RTEMS 5.2
component_mcan.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_MCAN_COMPONENT_
31#define _SAMV71_MCAN_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __I uint32_t MCAN_CREL;
43 __I uint32_t MCAN_ENDN;
44 __IO uint32_t MCAN_CUST;
45 __IO uint32_t MCAN_FBTP;
46 __IO uint32_t MCAN_TEST;
47 __IO uint32_t MCAN_RWD;
48 __IO uint32_t MCAN_CCCR;
49 __IO uint32_t MCAN_BTP;
50 __IO uint32_t MCAN_TSCC;
51 __IO uint32_t MCAN_TSCV;
52 __IO uint32_t MCAN_TOCC;
53 __IO uint32_t MCAN_TOCV;
54 __I uint32_t Reserved1[4];
55 __I uint32_t MCAN_ECR;
56 __I uint32_t MCAN_PSR;
57 __I uint32_t Reserved2[2];
58 __IO uint32_t MCAN_IR;
59 __IO uint32_t MCAN_IE;
60 __IO uint32_t MCAN_ILS;
61 __IO uint32_t MCAN_ILE;
62 __I uint32_t Reserved3[8];
63 __IO uint32_t MCAN_GFC;
64 __IO uint32_t MCAN_SIDFC;
65 __IO uint32_t MCAN_XIDFC;
66 __I uint32_t Reserved4[1];
67 __IO uint32_t MCAN_XIDAM;
68 __I uint32_t MCAN_HPMS;
69 __IO uint32_t MCAN_NDAT1;
70 __IO uint32_t MCAN_NDAT2;
71 __IO uint32_t MCAN_RXF0C;
72 __I uint32_t MCAN_RXF0S;
73 __IO uint32_t MCAN_RXF0A;
74 __IO uint32_t MCAN_RXBC;
75 __IO uint32_t MCAN_RXF1C;
76 __I uint32_t MCAN_RXF1S;
77 __IO uint32_t MCAN_RXF1A;
78 __IO uint32_t MCAN_RXESC;
79 __IO uint32_t MCAN_TXBC;
80 __I uint32_t MCAN_TXFQS;
81 __IO uint32_t MCAN_TXESC;
82 __I uint32_t MCAN_TXBRP;
83 __IO uint32_t MCAN_TXBAR;
84 __IO uint32_t MCAN_TXBCR;
85 __I uint32_t MCAN_TXBTO;
86 __I uint32_t MCAN_TXBCF;
87 __IO uint32_t MCAN_TXBTIE;
88 __IO uint32_t MCAN_TXBCIE;
89 __I uint32_t Reserved5[2];
90 __IO uint32_t MCAN_TXEFC;
91 __I uint32_t MCAN_TXEFS;
92 __IO uint32_t MCAN_TXEFA;
93} Mcan;
94#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
95/* -------- MCAN_CREL : (MCAN Offset: 0x00) Core Release Register -------- */
96#define MCAN_CREL_DAY_Pos 0
97#define MCAN_CREL_DAY_Msk (0xffu << MCAN_CREL_DAY_Pos)
98#define MCAN_CREL_MON_Pos 8
99#define MCAN_CREL_MON_Msk (0xffu << MCAN_CREL_MON_Pos)
100#define MCAN_CREL_YEAR_Pos 16
101#define MCAN_CREL_YEAR_Msk (0xfu << MCAN_CREL_YEAR_Pos)
102#define MCAN_CREL_SUBSTEP_Pos 20
103#define MCAN_CREL_SUBSTEP_Msk (0xfu << MCAN_CREL_SUBSTEP_Pos)
104#define MCAN_CREL_STEP_Pos 24
105#define MCAN_CREL_STEP_Msk (0xfu << MCAN_CREL_STEP_Pos)
106#define MCAN_CREL_REL_Pos 28
107#define MCAN_CREL_REL_Msk (0xfu << MCAN_CREL_REL_Pos)
108/* -------- MCAN_ENDN : (MCAN Offset: 0x04) Endian Register -------- */
109#define MCAN_ENDN_ETV_Pos 0
110#define MCAN_ENDN_ETV_Msk (0xffffffffu << MCAN_ENDN_ETV_Pos)
111/* -------- MCAN_CUST : (MCAN Offset: 0x08) Customer Register -------- */
112#define MCAN_CUST_CSV_Pos 0
113#define MCAN_CUST_CSV_Msk (0xffffffffu << MCAN_CUST_CSV_Pos)
114#define MCAN_CUST_CSV(value) ((MCAN_CUST_CSV_Msk & ((value) << MCAN_CUST_CSV_Pos)))
115/* -------- MCAN_FBTP : (MCAN Offset: 0x0C) Fast Bit Timing and Prescaler Register -------- */
116#define MCAN_FBTP_FSJW_Pos 0
117#define MCAN_FBTP_FSJW_Msk (0x3u << MCAN_FBTP_FSJW_Pos)
118#define MCAN_FBTP_FSJW(value) ((MCAN_FBTP_FSJW_Msk & ((value) << MCAN_FBTP_FSJW_Pos)))
119#define MCAN_FBTP_FTSEG2_Pos 4
120#define MCAN_FBTP_FTSEG2_Msk (0x7u << MCAN_FBTP_FTSEG2_Pos)
121#define MCAN_FBTP_FTSEG2(value) ((MCAN_FBTP_FTSEG2_Msk & ((value) << MCAN_FBTP_FTSEG2_Pos)))
122#define MCAN_FBTP_FTSEG1_Pos 8
123#define MCAN_FBTP_FTSEG1_Msk (0xfu << MCAN_FBTP_FTSEG1_Pos)
124#define MCAN_FBTP_FTSEG1(value) ((MCAN_FBTP_FTSEG1_Msk & ((value) << MCAN_FBTP_FTSEG1_Pos)))
125#define MCAN_FBTP_FBRP_Pos 16
126#define MCAN_FBTP_FBRP_Msk (0x1fu << MCAN_FBTP_FBRP_Pos)
127#define MCAN_FBTP_FBRP(value) ((MCAN_FBTP_FBRP_Msk & ((value) << MCAN_FBTP_FBRP_Pos)))
128#define MCAN_FBTP_TDC (0x1u << 23)
129#define MCAN_FBTP_TDC_DISABLED (0x0u << 23)
130#define MCAN_FBTP_TDC_ENABLED (0x1u << 23)
131#define MCAN_FBTP_TDCO_Pos 24
132#define MCAN_FBTP_TDCO_Msk (0x1fu << MCAN_FBTP_TDCO_Pos)
133#define MCAN_FBTP_TDCO(value) ((MCAN_FBTP_TDCO_Msk & ((value) << MCAN_FBTP_TDCO_Pos)))
134/* -------- MCAN_TEST : (MCAN Offset: 0x10) Test Register -------- */
135#define MCAN_TEST_LBCK (0x1u << 4)
136#define MCAN_TEST_LBCK_DISABLED (0x0u << 4)
137#define MCAN_TEST_LBCK_ENABLED (0x1u << 4)
138#define MCAN_TEST_TX_Pos 5
139#define MCAN_TEST_TX_Msk (0x3u << MCAN_TEST_TX_Pos)
140#define MCAN_TEST_TX(value) ((MCAN_TEST_TX_Msk & ((value) << MCAN_TEST_TX_Pos)))
141#define MCAN_TEST_TX_RESET (0x0u << 5)
142#define MCAN_TEST_TX_SAMPLE_POINT_MONITORING (0x1u << 5)
143#define MCAN_TEST_TX_DOMINANT (0x2u << 5)
144#define MCAN_TEST_TX_RECESSIVE (0x3u << 5)
145#define MCAN_TEST_RX (0x1u << 7)
146#define MCAN_TEST_TDCV_Pos 8
147#define MCAN_TEST_TDCV_Msk (0x3fu << MCAN_TEST_TDCV_Pos)
148#define MCAN_TEST_TDCV(value) ((MCAN_TEST_TDCV_Msk & ((value) << MCAN_TEST_TDCV_Pos)))
149/* -------- MCAN_RWD : (MCAN Offset: 0x14) RAM Watchdog Register -------- */
150#define MCAN_RWD_WDC_Pos 0
151#define MCAN_RWD_WDC_Msk (0xffu << MCAN_RWD_WDC_Pos)
