_ASR0_PID27 (0x1u << 27)
611#define PMC_SLPWK_ASR0_PID28 (0x1u << 28)
612#define PMC_SLPWK_ASR0_PID29 (0x1u << 29)
613#define PMC_SLPWK_ASR0_PID30 (0x1u << 30)
614#define PMC_SLPWK_ASR0_PID31 (0x1u << 31)
615/* -------- PMC_PMMR : (PMC Offset: 0x0130) PLL Maximum Multiplier Value Register -------- */
616#define PMC_PMMR_PLLA_MMAX_Pos 0
617#define PMC_PMMR_PLLA_MMAX_Msk (0x7ffu << PMC_PMMR_PLLA_MMAX_Pos)
618#define PMC_PMMR_PLLA_MMAX(value) ((PMC_PMMR_PLLA_MMAX_Msk & ((value) << PMC_PMMR_PLLA_MMAX_Pos)))
619/* -------- PMC_SLPWK_ER1 : (PMC Offset: 0x0134) SleepWalking Enable Register 1 -------- */
620#define PMC_SLPWK_ER1_PID32 (0x1u << 0)
621#define PMC_SLPWK_ER1_PID33 (0x1u << 1)
622#define PMC_SLPWK_ER1_PID34 (0x1u << 2)
623#define PMC_SLPWK_ER1_PID35 (0x1u << 3)
624#define PMC_SLPWK_ER1_PID37 (0x1u << 5)
625#define PMC_SLPWK_ER1_PID39 (0x1u << 7)
626#define PMC_SLPWK_ER1_PID40 (0x1u << 8)
627#define PMC_SLPWK_ER1_PID41 (0x1u << 9)
628#define PMC_SLPWK_ER1_PID42 (0x1u << 10)
629#define PMC_SLPWK_ER1_PID43 (0x1u << 11)
630#define PMC_SLPWK_ER1_PID44 (0x1u << 12)
631#define PMC_SLPWK_ER1_PID45 (0x1u << 13)
632#define PMC_SLPWK_ER1_PID46 (0x1u << 14)
633#define PMC_SLPWK_ER1_PID47 (0x1u << 15)
634#define PMC_SLPWK_ER1_PID48 (0x1u << 16)
635#define PMC_SLPWK_ER1_PID49 (0x1u << 17)
636#define PMC_SLPWK_ER1_PID50 (0x1u << 18)
637#define PMC_SLPWK_ER1_PID51 (0x1u << 19)
638#define PMC_SLPWK_ER1_PID52 (0x1u << 20)
639#define PMC_SLPWK_ER1_PID53 (0x1u << 21)
640#define PMC_SLPWK_ER1_PID56 (0x1u << 24)
641#define PMC_SLPWK_ER1_PID57 (0x1u << 25)
642#define PMC_SLPWK_ER1_PID58 (0x1u << 26)
643#define PMC_SLPWK_ER1_PID59 (0x1u << 27)
644#define PMC_SLPWK_ER1_PID60 (0x1u << 28)
645/* -------- PMC_SLPWK_DR1 : (PMC Offset: 0x0138) SleepWalking Disable Register 1 -------- */
646#define PMC_SLPWK_DR1_PID32 (0x1u << 0)
647#define PMC_SLPWK_DR1_PID33 (0x1u << 1)
648#define PMC_SLPWK_DR1_PID34 (0x1u << 2)
649#define PMC_SLPWK_DR1_PID35 (0x1u << 3)
650#define PMC_SLPWK_DR1_PID37 (0x1u << 5)
651#define PMC_SLPWK_DR1_PID39 (0x1u << 7)
652#define PMC_SLPWK_DR1_PID40 (0x1u << 8)
653#define PMC_SLPWK_DR1_PID41 (0x1u << 9)
654#define PMC_SLPWK_DR1_PID42 (0x1u << 10)
655#define PMC_SLPWK_DR1_PID43 (0x1u << 11)
656#define PMC_SLPWK_DR1_PID44 (0x1u << 12)
657#define PMC_SLPWK_DR1_PID45 (0x1u << 13)
658#define PMC_SLPWK_DR1_PID46 (0x1u << 14)
659#define PMC_SLPWK_DR1_PID47 (0x1u << 15)
660#define PMC_SLPWK_DR1_PID48 (0x1u << 16)
661#define PMC_SLPWK_DR1_PID49 (0x1u << 17)
662#define PMC_SLPWK_DR1_PID50 (0x1u << 18)
663#define PMC_SLPWK_DR1_PID51 (0x1u << 19)
664#define PMC_SLPWK_DR1_PID52 (0x1u << 20)
665#define PMC_SLPWK_DR1_PID53 (0x1u << 21)
666#define PMC_SLPWK_DR1_PID56 (0x1u << 24)
667#define PMC_SLPWK_DR1_PID57 (0x1u << 25)
668#define PMC_SLPWK_DR1_PID58 (0x1u << 26)
669#define PMC_SLPWK_DR1_PID59 (0x1u << 27)
670#define PMC_SLPWK_DR1_PID60 (0x1u << 28)
