RTEMS 5.2
component_gmac.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_GMAC_COMPONENT_
31#define _SAMV71_GMAC_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __IO uint32_t GMAC_SAB;
43 __IO uint32_t GMAC_SAT;
44} GmacSa;
45
47typedef struct {
48 __IO uint32_t GMAC_ST2COM0;
49 __IO uint32_t GMAC_ST2COM1;
51
53#define GMACSA_NUMBER 4
54#define GMACST2COMPARE_NUMBER 24
55typedef struct {
56 __IO uint32_t GMAC_NCR;
57 __IO uint32_t GMAC_NCFGR;
58 __I uint32_t GMAC_NSR;
59 __IO uint32_t GMAC_UR;
60 __IO uint32_t GMAC_DCFGR;
61 __IO uint32_t GMAC_TSR;
62 __IO uint32_t GMAC_RBQB;
63 __IO uint32_t GMAC_TBQB;
64 __IO uint32_t GMAC_RSR;
65 __I uint32_t GMAC_ISR;
66 __O uint32_t GMAC_IER;
67 __O uint32_t GMAC_IDR;
68 __IO uint32_t GMAC_IMR;
69 __IO uint32_t GMAC_MAN;
70 __I uint32_t GMAC_RPQ;
71 __IO uint32_t GMAC_TPQ;
72 __IO uint32_t GMAC_TPSF;
73 __IO uint32_t GMAC_RPSF;
74 __IO uint32_t GMAC_RJFML;
75 __I uint32_t Reserved1[13];
76 __IO uint32_t GMAC_HRB;
77 __IO uint32_t GMAC_HRT;
78 GmacSa GMAC_SA[GMACSA_NUMBER];
79 __IO uint32_t GMAC_TIDM1;
80 __IO uint32_t GMAC_TIDM2;
81 __IO uint32_t GMAC_TIDM3;
82 __IO uint32_t GMAC_TIDM4;
83 __IO uint32_t GMAC_WOL;
84 __IO uint32_t GMAC_IPGS;
85 __IO uint32_t GMAC_SVLAN;
86 __IO uint32_t GMAC_TPFCP;
87 __IO uint32_t GMAC_SAMB1;
88 __IO uint32_t GMAC_SAMT1;
89 __I uint32_t Reserved2[3];
90 __IO uint32_t GMAC_NSC;
91 __IO uint32_t GMAC_SCL;
92 __IO uint32_t GMAC_SCH;
93 __I uint32_t GMAC_EFTSH;
94 __I uint32_t GMAC_EFRSH;
95 __I uint32_t GMAC_PEFTSH;
96 __I uint32_t GMAC_PEFRSH;
97 __I uint32_t Reserved3[1];
98 __I uint32_t GMAC_MID;
99 __I uint32_t GMAC_OTLO;
100 __I uint32_t GMAC_OTHI;
101 __I uint32_t GMAC_FT;
102 __I uint32_t GMAC_BCFT;
103 __I uint32_t GMAC_MFT;
104 __I uint32_t GMAC_PFT;
105 __I uint32_t GMAC_BFT64;
106 __I uint32_t GMAC_TBFT127;
107 __I uint32_t GMAC_TBFT255;
108 __I uint32_t GMAC_TBFT511;
109 __I uint32_t GMAC_TBFT1023;
110 __I uint32_t GMAC_TBFT1518;
111 __I uint32_t GMAC_GTBFT1518;
112 __I uint32_t GMAC_TUR;
113 __I uint32_t GMAC_SCF;
114 __I uint32_t GMAC_MCF;
115 __I uint32_t GMAC_EC;
116 __I uint32_t GMAC_LC;
117 __I uint32_t GMAC_DTF;
118 __I uint32_t GMAC_CSE;
119 __I uint32_t GMAC_ORLO;
120 __I uint32_t GMAC_ORHI;
121 __I uint32_t GMAC_FR;
122 __I uint32_t GMAC_BCFR;
123 __I uint32_t GMAC_MFR;
124 __I uint32_t GMAC_PFR;
125 __I uint32_t GMAC_BFR64;
126 __I uint32_t GMAC_TBFR127;
127 __I uint32_t GMAC_TBFR255;
128 __I uint32_t GMAC_TBFR511;
129 __I uint32_t GMAC_TBFR1023;
130 __I uint32_t GMAC_TBFR1518;
131 __I uint32_t GMAC_TMXBFR;
132 __I uint32_t GMAC_UFR;
133 __I uint32_t GMAC_OFR;
134 __I uint32_t GMAC_JR;
135 __I uint32_t GMAC_FCSE;
136 __I uint32_t GMAC_LFFE;
137 __I uint32_t GMAC_RSE;
138 __I uint32_t GMAC_AE;
139 __I uint32_t GMAC_RRE;
140 __I uint32_t GMAC_ROE;
141 __I uint32_t GMAC_IHCE;
142 __I uint32_t GMAC_TCE;
143 __I uint32_t GMAC_UCE;
144 __I uint32_t Reserved4[2];
145 __IO uint32_t GMAC_TISUBN;
146 __IO uint32_t GMAC_TSH;
147 __I uint32_t Reserved5[3];
148 __IO uint32_t GMAC_TSL;
149 __IO uint32_t GMAC_TN;
150 __O uint32_t GMAC_TA;
151 __IO uint32_t GMAC_TI;
152 __I uint32_t GMAC_EFTSL;
153 __I uint32_t GMAC_EFTN;
154 __I uint32_t GMAC_EFRSL;
155 __I uint32_t GMAC_EFRN;
156 __I uint32_t GMAC_PEFTSL;
157 __I uint32_t GMAC_PEFTN;
158 __I uint32_t GMAC_PEFRSL;
159 __I uint32_t GMAC_PEFRN;
160 __I uint32_t Reserved6[128];
161 __I uint32_t GMAC_ISRPQ[2];
162 __I uint32_t Reserved7[14];
163 __IO uint32_t GMAC_TBQBAPQ[2];
164 __I uint32_t Reserved8[14];
165 __IO uint32_t GMAC_RBQBAPQ[2];
166 __I uint32_t Reserved9[6];
167 __IO uint32_t GMAC_RBSRPQ[2];
168 __I uint32_t Reserved10[5];
169 __IO uint32_t GMAC_CBSCR;
170 __IO uint32_t GMAC_CBSISQA;
171 __IO uint32_t GMAC_CBSISQB;
172 __I uint32_t Reserved11[14];
173 __IO uint32_t GMAC_ST1RPQ[4];
174 __I uint32_t Reserved12[12];
175 __IO uint32_t GMAC_ST2RPQ[8];
176 __I uint32_t Reserved13[12];
177 __I uint32_t Reserved14[28];
178 __O uint32_t GMAC_IERPQ[2];
179 __I uint32_t Reserved15[6];
180 __O uint32_t GMAC_IDRPQ[2];
181 __I uint32_t Reserved16[6];
182 __IO uint32_t GMAC_IMRPQ[2];
183 __I uint32_t Reserved17[38];
184 __IO uint32_t GMAC_ST2ER[4];
185 __I uint32_t Reserved18[4];
186 __IO GmacSt2Compare GMAC_ST2COMP[GMACST2COMPARE_NUMBER];
187} Gmac;
188#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
189/* -------- GMAC_NCR : (GMAC Offset: 0x000) Network Control Register -------- */
190#define GMAC_NCR_LBL (0x1u << 1)
191#define GMAC_NCR_RXEN (0x1u << 2)
192#define GMAC_NCR_TXEN (0x1u << 3)
193#define GMAC_NCR_MPE (0x1u << 4)
194#define GMAC_NCR_CLRSTAT (0x1u << 5)
195#define GMAC_NCR_INCSTAT (0x1u << 6)
196#define GMAC_NCR_WESTAT (0x1u << 7)
197#define GMAC_NCR_BP (0x1u << 8)
198#define GMAC_NCR_TSTART (0x1u << 9)
199#define GMAC_NCR_THALT (0x1u << 10)
200#define GMAC_NCR_TXPF (0x1u << 11)
201#define GMAC_NCR_TXZQPF (0x1u << 12)
202#define GMAC_NCR_SRTSM (0x1u << 15)
203#define GMAC_NCR_ENPBPR (0x1u << 16)
204#define GMAC_NCR_TXPBPF (0x1u << 17)
205#define GMAC_NCR_FNP (0x1u << 18)
206/* -------- GMAC_NCFGR : (GMAC Offset: 0x004) Network Configuration Register -------- */
207#define GMAC_NCFGR_SPD (0x1u << 0)
208#define GMAC_NCFGR_FD (0x1u << 1)
209#define GMAC_NCFGR_DNVLAN (0x1u << 2)
210#define GMAC_NCFGR_JFRAME (0x1u << 3)
211#define GMAC_NCFGR_CAF (0x1u << 4)
212#define GMAC_NCFGR_NBC (0x1u << 5)
213#define GMAC_NCFGR_MTIHEN (0x1u << 6)
214#define GMAC_NCFGR_UNIHEN (0x1u << 7)
215#define GMAC_NCFGR_MAXFS (0x1u << 8)
216#define GMAC_NCFGR_RTY (0x1u << 12)
217#define GMAC_NCFGR_PEN (0x1u << 13)
218#define GMAC_NCFGR_RXBUFO_Pos 14
219#define GMAC_NCFGR_RXBUFO_Msk (0x3u << GMAC_NCFGR_RXBUFO_Pos)
220#define GMAC_NCFGR_RXBUFO(value) ((GMAC_NCFGR_RXBUFO_Msk & ((value) << GMAC_NCFGR_RXBUFO_Pos)))
221#define GMAC_NCFGR_LFERD (0x1u << 16)
222#define GMAC_NCFGR_RFCS (0x1u << 17)
223#define GMAC_NCFGR_CLK_Pos 18
224#define GMAC_NCFGR_CLK_Msk (0x7u << GMAC_NCFGR_CLK_Pos)
225#define GMAC_NCFGR_CLK(value) ((GMAC_NCFGR_CLK_Msk & ((value) << GMAC_NCFGR_CLK_Pos)))
226#define GMAC_NCFGR_CLK_MCK_8 (0x0u << 18)
227#define GMAC_NCFGR_CLK_MCK_16 (0x1u << 18)
228#define GMAC_NCFGR_CLK_MCK_32 (0x2u << 18)
229#define GMAC_NCFGR_CLK_MCK_48 (0x3u << 18)
230#define GMAC_NCFGR_CLK_MCK_64 (0x4u << 18)
231#define GMAC_NCFGR_CLK_MCK_96 (0x5u << 18)
232#define GMAC_NCFGR_DBW_Pos 21
233#define GMAC_NCFGR_DBW_Msk (0x3u << GMAC_NCFGR_DBW_Pos)
234#define GMAC_NCFGR_DBW(value) ((GMAC_NCFGR_DBW_Msk & ((value) << GMAC_NCFGR_DBW_Pos)))
235#define GMAC_NCFGR_DCPF (0x1u << 23)
236#define GMAC_NCFGR_RXCOEN (0x1u << 24)
237#define GMAC_NCFGR_EFRHD (0x1u << 25)
238#define GMAC_NCFGR_IRXFCS (0x1u << 26)
239#define GMAC_NCFGR_IPGSEN (0x1u << 28)
240#define GMAC_NCFGR_RXBP (0x1u << 29)
241#define GMAC_NCFGR_IRXER (0x1u << 30)
242/* -------- GMAC_NSR : (GMAC Offset: 0x008) Network Status Register -------- */
243#define GMAC_NSR_MDIO (0x1u << 1)
244#define GMAC_NSR_IDLE (0x1u << 2)
245/* -------- GMAC_UR : (GMAC Offset: 0x00C) User Register -------- */
246#define GMAC_UR_RMII (0x1u << 0)
247/* -------- GMAC_DCFGR : (GMAC Offset: 0x010) DMA Configuration Register -------- */
248#define GMAC_DCFGR_FBLDO_Pos 0
249#define GMAC_DCFGR_FBLDO_Msk (0x1fu << GMAC_DCFGR_FBLDO_Pos)
250#define GMAC_DCFGR_FBLDO(value) ((GMAC_DCFGR_FBLDO_Msk & ((value) << GMAC_DCFGR_FBLDO_Pos)))
251#define GMAC_DCFGR_FBLDO_SINGLE (0x1u << 0)
252#define GMAC_DCFGR_FBLDO_INCR4 (0x4u << 0)
253#define GMAC_DCFGR_FBLDO_INCR8 (0x8u << 0)
254#define GMAC_DCFGR_FBLDO_INCR16 (0x10u << 0)
255#define GMAC_DCFGR_ESMA (0x1u << 6)
256#define GMAC_DCFGR_ESPA (0x1u << 7)
257#define GMAC_DCFGR_RXBMS_Pos 8
258#define GMAC_DCFGR_RXBMS_Msk (0x3u << GMAC_DCFGR_RXBMS_Pos)
259#define GMAC_DCFGR_RXBMS(value) ((GMAC_DCFGR_RXBMS_Msk & ((value) << GMAC_DCFGR_RXBMS_Pos)))
260#define GMAC_DCFGR_RXBMS_EIGHTH (0x0u << 8)
261#define GMAC_DCFGR_RXBMS_QUARTER (0x1u << 8)
262#define GMAC_DCFGR_RXBMS_HALF (0x2u << 8)
263#define GMAC_DCFGR_RXBMS_FULL (0x3u << 8)
264#define GMAC_DCFGR_TXPBMS (0x1u << 10)
265#define GMAC_DCFGR_TXCOEN (0x1u << 11)
266#define GMAC_DCFGR_DRBS_Pos 16
267#define GMAC_DCFGR_DRBS_Msk (0xffu << GMAC_DCFGR_DRBS_Pos)
268#define GMAC_DCFGR_DRBS(value) ((GMAC_DCFGR_DRBS_Msk & ((value) << GMAC_DCFGR_DRBS_Pos)))
269#define GMAC_DCFGR_DDRP (0x1u << 24)