152#define MCAN_RWD_WDC(value) ((MCAN_RWD_WDC_Msk & ((value) << MCAN_RWD_WDC_Pos)))
153#define MCAN_RWD_WDV_Pos 8
154#define MCAN_RWD_WDV_Msk (0xffu << MCAN_RWD_WDV_Pos)
155#define MCAN_RWD_WDV(value) ((MCAN_RWD_WDV_Msk & ((value) << MCAN_RWD_WDV_Pos)))
156/* -------- MCAN_CCCR : (MCAN Offset: 0x18) CC Control Register -------- */
157#define MCAN_CCCR_INIT (0x1u << 0)
158#define MCAN_CCCR_INIT_DISABLED (0x0u << 0)
159#define MCAN_CCCR_INIT_ENABLED (0x1u << 0)
160#define MCAN_CCCR_CCE (0x1u << 1)
161#define MCAN_CCCR_CCE_PROTECTED (0x0u << 1)
162#define MCAN_CCCR_CCE_CONFIGURABLE (0x1u << 1)
163#define MCAN_CCCR_ASM (0x1u << 2)
164#define MCAN_CCCR_ASM_NORMAL (0x0u << 2)
165#define MCAN_CCCR_ASM_RESTRICTED (0x1u << 2)
166#define MCAN_CCCR_CSA (0x1u << 3)
167#define MCAN_CCCR_CSR (0x1u << 4)
168#define MCAN_CCCR_CSR_NO_CLOCK_STOP (0x0u << 4)
169#define MCAN_CCCR_CSR_CLOCK_STOP (0x1u << 4)
170#define MCAN_CCCR_MON (0x1u << 5)
171#define MCAN_CCCR_MON_DISABLED (0x0u << 5)
172#define MCAN_CCCR_MON_ENABLED (0x1u << 5)
173#define MCAN_CCCR_DAR (0x1u << 6)
174#define MCAN_CCCR_DAR_AUTO_RETX (0x0u << 6)
175#define MCAN_CCCR_DAR_NO_AUTO_RETX (0x1u << 6)
176#define MCAN_CCCR_TEST (0x1u << 7)
177#define MCAN_CCCR_TEST_DISABLED (0x0u << 7)
178#define MCAN_CCCR_TEST_ENABLED (0x1u << 7)
179#define MCAN_CCCR_CME_Pos 8
180#define MCAN_CCCR_CME_Msk (0x3u << MCAN_CCCR_CME_Pos)
181#define MCAN_CCCR_CME(value) ((MCAN_CCCR_CME_Msk & ((value) << MCAN_CCCR_CME_Pos)))
182#define MCAN_CCCR_CME_ISO11898_1 (0x0u << 8)
183#define MCAN_CCCR_CME_FD (0x1u << 8)
184#define MCAN_CCCR_CMR_Pos 10
185#define MCAN_CCCR_CMR_Msk (0x3u << MCAN_CCCR_CMR_Pos)
186#define MCAN_CCCR_CMR(value) ((MCAN_CCCR_CMR_Msk & ((value) << MCAN_CCCR_CMR_Pos)))
187#define MCAN_CCCR_CMR_NO_CHANGE (0x0u << 10)
188#define MCAN_CCCR_CMR_FD (0x1u << 10)
189#define MCAN_CCCR_CMR_FD_BITRATE_SWITCH (0x2u << 10)
190#define MCAN_CCCR_CMR_ISO11898_1 (0x3u << 10)
191#define MCAN_CCCR_FDO (0x1u << 12)
192#define MCAN_CCCR_FDBS (0x1u << 13)
193#define MCAN_CCCR_TXP (0x1u << 14)
194/* -------- MCAN_BTP : (MCAN Offset: 0x1C) Bit Timing and Prescaler Register -------- */
195#define MCAN_BTP_SJW_Pos 0
196#define MCAN_BTP_SJW_Msk (0xfu << MCAN_BTP_SJW_Pos)
197#define MCAN_BTP_SJW(value) ((MCAN_BTP_SJW_Msk & ((value) << MCAN_BTP_SJW_Pos)))
198#define MCAN_BTP_TSEG2_Pos 4
199#define MCAN_BTP_TSEG2_Msk (0xfu << MCAN_BTP_TSEG2_Pos)
200#define MCAN_BTP_TSEG2(value) ((MCAN_BTP_TSEG2_Msk & ((value) << MCAN_BTP_TSEG2_Pos)))
201#define MCAN_BTP_TSEG1_Pos 8
202#define MCAN_BTP_TSEG1_Msk (0x3fu << MCAN_BTP_TSEG1_Pos)
203#define MCAN_BTP_TSEG1(value) ((MCAN_BTP_TSEG1_Msk & ((value) << MCAN_BTP_TSEG1_Pos)))
204#define MCAN_BTP_BRP_Pos 16
205#define MCAN_BTP_BRP_Msk (0x3ffu << MCAN_BTP_BRP_Pos)
206#define MCAN_BTP_BRP(value) ((MCAN_BTP_BRP_Msk & ((value) << MCAN_BTP_BRP_Pos)))
207/* -------- MCAN_TSCC : (MCAN Offset: 0x20) Timestamp Counter Configuration Register -------- */
208#define MCAN_TSCC_TSS_Pos 0
209#define MCAN_TSCC_TSS_Msk (0x3u << MCAN_TSCC_TSS_Pos)
210#define MCAN_TSCC_TSS(value) ((MCAN_TSCC_TSS_Msk & ((value) << MCAN_TSCC_TSS_Pos)))
211#define MCAN_TSCC_TSS_ALWAYS_0 (0x0u << 0)
212#define MCAN_TSCC_TSS_TCP_INC (0x1u << 0)
213#define MCAN_TSCC_TSS_EXT_TIMESTAMP (0x2u << 0)
214#define MCAN_TSCC_TCP_Pos 16
215#define MCAN_TSCC_TCP_Msk (0xfu << MCAN_TSCC_TCP_Pos)
216#define MCAN_TSCC_TCP(value) ((MCAN_TSCC_TCP_Msk & ((value) << MCAN_TSCC_TCP_Pos)))
217/* -------- MCAN_TSCV : (MCAN Offset: 0x24) Timestamp Counter Value Register -------- */
218#define MCAN_TSCV_TSC_Pos 0
219#define MCAN_TSCV_TSC_Msk (0xffffu << MCAN_TSCV_TSC_Pos)
220#define MCAN_TSCV_TSC(value) ((MCAN_TSCV_TSC_Msk & ((value) << MCAN_TSCV_TSC_Pos)))
221/* -------- MCAN_TOCC : (MCAN Offset: 0x28) Timeout Counter Configuration Register -------- */
222#define MCAN_TOCC_ETOC (0x1u << 0)
223#define MCAN_TOCC_ETOC_NO_TIMEOUT (0x0u << 0)
224#define MCAN_TOCC_ETOC_TOS_CONTROLLED (0x1u << 0)
225#define MCAN_TOCC_TOS_Pos 1
226#define MCAN_TOCC_TOS_Msk (0x3u << MCAN_TOCC_TOS_Pos)
227#define MCAN_TOCC_TOS(value) ((MCAN_TOCC_TOS_Msk & ((value) << MCAN_TOCC_TOS_Pos)))
228#define MCAN_TOCC_TOS_CONTINUOUS (0x0u << 1)
229#define MCAN_TOCC_TOS_TX_EV_TIMEOUT (0x1u << 1)
230#define MCAN_TOCC_TOS_RX0_EV_TIMEOUT (0x2u << 1)
231#define MCAN_TOCC_TOS_RX1_EV_TIMEOUT (0x3u << 1)
232#define MCAN_TOCC_TOP_Pos 16
233#define MCAN_TOCC_TOP_Msk (0xffffu << MCAN_TOCC_TOP_Pos)
234#define MCAN_TOCC_TOP(value) ((MCAN_TOCC_TOP_Msk & ((value) << MCAN_TOCC_TOP_Pos)))
235/* -------- MCAN_TOCV : (MCAN Offset: 0x2C) Timeout Counter Value Register -------- */
236#define MCAN_TOCV_TOC_Pos 0
237#define MCAN_TOCV_TOC_Msk (0xffffu << MCAN_TOCV_TOC_Pos)
238#define MCAN_TOCV_TOC(value) ((MCAN_TOCV_TOC_Msk & ((value) << MCAN_TOCV_TOC_Pos)))
239/* -------- MCAN_ECR : (MCAN Offset: 0x40) Error Counter Register -------- */
240#define MCAN_ECR_TEC_Pos 0
241#define MCAN_ECR_TEC_Msk (0xffu << MCAN_ECR_TEC_Pos)