671/* -------- PMC_SLPWK_SR1 : (PMC Offset: 0x013C) SleepWalking Status Register 1 -------- */
672#define PMC_SLPWK_SR1_PID32 (0x1u << 0)
673#define PMC_SLPWK_SR1_PID33 (0x1u << 1)
674#define PMC_SLPWK_SR1_PID34 (0x1u << 2)
675#define PMC_SLPWK_SR1_PID35 (0x1u << 3)
676#define PMC_SLPWK_SR1_PID37 (0x1u << 5)
677#define PMC_SLPWK_SR1_PID39 (0x1u << 7)
678#define PMC_SLPWK_SR1_PID40 (0x1u << 8)
679#define PMC_SLPWK_SR1_PID41 (0x1u << 9)
680#define PMC_SLPWK_SR1_PID42 (0x1u << 10)
681#define PMC_SLPWK_SR1_PID43 (0x1u << 11)
682#define PMC_SLPWK_SR1_PID44 (0x1u << 12)
683#define PMC_SLPWK_SR1_PID45 (0x1u << 13)
684#define PMC_SLPWK_SR1_PID46 (0x1u << 14)
685#define PMC_SLPWK_SR1_PID47 (0x1u << 15)
686#define PMC_SLPWK_SR1_PID48 (0x1u << 16)
687#define PMC_SLPWK_SR1_PID49 (0x1u << 17)
688#define PMC_SLPWK_SR1_PID50 (0x1u << 18)
689#define PMC_SLPWK_SR1_PID51 (0x1u << 19)
690#define PMC_SLPWK_SR1_PID52 (0x1u << 20)
691#define PMC_SLPWK_SR1_PID53 (0x1u << 21)
692#define PMC_SLPWK_SR1_PID56 (0x1u << 24)
693#define PMC_SLPWK_SR1_PID57 (0x1u << 25)
694#define PMC_SLPWK_SR1_PID58 (0x1u << 26)
695#define PMC_SLPWK_SR1_PID59 (0x1u << 27)
696#define PMC_SLPWK_SR1_PID60 (0x1u << 28)
697/* -------- PMC_SLPWK_ASR1 : (PMC Offset: 0x0140) SleepWalking Activity Status Register 1 -------- */
698#define PMC_SLPWK_ASR1_PID32 (0x1u << 0)
699#define PMC_SLPWK_ASR1_PID33 (0x1u << 1)
700#define PMC_SLPWK_ASR1_PID34 (0x1u << 2)
701#define PMC_SLPWK_ASR1_PID35 (0x1u << 3)
702#define PMC_SLPWK_ASR1_PID37 (0x1u << 5)
703#define PMC_SLPWK_ASR1_PID39 (0x1u << 7)
704#define PMC_SLPWK_ASR1_PID40 (0x1u << 8)
705#define PMC_SLPWK_ASR1_PID41 (0x1u << 9)
706#define PMC_SLPWK_ASR1_PID42 (0x1u << 10)
707#define PMC_SLPWK_ASR1_PID43 (0x1u << 11)
708#define PMC_SLPWK_ASR1_PID44 (0x1u << 12)
709#define PMC_SLPWK_ASR1_PID45 (0x1u << 13)
710#define PMC_SLPWK_ASR1_PID46 (0x1u << 14)
711#define PMC_SLPWK_ASR1_PID47 (0x1u << 15)
712#define PMC_SLPWK_ASR1_PID48 (0x1u << 16)
713#define PMC_SLPWK_ASR1_PID49 (0x1u << 17)
714#define PMC_SLPWK_ASR1_PID50 (0x1u << 18)
715#define PMC_SLPWK_ASR1_PID51 (0x1u << 19)
716#define PMC_SLPWK_ASR1_PID52 (0x1u << 20)
717#define PMC_SLPWK_ASR1_PID53 (0x1u << 21)
718#define PMC_SLPWK_ASR1_PID56 (0x1u << 24)
719#define PMC_SLPWK_ASR1_PID57 (0x1u << 25)
720#define PMC_SLPWK_ASR1_PID58 (0x1u << 26)
721#define PMC_SLPWK_ASR1_PID59 (0x1u << 27)
722#define PMC_SLPWK_ASR1_PID60 (0x1u << 28)
723/* -------- PMC_SLPWK_AIPR : (PMC Offset: 0x0144) SleepWalking Activity In Progress Register -------- */
724#define PMC_SLPWK_AIPR_AIP (0x1u << 0)
727
728
729#endif /* _SAMV71_PMC_COMPONENT_ */
#define __O
Definition: core_cm7.h:286
#define __IO
Definition: core_cm7.h:287
#define __I
Definition: core_cm7.h:284
Pmc hardware registers.
Definition: component_pmc.h:41
(Pmc Offset: 0x00FC) Version Register
Definition: component_pmc.h:71