270/* -------- GMAC_TSR : (GMAC Offset: 0x014) Transmit Status Register -------- */
271#define GMAC_TSR_UBR (0x1u << 0)
272#define GMAC_TSR_COL (0x1u << 1)
273#define GMAC_TSR_RLE (0x1u << 2)
274#define GMAC_TSR_TXGO (0x1u << 3)
275#define GMAC_TSR_TFC (0x1u << 4)
276#define GMAC_TSR_TXCOMP (0x1u << 5)
277#define GMAC_TSR_HRESP (0x1u << 8)
278/* -------- GMAC_RBQB : (GMAC Offset: 0x018) Receive Buffer Queue Base Address Register -------- */
279#define GMAC_RBQB_ADDR_Pos 2
280#define GMAC_RBQB_ADDR_Msk (0x3fffffffu << GMAC_RBQB_ADDR_Pos)
281#define GMAC_RBQB_ADDR(value) ((GMAC_RBQB_ADDR_Msk & ((value) << GMAC_RBQB_ADDR_Pos)))
282/* -------- GMAC_TBQB : (GMAC Offset: 0x01C) Transmit Buffer Queue Base Address Register -------- */
283#define GMAC_TBQB_ADDR_Pos 2
284#define GMAC_TBQB_ADDR_Msk (0x3fffffffu << GMAC_TBQB_ADDR_Pos)
285#define GMAC_TBQB_ADDR(value) ((GMAC_TBQB_ADDR_Msk & ((value) << GMAC_TBQB_ADDR_Pos)))
286/* -------- GMAC_RSR : (GMAC Offset: 0x020) Receive Status Register -------- */
287#define GMAC_RSR_BNA (0x1u << 0)
288#define GMAC_RSR_REC (0x1u << 1)
289#define GMAC_RSR_RXOVR (0x1u << 2)
290#define GMAC_RSR_HNO (0x1u << 3)
291/* -------- GMAC_ISR : (GMAC Offset: 0x024) Interrupt Status Register -------- */
292#define GMAC_ISR_MFS (0x1u << 0)
293#define GMAC_ISR_RCOMP (0x1u << 1)
294#define GMAC_ISR_RXUBR (0x1u << 2)
295#define GMAC_ISR_TXUBR (0x1u << 3)
296#define GMAC_ISR_TUR (0x1u << 4)
297#define GMAC_ISR_RLEX (0x1u << 5)
298#define GMAC_ISR_TFC (0x1u << 6)
299#define GMAC_ISR_TCOMP (0x1u << 7)
300#define GMAC_ISR_ROVR (0x1u << 10)
301#define GMAC_ISR_HRESP (0x1u << 11)
302#define GMAC_ISR_PFNZ (0x1u << 12)
303#define GMAC_ISR_PTZ (0x1u << 13)
304#define GMAC_ISR_PFTR (0x1u << 14)
305#define GMAC_ISR_DRQFR (0x1u << 18)
306#define GMAC_ISR_SFR (0x1u << 19)
307#define GMAC_ISR_DRQFT (0x1u << 20)
308#define GMAC_ISR_SFT (0x1u << 21)
309#define GMAC_ISR_PDRQFR (0x1u << 22)
310#define GMAC_ISR_PDRSFR (0x1u << 23)
311#define GMAC_ISR_PDRQFT (0x1u << 24)
312#define GMAC_ISR_PDRSFT (0x1u << 25)
313#define GMAC_ISR_SRI (0x1u << 26)
314#define GMAC_ISR_WOL (0x1u << 28)
315#define GMAC_ISR_TSU (0x1u << 29)
316/* -------- GMAC_IER : (GMAC Offset: 0x028) Interrupt Enable Register -------- */
317#define GMAC_IER_MFS (0x1u << 0)
318#define GMAC_IER_RCOMP (0x1u << 1)
319#define GMAC_IER_RXUBR (0x1u << 2)
320#define GMAC_IER_TXUBR (0x1u << 3)
321#define GMAC_IER_TUR (0x1u << 4)
322#define GMAC_IER_RLEX (0x1u << 5)
323#define GMAC_IER_TFC (0x1u << 6)
324#define GMAC_IER_TCOMP (0x1u << 7)
325#define GMAC_IER_ROVR (0x1u << 10)
326#define GMAC_IER_HRESP (0x1u << 11)
327#define GMAC_IER_PFNZ (0x1u << 12)
328#define GMAC_IER_PTZ (0x1u << 13)
329#define GMAC_IER_PFTR (0x1u << 14)
330#define GMAC_IER_EXINT (0x1u << 15)
331#define GMAC_IER_DRQFR (0x1u << 18)
332#define GMAC_IER_SFR (0x1u << 19)
333#define GMAC_IER_DRQFT (0x1u << 20)
334#define GMAC_IER_SFT (0x1u << 21)
335#define GMAC_IER_PDRQFR (0x1u << 22)
336#define GMAC_IER_PDRSFR (0x1u << 23)
337#define GMAC_IER_PDRQFT (0x1u << 24)
338#define GMAC_IER_PDRSFT (0x1u << 25)
339#define GMAC_IER_SRI (0x1u << 26)
340#define GMAC_IER_WOL (0x1u << 28)
341/* -------- GMAC_IDR : (GMAC Offset: 0x02C) Interrupt Disable Register -------- */
342#define GMAC_IDR_MFS (0x1u << 0)
343#define GMAC_IDR_RCOMP (0x1u << 1)
344#define GMAC_IDR_RXUBR (0x1u << 2)
345#define GMAC_IDR_TXUBR (0x1u << 3)
346#define GMAC_IDR_TUR (0x1u << 4)
347#define GMAC_IDR_RLEX (0x1u << 5)
348#define GMAC_IDR_TFC (0x1u << 6)
349#define GMAC_IDR_TCOMP (0x1u << 7)
350#define GMAC_IDR_ROVR (0x1u << 10)
351#define GMAC_IDR_HRESP (0x1u << 11)
352#define GMAC_IDR_PFNZ (0x1u << 12)
353#define GMAC_IDR_PTZ (0x1u << 13)
354#define GMAC_IDR_PFTR (0x1u << 14)
355#define GMAC_IDR_EXINT (0x1u << 15)
356#define GMAC_IDR_DRQFR (0x1u << 18)
357#define GMAC_IDR_SFR (0x1u << 19)
358#define GMAC_IDR_DRQFT (0x1u << 20)
359#define GMAC_IDR_SFT (0x1u << 21)
360#define GMAC_IDR_PDRQFR (0x1u << 22)
361#define GMAC_IDR_PDRSFR (0x1u << 23)
362#define GMAC_IDR_PDRQFT (0x1u << 24)
363#define GMAC_IDR_PDRSFT (0x1u << 25)
364#define GMAC_IDR_SRI (0x1u << 26)
365#define GMAC_IDR_WOL (0x1u << 28)
366/* -------- GMAC_IMR : (GMAC Offset: 0x030) Interrupt Mask Register -------- */
367#define GMAC_IMR_MFS (0x1u << 0)
368#define GMAC_IMR_RCOMP (0x1u << 1)
369#define GMAC_IMR_RXUBR (0x1u << 2)
370#define GMAC_IMR_TXUBR (0x1u << 3)
371#define GMAC_IMR_TUR (0x1u << 4)
372#define GMAC_IMR_RLEX (0x1u << 5)
373#define GMAC_IMR_TFC (0x1u << 6)
374#define GMAC_IMR_TCOMP (0x1u << 7)
375#define GMAC_IMR_ROVR (0x1u << 10)
376#define GMAC_IMR_HRESP (0x1u << 11)
377#define GMAC_IMR_PFNZ (0x1u << 12)
378#define GMAC_IMR_PTZ (0x1u << 13)
379#define GMAC_IMR_PFTR (0x1u << 14)
380#define GMAC_IMR_EXINT (0x1u << 15)
381#define GMAC_IMR_DRQFR (0x1u << 18)
382#define GMAC_IMR_SFR (0x1u << 19)
383#define GMAC_IMR_DRQFT (0x1u << 20)
384#define GMAC_IMR_SFT (0x1u << 21)
385#define GMAC_IMR_PDRQFR (0x1u << 22)
386#define GMAC_IMR_PDRSFR (0x1u << 23)
387#define GMAC_IMR_PDRQFT (0x1u << 24)
388#define GMAC_IMR_PDRSFT (0x1u << 25)
389/* -------- GMAC_MAN : (GMAC Offset: 0x034) PHY Maintenance Register -------- */
390#define GMAC_MAN_DATA_Pos 0
391#define GMAC_MAN_DATA_Msk (0xffffu << GMAC_MAN_DATA_Pos)
392#define GMAC_MAN_DATA(value) ((GMAC_MAN_DATA_Msk & ((value) << GMAC_MAN_DATA_Pos)))
393#define GMAC_MAN_WTN_Pos 16
394#define GMAC_MAN_WTN_Msk (0x3u << GMAC_MAN_WTN_Pos)
395#define GMAC_MAN_WTN(value) ((GMAC_MAN_WTN_Msk & ((value) << GMAC_MAN_WTN_Pos)))
396#define GMAC_MAN_REGA_Pos 18
397#define GMAC_MAN_REGA_Msk (0x1fu << GMAC_MAN_REGA_Pos)
398#define GMAC_MAN_REGA(value) ((GMAC_MAN_REGA_Msk & ((value) << GMAC_MAN_REGA_Pos)))
399#define GMAC_MAN_PHYA_Pos 23
400#define GMAC_MAN_PHYA_Msk (0x1fu << GMAC_MAN_PHYA_Pos)
401#define GMAC_MAN_PHYA(value) ((GMAC_MAN_PHYA_Msk & ((value) << GMAC_MAN_PHYA_Pos)))
402#define GMAC_MAN_OP_Pos 28
403#define GMAC_MAN_OP_Msk (0x3u << GMAC_MAN_OP_Pos)
404#define GMAC_MAN_OP(value) ((GMAC_MAN_OP_Msk & ((value) << GMAC_MAN_OP_Pos)))
405#define GMAC_MAN_CLTTO (0x1u << 30)
406#define GMAC_MAN_WZO (0x1u << 31)
407/* -------- GMAC_RPQ : (GMAC Offset: 0x038) Received Pause Quantum Register -------- */
408#define GMAC_RPQ_RPQ_Pos 0
409#define GMAC_RPQ_RPQ_Msk (0xffffu << GMAC_RPQ_RPQ_Pos)
410/* -------- GMAC_TPQ : (GMAC Offset: 0x03C) Transmit Pause Quantum Register -------- */
411#define GMAC_TPQ_TPQ_Pos 0
412#define GMAC_TPQ_TPQ_Msk (0xffffu << GMAC_TPQ_TPQ_Pos)
413#define GMAC_TPQ_TPQ(value) ((GMAC_TPQ_TPQ_Msk & ((value) << GMAC_TPQ_TPQ_Pos)))
414/* -------- GMAC_TPSF : (GMAC Offset: 0x040) TX Partial Store and Forward Register -------- */
415#define GMAC_TPSF_TPB1ADR_Pos 0
416#define GMAC_TPSF_TPB1ADR_Msk (0xfffu << GMAC_TPSF_TPB1ADR_Pos)
417#define GMAC_TPSF_TPB1ADR(value) ((GMAC_TPSF_TPB1ADR_Msk & ((value) << GMAC_TPSF_TPB1ADR_Pos)))
418#define GMAC_TPSF_ENTXP (0x1u << 31)
419/* -------- GMAC_RPSF : (GMAC Offset: 0x044) RX Partial Store and Forward Register -------- */
420#define GMAC_RPSF_RPB1ADR_Pos 0
421#define GMAC_RPSF_RPB1ADR_Msk (0xfffu << GMAC_RPSF_RPB1ADR_Pos)
422#define GMAC_RPSF_RPB1ADR(value) ((GMAC_RPSF_RPB1ADR_Msk & ((value) << GMAC_RPSF_RPB1ADR_Pos)))
423#define GMAC_RPSF_ENRXP (0x1u << 31)
424/* -------- GMAC_RJFML : (GMAC Offset: 0x048) RX Jumbo Frame Max Length Register -------- */
425#define GMAC_RJFML_FML_Pos 0
426#define GMAC_RJFML_FML_Msk (0x3fffu << GMAC_RJFML_FML_Pos)
427#define GMAC_RJFML_FML(value) ((GMAC_RJFML_FML_Msk & ((value) << GMAC_RJFML_FML_Pos)))
428/* -------- GMAC_HRB : (GMAC Offset: 0x080) Hash Register Bottom -------- */
429#define GMAC_HRB_ADDR_Pos 0
430#define GMAC_HRB_ADDR_Msk (0xffffffffu << GMAC_HRB_ADDR_Pos)
431#define GMAC_HRB_ADDR(value) ((GMAC_HRB_ADDR_Msk & ((value) << GMAC_HRB_ADDR_Pos)))
432/* -------- GMAC_HRT : (GMAC Offset: 0x084) Hash Register Top -------- */
433#define GMAC_HRT_ADDR_Pos 0
434#define GMAC_HRT_ADDR_Msk (0xffffffffu << GMAC_HRT_ADDR_Pos)
435#define GMAC_HRT_ADDR(value) ((GMAC_HRT_ADDR_Msk & ((value) << GMAC_HRT_ADDR_Pos)))
436/* -------- GMAC_SAB : (GMAC Offset: N/A) Specific Address 1 Bottom Register -------- */
437#define GMAC_SAB_ADDR_Pos 0
438#define GMAC_SAB_ADDR_Msk (0xffffffffu << GMAC_SAB_ADDR_Pos)