242#define MCAN_ECR_REC_Pos 8
243#define MCAN_ECR_REC_Msk (0x7fu << MCAN_ECR_REC_Pos)
244#define MCAN_ECR_RP (0x1u << 15)
245#define MCAN_ECR_CEL_Pos 16
246#define MCAN_ECR_CEL_Msk (0xffu << MCAN_ECR_CEL_Pos)
247/* -------- MCAN_PSR : (MCAN Offset: 0x44) Protocol Status Register -------- */
248#define MCAN_PSR_LEC_Pos 0
249#define MCAN_PSR_LEC_Msk (0x7u << MCAN_PSR_LEC_Pos)
250#define MCAN_PSR_LEC_NO_ERROR (0x0u << 0)
251#define MCAN_PSR_LEC_STUFF_ERROR (0x1u << 0)
252#define MCAN_PSR_LEC_FORM_ERROR (0x2u << 0)
253#define MCAN_PSR_LEC_ACK_ERROR (0x3u << 0)
254#define MCAN_PSR_LEC_BIT1_ERROR (0x4u << 0)
255#define MCAN_PSR_LEC_BIT0_ERROR (0x5u << 0)
256#define MCAN_PSR_LEC_CRC_ERROR (0x6u << 0)
257#define MCAN_PSR_LEC_NO_CHANGE (0x7u << 0)
258#define MCAN_PSR_ACT_Pos 3
259#define MCAN_PSR_ACT_Msk (0x3u << MCAN_PSR_ACT_Pos)
260#define MCAN_PSR_ACT_SYNCHRONIZING (0x0u << 3)
261#define MCAN_PSR_ACT_IDLE (0x1u << 3)
262#define MCAN_PSR_ACT_RECEIVER (0x2u << 3)
263#define MCAN_PSR_ACT_TRANSMITTER (0x3u << 3)
264#define MCAN_PSR_EP (0x1u << 5)
265#define MCAN_PSR_EW (0x1u << 6)
266#define MCAN_PSR_BO (0x1u << 7)
267#define MCAN_PSR_FLEC_Pos 8
268#define MCAN_PSR_FLEC_Msk (0x7u << MCAN_PSR_FLEC_Pos)
269#define MCAN_PSR_RESI (0x1u << 11)
270#define MCAN_PSR_RBRS (0x1u << 12)
271#define MCAN_PSR_REDL (0x1u << 13)
272/* -------- MCAN_IR : (MCAN Offset: 0x50) Interrupt Register -------- */
273#define MCAN_IR_RF0N (0x1u << 0)
274#define MCAN_IR_RF0W (0x1u << 1)
275#define MCAN_IR_RF0F (0x1u << 2)
276#define MCAN_IR_RF0L (0x1u << 3)
277#define MCAN_IR_RF1N (0x1u << 4)
278#define MCAN_IR_RF1W (0x1u << 5)
279#define MCAN_IR_RF1F (0x1u << 6)
280#define MCAN_IR_RF1L (0x1u << 7)
281#define MCAN_IR_HPM (0x1u << 8)
282#define MCAN_IR_TC (0x1u << 9)
283#define MCAN_IR_TCF (0x1u << 10)
284#define MCAN_IR_TFE (0x1u << 11)
285#define MCAN_IR_TEFN (0x1u << 12)
286#define MCAN_IR_TEFW (0x1u << 13)
287#define MCAN_IR_TEFF (0x1u << 14)
288#define MCAN_IR_TEFL (0x1u << 15)
289#define MCAN_IR_TSW (0x1u << 16)
290#define MCAN_IR_MRAF (0x1u << 17)
291#define MCAN_IR_TOO (0x1u << 18)
292#define MCAN_IR_DRX (0x1u << 19)
293#define MCAN_IR_BEC (0x1u << 20)
294#define MCAN_IR_BEU (0x1u << 21)
295#define MCAN_IR_ELO (0x1u << 22)
296#define MCAN_IR_EP (0x1u << 23)
297#define MCAN_IR_EW (0x1u << 24)
298#define MCAN_IR_BO (0x1u << 25)
299#define MCAN_IR_WDI (0x1u << 26)
300#define MCAN_IR_CRCE (0x1u << 27)
301#define MCAN_IR_BE (0x1u << 28)
302#define MCAN_IR_ACKE (0x1u << 29)
303#define MCAN_IR_FOE (0x1u << 30)
304#define MCAN_IR_STE (0x1u << 31)
305/* -------- MCAN_IE : (MCAN Offset: 0x54) Interrupt Enable Register -------- */
306#define MCAN_IE_RF0NE (0x1u << 0)
307#define MCAN_IE_RF0WE (0x1u << 1)
308#define MCAN_IE_RF0FE (0x1u << 2)
309#define MCAN_IE_RF0LE (0x1u << 3)
310#define MCAN_IE_RF1NE (0x1u << 4)
311#define MCAN_IE_RF1WE (0x1u << 5)
312#define MCAN_IE_RF1FE (0x1u << 6)
313#define MCAN_IE_RF1LE (0x1u << 7)
314#define MCAN_IE_HPME (0x1u << 8)
315#define MCAN_IE_TCE (0x1u << 9)
316#define MCAN_IE_TCFE (0x1u << 10)
317#define MCAN_IE_TFEE (0x1u << 11)
318#define MCAN_IE_TEFNE (0x1u << 12)
319#define MCAN_IE_TEFWE (0x1u << 13)
320#define MCAN_IE_TEFFE (0x1u << 14)
321#define MCAN_IE_TEFLE (0x1u << 15)
322#define MCAN_IE_TSWE (0x1u << 16)
323#define MCAN_IE_MRAFE (0x1u << 17)
324#define MCAN_IE_TOOE (0x1u << 18)
325#define MCAN_IE_DRXE (0x1u << 19)
326#define MCAN_IE_BECE (0x1u << 20)
327#define MCAN_IE_BEUE (0x1u << 21)
328#define MCAN_IE_ELOE (0x1u << 22)
329#define MCAN_IE_EPE (0x1u << 23)
330#define MCAN_IE_EWE (0x1u << 24)
331#define MCAN_IE_BOE (0x1u << 25)
332#define MCAN_IE_WDIE (0x1u << 26)
333#define MCAN_IE_CRCEE (0x1u << 27)
334#define MCAN_IE_BEE (0x1u << 28)
335#define MCAN_IE_ACKEE (0x1u << 29)
336#define MCAN_IE_FOEE (0x1u << 30)
337#define MCAN_IE_STEE (0x1u << 31)
338/* -------- MCAN_ILS : (MCAN Offset: 0x58) Interrupt Line Select Register -------- */
339#define MCAN_ILS_RF0NL (0x1u << 0)
340#define MCAN_ILS_RF0WL (0x1u << 1)
341#define MCAN_ILS_RF0FL (0x1u << 2)
342#define MCAN_ILS_RF0LL (0x1u << 3)
343#define MCAN_ILS_RF1NL (0x1u << 4)
344#define MCAN_ILS_RF1WL (0x1u << 5)
345#define MCAN_ILS_RF1FL (0x1u << 6)
346#define MCAN_ILS_RF1LL (0x1u << 7)
347#define MCAN_ILS_HPML (0x1u << 8)
348#define MCAN_ILS_TCL (0x1u << 9)
349#define MCAN_ILS_TCFL (0x1u << 10)
350#define MCAN_ILS_TFEL (0x1u << 11)
351#define MCAN_ILS_TEFNL (0x1u << 12)
352#define MCAN_ILS_TEFWL (0x1u << 13)
353#define MCAN_ILS_TEFFL (0x1u << 14)
354#define MCAN_ILS_TEFLL (0x1u << 15)
355#define MCAN_ILS_TSWL (0x1u << 16)
356#define MCAN_ILS_MRAFL (0x1u << 17)
357#define MCAN_ILS_TOOL (0x1u << 18)
358#define MCAN_ILS_DRXL (0x1u << 19)
359#define MCAN_ILS_BECL (0x1u << 20)
360#define MCAN_ILS_BEUL (0x1u << 21)
361#define MCAN_ILS_ELOL (0x1u << 22)
362#define MCAN_ILS_EPL (0x1u << 23)
363#define MCAN_ILS_EWL (0x1u << 24)
364#define MCAN_ILS_BOL (0x1u << 25)
365#define MCAN_ILS_WDIL (0x1u << 26)
366#define MCAN_ILS_CRCEL (0x1u << 27)
367#define MCAN_ILS_BEL (0x1u << 28)
368#define MCAN_ILS_ACKEL (0x1u << 29)
369#define MCAN_ILS_FOEL (0x1u << 30)
370#define MCAN_ILS_STEL (0x1u << 31)
371/* -------- MCAN_ILE : (MCAN Offset: 0x5C) Interrupt Line Enable Register -------- */
372#define MCAN_ILE_EINT0 (0x1u << 0)
373#define MCAN_ILE_EINT1 (0x1u << 1)
374/* -------- MCAN_GFC : (MCAN Offset: 0x80) Global Filter Configuration Register -------- */
375#define MCAN_GFC_RRFE (0x1u << 0)
376#define MCAN_GFC_RRFE_FILTER (0x0u << 0)
377#define MCAN_GFC_RRFE_REJECT (0x1u << 0)
378#define MCAN_GFC_RRFS (0x1u << 1)
379#define MCAN_GFC_RRFS_FILTER (0x0u << 1)
380#define MCAN_GFC_RRFS_REJECT (0x1u << 1)
381#define MCAN_GFC_ANFE_Pos 2
382#define MCAN_GFC_ANFE_Msk (0x3u << MCAN_GFC_ANFE_Pos)
383#define MCAN_GFC_ANFE(value) ((MCAN_GFC_ANFE_Msk & ((value) << MCAN_GFC_ANFE_Pos)))
384#define MCAN_GFC_ANFE_RX_FIFO_0 (0x0u << 2)
385#define MCAN_GFC_ANFE_RX_FIFO_1 (0x1u << 2)
386#define MCAN_GFC_ANFS_Pos 4
387#define MCAN_GFC_ANFS_Msk (0x3u << MCAN_GFC_ANFS_Pos)
388#define MCAN_GFC_ANFS(value) ((MCAN_GFC_ANFS_Msk & ((value) << MCAN_GFC_ANFS_Pos)))
389#define MCAN_GFC_ANFS_RX_FIFO_0 (0x0u << 4)
390#define MCAN_GFC_ANFS_RX_FIFO_1 (0x1u << 4)
391/* -------- MCAN_SIDFC : (MCAN Offset: 0x84) Standard ID Filter Configuration Register -------- */
392#define MCAN_SIDFC_FLSSA_Pos 2
393#define MCAN_SIDFC_FLSSA_Msk (0x3fffu << MCAN_SIDFC_FLSSA_Pos)
394#define MCAN_SIDFC_FLSSA(value) ((MCAN_SIDFC_FLSSA_Msk & ((value) << MCAN_SIDFC_FLSSA_Pos)))
395#define MCAN_SIDFC_LSS_Pos 16
396#define MCAN_SIDFC_LSS_Msk (0xffu << MCAN_SIDFC_LSS_Pos)
397#define MCAN_SIDFC_LSS(value) ((MCAN_SIDFC_LSS_Msk & ((value) << MCAN_SIDFC_LSS_Pos)))
398/* -------- MCAN_XIDFC : (MCAN Offset: 0x88) Extended ID Filter Configuration Register -------- */
399#define MCAN_XIDFC_FLESA_Pos 2
400#define MCAN_XIDFC_FLESA_Msk (0x3fffu << MCAN_XIDFC_FLESA_Pos)
401#define MCAN_XIDFC_FLESA(value) ((MCAN_XIDFC_FLESA_Msk & ((value) << MCAN_XIDFC_FLESA_Pos)))
402#define MCAN_XIDFC_LSE_Pos 16
403#define MCAN_XIDFC_LSE_Msk (0x7fu << MCAN_XIDFC_LSE_Pos)
404#define MCAN_XIDFC_LSE(value) ((MCAN_XIDFC_LSE_Msk & ((value) << MCAN_XIDFC_LSE_Pos)))
405/* -------- MCAN_XIDAM : (MCAN Offset: 0x90) Extended ID AND Mask Register -------- */
406#define MCAN_XIDAM_EIDM_Pos 0
407#define MCAN_XIDAM_EIDM_Msk (0x1fffffffu << MCAN_XIDAM_EIDM_Pos)
408#define MCAN_XIDAM_EIDM(value) ((MCAN_XIDAM_EIDM_Msk & ((value) << MCAN_XIDAM_EIDM_Pos)))
409/* -------- MCAN_HPMS : (MCAN Offset: 0x94) High Priority Message Status Register -------- */
410#define MCAN_HPMS_BIDX_Pos 0
411#define MCAN_HPMS_BIDX_Msk (0x3fu << MCAN_HPMS_BIDX_Pos)
412#define MCAN_HPMS_MSI_Pos 6
413#define MCAN_HPMS_MSI_Msk (0x3u << MCAN_HPMS_MSI_Pos)
414#define MCAN_HPMS_MSI_NO_FIFO_SEL (0x0u << 6)
415#define MCAN_HPMS_MSI_LOST (0x1u << 6)
416#define MCAN_HPMS_MSI_FIFO_0 (0x2u << 6)
417#define MCAN_HPMS_MSI_FIFO_1 (0x3u << 6)
418#define MCAN_HPMS_FIDX_Pos 8
419#define MCAN_HPMS_FIDX_Msk (0x7fu << MCAN_HPMS_FIDX_Pos)
420#define MCAN_HPMS_FLST (0x1u << 15)
421/* -------- MCAN_NDAT1 : (MCAN Offset: 0x98) New Data 1 Register -------- */
422#define MCAN_NDAT1_ND0 (0x1u << 0)
423#define MCAN_NDAT1_ND1 (0x1u << 1)
424#define MCAN_NDAT1_ND2 (0x1u << 2)
425#define MCAN_NDAT1_ND3 (0x1u << 3)
426#define MCAN_NDAT1_ND4 (0x1u << 4)
427#define MCAN_NDAT1_ND5 (0x1u << 5)
428#define MCAN_NDAT1_ND6 (0x1u << 6)
429#define MCAN_NDAT1_ND7 (0x1u << 7)
430#define MCAN_NDAT1_ND8 (0x1u << 8)
431#define MCAN_NDAT1_ND9 (0x1u << 9)
432#define MCAN_NDAT1_ND10 (0x1u << 10)
433#define MCAN_NDAT1_ND11 (0x1u << 11)
434#define MCAN_NDAT1_ND12 (0x1u << 12)
435#define MCAN_NDAT1_ND13 (0x1u << 13)
436#define MCAN_NDAT1_ND14 (0x1u << 14)
437#define MCAN_NDAT1_ND15 (0x1u << 15)
438#define MCAN_NDAT1_ND16 (0x1u << 16)
439#define MCAN_NDAT1_ND17 (0x1u << 17)
440#define MCAN_NDAT1_ND18 (0x1u << 18)
441#define MCAN_NDAT1_ND19 (0x1u << 19)
442#define MCAN_NDAT1_ND20 (0x1u << 20)
443#define MCAN_NDAT1_ND21 (0x1u << 21)
444#define MCAN_NDAT1_ND22 (0x1u << 22)
445#define MCAN_NDAT1_ND23 (0x1u << 23)
446#define MCAN_NDAT1_ND24 (0x1u << 24)
447#define MCAN_NDAT1_ND25 (0x1u << 25)
448#define MCAN_NDAT1_ND26 (0x1u << 26)
449#define MCAN_NDAT1_ND27 (0x1u << 27)
450#define MCAN_NDAT1_ND28 (0x1u << 28)
451#define MCAN_NDAT1_ND29 (0x1u << 29)
452#define MCAN_NDAT1_ND30 (0x1u << 30)
453#define MCAN_NDAT1_ND31 (0x1u << 31)
454/* -------- MCAN_NDAT2 : (MCAN Offset: 0x9C) New Data 2 Register -------- */
455#define MCAN_NDAT2_ND32 (0x1u << 0)
456#define MCAN_NDAT2_ND33 (0x1u << 1)
457#define MCAN_NDAT2_ND34 (0x1u << 2)
458#define MCAN_NDAT2_ND35 (0x1u << 3)
459#define MCAN_NDAT2_ND36 (0x1u << 4)
460#define MCAN_NDAT2_ND37 (0x1u << 5)
461#define MCAN_NDAT2_ND38 (0x1u << 6)
462#define MCAN_NDAT2_ND39 (0x1u << 7)