439#define GMAC_SAB_ADDR(value) ((GMAC_SAB_ADDR_Msk & ((value) << GMAC_SAB_ADDR_Pos)))
440/* -------- GMAC_SAT : (GMAC Offset: N/A) Specific Address 1 Top Register -------- */
441#define GMAC_SAT_ADDR_Pos 0
442#define GMAC_SAT_ADDR_Msk (0xffffu << GMAC_SAT_ADDR_Pos)
443#define GMAC_SAT_ADDR(value) ((GMAC_SAT_ADDR_Msk & ((value) << GMAC_SAT_ADDR_Pos)))
444/* -------- GMAC_TIDM1 : (GMAC Offset: 0x0A8) Type ID Match 1 Register -------- */
445#define GMAC_TIDM1_TID_Pos 0
446#define GMAC_TIDM1_TID_Msk (0xffffu << GMAC_TIDM1_TID_Pos)
447#define GMAC_TIDM1_TID(value) ((GMAC_TIDM1_TID_Msk & ((value) << GMAC_TIDM1_TID_Pos)))
448#define GMAC_TIDM1_ENID1 (0x1u << 31)
449/* -------- GMAC_TIDM2 : (GMAC Offset: 0x0AC) Type ID Match 2 Register -------- */
450#define GMAC_TIDM2_TID_Pos 0
451#define GMAC_TIDM2_TID_Msk (0xffffu << GMAC_TIDM2_TID_Pos)
452#define GMAC_TIDM2_TID(value) ((GMAC_TIDM2_TID_Msk & ((value) << GMAC_TIDM2_TID_Pos)))
453#define GMAC_TIDM2_ENID2 (0x1u << 31)
454/* -------- GMAC_TIDM3 : (GMAC Offset: 0x0B0) Type ID Match 3 Register -------- */
455#define GMAC_TIDM3_TID_Pos 0
456#define GMAC_TIDM3_TID_Msk (0xffffu << GMAC_TIDM3_TID_Pos)
457#define GMAC_TIDM3_TID(value) ((GMAC_TIDM3_TID_Msk & ((value) << GMAC_TIDM3_TID_Pos)))
458#define GMAC_TIDM3_ENID3 (0x1u << 31)
459/* -------- GMAC_TIDM4 : (GMAC Offset: 0x0B4) Type ID Match 4 Register -------- */
460#define GMAC_TIDM4_TID_Pos 0
461#define GMAC_TIDM4_TID_Msk (0xffffu << GMAC_TIDM4_TID_Pos)
462#define GMAC_TIDM4_TID(value) ((GMAC_TIDM4_TID_Msk & ((value) << GMAC_TIDM4_TID_Pos)))
463#define GMAC_TIDM4_ENID4 (0x1u << 31)
464/* -------- GMAC_WOL : (GMAC Offset: 0x0B8) Wake on LAN Register -------- */
465#define GMAC_WOL_IP_Pos 0
466#define GMAC_WOL_IP_Msk (0xffffu << GMAC_WOL_IP_Pos)
467#define GMAC_WOL_IP(value) ((GMAC_WOL_IP_Msk & ((value) << GMAC_WOL_IP_Pos)))
468#define GMAC_WOL_MAG (0x1u << 16)
469#define GMAC_WOL_ARP (0x1u << 17)
470#define GMAC_WOL_SA1 (0x1u << 18)
471#define GMAC_WOL_MTI (0x1u << 19)
472/* -------- GMAC_IPGS : (GMAC Offset: 0x0BC) IPG Stretch Register -------- */
473#define GMAC_IPGS_FL_Pos 0
474#define GMAC_IPGS_FL_Msk (0xffffu << GMAC_IPGS_FL_Pos)
475#define GMAC_IPGS_FL(value) ((GMAC_IPGS_FL_Msk & ((value) << GMAC_IPGS_FL_Pos)))
476/* -------- GMAC_SVLAN : (GMAC Offset: 0x0C0) Stacked VLAN Register -------- */
477#define GMAC_SVLAN_VLAN_TYPE_Pos 0
478#define GMAC_SVLAN_VLAN_TYPE_Msk (0xffffu << GMAC_SVLAN_VLAN_TYPE_Pos)
479#define GMAC_SVLAN_VLAN_TYPE(value) ((GMAC_SVLAN_VLAN_TYPE_Msk & ((value) << GMAC_SVLAN_VLAN_TYPE_Pos)))
480#define GMAC_SVLAN_ESVLAN (0x1u << 31)
481/* -------- GMAC_TPFCP : (GMAC Offset: 0x0C4) Transmit PFC Pause Register -------- */
482#define GMAC_TPFCP_PEV_Pos 0
483#define GMAC_TPFCP_PEV_Msk (0xffu << GMAC_TPFCP_PEV_Pos)
484#define GMAC_TPFCP_PEV(value) ((GMAC_TPFCP_PEV_Msk & ((value) << GMAC_TPFCP_PEV_Pos)))
485#define GMAC_TPFCP_PQ_Pos 8
486#define GMAC_TPFCP_PQ_Msk (0xffu << GMAC_TPFCP_PQ_Pos)
487#define GMAC_TPFCP_PQ(value) ((GMAC_TPFCP_PQ_Msk & ((value) << GMAC_TPFCP_PQ_Pos)))
488/* -------- GMAC_SAMB1 : (GMAC Offset: 0x0C8) Specific Address 1 Mask Bottom Register -------- */
489#define GMAC_SAMB1_ADDR_Pos 0
490#define GMAC_SAMB1_ADDR_Msk (0xffffffffu << GMAC_SAMB1_ADDR_Pos)
491#define GMAC_SAMB1_ADDR(value) ((GMAC_SAMB1_ADDR_Msk & ((value) << GMAC_SAMB1_ADDR_Pos)))
492/* -------- GMAC_SAMT1 : (GMAC Offset: 0x0CC) Specific Address 1 Mask Top Register -------- */
493#define GMAC_SAMT1_ADDR_Pos 0
494#define GMAC_SAMT1_ADDR_Msk (0xffffu << GMAC_SAMT1_ADDR_Pos)
495#define GMAC_SAMT1_ADDR(value) ((GMAC_SAMT1_ADDR_Msk & ((value) << GMAC_SAMT1_ADDR_Pos)))
496/* -------- GMAC_NSC : (GMAC Offset: 0x0DC) 1588 Timer Nanosecond Comparison Register -------- */
497#define GMAC_NSC_NANOSEC_Pos 0
498#define GMAC_NSC_NANOSEC_Msk (0x3fffffu << GMAC_NSC_NANOSEC_Pos)
499#define GMAC_NSC_NANOSEC(value) ((GMAC_NSC_NANOSEC_Msk & ((value) << GMAC_NSC_NANOSEC_Pos)))
500/* -------- GMAC_SCL : (GMAC Offset: 0x0E0) 1588 Timer Second Comparison Low Register -------- */
501#define GMAC_SCL_SEC_Pos 0
502#define GMAC_SCL_SEC_Msk (0xffffffffu << GMAC_SCL_SEC_Pos)
503#define GMAC_SCL_SEC(value) ((GMAC_SCL_SEC_Msk & ((value) << GMAC_SCL_SEC_Pos)))
504/* -------- GMAC_SCH : (GMAC Offset: 0x0E4) 1588 Timer Second Comparison High Register -------- */
505#define GMAC_SCH_SEC_Pos 0
506#define GMAC_SCH_SEC_Msk (0xffffu << GMAC_SCH_SEC_Pos)
507#define GMAC_SCH_SEC(value) ((GMAC_SCH_SEC_Msk & ((value) << GMAC_SCH_SEC_Pos)))
508/* -------- GMAC_EFTSH : (GMAC Offset: 0x0E8) PTP Event Frame Transmitted Seconds High Register -------- */
509#define GMAC_EFTSH_RUD_Pos 0
510#define GMAC_EFTSH_RUD_Msk (0xffffu << GMAC_EFTSH_RUD_Pos)
511/* -------- GMAC_EFRSH : (GMAC Offset: 0x0EC) PTP Event Frame Received Seconds High Register -------- */
512#define GMAC_EFRSH_RUD_Pos 0
513#define GMAC_EFRSH_RUD_Msk (0xffffu << GMAC_EFRSH_RUD_Pos)
514/* -------- GMAC_PEFTSH : (GMAC Offset: 0x0F0) PTP Peer Event Frame Transmitted Seconds High Register -------- */
515#define GMAC_PEFTSH_RUD_Pos 0
516#define GMAC_PEFTSH_RUD_Msk (0xffffu << GMAC_PEFTSH_RUD_Pos)
517/* -------- GMAC_PEFRSH : (GMAC Offset: 0x0F4) PTP Peer Event Frame Received Seconds High Register -------- */
518#define GMAC_PEFRSH_RUD_Pos 0
519#define GMAC_PEFRSH_RUD_Msk (0xffffu << GMAC_PEFRSH_RUD_Pos)
520/* -------- GMAC_MID : (GMAC Offset: 0x0FC) Module ID Register -------- */
521#define GMAC_MID_MREV_Pos 0
522#define GMAC_MID_MREV_Msk (0xffffu << GMAC_MID_MREV_Pos)
523#define GMAC_MID_MID_Pos 16
524#define GMAC_MID_MID_Msk (0xffffu << GMAC_MID_MID_Pos)
525/* -------- GMAC_OTLO : (GMAC Offset: 0x100) Octets Transmitted Low Register -------- */
526#define GMAC_OTLO_TXO_Pos 0
527#define GMAC_OTLO_TXO_Msk (0xffffffffu << GMAC_OTLO_TXO_Pos)
528/* -------- GMAC_OTHI : (GMAC Offset: 0x104) Octets Transmitted High Register -------- */
529#define GMAC_OTHI_TXO_Pos 0
530#define GMAC_OTHI_TXO_Msk (0xffffu << GMAC_OTHI_TXO_Pos)
531/* -------- GMAC_FT : (GMAC Offset: 0x108) Frames Transmitted Register -------- */
532#define GMAC_FT_FTX_Pos 0
533#define GMAC_FT_FTX_Msk (0xffffffffu << GMAC_FT_FTX_Pos)
534/* -------- GMAC_BCFT : (GMAC Offset: 0x10C) Broadcast Frames Transmitted Register -------- */
535#define GMAC_BCFT_BFTX_Pos 0
536#define GMAC_BCFT_BFTX_Msk (0xffffffffu << GMAC_BCFT_BFTX_Pos)
537/* -------- GMAC_MFT : (GMAC Offset: 0x110) Multicast Frames Transmitted Register -------- */
538#define GMAC_MFT_MFTX_Pos 0
539#define GMAC_MFT_MFTX_Msk (0xffffffffu << GMAC_MFT_MFTX_Pos)
540/* -------- GMAC_PFT : (GMAC Offset: 0x114) Pause Frames Transmitted Register -------- */
541#define GMAC_PFT_PFTX_Pos 0
542#define GMAC_PFT_PFTX_Msk (0xffffu << GMAC_PFT_PFTX_Pos)
543/* -------- GMAC_BFT64 : (GMAC Offset: 0x118) 64 Byte Frames Transmitted Register -------- */
544#define GMAC_BFT64_NFTX_Pos 0
545#define GMAC_BFT64_NFTX_Msk (0xffffffffu << GMAC_BFT64_NFTX_Pos)
546/* -------- GMAC_TBFT127 : (GMAC Offset: 0x11C) 65 to 127 Byte Frames Transmitted Register -------- */
547#define GMAC_TBFT127_NFTX_Pos 0
548#define GMAC_TBFT127_NFTX_Msk (0xffffffffu << GMAC_TBFT127_NFTX_Pos)
549/* -------- GMAC_TBFT255 : (GMAC Offset: 0x120) 128 to 255 Byte Frames Transmitted Register -------- */
550#define GMAC_TBFT255_NFTX_Pos 0
551#define GMAC_TBFT255_NFTX_Msk (0xffffffffu << GMAC_TBFT255_NFTX_Pos)
552/* -------- GMAC_TBFT511 : (GMAC Offset: 0x124) 256 to 511 Byte Frames Transmitted Register -------- */
553#define GMAC_TBFT511_NFTX_Pos 0
554#define GMAC_TBFT511_NFTX_Msk (0xffffffffu << GMAC_TBFT511_NFTX_Pos)
555/* -------- GMAC_TBFT1023 : (GMAC Offset: 0x128) 512 to 1023 Byte Frames Transmitted Register -------- */
556#define GMAC_TBFT1023_NFTX_Pos 0
557#define GMAC_TBFT1023_NFTX_Msk (0xffffffffu << GMAC_TBFT1023_NFTX_Pos)
558/* -------- GMAC_TBFT1518 : (GMAC Offset: 0x12C) 1024 to 1518 Byte Frames Transmitted Register -------- */
559#define GMAC_TBFT1518_NFTX_Pos 0
560#define GMAC_TBFT1518_NFTX_Msk (0xffffffffu << GMAC_TBFT1518_NFTX_Pos)
561/* -------- GMAC_GTBFT1518 : (GMAC Offset: 0x130) Greater Than 1518 Byte Frames Transmitted Register -------- */
562#define GMAC_GTBFT1518_NFTX_Pos 0
563#define GMAC_GTBFT1518_NFTX_Msk (0xffffffffu << GMAC_GTBFT1518_NFTX_Pos)
564/* -------- GMAC_TUR : (GMAC Offset: 0x134) Transmit Underruns Register -------- */
565#define GMAC_TUR_TXUNR_Pos 0
566#define GMAC_TUR_TXUNR_Msk (0x3ffu << GMAC_TUR_TXUNR_Pos)
567/* -------- GMAC_SCF : (GMAC Offset: 0x138) Single Collision Frames Register -------- */
568#define GMAC_SCF_SCOL_Pos 0
569#define GMAC_SCF_SCOL_Msk (0x3ffffu << GMAC_SCF_SCOL_Pos)
570/* -------- GMAC_MCF : (GMAC Offset: 0x13C) Multiple Collision Frames Register -------- */
571#define GMAC_MCF_MCOL_Pos 0
572#define GMAC_MCF_MCOL_Msk (0x3ffffu << GMAC_MCF_MCOL_Pos)
573/* -------- GMAC_EC : (GMAC Offset: 0x140) Excessive Collisions Register -------- */
574#define GMAC_EC_XCOL_Pos 0
575#define GMAC_EC_XCOL_Msk (0x3ffu << GMAC_EC_XCOL_Pos)
576/* -------- GMAC_LC : (GMAC Offset: 0x144) Late Collisions Register -------- */
577#define GMAC_LC_LCOL_Pos 0
578#define GMAC_LC_LCOL_Msk (0x3ffu << GMAC_LC_LCOL_Pos)
579/* -------- GMAC_DTF : (GMAC Offset: 0x148) Deferred Transmission Frames Register -------- */
580#define GMAC_DTF_DEFT_Pos 0
581#define GMAC_DTF_DEFT_Msk (0x3ffffu << GMAC_DTF_DEFT_Pos)
582/* -------- GMAC_CSE : (GMAC Offset: 0x14C) Carrier Sense Errors Register -------- */
583#define GMAC_CSE_CSR_Pos 0
584#define GMAC_CSE_CSR_Msk (0x3ffu << GMAC_CSE_CSR_Pos)
585/* -------- GMAC_ORLO : (GMAC Offset: 0x150) Octets Received Low Received Register -------- */
586#define GMAC_ORLO_RXO_Pos 0
587#define GMAC_ORLO_RXO_Msk (0xffffffffu << GMAC_ORLO_RXO_Pos)
588/* -------- GMAC_ORHI : (GMAC Offset: 0x154) Octets Received High Received Register -------- */
589#define GMAC_ORHI_RXO_Pos 0
590#define GMAC_ORHI_RXO_Msk (0xffffu << GMAC_ORHI_RXO_Pos)
591/* -------- GMAC_FR : (GMAC Offset: 0x158) Frames Received Register -------- */
592#define GMAC_FR_FRX_Pos 0
593#define GMAC_FR_FRX_Msk (0xffffffffu << GMAC_FR_FRX_Pos)
594/* -------- GMAC_BCFR : (GMAC Offset: 0x15C) Broadcast Frames Received Register -------- */
595#define GMAC_BCFR_BFRX_Pos 0
596#define GMAC_BCFR_BFRX_Msk (0xffffffffu << GMAC_BCFR_BFRX_Pos)
597/* -------- GMAC_MFR : (GMAC Offset: 0x160) Multicast Frames Received Register -------- */
598#define GMAC_MFR_MFRX_Pos 0
599#define GMAC_MFR_MFRX_Msk (0xffffffffu << GMAC_MFR_MFRX_Pos)
600/* -------- GMAC_PFR : (GMAC Offset: 0x164) Pause Frames Received Register -------- */
601#define GMAC_PFR_PFRX_Pos 0
602#define GMAC_PFR_PFRX_Msk (0xffffu << GMAC_PFR_PFRX_Pos)
603/* -------- GMAC_BFR64 : (GMAC Offset: 0x168) 64 Byte Frames Received Register -------- */
604#define GMAC_BFR64_NFRX_Pos 0
605#define GMAC_BFR64_NFRX_Msk (0xffffffffu << GMAC_BFR64_NFRX_Pos)
606/* -------- GMAC_TBFR127 : (GMAC Offset: 0x16C) 65 to 127 Byte Frames Received Register -------- */
607#define GMAC_TBFR127_NFRX_Pos 0
608#define GMAC_TBFR127_NFRX_Msk (0xffffffffu << GMAC_TBFR127_NFRX_Pos)
609/* -------- GMAC_TBFR255 : (GMAC Offset: 0x170) 128 to 255 Byte Frames Received Register -------- */
610#define GMAC_TBFR255_NFRX_Pos 0
611#define GMAC_TBFR255_NFRX_Msk (0xffffffffu << GMAC_TBFR255_NFRX_Pos)
612/* -------- GMAC_TBFR511 : (GMAC Offset: 0x174) 256 to 511 Byte Frames Received Register -------- */
613#define GMAC_TBFR511_NFRX_Pos 0
614#define GMAC_TBFR511_NFRX_Msk (0xffffffffu << GMAC_TBFR511_NFRX_Pos)
615/* -------- GMAC_TBFR1023 : (GMAC Offset: 0x178) 512 to 1023 Byte Frames Received Register -------- */
616#define GMAC_TBFR1023_NFRX_Pos 0
617#define GMAC_TBFR1023_NFRX_Msk (0xffffffffu << GMAC_TBFR1023_NFRX_Pos)
618/* -------- GMAC_TBFR1518 : (GMAC Offset: 0x17C) 1024 to 1518 Byte Frames Received Register -------- */
619#define GMAC_TBFR1518_NFRX_Pos 0
620#define GMAC_TBFR1518_NFRX_Msk (0xffffffffu << GMAC_TBFR1518_NFRX_Pos)
621/* -------- GMAC_TMXBFR : (GMAC Offset: 0x180) 1519 to Maximum Byte Frames Received Register -------- */
622#define GMAC_TMXBFR_NFRX_Pos 0
623#define GMAC_TMXBFR_NFRX_Msk (0xffffffffu << GMAC_TMXBFR_NFRX_Pos)
624/* -------- GMAC_UFR : (GMAC Offset: 0x184) Undersize Frames Received Register -------- */
625#define GMAC_UFR_UFRX_Pos 0
626#define GMAC_UFR_UFRX_Msk (0x3ffu << GMAC_UFR_UFRX_Pos)
627/* -------- GMAC_OFR : (GMAC Offset: 0x188) Oversize Frames Received Register -------- */
628#define GMAC_OFR_OFRX_Pos 0
629#define GMAC_OFR_OFRX_Msk (0x3ffu << GMAC_OFR_OFRX_Pos)
630/* -------- GMAC_JR : (GMAC Offset: 0x18C) Jabbers Received Register -------- */
631#define GMAC_JR_JRX_Pos 0
632#define GMAC_JR_JRX_Msk (0x3ffu << GMAC_JR_JRX_Pos)
633/* -------- GMAC_FCSE : (GMAC Offset: 0x190) Frame Check Sequence Errors Register -------- */
634#define GMAC_FCSE_FCKR_Pos 0
635#define GMAC_FCSE_FCKR_Msk (0x3ffu << GMAC_FCSE_FCKR_Pos)
636/* -------- GMAC_LFFE : (GMAC Offset: 0x194) Length Field Frame Errors Register -------- */
637#define GMAC_LFFE_LFER_Pos 0
638#define GMAC_LFFE_LFER_Msk (0x3ffu << GMAC_LFFE_LFER_Pos)
639/* -------- GMAC_RSE : (GMAC Offset: 0x198) Receive Symbol Errors Register -------- */
640#define GMAC_RSE_RXSE_Pos 0
641#define GMAC_RSE_RXSE_Msk (0x3ffu << GMAC_RSE_RXSE_Pos)
642/* -------- GMAC_AE : (GMAC Offset: 0x19C) Alignment Errors Register -------- */
643#define GMAC_AE_AER_Pos 0
644#define GMAC_AE_AER_Msk (0x3ffu << GMAC_AE_AER_Pos)
645/* -------- GMAC_RRE : (GMAC Offset: 0x1A0) Receive Resource Errors Register -------- */
646#define GMAC_RRE_RXRER_Pos 0
647#define GMAC_RRE_RXRER_Msk (0x3ffffu << GMAC_RRE_RXRER_Pos)
648/* -------- GMAC_ROE : (GMAC Offset: 0x1A4) Receive Overrun Register -------- */
649#define GMAC_ROE_RXOVR_Pos 0
650#define GMAC_ROE_RXOVR_Msk (0x3ffu << GMAC_ROE_RXOVR_Pos)
651/* -------- GMAC_IHCE : (GMAC Offset: 0x1A8) IP Header Checksum Errors Register -------- */
652#define GMAC_IHCE_HCKER_Pos 0
653#define GMAC_IHCE_HCKER_Msk (0xffu << GMAC_IHCE_HCKER_Pos)
654/* -------- GMAC_TCE : (GMAC Offset: 0x1AC) TCP Checksum Errors Register -------- */
655#define GMAC_TCE_TCKER_Pos 0
656#define GMAC_TCE_TCKER_Msk (0xffu << GMAC_TCE_TCKER_Pos)
657/* -------- GMAC_UCE : (GMAC Offset: 0x1B0) UDP Checksum Errors Register -------- */
658#define GMAC_UCE_UCKER_Pos 0
659#define GMAC_UCE_UCKER_Msk (0xffu << GMAC_UCE_UCKER_Pos)
660/* -------- GMAC_TISUBN : (GMAC Offset: 0x1BC) 1588 Timer Increment Sub-nanoseconds Register -------- */
661#define GMAC_TISUBN_LSBTIR_Pos 0
662#define GMAC_TISUBN_LSBTIR_Msk (0xffffu << GMAC_TISUBN_LSBTIR_Pos)
663#define GMAC_TISUBN_LSBTIR(value) ((GMAC_TISUBN_LSBTIR_Msk & ((value) << GMAC_TISUBN_LSBTIR_Pos)))
664/* -------- GMAC_TSH : (GMAC Offset: 0x1C0) 1588 Timer Seconds High Register -------- */
665#define GMAC_TSH_TCS_Pos 0
666#define GMAC_TSH_TCS_Msk (0xffffu << GMAC_TSH_TCS_Pos)
667#define GMAC_TSH_TCS(value) ((GMAC_TSH_TCS_Msk & ((value) << GMAC_TSH_TCS_Pos)))
668/* -------- GMAC_TSL : (GMAC Offset: 0x1D0) 1588 Timer Seconds Low Register -------- */
669#define GMAC_TSL_TCS_Pos 0
670#define GMAC_TSL_TCS_Msk (0xffffffffu << GMAC_TSL_TCS_Pos)
671#define GMAC_TSL_TCS(value) ((GMAC_TSL_TCS_Msk & ((value) << GMAC_TSL_TCS_Pos)))
672/* -------- GMAC_TN : (GMAC Offset: 0x1D4) 1588 Timer Nanoseconds Register -------- */
673#define GMAC_TN_TNS_Pos 0
674#define GMAC_TN_TNS_Msk (0x3fffffffu << GMAC_TN_TNS_Pos)
675#define GMAC_TN_TNS(value) ((GMAC_TN_TNS_Msk & ((value) << GMAC_TN_TNS_Pos)))
676/* -------- GMAC_TA : (GMAC Offset: 0x1D8) 1588 Timer Adjust Register -------- */
677#define GMAC_TA_ITDT_Pos 0
678#define GMAC_TA_ITDT_Msk (0x3fffffffu << GMAC_TA_ITDT_Pos)
679#define GMAC_TA_ITDT(value) ((GMAC_TA_ITDT_Msk & ((value) << GMAC_TA_ITDT_Pos)))
680#define GMAC_TA_ADJ (0x1u << 31)
681/* -------- GMAC_TI : (GMAC Offset: 0x1DC) 1588 Timer Increment Register -------- */
682#define GMAC_TI_CNS_Pos 0
683#define GMAC_TI_CNS_Msk (0xffu << GMAC_TI_CNS_Pos)
684#define GMAC_TI_CNS(value) ((GMAC_TI_CNS_Msk & ((value) << GMAC_TI_CNS_Pos)))
685#define GMAC_TI_ACNS_Pos 8
686#define GMAC_TI_ACNS_Msk (0xffu << GMAC_TI_ACNS_Pos)
687#define GMAC_TI_ACNS(value) ((GMAC_TI_ACNS_Msk & ((value) << GMAC_TI_ACNS_Pos)))
688#define GMAC_TI_NIT_Pos 16
689#define GMAC_TI_NIT_Msk (0xffu << GMAC_TI_NIT_Pos)
690#define GMAC_TI_NIT(value) ((GMAC_TI_NIT_Msk & ((value) << GMAC_TI_NIT_Pos)))
691/* -------- GMAC_EFTSL : (GMAC Offset: 0x1E0) PTP Event Frame Transmitted Seconds Low Register -------- */
692#define GMAC_EFTSL_RUD_Pos 0
693#define GMAC_EFTSL_RUD_Msk (0xffffffffu << GMAC_EFTSL_RUD_Pos)
694/* -------- GMAC_EFTN : (GMAC Offset: 0x1E4) PTP Event Frame Transmitted Nanoseconds Register -------- */