463#define MCAN_NDAT2_ND40 (0x1u << 8)
464#define MCAN_NDAT2_ND41 (0x1u << 9)
465#define MCAN_NDAT2_ND42 (0x1u << 10)
466#define MCAN_NDAT2_ND43 (0x1u << 11)
467#define MCAN_NDAT2_ND44 (0x1u << 12)
468#define MCAN_NDAT2_ND45 (0x1u << 13)
469#define MCAN_NDAT2_ND46 (0x1u << 14)
470#define MCAN_NDAT2_ND47 (0x1u << 15)
471#define MCAN_NDAT2_ND48 (0x1u << 16)
472#define MCAN_NDAT2_ND49 (0x1u << 17)
473#define MCAN_NDAT2_ND50 (0x1u << 18)
474#define MCAN_NDAT2_ND51 (0x1u << 19)
475#define MCAN_NDAT2_ND52 (0x1u << 20)
476#define MCAN_NDAT2_ND53 (0x1u << 21)
477#define MCAN_NDAT2_ND54 (0x1u << 22)
478#define MCAN_NDAT2_ND55 (0x1u << 23)
479#define MCAN_NDAT2_ND56 (0x1u << 24)
480#define MCAN_NDAT2_ND57 (0x1u << 25)
481#define MCAN_NDAT2_ND58 (0x1u << 26)
482#define MCAN_NDAT2_ND59 (0x1u << 27)
483#define MCAN_NDAT2_ND60 (0x1u << 28)
484#define MCAN_NDAT2_ND61 (0x1u << 29)
485#define MCAN_NDAT2_ND62 (0x1u << 30)
486#define MCAN_NDAT2_ND63 (0x1u << 31)
487/* -------- MCAN_RXF0C : (MCAN Offset: 0xA0) Receive FIFO 0 Configuration Register -------- */
488#define MCAN_RXF0C_F0SA_Pos 2
489#define MCAN_RXF0C_F0SA_Msk (0x3fffu << MCAN_RXF0C_F0SA_Pos)
490#define MCAN_RXF0C_F0SA(value) ((MCAN_RXF0C_F0SA_Msk & ((value) << MCAN_RXF0C_F0SA_Pos)))
491#define MCAN_RXF0C_F0S_Pos 16
492#define MCAN_RXF0C_F0S_Msk (0x7fu << MCAN_RXF0C_F0S_Pos)
493#define MCAN_RXF0C_F0S(value) ((MCAN_RXF0C_F0S_Msk & ((value) << MCAN_RXF0C_F0S_Pos)))
494#define MCAN_RXF0C_F0WM_Pos 24
495#define MCAN_RXF0C_F0WM_Msk (0x7fu << MCAN_RXF0C_F0WM_Pos)
496#define MCAN_RXF0C_F0WM(value) ((MCAN_RXF0C_F0WM_Msk & ((value) << MCAN_RXF0C_F0WM_Pos)))
497#define MCAN_RXF0C_F0OM (0x1u << 31)
498/* -------- MCAN_RXF0S : (MCAN Offset: 0xA4) Receive FIFO 0 Status Register -------- */
499#define MCAN_RXF0S_F0FL_Pos 0
500#define MCAN_RXF0S_F0FL_Msk (0x7fu << MCAN_RXF0S_F0FL_Pos)
501#define MCAN_RXF0S_F0GI_Pos 8
502#define MCAN_RXF0S_F0GI_Msk (0x3fu << MCAN_RXF0S_F0GI_Pos)
503#define MCAN_RXF0S_F0PI_Pos 16
504#define MCAN_RXF0S_F0PI_Msk (0x3fu << MCAN_RXF0S_F0PI_Pos)
505#define MCAN_RXF0S_F0F (0x1u << 24)
506#define MCAN_RXF0S_RF0L (0x1u << 25)
507/* -------- MCAN_RXF0A : (MCAN Offset: 0xA8) Receive FIFO 0 Acknowledge Register -------- */
508#define MCAN_RXF0A_F0AI_Pos 0
509#define MCAN_RXF0A_F0AI_Msk (0x3fu << MCAN_RXF0A_F0AI_Pos)
510#define MCAN_RXF0A_F0AI(value) ((MCAN_RXF0A_F0AI_Msk & ((value) << MCAN_RXF0A_F0AI_Pos)))
511/* -------- MCAN_RXBC : (MCAN Offset: 0xAC) Receive Rx Buffer Configuration Register -------- */
512#define MCAN_RXBC_RBSA_Pos 2
513#define MCAN_RXBC_RBSA_Msk (0x3fffu << MCAN_RXBC_RBSA_Pos)
514#define MCAN_RXBC_RBSA(value) ((MCAN_RXBC_RBSA_Msk & ((value) << MCAN_RXBC_RBSA_Pos)))
515/* -------- MCAN_RXF1C : (MCAN Offset: 0xB0) Receive FIFO 1 Configuration Register -------- */
516#define MCAN_RXF1C_F1SA_Pos 2
517#define MCAN_RXF1C_F1SA_Msk (0x3fffu << MCAN_RXF1C_F1SA_Pos)
518#define MCAN_RXF1C_F1SA(value) ((MCAN_RXF1C_F1SA_Msk & ((value) << MCAN_RXF1C_F1SA_Pos)))
519#define MCAN_RXF1C_F1S_Pos 16
520#define MCAN_RXF1C_F1S_Msk (0x7fu << MCAN_RXF1C_F1S_Pos)
521#define MCAN_RXF1C_F1S(value) ((MCAN_RXF1C_F1S_Msk & ((value) << MCAN_RXF1C_F1S_Pos)))
522#define MCAN_RXF1C_F1WM_Pos 24
523#define MCAN_RXF1C_F1WM_Msk (0x7fu << MCAN_RXF1C_F1WM_Pos)
524#define MCAN_RXF1C_F1WM(value) ((MCAN_RXF1C_F1WM_Msk & ((value) << MCAN_RXF1C_F1WM_Pos)))
525#define MCAN_RXF1C_F1OM (0x1u << 31)
526/* -------- MCAN_RXF1S : (MCAN Offset: 0xB4) Receive FIFO 1 Status Register -------- */
527#define MCAN_RXF1S_F1FL_Pos 0
528#define MCAN_RXF1S_F1FL_Msk (0x7fu << MCAN_RXF1S_F1FL_Pos)
529#define MCAN_RXF1S_F1GI_Pos 8
530#define MCAN_RXF1S_F1GI_Msk (0x3fu << MCAN_RXF1S_F1GI_Pos)
531#define MCAN_RXF1S_F1PI_Pos 16
532#define MCAN_RXF1S_F1PI_Msk (0x3fu << MCAN_RXF1S_F1PI_Pos)
533#define MCAN_RXF1S_F1F (0x1u << 24)
534#define MCAN_RXF1S_RF1L (0x1u << 25)
535#define MCAN_RXF1S_DMS_Pos 30
536#define MCAN_RXF1S_DMS_Msk (0x3u << MCAN_RXF1S_DMS_Pos)
537#define MCAN_RXF1S_DMS_IDLE (0x0u << 30)
538#define MCAN_RXF1S_DMS_MSG_A (0x1u << 30)
539#define MCAN_RXF1S_DMS_MSG_AB (0x2u << 30)
540#define MCAN_RXF1S_DMS_MSG_ABC (0x3u << 30)
541/* -------- MCAN_RXF1A : (MCAN Offset: 0xB8) Receive FIFO 1 Acknowledge Register -------- */
542#define MCAN_RXF1A_F1AI_Pos 0
543#define MCAN_RXF1A_F1AI_Msk (0x3fu << MCAN_RXF1A_F1AI_Pos)
544#define MCAN_RXF1A_F1AI(value) ((MCAN_RXF1A_F1AI_Msk & ((value) << MCAN_RXF1A_F1AI_Pos)))
545/* -------- MCAN_RXESC : (MCAN Offset: 0xBC) Receive Buffer / FIFO Element Size Configuration Register -------- */
546#define MCAN_RXESC_F0DS_Pos 0
547#define MCAN_RXESC_F0DS_Msk (0x7u << MCAN_RXESC_F0DS_Pos)
548#define MCAN_RXESC_F0DS(value) ((MCAN_RXESC_F0DS_Msk & ((value) << MCAN_RXESC_F0DS_Pos)))
549#define MCAN_RXESC_F0DS_8_BYTE (0x0u << 0)
550#define MCAN_RXESC_F0DS_12_BYTE (0x1u << 0)
551#define MCAN_RXESC_F0DS_16_BYTE (0x2u << 0)