695#define GMAC_EFTN_RUD_Pos 0
696#define GMAC_EFTN_RUD_Msk (0x3fffffffu << GMAC_EFTN_RUD_Pos)
697/* -------- GMAC_EFRSL : (GMAC Offset: 0x1E8) PTP Event Frame Received Seconds Low Register -------- */
698#define GMAC_EFRSL_RUD_Pos 0
699#define GMAC_EFRSL_RUD_Msk (0xffffffffu << GMAC_EFRSL_RUD_Pos)
700/* -------- GMAC_EFRN : (GMAC Offset: 0x1EC) PTP Event Frame Received Nanoseconds Register -------- */
701#define GMAC_EFRN_RUD_Pos 0
702#define GMAC_EFRN_RUD_Msk (0x3fffffffu << GMAC_EFRN_RUD_Pos)
703/* -------- GMAC_PEFTSL : (GMAC Offset: 0x1F0) PTP Peer Event Frame Transmitted Seconds Low Register -------- */
704#define GMAC_PEFTSL_RUD_Pos 0
705#define GMAC_PEFTSL_RUD_Msk (0xffffffffu << GMAC_PEFTSL_RUD_Pos)
706/* -------- GMAC_PEFTN : (GMAC Offset: 0x1F4) PTP Peer Event Frame Transmitted Nanoseconds Register -------- */
707#define GMAC_PEFTN_RUD_Pos 0
708#define GMAC_PEFTN_RUD_Msk (0x3fffffffu << GMAC_PEFTN_RUD_Pos)
709/* -------- GMAC_PEFRSL : (GMAC Offset: 0x1F8) PTP Peer Event Frame Received Seconds Low Register -------- */
710#define GMAC_PEFRSL_RUD_Pos 0
711#define GMAC_PEFRSL_RUD_Msk (0xffffffffu << GMAC_PEFRSL_RUD_Pos)
712/* -------- GMAC_PEFRN : (GMAC Offset: 0x1FC) PTP Peer Event Frame Received Nanoseconds Register -------- */
713#define GMAC_PEFRN_RUD_Pos 0
714#define GMAC_PEFRN_RUD_Msk (0x3fffffffu << GMAC_PEFRN_RUD_Pos)
715/* -------- GMAC_ISRPQ[2] : (GMAC Offset: 0x400) Interrupt Status Register Priority Queue (index = 1) -------- */
716#define GMAC_ISRPQ_RCOMP (0x1u << 1)
717#define GMAC_ISRPQ_RXUBR (0x1u << 2)
718#define GMAC_ISRPQ_RLEX (0x1u << 5)
719#define GMAC_ISRPQ_TFC (0x1u << 6)
720#define GMAC_ISRPQ_TCOMP (0x1u << 7)
721#define GMAC_ISRPQ_ROVR (0x1u << 10)
722#define GMAC_ISRPQ_HRESP (0x1u << 11)
723/* -------- GMAC_TBQBAPQ[2] : (GMAC Offset: 0x440) Transmit Buffer Queue Base Address Register Priority Queue (index = 1) -------- */
724#define GMAC_TBQBAPQ_TXBQBA_Pos 2
725#define GMAC_TBQBAPQ_TXBQBA_Msk (0x3fffffffu << GMAC_TBQBAPQ_TXBQBA_Pos)
726#define GMAC_TBQBAPQ_TXBQBA(value) ((GMAC_TBQBAPQ_TXBQBA_Msk & ((value) << GMAC_TBQBAPQ_TXBQBA_Pos)))
727/* -------- GMAC_RBQBAPQ[2] : (GMAC Offset: 0x480) Receive Buffer Queue Base Address Register Priority Queue (index = 1) -------- */
728#define GMAC_RBQBAPQ_RXBQBA_Pos 2
729#define GMAC_RBQBAPQ_RXBQBA_Msk (0x3fffffffu << GMAC_RBQBAPQ_RXBQBA_Pos)
730#define GMAC_RBQBAPQ_RXBQBA(value) ((GMAC_RBQBAPQ_RXBQBA_Msk & ((value) << GMAC_RBQBAPQ_RXBQBA_Pos)))
731/* -------- GMAC_RBSRPQ[2] : (GMAC Offset: 0x4A0) Receive Buffer Size Register Priority Queue (index = 1) -------- */
732#define GMAC_RBSRPQ_RBS_Pos 0
733#define GMAC_RBSRPQ_RBS_Msk (0xffffu << GMAC_RBSRPQ_RBS_Pos)
734#define GMAC_RBSRPQ_RBS(value) ((GMAC_RBSRPQ_RBS_Msk & ((value) << GMAC_RBSRPQ_RBS_Pos)))
735/* -------- GMAC_CBSCR : (GMAC Offset: 0x4BC) Credit-Based Shaping Control Register -------- */
736#define GMAC_CBSCR_QBE (0x1u << 0)
737#define GMAC_CBSCR_QAE (0x1u << 1)
738/* -------- GMAC_CBSISQA : (GMAC Offset: 0x4C0) Credit-Based Shaping IdleSlope Register for Queue A -------- */
739#define GMAC_CBSISQA_IS_Pos 0
740#define GMAC_CBSISQA_IS_Msk (0xffffffffu << GMAC_CBSISQA_IS_Pos)
741#define GMAC_CBSISQA_IS(value) ((GMAC_CBSISQA_IS_Msk & ((value) << GMAC_CBSISQA_IS_Pos)))
742/* -------- GMAC_CBSISQB : (GMAC Offset: 0x4C4) Credit-Based Shaping IdleSlope Register for Queue B -------- */
743#define GMAC_CBSISQB_IS_Pos 0
744#define GMAC_CBSISQB_IS_Msk (0xffffffffu << GMAC_CBSISQB_IS_Pos)
745#define GMAC_CBSISQB_IS(value) ((GMAC_CBSISQB_IS_Msk & ((value) << GMAC_CBSISQB_IS_Pos)))
746/* -------- GMAC_ST1RPQ[4] : (GMAC Offset: 0x500) Screening Type 1 Register Priority Queue (index = 0) -------- */
747#define GMAC_ST1RPQ_QNB_Pos 0
748#define GMAC_ST1RPQ_QNB_Msk (0x7u << GMAC_ST1RPQ_QNB_Pos)
749#define GMAC_ST1RPQ_QNB(value) ((GMAC_ST1RPQ_QNB_Msk & ((value) << GMAC_ST1RPQ_QNB_Pos)))
750#define GMAC_ST1RPQ_DSTCM_Pos 4
751#define GMAC_ST1RPQ_DSTCM_Msk (0xffu << GMAC_ST1RPQ_DSTCM_Pos)
752#define GMAC_ST1RPQ_DSTCM(value) ((GMAC_ST1RPQ_DSTCM_Msk & ((value) << GMAC_ST1RPQ_DSTCM_Pos)))
753#define GMAC_ST1RPQ_UDPM_Pos 12
754#define GMAC_ST1RPQ_UDPM_Msk (0xffffu << GMAC_ST1RPQ_UDPM_Pos)
755#define GMAC_ST1RPQ_UDPM(value) ((GMAC_ST1RPQ_UDPM_Msk & ((value) << GMAC_ST1RPQ_UDPM_Pos)))
756#define GMAC_ST1RPQ_DSTCE (0x1u << 28)
757#define GMAC_ST1RPQ_UDPE (0x1u << 29)
758/* -------- GMAC_ST2RPQ[8] : (GMAC Offset: 0x540) Screening Type 2 Register Priority Queue (index = 0) -------- */
759#define GMAC_ST2RPQ_QNB_Pos 0
760#define GMAC_ST2RPQ_QNB_Msk (0x7u << GMAC_ST2RPQ_QNB_Pos)
761#define GMAC_ST2RPQ_QNB(value) ((GMAC_ST2RPQ_QNB_Msk & ((value) << GMAC_ST2RPQ_QNB_Pos)))
762#define GMAC_ST2RPQ_VLANP_Pos 4
763#define GMAC_ST2RPQ_VLANP_Msk (0x7u << GMAC_ST2RPQ_VLANP_Pos)
764#define GMAC_ST2RPQ_VLANP(value) ((GMAC_ST2RPQ_VLANP_Msk & ((value) << GMAC_ST2RPQ_VLANP_Pos)))
765#define GMAC_ST2RPQ_VLANE (0x1u << 8)
766#define GMAC_ST2RPQ_I2ETH_Pos 9
767#define GMAC_ST2RPQ_I2ETH_Msk (0x7u << GMAC_ST2RPQ_I2ETH_Pos)
768#define GMAC_ST2RPQ_I2ETH(value) ((GMAC_ST2RPQ_I2ETH_Msk & ((value) << GMAC_ST2RPQ_I2ETH_Pos)))
769#define GMAC_ST2RPQ_ETHE (0x1u << 12)
770#define GMAC_ST2RPQ_COMPA_Pos 13
771#define GMAC_ST2RPQ_COMPA_Msk (0x1fu << GMAC_ST2RPQ_COMPA_Pos)
772#define GMAC_ST2RPQ_COMPA(value) ((GMAC_ST2RPQ_COMPA_Msk & ((value) << GMAC_ST2RPQ_COMPA_Pos)))
773#define GMAC_ST2RPQ_COMPAE (0x1u << 18)
774#define GMAC_ST2RPQ_COMPB_Pos 19
775#define GMAC_ST2RPQ_COMPB_Msk (0x1fu << GMAC_ST2RPQ_COMPB_Pos)
776#define GMAC_ST2RPQ_COMPB(value) ((GMAC_ST2RPQ_COMPB_Msk & ((value) << GMAC_ST2RPQ_COMPB_Pos)))
777#define GMAC_ST2RPQ_COMPBE (0x1u << 24)
778#define GMAC_ST2RPQ_COMPC_Pos 25
779#define GMAC_ST2RPQ_COMPC_Msk (0x1fu << GMAC_ST2RPQ_COMPC_Pos)
780#define GMAC_ST2RPQ_COMPC(value) ((GMAC_ST2RPQ_COMPC_Msk & ((value) << GMAC_ST2RPQ_COMPC_Pos)))
781#define GMAC_ST2RPQ_COMPCE (0x1u << 30)
782/* -------- GMAC_IERPQ[2] : (GMAC Offset: 0x600) Interrupt Enable Register Priority Queue (index = 1) -------- */
783#define GMAC_IERPQ_RCOMP (0x1u << 1)
784#define GMAC_IERPQ_RXUBR (0x1u << 2)
785#define GMAC_IERPQ_RLEX (0x1u << 5)
786#define GMAC_IERPQ_TFC (0x1u << 6)
787#define GMAC_IERPQ_TCOMP (0x1u << 7)
788#define GMAC_IERPQ_ROVR (0x1u << 10)
789#define GMAC_IERPQ_HRESP (0x1u << 11)
790/* -------- GMAC_IDRPQ[2] : (GMAC Offset: 0x620) Interrupt Disable Register Priority Queue (index = 1) -------- */
791#define GMAC_IDRPQ_RCOMP (0x1u << 1)
792#define GMAC_IDRPQ_RXUBR (0x1u << 2)
793#define GMAC_IDRPQ_RLEX (0x1u << 5)
794#define GMAC_IDRPQ_TFC (0x1u << 6)
795#define GMAC_IDRPQ_TCOMP (0x1u << 7)
796#define GMAC_IDRPQ_ROVR (0x1u << 10)
797#define GMAC_IDRPQ_HRESP (0x1u << 11)
798/* -------- GMAC_IMRPQ[2] : (GMAC Offset: 0x640) Interrupt Mask Register Priority Queue (index = 1) -------- */
799#define GMAC_IMRPQ_RCOMP (0x1u << 1)
800#define GMAC_IMRPQ_RXUBR (0x1u << 2)
801#define GMAC_IMRPQ_RLEX (0x1u << 5)
802#define GMAC_IMRPQ_AHB (0x1u << 6)
803#define GMAC_IMRPQ_TCOMP (0x1u << 7)
804#define GMAC_IMRPQ_ROVR (0x1u << 10)
805#define GMAC_IMRPQ_HRESP (0x1u << 11)
806/* -------- GMAC_ST2ER[4] : (GMAC Offset: 0x6E0) Screening Type 2 Ethertype Register (index = 0) -------- */
807#define GMAC_ST2ER_COMPVAL_Pos 0
808#define GMAC_ST2ER_COMPVAL_Msk (0xffffu << GMAC_ST2ER_COMPVAL_Pos)
809#define GMAC_ST2ER_COMPVAL(value) ((GMAC_ST2ER_COMPVAL_Msk & ((value) << GMAC_ST2ER_COMPVAL_Pos)))
810/* -------- GMAC_ST2CW00 : (GMAC Offset: 0x700) Screening Type 2 Compare Word 0 Register (index = 0) -------- */
811#define GMAC_ST2CW00_MASKVAL_Pos 0
812#define GMAC_ST2CW00_MASKVAL_Msk (0xffffu << GMAC_ST2CW00_MASKVAL_Pos)
813#define GMAC_ST2CW00_MASKVAL(value) ((GMAC_ST2CW00_MASKVAL_Msk & ((value) << GMAC_ST2CW00_MASKVAL_Pos)))
814#define GMAC_ST2CW00_COMPVAL_Pos 16
815#define GMAC_ST2CW00_COMPVAL_Msk (0xffffu << GMAC_ST2CW00_COMPVAL_Pos)
816#define GMAC_ST2CW00_COMPVAL(value) ((GMAC_ST2CW00_COMPVAL_Msk & ((value) << GMAC_ST2CW00_COMPVAL_Pos)))
817/* -------- GMAC_ST2CW10 : (GMAC Offset: 0x704) Screening Type 2 Compare Word 1 Register (index = 0) -------- */
818#define GMAC_ST2CW10_OFFSVAL_Pos 0
819#define GMAC_ST2CW10_OFFSVAL_Msk (0x7fu << GMAC_ST2CW10_OFFSVAL_Pos)
820#define GMAC_ST2CW10_OFFSVAL(value) ((GMAC_ST2CW10_OFFSVAL_Msk & ((value) << GMAC_ST2CW10_OFFSVAL_Pos)))
821#define GMAC_ST2CW10_OFFSSTRT_Pos 7
822#define GMAC_ST2CW10_OFFSSTRT_Msk (0x3u << GMAC_ST2CW10_OFFSSTRT_Pos)
823#define GMAC_ST2CW10_OFFSSTRT(value) ((GMAC_ST2CW10_OFFSSTRT_Msk & ((value) << GMAC_ST2CW10_OFFSSTRT_Pos)))
824#define GMAC_ST2CW10_OFFSSTRT_FRAMESTART (0x0u << 7)
825#define GMAC_ST2CW10_OFFSSTRT_ETHERTYPE (0x1u << 7)
826#define GMAC_ST2CW10_OFFSSTRT_IP (0x2u << 7)
827#define GMAC_ST2CW10_OFFSSTRT_TCP_UDP (0x3u << 7)
828/* -------- GMAC_ST2CW01 : (GMAC Offset: 0x708) Screening Type 2 Compare Word 0 Register (index = 1) -------- */
829#define GMAC_ST2CW01_MASKVAL_Pos 0
830#define GMAC_ST2CW01_MASKVAL_Msk (0xffffu << GMAC_ST2CW01_MASKVAL_Pos)
831#define GMAC_ST2CW01_MASKVAL(value) ((GMAC_ST2CW01_MASKVAL_Msk & ((value) << GMAC_ST2CW01_MASKVAL_Pos)))
832#define GMAC_ST2CW01_COMPVAL_Pos 16
833#define GMAC_ST2CW01_COMPVAL_Msk (0xffffu << GMAC_ST2CW01_COMPVAL_Pos)
834#define GMAC_ST2CW01_COMPVAL(value) ((GMAC_ST2CW01_COMPVAL_Msk & ((value) << GMAC_ST2CW01_COMPVAL_Pos)))
835/* -------- GMAC_ST2CW11 : (GMAC Offset: 0x70C) Screening Type 2 Compare Word 1 Register (index = 1) -------- */
836#define GMAC_ST2CW11_OFFSVAL_Pos 0
837#define GMAC_ST2CW11_OFFSVAL_Msk (0x7fu << GMAC_ST2CW11_OFFSVAL_Pos)
838#define GMAC_ST2CW11_OFFSVAL(value) ((GMAC_ST2CW11_OFFSVAL_Msk & ((value) << GMAC_ST2CW11_OFFSVAL_Pos)))
839#define GMAC_ST2CW11_OFFSSTRT_Pos 7
840#define GMAC_ST2CW11_OFFSSTRT_Msk (0x3u << GMAC_ST2CW11_OFFSSTRT_Pos)
841#define GMAC_ST2CW11_OFFSSTRT(value) ((GMAC_ST2CW11_OFFSSTRT_Msk & ((value) << GMAC_ST2CW11_OFFSSTRT_Pos)))
842#define GMAC_ST2CW11_OFFSSTRT_FRAMESTART (0x0u << 7)
843#define GMAC_ST2CW11_OFFSSTRT_ETHERTYPE (0x1u << 7)
844#define GMAC_ST2CW11_OFFSSTRT_IP (0x2u << 7)
845#define GMAC_ST2CW11_OFFSSTRT_TCP_UDP (0x3u << 7)
846/* -------- GMAC_ST2CW02 : (GMAC Offset: 0x710) Screening Type 2 Compare Word 0 Register (index = 2) -------- */
847#define GMAC_ST2CW02_MASKVAL_Pos 0
848#define GMAC_ST2CW02_MASKVAL_Msk (0xffffu << GMAC_ST2CW02_MASKVAL_Pos)
849#define GMAC_ST2CW02_MASKVAL(value) ((GMAC_ST2CW02_MASKVAL_Msk & ((value) << GMAC_ST2CW02_MASKVAL_Pos)))
850#define GMAC_ST2CW02_COMPVAL_Pos 16
851#define GMAC_ST2CW02_COMPVAL_Msk (0xffffu << GMAC_ST2CW02_COMPVAL_Pos)
852#define GMAC_ST2CW02_COMPVAL(value) ((GMAC_ST2CW02_COMPVAL_Msk & ((value) << GMAC_ST2CW02_COMPVAL_Pos)))
853/* -------- GMAC_ST2CW12 : (GMAC Offset: 0x714) Screening Type 2 Compare Word 1 Register (index = 2) -------- */
854#define GMAC_ST2CW12_OFFSVAL_Pos 0
855#define GMAC_ST2CW12_OFFSVAL_Msk (0x7fu << GMAC_ST2CW12_OFFSVAL_Pos)
856#define GMAC_ST2CW12_OFFSVAL(value) ((GMAC_ST2CW12_OFFSVAL_Msk & ((value) << GMAC_ST2CW12_OFFSVAL_Pos)))
857#define GMAC_ST2CW12_OFFSSTRT_Pos 7
858#define GMAC_ST2CW12_OFFSSTRT_Msk (0x3u << GMAC_ST2CW12_OFFSSTRT_Pos)
859#define GMAC_ST2CW12_OFFSSTRT(value) ((GMAC_ST2CW12_OFFSSTRT_Msk & ((value) << GMAC_ST2CW12_OFFSSTRT_Pos)))
860#define GMAC_ST2CW12_OFFSSTRT_FRAMESTART (0x0u << 7)
861#define GMAC_ST2CW12_OFFSSTRT_ETHERTYPE (0x1u << 7)
862#define GMAC_ST2CW12_OFFSSTRT_IP (0x2u << 7)
863#define GMAC_ST2CW12_OFFSSTRT_TCP_UDP (0x3u << 7)
864/* -------- GMAC_ST2CW03 : (GMAC Offset: 0x718) Screening Type 2 Compare Word 0 Register (index = 3) -------- */
865#define GMAC_ST2CW03_MASKVAL_Pos 0
866#define GMAC_ST2CW03_MASKVAL_Msk (0xffffu << GMAC_ST2CW03_MASKVAL_Pos)
867#define GMAC_ST2CW03_MASKVAL(value) ((GMAC_ST2CW03_MASKVAL_Msk & ((value) << GMAC_ST2CW03_MASKVAL_Pos)))
868#define GMAC_ST2CW03_COMPVAL_Pos 16
869#define GMAC_ST2CW03_COMPVAL_Msk (0xffffu << GMAC_ST2CW03_COMPVAL_Pos)
870#define GMAC_ST2CW03_COMPVAL(value) ((GMAC_ST2CW03_COMPVAL_Msk & ((value) << GMAC_ST2CW03_COMPVAL_Pos)))
871/* -------- GMAC_ST2CW13 : (GMAC Offset: 0x71C) Screening Type 2 Compare Word 1 Register (index = 3) -------- */
872#define GMAC_ST2CW13_OFFSVAL_Pos 0
873#define GMAC_ST2CW13_OFFSVAL_Msk (0x7fu << GMAC_ST2CW13_OFFSVAL_Pos)
874#define GMAC_ST2CW13_OFFSVAL(value) ((GMAC_ST2CW13_OFFSVAL_Msk & ((value) << GMAC_ST2CW13_OFFSVAL_Pos)))
875#define GMAC_ST2CW13_OFFSSTRT_Pos 7
876#define GMAC_ST2CW13_OFFSSTRT_Msk (0x3u << GMAC_ST2CW13_OFFSSTRT_Pos)
877#define GMAC_ST2CW13_OFFSSTRT(value) ((GMAC_ST2CW13_OFFSSTRT_Msk & ((value) << GMAC_ST2CW13_OFFSSTRT_Pos)))
878#define GMAC_ST2CW13_OFFSSTRT_FRAMESTART (0x0u << 7)
879#define GMAC_ST2CW13_OFFSSTRT_ETHERTYPE (0x1u << 7)
880#define GMAC_ST2CW13_OFFSSTRT_IP (0x2u << 7)
881#define GMAC_ST2CW13_OFFSSTRT_TCP_UDP (0x3u << 7)
882/* -------- GMAC_ST2CW04 : (GMAC Offset: 0x720) Screening Type 2 Compare Word 0 Register (index = 4) -------- */
883#define GMAC_ST2CW04_MASKVAL_Pos 0
884#define GMAC_ST2CW04_MASKVAL_Msk (0xffffu << GMAC_ST2CW04_MASKVAL_Pos)
885#define GMAC_ST2CW04_MASKVAL(value) ((GMAC_ST2CW04_MASKVAL_Msk & ((value) << GMAC_ST2CW04_MASKVAL_Pos)))
886#define GMAC_ST2CW04_COMPVAL_Pos 16
887#define GMAC_ST2CW04_COMPVAL_Msk (0xffffu << GMAC_ST2CW04_COMPVAL_Pos)
888#define GMAC_ST2CW04_COMPVAL(value) ((GMAC_ST2CW04_COMPVAL_Msk & ((value) << GMAC_ST2CW04_COMPVAL_Pos)))
889/* -------- GMAC_ST2CW14 : (GMAC Offset: 0x724) Screening Type 2 Compare Word 1 Register (index = 4) -------- */
890#define GMAC_ST2CW14_OFFSVAL_Pos 0
891#define GMAC_ST2CW14_OFFSVAL_Msk (0x7fu << GMAC_ST2CW14_OFFSVAL_Pos)
892#define GMAC_ST2CW14_OFFSVAL(value) ((GMAC_ST2CW14_OFFSVAL_Msk & ((value) << GMAC_ST2CW14_OFFSVAL_Pos)))
893#define GMAC_ST2CW14_OFFSSTRT_Pos 7
894#define GMAC_ST2CW14_OFFSSTRT_Msk (0x3u << GMAC_ST2CW14_OFFSSTRT_Pos)
895#define GMAC_ST2CW14_OFFSSTRT(value) ((GMAC_ST2CW14_OFFSSTRT_Msk & ((value) << GMAC_ST2CW14_OFFSSTRT_Pos)))
896#define GMAC_ST2CW14_OFFSSTRT_FRAMESTART (0x0u << 7)
897#define GMAC_ST2CW14_OFFSSTRT_ETHERTYPE (0x1u << 7)
898#define GMAC_ST2CW14_OFFSSTRT_IP (0x2u << 7)
899#define GMAC_ST2CW14_OFFSSTRT_TCP_UDP (0x3u << 7)
900/* -------- GMAC_ST2CW05 : (GMAC Offset: 0x728) Screening Type 2 Compare Word 0 Register (index = 5) -------- */
901#define GMAC_ST2CW05_MASKVAL_Pos 0
902#define GMAC_ST2CW05_MASKVAL_Msk (0xffffu << GMAC_ST2CW05_MASKVAL_Pos)
903#define GMAC_ST2CW05_MASKVAL(value) ((GMAC_ST2CW05_MASKVAL_Msk & ((value) << GMAC_ST2CW05_MASKVAL_Pos)))
904#define GMAC_ST2CW05_COMPVAL_Pos 16
905#define GMAC_ST2CW05_COMPVAL_Msk (0xffffu << GMAC_ST2CW05_COMPVAL_Pos)
906#define GMAC_ST2CW05_COMPVAL(value) ((GMAC_ST2CW05_COMPVAL_Msk & ((value) << GMAC_ST2CW05_COMPVAL_Pos)))
907/* -------- GMAC_ST2CW15 : (GMAC Offset: 0x72C) Screening Type 2 Compare Word 1 Register (index = 5) -------- */
908#define GMAC_ST2CW15_OFFSVAL_Pos 0
909#define GMAC_ST2CW15_OFFSVAL_Msk (0x7fu << GMAC_ST2CW15_OFFSVAL_Pos)
910#define GMAC_ST2CW15_OFFSVAL(value) ((GMAC_ST2CW15_OFFSVAL_Msk & ((value) << GMAC_ST2CW15_OFFSVAL_Pos)))
911#define GMAC_ST2CW15_OFFSSTRT_Pos 7
912#define GMAC_ST2CW15_OFFSSTRT_Msk (0x3u << GMAC_ST2CW15_OFFSSTRT_Pos)
913#define GMAC_ST2CW15_OFFSSTRT(value) ((GMAC_ST2CW15_OFFSSTRT_Msk & ((value) << GMAC_ST2CW15_OFFSSTRT_Pos)))
914#define GMAC_ST2CW15_OFFSSTRT_FRAMESTART (0x0u << 7)
915#define GMAC_ST2CW15_OFFSSTRT_ETHERTYPE (0x1u << 7)
916#define GMAC_ST2CW15_OFFSSTRT_IP (0x2u << 7)
917#define GMAC_ST2CW15_OFFSSTRT_TCP_UDP (0x3u << 7)
918/* -------- GMAC_ST2CW06 : (GMAC Offset: 0x730) Screening Type 2 Compare Word 0 Register (index = 6) -------- */
919#define GMAC_ST2CW06_MASKVAL_Pos 0
920#define GMAC_ST2CW06_MASKVAL_Msk (0xffffu << GMAC_ST2CW06_MASKVAL_Pos)
921#define GMAC_ST2CW06_MASKVAL(value) ((GMAC_ST2CW06_MASKVAL_Msk & ((value) << GMAC_ST2CW06_MASKVAL_Pos)))
922#define GMAC_ST2CW06_COMPVAL_Pos 16
923#define GMAC_ST2CW06_COMPVAL_Msk (0xffffu << GMAC_ST2CW06_COMPVAL_Pos)
924#define GMAC_ST2CW06_COMPVAL(value) ((GMAC_ST2CW06_COMPVAL_Msk & ((value) << GMAC_ST2CW06_COMPVAL_Pos)))
925/* -------- GMAC_ST2CW16 : (GMAC Offset: 0x734) Screening Type 2 Compare Word 1 Register (index = 6) -------- */
926#define GMAC_ST2CW16_OFFSVAL_Pos 0
927#define GMAC_ST2CW16_OFFSVAL_Msk (0x7fu << GMAC_ST2CW16_OFFSVAL_Pos)
928#define GMAC_ST2CW16_OFFSVAL(value) ((GMAC_ST2CW16_OFFSVAL_Msk & ((value) << GMAC_ST2CW16_OFFSVAL_Pos)))
929#define GMAC_ST2CW16_OFFSSTRT_Pos 7
930#define GMAC_ST2CW16_OFFSSTRT_Msk (0x3u << GMAC_ST2CW16_OFFSSTRT_Pos)
931#define GMAC_ST2CW16_OFFSSTRT(value) ((GMAC_ST2CW16_OFFSSTRT_Msk & ((value) << GMAC_ST2CW16_OFFSSTRT_Pos)))