552#define MCAN_RXESC_F0DS_20_BYTE (0x3u << 0)
553#define MCAN_RXESC_F0DS_24_BYTE (0x4u << 0)
554#define MCAN_RXESC_F0DS_32_BYTE (0x5u << 0)
555#define MCAN_RXESC_F0DS_48_BYTE (0x6u << 0)
556#define MCAN_RXESC_F0DS_64_BYTE (0x7u << 0)
557#define MCAN_RXESC_F1DS_Pos 4
558#define MCAN_RXESC_F1DS_Msk (0x7u << MCAN_RXESC_F1DS_Pos)
559#define MCAN_RXESC_F1DS(value) ((MCAN_RXESC_F1DS_Msk & ((value) << MCAN_RXESC_F1DS_Pos)))
560#define MCAN_RXESC_F1DS_8_BYTE (0x0u << 4)
561#define MCAN_RXESC_F1DS_12_BYTE (0x1u << 4)
562#define MCAN_RXESC_F1DS_16_BYTE (0x2u << 4)
563#define MCAN_RXESC_F1DS_20_BYTE (0x3u << 4)
564#define MCAN_RXESC_F1DS_24_BYTE (0x4u << 4)
565#define MCAN_RXESC_F1DS_32_BYTE (0x5u << 4)
566#define MCAN_RXESC_F1DS_48_BYTE (0x6u << 4)
567#define MCAN_RXESC_F1DS_64_BYTE (0x7u << 4)
568#define MCAN_RXESC_RBDS_Pos 8
569#define MCAN_RXESC_RBDS_Msk (0x7u << MCAN_RXESC_RBDS_Pos)
570#define MCAN_RXESC_RBDS(value) ((MCAN_RXESC_RBDS_Msk & ((value) << MCAN_RXESC_RBDS_Pos)))
571#define MCAN_RXESC_RBDS_8_BYTE (0x0u << 8)
572#define MCAN_RXESC_RBDS_12_BYTE (0x1u << 8)
573#define MCAN_RXESC_RBDS_16_BYTE (0x2u << 8)
574#define MCAN_RXESC_RBDS_20_BYTE (0x3u << 8)
575#define MCAN_RXESC_RBDS_24_BYTE (0x4u << 8)
576#define MCAN_RXESC_RBDS_32_BYTE (0x5u << 8)
577#define MCAN_RXESC_RBDS_48_BYTE (0x6u << 8)
578#define MCAN_RXESC_RBDS_64_BYTE (0x7u << 8)
579/* -------- MCAN_TXBC : (MCAN Offset: 0xC0) Transmit Buffer Configuration Register -------- */
580#define MCAN_TXBC_TBSA_Pos 2
581#define MCAN_TXBC_TBSA_Msk (0x3fffu << MCAN_TXBC_TBSA_Pos)
582#define MCAN_TXBC_TBSA(value) ((MCAN_TXBC_TBSA_Msk & ((value) << MCAN_TXBC_TBSA_Pos)))
583#define MCAN_TXBC_NDTB_Pos 16
584#define MCAN_TXBC_NDTB_Msk (0x3fu << MCAN_TXBC_NDTB_Pos)
585#define MCAN_TXBC_NDTB(value) ((MCAN_TXBC_NDTB_Msk & ((value) << MCAN_TXBC_NDTB_Pos)))
586#define MCAN_TXBC_TFQS_Pos 24
587#define MCAN_TXBC_TFQS_Msk (0x3fu << MCAN_TXBC_TFQS_Pos)
588#define MCAN_TXBC_TFQS(value) ((MCAN_TXBC_TFQS_Msk & ((value) << MCAN_TXBC_TFQS_Pos)))
589#define MCAN_TXBC_TFQM (0x1u << 30)
590/* -------- MCAN_TXFQS : (MCAN Offset: 0xC4) Transmit FIFO/Queue Status Register -------- */
591#define MCAN_TXFQS_TFFL_Pos 0
592#define MCAN_TXFQS_TFFL_Msk (0x3fu << MCAN_TXFQS_TFFL_Pos)
593#define MCAN_TXFQS_TFGI_Pos 8
594#define MCAN_TXFQS_TFGI_Msk (0x1fu << MCAN_TXFQS_TFGI_Pos)
595#define MCAN_TXFQS_TFQPI_Pos 16
596#define MCAN_TXFQS_TFQPI_Msk (0x1fu << MCAN_TXFQS_TFQPI_Pos)
597#define MCAN_TXFQS_TFQF (0x1u << 21)
598/* -------- MCAN_TXESC : (MCAN Offset: 0xC8) Transmit Buffer Element Size Configuration Register -------- */
599#define MCAN_TXESC_TBDS_Pos 0
600#define MCAN_TXESC_TBDS_Msk (0x7u << MCAN_TXESC_TBDS_Pos)
601#define MCAN_TXESC_TBDS(value) ((MCAN_TXESC_TBDS_Msk & ((value) << MCAN_TXESC_TBDS_Pos)))
602#define MCAN_TXESC_TBDS_8_BYTE (0x0u << 0)
603#define MCAN_TXESC_TBDS_12_BYTE (0x1u << 0)
604#define MCAN_TXESC_TBDS_16_BYTE (0x2u << 0)
605#define MCAN_TXESC_TBDS_20_BYTE (0x3u << 0)
606#define MCAN_TXESC_TBDS_24_BYTE (0x4u << 0)
607#define MCAN_TXESC_TBDS_32_BYTE (0x5u << 0)
608#define MCAN_TXESC_TBDS_48_BYTE (0x6u << 0)
609#define MCAN_TXESC_TBDS_64_BYTE (0x7u << 0)
610/* -------- MCAN_TXBRP : (MCAN Offset: 0xCC) Transmit Buffer Request Pending Register -------- */
611#define MCAN_TXBRP_TRP0 (0x1u << 0)
612#define MCAN_TXBRP_TRP1 (0x1u << 1)
613#define MCAN_TXBRP_TRP2 (0x1u << 2)
614#define MCAN_TXBRP_TRP3 (0x1u << 3)
615#define MCAN_TXBRP_TRP4 (0x1u << 4)
616#define MCAN_TXBRP_TRP5 (0x1u << 5)
617#define MCAN_TXBRP_TRP6 (0x1u << 6)
618#define MCAN_TXBRP_TRP7 (0x1u << 7)
619#define MCAN_TXBRP_TRP8 (0x1u << 8)
620#define MCAN_TXBRP_TRP9 (0x1u << 9)
621#define MCAN_TXBRP_TRP10 (0x1u << 10)
622#define MCAN_TXBRP_TRP11 (0x1u << 11)
623#define MCAN_TXBRP_TRP12 (0x1u << 12)
624#define MCAN_TXBRP_TRP13 (0x1u << 13)
625#define MCAN_TXBRP_TRP14 (0x1u << 14)
626#define MCAN_TXBRP_TRP15 (0x1u << 15)
627#define MCAN_TXBRP_TRP16 (0x1u << 16)
628#define MCAN_TXBRP_TRP17 (0x1u << 17)
629#define MCAN_TXBRP_TRP18 (0x1u << 18)
630#define MCAN_TXBRP_TRP19 (0x1u << 19)
631#define MCAN_TXBRP_TRP20 (0x1u << 20)
632#define MCAN_TXBRP_TRP21 (0x1u << 21)
633#define MCAN_TXBRP_TRP22 (0x1u << 22)
634#define MCAN_TXBRP_TRP23 (0x1u << 23)
635#define MCAN_TXBRP_TRP24 (0x1u << 24)
636#define MCAN_TXBRP_TRP25 (0x1u << 25)
637#define MCAN_TXBRP_TRP26 (0x1u << 26)
638#define MCAN_TXBRP_TRP27 (0x1u << 27)
639#define MCAN_TXBRP_TRP28 (0x1u << 28)
640#define MCAN_TXBRP_TRP29 (0x1u << 29)
641#define MCAN_TXBRP_TRP30 (0x1u << 30)
642#define MCAN_TXBRP_TRP31 (0x1u << 31)
643/* -------- MCAN_TXBAR : (MCAN Offset: 0xD0) Transmit Buffer Add Request Register -------- */
644#define MCAN_TXBAR_AR0 (0x1u << 0)
645#define MCAN_TXBAR_AR1 (0x1u << 1)
646#define MCAN_TXBAR_AR2 (0x1u << 2)
647#define MCAN_TXBAR_AR3 (0x1u << 3)
648#define MCAN_TXBAR_AR4 (0x1u << 4)
649#define MCAN_TXBAR_AR5 (0x1u << 5)
650#define MCAN_TXBAR_AR6 (0x1u << 6)
651#define MCAN_TXBAR_AR7 (0x1u << 7)
652#define MCAN_TXBAR_AR8 (0x1u << 8)
653#define MCAN_TXBAR_AR9 (0x1u << 9)
654#define MCAN_TXBAR_AR10 (0x1u << 10)
655#define MCAN_TXBAR_AR11 (0x1u << 11)
656#define MCAN_TXBAR_AR12 (0x1u << 12)
657#define MCAN_TXBAR_AR13 (0x1u << 13)
658#define MCAN_TXBAR_AR14 (0x1u << 14)
659#define MCAN_TXBAR_AR15 (0x1u << 15)
660#define MCAN_TXBAR_AR16 (0x1u << 16)
661#define MCAN_TXBAR_AR17 (0x1u << 17)
662#define MCAN_TXBAR_AR18 (0x1u << 18)
663#define MCAN_TXBAR_AR19 (0x1u << 19)
664#define MCAN_TXBAR_AR20 (0x1u << 20)
665#define MCAN_TXBAR_AR21 (0x1u << 21)
666#define MCAN_TXBAR_AR22 (0x1u << 22)
667#define MCAN_TXBAR_AR23 (0x1u << 23)
668#define MCAN_TXBAR_AR24 (0x1u << 24)
669#define MCAN_TXBAR_AR25 (0x1u << 25)
670#define MCAN_TXBAR_AR26 (0x1u << 26)
671#define MCAN_TXBAR_AR27 (0x1u << 27)
672#define MCAN_TXBAR_AR28 (0x1u << 28)
673#define MCAN_TXBAR_AR29 (0x1u << 29)
674#define MCAN_TXBAR_AR30 (0x1u << 30)
675#define MCAN_TXBAR_AR31 (0x1u << 31)
676/* -------- MCAN_TXBCR : (MCAN Offset: 0xD4) Transmit Buffer Cancellation Request Register -------- */
677#define MCAN_TXBCR_CR0 (0x1u << 0)
678#define MCAN_TXBCR_CR1 (0x1u << 1)
679#define MCAN_TXBCR_CR2 (0x1u << 2)
680#define MCAN_TXBCR_CR3 (0x1u << 3)
681#define MCAN_TXBCR_CR4 (0x1u << 4)
682#define MCAN_TXBCR_CR5 (0x1u << 5)
683#define MCAN_TXBCR_CR6 (0x1u << 6)
684#define MCAN_TXBCR_CR7 (0x1u << 7)
685#define MCAN_TXBCR_CR8 (0x1u << 8)
686#define MCAN_TXBCR_CR9 (0x1u << 9)
687#define MCAN_TXBCR_CR10 (0x1u << 10)
688#define MCAN_TXBCR_CR11 (0x1u << 11)
689#define MCAN_TXBCR_CR12 (0x1u << 12)
690#define MCAN_TXBCR_CR13 (0x1u << 13)
691#define MCAN_TXBCR_CR14 (0x1u << 14)
692#define MCAN_TXBCR_CR15 (0x1u << 15)
693#define MCAN_TXBCR_CR16 (0x1u << 16)
694#define MCAN_TXBCR_CR17 (0x1u << 17)
695#define MCAN_TXBCR_CR18 (0x1u << 18)
696#define MCAN_TXBCR_CR19 (0x1u << 19)
697#define MCAN_TXBCR_CR20 (0x1u << 20)
698#define MCAN_TXBCR_CR21 (0x1u << 21)
699#define MCAN_TXBCR_CR22 (0x1u << 22)
700#define MCAN_TXBCR_CR23 (0x1u << 23)
701#define MCAN_TXBCR_CR24 (0x1u << 24)
702#define MCAN_TXBCR_CR25 (0x1u << 25)
703#define MCAN_TXBCR_CR26 (0x1u << 26)
704#define MCAN_TXBCR_CR27 (0x1u << 27)
705#define MCAN_TXBCR_CR28 (0x1u << 28)
706#define MCAN_TXBCR_CR29 (0x1u << 29)
707#define MCAN_TXBCR_CR30 (0x1u << 30)
708#define MCAN_TXBCR_CR31 (0x1u << 31)
709/* -------- MCAN_TXBTO : (MCAN Offset: 0xD8) Transmit Buffer Transmission Occurred Register -------- */
710#define MCAN_TXBTO_TO0 (0x1u << 0)
711#define MCAN_TXBTO_TO1 (0x1u << 1)
712#define MCAN_TXBTO_TO2 (0x1u << 2)
713#define MCAN_TXBTO_TO3 (0x1u << 3)
714#define MCAN_TXBTO_TO4 (0x1u << 4)
715#define MCAN_TXBTO_TO5 (0x1u << 5)
716#define MCAN_TXBTO_TO6 (0x1u << 6)
717#define MCAN_TXBTO_TO7 (0x1u << 7)
718#define MCAN_TXBTO_TO8 (0x1u << 8)
719#define MCAN_TXBTO_TO9 (0x1u << 9)
720#define MCAN_TXBTO_TO10 (0x1u << 10)
721#define MCAN_TXBTO_TO11 (0x1u << 11)
722#define MCAN_TXBTO_TO12 (0x1u << 12)
723#define MCAN_TXBTO_TO13 (0x1u << 13)
724#define MCAN_TXBTO_TO14 (0x1u << 14)
725#define MCAN_TXBTO_TO15 (0x1u << 15)
726#define MCAN_TXBTO_TO16 (0x1u << 16)
727#define MCAN_TXBTO_TO17 (0x1u << 17)
728#define MCAN_TXBTO_TO18 (0x1u << 18)
729#define MCAN_TXBTO_TO19 (0x1u << 19)
730#define MCAN_TXBTO_TO20 (0x1u << 20)
731#define MCAN_TXBTO_TO21 (0x1u << 21)
732#define MCAN_TXBTO_TO22 (0x1u << 22)
733#define MCAN_TXBTO_TO23 (0x1u << 23)
734#define MCAN_TXBTO_TO24 (0x1u << 24)
735#define MCAN_TXBTO_TO25 (0x1u << 25)
736#define MCAN_TXBTO_TO26 (0x1u << 26)
737#define MCAN_TXBTO_TO27 (0x1u << 27)
738#define MCAN_TXBTO_TO28 (0x1u << 28)
739#define MCAN_TXBTO_TO29 (0x1u << 29)
740#define MCAN_TXBTO_TO30 (0x1u << 30)
741#define MCAN_TXBTO_TO31 (0x1u << 31)
742/* -------- MCAN_TXBCF : (MCAN Offset: 0xDC) Transmit Buffer Cancellation Finished Register -------- */
743#define MCAN_TXBCF_CF0 (0x1u << 0)
744#define MCAN_TXBCF_CF1 (0x1u << 1)
745#define MCAN_TXBCF_CF2 (0x1u << 2)
746#define MCAN_TXBCF_CF3 (0x1u << 3)
747#define MCAN_TXBCF_CF4 (0x1u << 4)
748#define MCAN_TXBCF_CF5 (0x1u << 5)
749#define MCAN_TXBCF_CF6 (0x1u << 6)
750#define MCAN_TXBCF_CF7 (0x1u << 7)
751#define MCAN_TXBCF_CF8 (0x1u << 8)
752#define MCAN_TXBCF_CF9 (0x1u << 9)
753#define MCAN_TXBCF_CF10 (0x1u << 10)
754#define MCAN_TXBCF_CF11 (0x1u << 11)
755#define MCAN_TXBCF_CF12 (0x1u << 12)
756#define MCAN_TXBCF_CF13 (0x1u << 13)
757#define MCAN_TXBCF_CF14 (0x1u << 14)
758#define MCAN_TXBCF_CF15 (0x1u << 15)
759#define MCAN_TXBCF_CF16 (0x1u << 16)
760#define MCAN_TXBCF_CF17 (0x1u << 17)
761#define MCAN_TXBCF_CF18 (0x1u << 18)
762#define MCAN_TXBCF_CF19 (0x1u << 19)
763#define MCAN_TXBCF_CF20 (0x1u << 20)
764#define MCAN_TXBCF_CF21 (0x1u << 21)
765#define MCAN_TXBCF_CF22 (0x1u << 22)
766#define MCAN_TXBCF_CF23 (0x1u << 23)
767#define MCAN_TXBCF_CF24 (0x1u << 24)
768#define MCAN_TXBCF_CF25 (0x1u << 25)