932#define GMAC_ST2CW16_OFFSSTRT_FRAMESTART (0x0u << 7)
933#define GMAC_ST2CW16_OFFSSTRT_ETHERTYPE (0x1u << 7)
934#define GMAC_ST2CW16_OFFSSTRT_IP (0x2u << 7)
935#define GMAC_ST2CW16_OFFSSTRT_TCP_UDP (0x3u << 7)
936/* -------- GMAC_ST2CW07 : (GMAC Offset: 0x738) Screening Type 2 Compare Word 0 Register (index = 7) -------- */
937#define GMAC_ST2CW07_MASKVAL_Pos 0
938#define GMAC_ST2CW07_MASKVAL_Msk (0xffffu << GMAC_ST2CW07_MASKVAL_Pos)
939#define GMAC_ST2CW07_MASKVAL(value) ((GMAC_ST2CW07_MASKVAL_Msk & ((value) << GMAC_ST2CW07_MASKVAL_Pos)))
940#define GMAC_ST2CW07_COMPVAL_Pos 16
941#define GMAC_ST2CW07_COMPVAL_Msk (0xffffu << GMAC_ST2CW07_COMPVAL_Pos)
942#define GMAC_ST2CW07_COMPVAL(value) ((GMAC_ST2CW07_COMPVAL_Msk & ((value) << GMAC_ST2CW07_COMPVAL_Pos)))
943/* -------- GMAC_ST2CW17 : (GMAC Offset: 0x73C) Screening Type 2 Compare Word 1 Register (index = 7) -------- */
944#define GMAC_ST2CW17_OFFSVAL_Pos 0
945#define GMAC_ST2CW17_OFFSVAL_Msk (0x7fu << GMAC_ST2CW17_OFFSVAL_Pos)
946#define GMAC_ST2CW17_OFFSVAL(value) ((GMAC_ST2CW17_OFFSVAL_Msk & ((value) << GMAC_ST2CW17_OFFSVAL_Pos)))
947#define GMAC_ST2CW17_OFFSSTRT_Pos 7
948#define GMAC_ST2CW17_OFFSSTRT_Msk (0x3u << GMAC_ST2CW17_OFFSSTRT_Pos)
949#define GMAC_ST2CW17_OFFSSTRT(value) ((GMAC_ST2CW17_OFFSSTRT_Msk & ((value) << GMAC_ST2CW17_OFFSSTRT_Pos)))
950#define GMAC_ST2CW17_OFFSSTRT_FRAMESTART (0x0u << 7)
951#define GMAC_ST2CW17_OFFSSTRT_ETHERTYPE (0x1u << 7)
952#define GMAC_ST2CW17_OFFSSTRT_IP (0x2u << 7)
953#define GMAC_ST2CW17_OFFSSTRT_TCP_UDP (0x3u << 7)
954/* -------- GMAC_ST2CW08 : (GMAC Offset: 0x740) Screening Type 2 Compare Word 0 Register (index = 8) -------- */
955#define GMAC_ST2CW08_MASKVAL_Pos 0
956#define GMAC_ST2CW08_MASKVAL_Msk (0xffffu << GMAC_ST2CW08_MASKVAL_Pos)
957#define GMAC_ST2CW08_MASKVAL(value) ((GMAC_ST2CW08_MASKVAL_Msk & ((value) << GMAC_ST2CW08_MASKVAL_Pos)))
958#define GMAC_ST2CW08_COMPVAL_Pos 16
959#define GMAC_ST2CW08_COMPVAL_Msk (0xffffu << GMAC_ST2CW08_COMPVAL_Pos)
960#define GMAC_ST2CW08_COMPVAL(value) ((GMAC_ST2CW08_COMPVAL_Msk & ((value) << GMAC_ST2CW08_COMPVAL_Pos)))
961/* -------- GMAC_ST2CW18 : (GMAC Offset: 0x744) Screening Type 2 Compare Word 1 Register (index = 8) -------- */
962#define GMAC_ST2CW18_OFFSVAL_Pos 0
963#define GMAC_ST2CW18_OFFSVAL_Msk (0x7fu << GMAC_ST2CW18_OFFSVAL_Pos)
964#define GMAC_ST2CW18_OFFSVAL(value) ((GMAC_ST2CW18_OFFSVAL_Msk & ((value) << GMAC_ST2CW18_OFFSVAL_Pos)))
965#define GMAC_ST2CW18_OFFSSTRT_Pos 7
966#define GMAC_ST2CW18_OFFSSTRT_Msk (0x3u << GMAC_ST2CW18_OFFSSTRT_Pos)
967#define GMAC_ST2CW18_OFFSSTRT(value) ((GMAC_ST2CW18_OFFSSTRT_Msk & ((value) << GMAC_ST2CW18_OFFSSTRT_Pos)))
968#define GMAC_ST2CW18_OFFSSTRT_FRAMESTART (0x0u << 7)
969#define GMAC_ST2CW18_OFFSSTRT_ETHERTYPE (0x1u << 7)
970#define GMAC_ST2CW18_OFFSSTRT_IP (0x2u << 7)
971#define GMAC_ST2CW18_OFFSSTRT_TCP_UDP (0x3u << 7)
972/* -------- GMAC_ST2CW09 : (GMAC Offset: 0x748) Screening Type 2 Compare Word 0 Register (index = 9) -------- */
973#define GMAC_ST2CW09_MASKVAL_Pos 0
974#define GMAC_ST2CW09_MASKVAL_Msk (0xffffu << GMAC_ST2CW09_MASKVAL_Pos)
975#define GMAC_ST2CW09_MASKVAL(value) ((GMAC_ST2CW09_MASKVAL_Msk & ((value) << GMAC_ST2CW09_MASKVAL_Pos)))
976#define GMAC_ST2CW09_COMPVAL_Pos 16
977#define GMAC_ST2CW09_COMPVAL_Msk (0xffffu << GMAC_ST2CW09_COMPVAL_Pos)
978#define GMAC_ST2CW09_COMPVAL(value) ((GMAC_ST2CW09_COMPVAL_Msk & ((value) << GMAC_ST2CW09_COMPVAL_Pos)))
979/* -------- GMAC_ST2CW19 : (GMAC Offset: 0x74C) Screening Type 2 Compare Word 1 Register (index = 9) -------- */
980#define GMAC_ST2CW19_OFFSVAL_Pos 0
981#define GMAC_ST2CW19_OFFSVAL_Msk (0x7fu << GMAC_ST2CW19_OFFSVAL_Pos)
982#define GMAC_ST2CW19_OFFSVAL(value) ((GMAC_ST2CW19_OFFSVAL_Msk & ((value) << GMAC_ST2CW19_OFFSVAL_Pos)))
983#define GMAC_ST2CW19_OFFSSTRT_Pos 7
984#define GMAC_ST2CW19_OFFSSTRT_Msk (0x3u << GMAC_ST2CW19_OFFSSTRT_Pos)
985#define GMAC_ST2CW19_OFFSSTRT(value) ((GMAC_ST2CW19_OFFSSTRT_Msk & ((value) << GMAC_ST2CW19_OFFSSTRT_Pos)))
986#define GMAC_ST2CW19_OFFSSTRT_FRAMESTART (0x0u << 7)
987#define GMAC_ST2CW19_OFFSSTRT_ETHERTYPE (0x1u << 7)
988#define GMAC_ST2CW19_OFFSSTRT_IP (0x2u << 7)
989#define GMAC_ST2CW19_OFFSSTRT_TCP_UDP (0x3u << 7)
990/* -------- GMAC_ST2CW010 : (GMAC Offset: 0x750) Screening Type 2 Compare Word 0 Register (index = 10) -------- */
991#define GMAC_ST2CW010_MASKVAL_Pos 0
992#define GMAC_ST2CW010_MASKVAL_Msk (0xffffu << GMAC_ST2CW010_MASKVAL_Pos)
993#define GMAC_ST2CW010_MASKVAL(value) ((GMAC_ST2CW010_MASKVAL_Msk & ((value) << GMAC_ST2CW010_MASKVAL_Pos)))
994#define GMAC_ST2CW010_COMPVAL_Pos 16
995#define GMAC_ST2CW010_COMPVAL_Msk (0xffffu << GMAC_ST2CW010_COMPVAL_Pos)
996#define GMAC_ST2CW010_COMPVAL(value) ((GMAC_ST2CW010_COMPVAL_Msk & ((value) << GMAC_ST2CW010_COMPVAL_Pos)))
997/* -------- GMAC_ST2CW110 : (GMAC Offset: 0x754) Screening Type 2 Compare Word 1 Register (index = 10) -------- */
998#define GMAC_ST2CW110_OFFSVAL_Pos 0
999#define GMAC_ST2CW110_OFFSVAL_Msk (0x7fu << GMAC_ST2CW110_OFFSVAL_Pos)
1000#define GMAC_ST2CW110_OFFSVAL(value) ((GMAC_ST2CW110_OFFSVAL_Msk & ((value) << GMAC_ST2CW110_OFFSVAL_Pos)))
1001#define GMAC_ST2CW110_OFFSSTRT_Pos 7
1002#define GMAC_ST2CW110_OFFSSTRT_Msk (0x3u << GMAC_ST2CW110_OFFSSTRT_Pos)
1003#define GMAC_ST2CW110_OFFSSTRT(value) ((GMAC_ST2CW110_OFFSSTRT_Msk & ((value) << GMAC_ST2CW110_OFFSSTRT_Pos)))
1004#define GMAC_ST2CW110_OFFSSTRT_FRAMESTART (0x0u << 7)
1005#define GMAC_ST2CW110_OFFSSTRT_ETHERTYPE (0x1u << 7)
1006#define GMAC_ST2CW110_OFFSSTRT_IP (0x2u << 7)
1007#define GMAC_ST2CW110_OFFSSTRT_TCP_UDP (0x3u << 7)
1008/* -------- GMAC_ST2CW011 : (GMAC Offset: 0x758) Screening Type 2 Compare Word 0 Register (index = 11) -------- */
1009#define GMAC_ST2CW011_MASKVAL_Pos 0
1010#define GMAC_ST2CW011_MASKVAL_Msk (0xffffu << GMAC_ST2CW011_MASKVAL_Pos)
1011#define GMAC_ST2CW011_MASKVAL(value) ((GMAC_ST2CW011_MASKVAL_Msk & ((value) << GMAC_ST2CW011_MASKVAL_Pos)))
1012#define GMAC_ST2CW011_COMPVAL_Pos 16
1013#define GMAC_ST2CW011_COMPVAL_Msk (0xffffu << GMAC_ST2CW011_COMPVAL_Pos)
1014#define GMAC_ST2CW011_COMPVAL(value) ((GMAC_ST2CW011_COMPVAL_Msk & ((value) << GMAC_ST2CW011_COMPVAL_Pos)))
1015/* -------- GMAC_ST2CW111 : (GMAC Offset: 0x75C) Screening Type 2 Compare Word 1 Register (index = 11) -------- */
1016#define GMAC_ST2CW111_OFFSVAL_Pos 0
1017#define GMAC_ST2CW111_OFFSVAL_Msk (0x7fu << GMAC_ST2CW111_OFFSVAL_Pos)
1018#define GMAC_ST2CW111_OFFSVAL(value) ((GMAC_ST2CW111_OFFSVAL_Msk & ((value) << GMAC_ST2CW111_OFFSVAL_Pos)))
1019#define GMAC_ST2CW111_OFFSSTRT_Pos 7
1020#define GMAC_ST2CW111_OFFSSTRT_Msk (0x3u << GMAC_ST2CW111_OFFSSTRT_Pos)
1021#define GMAC_ST2CW111_OFFSSTRT(value) ((GMAC_ST2CW111_OFFSSTRT_Msk & ((value) << GMAC_ST2CW111_OFFSSTRT_Pos)))
1022#define GMAC_ST2CW111_OFFSSTRT_FRAMESTART (0x0u << 7)
1023#define GMAC_ST2CW111_OFFSSTRT_ETHERTYPE (0x1u << 7)
1024#define GMAC_ST2CW111_OFFSSTRT_IP (0x2u << 7)
1025#define GMAC_ST2CW111_OFFSSTRT_TCP_UDP (0x3u << 7)
1026/* -------- GMAC_ST2CW012 : (GMAC Offset: 0x760) Screening Type 2 Compare Word 0 Register (index = 12) -------- */
1027#define GMAC_ST2CW012_MASKVAL_Pos 0
1028#define GMAC_ST2CW012_MASKVAL_Msk (0xffffu << GMAC_ST2CW012_MASKVAL_Pos)
1029#define GMAC_ST2CW012_MASKVAL(value) ((GMAC_ST2CW012_MASKVAL_Msk & ((value) << GMAC_ST2CW012_MASKVAL_Pos)))
1030#define GMAC_ST2CW012_COMPVAL_Pos 16
1031#define GMAC_ST2CW012_COMPVAL_Msk (0xffffu << GMAC_ST2CW012_COMPVAL_Pos)
1032#define GMAC_ST2CW012_COMPVAL(value) ((GMAC_ST2CW012_COMPVAL_Msk & ((value) << GMAC_ST2CW012_COMPVAL_Pos)))
1033/* -------- GMAC_ST2CW112 : (GMAC Offset: 0x764) Screening Type 2 Compare Word 1 Register (index = 12) -------- */
1034#define GMAC_ST2CW112_OFFSVAL_Pos 0
1035#define GMAC_ST2CW112_OFFSVAL_Msk (0x7fu << GMAC_ST2CW112_OFFSVAL_Pos)
1036#define GMAC_ST2CW112_OFFSVAL(value) ((GMAC_ST2CW112_OFFSVAL_Msk & ((value) << GMAC_ST2CW112_OFFSVAL_Pos)))
1037#define GMAC_ST2CW112_OFFSSTRT_Pos 7
1038#define GMAC_ST2CW112_OFFSSTRT_Msk (0x3u << GMAC_ST2CW112_OFFSSTRT_Pos)
1039#define GMAC_ST2CW112_OFFSSTRT(value) ((GMAC_ST2CW112_OFFSSTRT_Msk & ((value) << GMAC_ST2CW112_OFFSSTRT_Pos)))
1040#define GMAC_ST2CW112_OFFSSTRT_FRAMESTART (0x0u << 7)
1041#define GMAC_ST2CW112_OFFSSTRT_ETHERTYPE (0x1u << 7)
1042#define GMAC_ST2CW112_OFFSSTRT_IP (0x2u << 7)