769#define MCAN_TXBCF_CF26 (0x1u << 26)
770#define MCAN_TXBCF_CF27 (0x1u << 27)
771#define MCAN_TXBCF_CF28 (0x1u << 28)
772#define MCAN_TXBCF_CF29 (0x1u << 29)
773#define MCAN_TXBCF_CF30 (0x1u << 30)
774#define MCAN_TXBCF_CF31 (0x1u << 31)
775/* -------- MCAN_TXBTIE : (MCAN Offset: 0xE0) Transmit Buffer Transmission Interrupt Enable Register -------- */
776#define MCAN_TXBTIE_TIE0 (0x1u << 0)
777#define MCAN_TXBTIE_TIE1 (0x1u << 1)
778#define MCAN_TXBTIE_TIE2 (0x1u << 2)
779#define MCAN_TXBTIE_TIE3 (0x1u << 3)
780#define MCAN_TXBTIE_TIE4 (0x1u << 4)
781#define MCAN_TXBTIE_TIE5 (0x1u << 5)
782#define MCAN_TXBTIE_TIE6 (0x1u << 6)
783#define MCAN_TXBTIE_TIE7 (0x1u << 7)
784#define MCAN_TXBTIE_TIE8 (0x1u << 8)
785#define MCAN_TXBTIE_TIE9 (0x1u << 9)
786#define MCAN_TXBTIE_TIE10 (0x1u << 10)
787#define MCAN_TXBTIE_TIE11 (0x1u << 11)
788#define MCAN_TXBTIE_TIE12 (0x1u << 12)
789#define MCAN_TXBTIE_TIE13 (0x1u << 13)
790#define MCAN_TXBTIE_TIE14 (0x1u << 14)
791#define MCAN_TXBTIE_TIE15 (0x1u << 15)
792#define MCAN_TXBTIE_TIE16 (0x1u << 16)
793#define MCAN_TXBTIE_TIE17 (0x1u << 17)
794#define MCAN_TXBTIE_TIE18 (0x1u << 18)
795#define MCAN_TXBTIE_TIE19 (0x1u << 19)
796#define MCAN_TXBTIE_TIE20 (0x1u << 20)
797#define MCAN_TXBTIE_TIE21 (0x1u << 21)
798#define MCAN_TXBTIE_TIE22 (0x1u << 22)
799#define MCAN_TXBTIE_TIE23 (0x1u << 23)
800#define MCAN_TXBTIE_TIE24 (0x1u << 24)
801#define MCAN_TXBTIE_TIE25 (0x1u << 25)
802#define MCAN_TXBTIE_TIE26 (0x1u << 26)
803#define MCAN_TXBTIE_TIE27 (0x1u << 27)
804#define MCAN_TXBTIE_TIE28 (0x1u << 28)
805#define MCAN_TXBTIE_TIE29 (0x1u << 29)
806#define MCAN_TXBTIE_TIE30 (0x1u << 30)
807#define MCAN_TXBTIE_TIE31 (0x1u << 31)
808/* -------- MCAN_TXBCIE : (MCAN Offset: 0xE4) Transmit Buffer Cancellation Finished Interrupt Enable Register -------- */
809#define MCAN_TXBCIE_CFIE0 (0x1u << 0)
810#define MCAN_TXBCIE_CFIE1 (0x1u << 1)
811#define MCAN_TXBCIE_CFIE2 (0x1u << 2)
812#define MCAN_TXBCIE_CFIE3 (0x1u << 3)
813#define MCAN_TXBCIE_CFIE4 (0x1u << 4)
814#define MCAN_TXBCIE_CFIE5 (0x1u << 5)
815#define MCAN_TXBCIE_CFIE6 (0x1u << 6)
816#define MCAN_TXBCIE_CFIE7 (0x1u << 7)
817#define MCAN_TXBCIE_CFIE8 (0x1u << 8)
818#define MCAN_TXBCIE_CFIE9 (0x1u << 9)
819#define MCAN_TXBCIE_CFIE10 (0x1u << 10)
820#define MCAN_TXBCIE_CFIE11 (0x1u << 11)
821#define MCAN_TXBCIE_CFIE12 (0x1u << 12)
822#define MCAN_TXBCIE_CFIE13 (0x1u << 13)
823#define MCAN_TXBCIE_CFIE14 (0x1u << 14)
824#define MCAN_TXBCIE_CFIE15 (0x1u << 15)
825#define MCAN_TXBCIE_CFIE16 (0x1u << 16)
826#define MCAN_TXBCIE_CFIE17 (0x1u << 17)
827#define MCAN_TXBCIE_CFIE18 (0x1u << 18)
828#define MCAN_TXBCIE_CFIE19 (0x1u << 19)
829#define MCAN_TXBCIE_CFIE20 (0x1u << 20)
830#define MCAN_TXBCIE_CFIE21 (0x1u << 21)
831#define MCAN_TXBCIE_CFIE22 (0x1u << 22)
832#define MCAN_TXBCIE_CFIE23 (0x1u << 23)
833#define MCAN_TXBCIE_CFIE24 (0x1u << 24)
834#define MCAN_TXBCIE_CFIE25 (0x1u << 25)
835#define MCAN_TXBCIE_CFIE26 (0x1u << 26)
836#define MCAN_TXBCIE_CFIE27 (0x1u << 27)
837#define MCAN_TXBCIE_CFIE28 (0x1u << 28)
838#define MCAN_TXBCIE_CFIE29 (0x1u << 29)
839#define MCAN_TXBCIE_CFIE30 (0x1u << 30)
840#define MCAN_TXBCIE_CFIE31 (0x1u << 31)
841/* -------- MCAN_TXEFC : (MCAN Offset: 0xF0) Transmit Event FIFO Configuration Register -------- */
842#define MCAN_TXEFC_EFSA_Pos 2
843#define MCAN_TXEFC_EFSA_Msk (0x3fffu << MCAN_TXEFC_EFSA_Pos)
844#define MCAN_TXEFC_EFSA(value) ((MCAN_TXEFC_EFSA_Msk & ((value) << MCAN_TXEFC_EFSA_Pos)))
845#define MCAN_TXEFC_EFS_Pos 16
846#define MCAN_TXEFC_EFS_Msk (0x3fu << MCAN_TXEFC_EFS_Pos)
847#define MCAN_TXEFC_EFS(value) ((MCAN_TXEFC_EFS_Msk & ((value) << MCAN_TXEFC_EFS_Pos)))
848#define MCAN_TXEFC_EFWM_Pos 24
849#define MCAN_TXEFC_EFWM_Msk (0x3fu << MCAN_TXEFC_EFWM_Pos)
850#define MCAN_TXEFC_EFWM(value) ((MCAN_TXEFC_EFWM_Msk & ((value) << MCAN_TXEFC_EFWM_Pos)))
851/* -------- MCAN_TXEFS : (MCAN Offset: 0xF4) Transmit Event FIFO Status Register -------- */
852#define MCAN_TXEFS_EFFL_Pos 0
853#define MCAN_TXEFS_EFFL_Msk (0x3fu << MCAN_TXEFS_EFFL_Pos)
854#define MCAN_TXEFS_EFGI_Pos 8
855#define MCAN_TXEFS_EFGI_Msk (0x1fu << MCAN_TXEFS_EFGI_Pos)
856#define MCAN_TXEFS_EFPI_Pos 16
857#define MCAN_TXEFS_EFPI_Msk (0x1fu << MCAN_TXEFS_EFPI_Pos)
858#define MCAN_TXEFS_EFF (0x1u << 24)
859#define MCAN_TXEFS_TEFL (0x1u << 25)
860/* -------- MCAN_TXEFA : (MCAN Offset: 0xF8) Transmit Event FIFO Acknowledge Register -------- */
861#define MCAN_TXEFA_EFAI_Pos 0
862#define MCAN_TXEFA_EFAI_Msk (0x1fu << MCAN_TXEFA_EFAI_Pos)
863#define MCAN_TXEFA_EFAI(value) ((MCAN_TXEFA_EFAI_Msk & ((value) << MCAN_TXEFA_EFAI_Pos)))
864
868#endif /* _SAMV71_MCAN_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __I
Definition: core_cm7.h:284
Mcan hardware registers.
Definition: component_mcan.h:41
(Mcan Offset: 0x04) Endian Register
Definition: component_mcan.h:43
(Mcan Offset: 0x00) Core Release Register
Definition: component_mcan.h:42