1043#define GMAC_ST2CW112_OFFSSTRT_TCP_UDP (0x3u << 7)
1044/* -------- GMAC_ST2CW013 : (GMAC Offset: 0x768) Screening Type 2 Compare Word 0 Register (index = 13) -------- */
1045#define GMAC_ST2CW013_MASKVAL_Pos 0
1046#define GMAC_ST2CW013_MASKVAL_Msk (0xffffu << GMAC_ST2CW013_MASKVAL_Pos)
1047#define GMAC_ST2CW013_MASKVAL(value) ((GMAC_ST2CW013_MASKVAL_Msk & ((value) << GMAC_ST2CW013_MASKVAL_Pos)))
1048#define GMAC_ST2CW013_COMPVAL_Pos 16
1049#define GMAC_ST2CW013_COMPVAL_Msk (0xffffu << GMAC_ST2CW013_COMPVAL_Pos)
1050#define GMAC_ST2CW013_COMPVAL(value) ((GMAC_ST2CW013_COMPVAL_Msk & ((value) << GMAC_ST2CW013_COMPVAL_Pos)))
1051/* -------- GMAC_ST2CW113 : (GMAC Offset: 0x76C) Screening Type 2 Compare Word 1 Register (index = 13) -------- */
1052#define GMAC_ST2CW113_OFFSVAL_Pos 0
1053#define GMAC_ST2CW113_OFFSVAL_Msk (0x7fu << GMAC_ST2CW113_OFFSVAL_Pos)
1054#define GMAC_ST2CW113_OFFSVAL(value) ((GMAC_ST2CW113_OFFSVAL_Msk & ((value) << GMAC_ST2CW113_OFFSVAL_Pos)))
1055#define GMAC_ST2CW113_OFFSSTRT_Pos 7
1056#define GMAC_ST2CW113_OFFSSTRT_Msk (0x3u << GMAC_ST2CW113_OFFSSTRT_Pos)
1057#define GMAC_ST2CW113_OFFSSTRT(value) ((GMAC_ST2CW113_OFFSSTRT_Msk & ((value) << GMAC_ST2CW113_OFFSSTRT_Pos)))
1058#define GMAC_ST2CW113_OFFSSTRT_FRAMESTART (0x0u << 7)
1059#define GMAC_ST2CW113_OFFSSTRT_ETHERTYPE (0x1u << 7)
1060#define GMAC_ST2CW113_OFFSSTRT_IP (0x2u << 7)
1061#define GMAC_ST2CW113_OFFSSTRT_TCP_UDP (0x3u << 7)
1062/* -------- GMAC_ST2CW014 : (GMAC Offset: 0x770) Screening Type 2 Compare Word 0 Register (index = 14) -------- */
1063#define GMAC_ST2CW014_MASKVAL_Pos 0
1064#define GMAC_ST2CW014_MASKVAL_Msk (0xffffu << GMAC_ST2CW014_MASKVAL_Pos)
1065#define GMAC_ST2CW014_MASKVAL(value) ((GMAC_ST2CW014_MASKVAL_Msk & ((value) << GMAC_ST2CW014_MASKVAL_Pos)))
1066#define GMAC_ST2CW014_COMPVAL_Pos 16
1067#define GMAC_ST2CW014_COMPVAL_Msk (0xffffu << GMAC_ST2CW014_COMPVAL_Pos)
1068#define GMAC_ST2CW014_COMPVAL(value) ((GMAC_ST2CW014_COMPVAL_Msk & ((value) << GMAC_ST2CW014_COMPVAL_Pos)))
1069/* -------- GMAC_ST2CW114 : (GMAC Offset: 0x774) Screening Type 2 Compare Word 1 Register (index = 14) -------- */
1070#define GMAC_ST2CW114_OFFSVAL_Pos 0
1071#define GMAC_ST2CW114_OFFSVAL_Msk (0x7fu << GMAC_ST2CW114_OFFSVAL_Pos)
1072#define GMAC_ST2CW114_OFFSVAL(value) ((GMAC_ST2CW114_OFFSVAL_Msk & ((value) << GMAC_ST2CW114_OFFSVAL_Pos)))
1073#define GMAC_ST2CW114_OFFSSTRT_Pos 7
1074#define GMAC_ST2CW114_OFFSSTRT_Msk (0x3u << GMAC_ST2CW114_OFFSSTRT_Pos)
1075#define GMAC_ST2CW114_OFFSSTRT(value) ((GMAC_ST2CW114_OFFSSTRT_Msk & ((value) << GMAC_ST2CW114_OFFSSTRT_Pos)))
1076#define GMAC_ST2CW114_OFFSSTRT_FRAMESTART (0x0u << 7)
1077#define GMAC_ST2CW114_OFFSSTRT_ETHERTYPE (0x1u << 7)
1078#define GMAC_ST2CW114_OFFSSTRT_IP (0x2u << 7)
1079#define GMAC_ST2CW114_OFFSSTRT_TCP_UDP (0x3u << 7)
1080/* -------- GMAC_ST2CW015 : (GMAC Offset: 0x778) Screening Type 2 Compare Word 0 Register (index = 15) -------- */
1081#define GMAC_ST2CW015_MASKVAL_Pos 0
1082#define GMAC_ST2CW015_MASKVAL_Msk (0xffffu << GMAC_ST2CW015_MASKVAL_Pos)
1083#define GMAC_ST2CW015_MASKVAL(value) ((GMAC_ST2CW015_MASKVAL_Msk & ((value) << GMAC_ST2CW015_MASKVAL_Pos)))
1084#define GMAC_ST2CW015_COMPVAL_Pos 16
1085#define GMAC_ST2CW015_COMPVAL_Msk (0xffffu << GMAC_ST2CW015_COMPVAL_Pos)
1086#define GMAC_ST2CW015_COMPVAL(value) ((GMAC_ST2CW015_COMPVAL_Msk & ((value) << GMAC_ST2CW015_COMPVAL_Pos)))
1087/* -------- GMAC_ST2CW115 : (GMAC Offset: 0x77C) Screening Type 2 Compare Word 1 Register (index = 15) -------- */
1088#define GMAC_ST2CW115_OFFSVAL_Pos 0
1089#define GMAC_ST2CW115_OFFSVAL_Msk (0x7fu << GMAC_ST2CW115_OFFSVAL_Pos)
1090#define GMAC_ST2CW115_OFFSVAL(value) ((GMAC_ST2CW115_OFFSVAL_Msk & ((value) << GMAC_ST2CW115_OFFSVAL_Pos)))
1091#define GMAC_ST2CW115_OFFSSTRT_Pos 7
1092#define GMAC_ST2CW115_OFFSSTRT_Msk (0x3u << GMAC_ST2CW115_OFFSSTRT_Pos)
1093#define GMAC_ST2CW115_OFFSSTRT(value) ((GMAC_ST2CW115_OFFSSTRT_Msk & ((value) << GMAC_ST2CW115_OFFSSTRT_Pos)))
1094#define GMAC_ST2CW115_OFFSSTRT_FRAMESTART (0x0u << 7)
1095#define GMAC_ST2CW115_OFFSSTRT_ETHERTYPE (0x1u << 7)
1096#define GMAC_ST2CW115_OFFSSTRT_IP (0x2u << 7)
1097#define GMAC_ST2CW115_OFFSSTRT_TCP_UDP (0x3u << 7)
1098/* -------- GMAC_ST2CW016 : (GMAC Offset: 0x780) Screening Type 2 Compare Word 0 Register (index = 16) -------- */
1099#define GMAC_ST2CW016_MASKVAL_Pos 0
1100#define GMAC_ST2CW016_MASKVAL_Msk (0xffffu << GMAC_ST2CW016_MASKVAL_Pos)
1101#define GMAC_ST2CW016_MASKVAL(value) ((GMAC_ST2CW016_MASKVAL_Msk & ((value) << GMAC_ST2CW016_MASKVAL_Pos)))
1102#define GMAC_ST2CW016_COMPVAL_Pos 16
1103#define GMAC_ST2CW016_COMPVAL_Msk (0xffffu << GMAC_ST2CW016_COMPVAL_Pos)
1104#define GMAC_ST2CW016_COMPVAL(value) ((GMAC_ST2CW016_COMPVAL_Msk & ((value) << GMAC_ST2CW016_COMPVAL_Pos)))
1105/* -------- GMAC_ST2CW116 : (GMAC Offset: 0x784) Screening Type 2 Compare Word 1 Register (index = 16) -------- */
1106#define GMAC_ST2CW116_OFFSVAL_Pos 0
1107#define GMAC_ST2CW116_OFFSVAL_Msk (0x7fu << GMAC_ST2CW116_OFFSVAL_Pos)
1108#define GMAC_ST2CW116_OFFSVAL(value) ((GMAC_ST2CW116_OFFSVAL_Msk & ((value) << GMAC_ST2CW116_OFFSVAL_Pos)))
1109#define GMAC_ST2CW116_OFFSSTRT_Pos 7
1110#define GMAC_ST2CW116_OFFSSTRT_Msk (0x3u << GMAC_ST2CW116_OFFSSTRT_Pos)
1111#define GMAC_ST2CW116_OFFSSTRT(value) ((GMAC_ST2CW116_OFFSSTRT_Msk & ((value) << GMAC_ST2CW116_OFFSSTRT_Pos)))
1112#define GMAC_ST2CW116_OFFSSTRT_FRAMESTART (0x0u << 7)
1113#define GMAC_ST2CW116_OFFSSTRT_ETHERTYPE (0x1u << 7)
1114#define GMAC_ST2CW116_OFFSSTRT_IP (0x2u << 7)
1115#define GMAC_ST2CW116_OFFSSTRT_TCP_UDP (0x3u << 7)
1116/* -------- GMAC_ST2CW017 : (GMAC Offset: 0x788) Screening Type 2 Compare Word 0 Register (index = 17) -------- */
1117#define GMAC_ST2CW017_MASKVAL_Pos 0
1118#define GMAC_ST2CW017_MASKVAL_Msk (0xffffu << GMAC_ST2CW017_MASKVAL_Pos)
1119#define GMAC_ST2CW017_MASKVAL(value) ((GMAC_ST2CW017_MASKVAL_Msk & ((value) << GMAC_ST2CW017_MASKVAL_Pos)))
1120#define GMAC_ST2CW017_COMPVAL_Pos 16
1121#define GMAC_ST2CW017_COMPVAL_Msk (0xffffu << GMAC_ST2CW017_COMPVAL_Pos)
1122#define GMAC_ST2CW017_COMPVAL(value) ((GMAC_ST2CW017_COMPVAL_Msk & ((value) << GMAC_ST2CW017_COMPVAL_Pos)))
1123/* -------- GMAC_ST2CW117 : (GMAC Offset: 0x78C) Screening Type 2 Compare Word 1 Register (index = 17) -------- */
1124#define GMAC_ST2CW117_OFFSVAL_Pos 0
1125#define GMAC_ST2CW117_OFFSVAL_Msk (0x7fu << GMAC_ST2CW117_OFFSVAL_Pos)
1126#define GMAC_ST2CW117_OFFSVAL(value) ((GMAC_ST2CW117_OFFSVAL_Msk & ((value) << GMAC_ST2CW117_OFFSVAL_Pos)))
1127#define GMAC_ST2CW117_OFFSSTRT_Pos 7
1128#define GMAC_ST2CW117_OFFSSTRT_Msk (0x3u << GMAC_ST2CW117_OFFSSTRT_Pos)
1129#define GMAC_ST2CW117_OFFSSTRT(value) ((GMAC_ST2CW117_OFFSSTRT_Msk & ((value) << GMAC_ST2CW117_OFFSSTRT_Pos)))
1130#define GMAC_ST2CW117_OFFSSTRT_FRAMESTART (0x0u << 7)
1131#define GMAC_ST2CW117_OFFSSTRT_ETHERTYPE (0x1u << 7)
1132#define GMAC_ST2CW117_OFFSSTRT_IP (0x2u << 7)
1133#define GMAC_ST2CW117_OFFSSTRT_TCP_UDP (0x3u << 7)
1134/* -------- GMAC_ST2CW018 : (GMAC Offset: 0x790) Screening Type 2 Compare Word 0 Register (index = 18) -------- */
1135#define GMAC_ST2CW018_MASKVAL_Pos 0
1136#define GMAC_ST2CW018_MASKVAL_Msk (0xffffu << GMAC_ST2CW018_MASKVAL_Pos)
1137#define GMAC_ST2CW018_MASKVAL(value) ((GMAC_ST2CW018_MASKVAL_Msk & ((value) << GMAC_ST2CW018_MASKVAL_Pos)))
1138#define GMAC_ST2CW018_COMPVAL_Pos 16
1139#define GMAC_ST2CW018_COMPVAL_Msk (0xffffu << GMAC_ST2CW018_COMPVAL_Pos)
1140#define GMAC_ST2CW018_COMPVAL(value) ((GMAC_ST2CW018_COMPVAL_Msk & ((value) << GMAC_ST2CW018_COMPVAL_Pos)))
1141/* -------- GMAC_ST2CW118 : (GMAC Offset: 0x794) Screening Type 2 Compare Word 1 Register (index = 18) -------- */
1142#define GMAC_ST2CW118_OFFSVAL_Pos 0
1143#define GMAC_ST2CW118_OFFSVAL_Msk (0x7fu << GMAC_ST2CW118_OFFSVAL_Pos)
1144#define GMAC_ST2CW118_OFFSVAL(value) ((GMAC_ST2CW118_OFFSVAL_Msk & ((value) << GMAC_ST2CW118_OFFSVAL_Pos)))
1145#define GMAC_ST2CW118_OFFSSTRT_Pos 7
1146#define GMAC_ST2CW118_OFFSSTRT_Msk (0x3u << GMAC_ST2CW118_OFFSSTRT_Pos)
1147#define GMAC_ST2CW118_OFFSSTRT(value) ((GMAC_ST2CW118_OFFSSTRT_Msk & ((value) << GMAC_ST2CW118_OFFSSTRT_Pos)))
1148#define GMAC_ST2CW118_OFFSSTRT_FRAMESTART (0x0u << 7)
1149#define GMAC_ST2CW118_OFFSSTRT_ETHERTYPE (0x1u << 7)
1150#define GMAC_ST2CW118_OFFSSTRT_IP (0x2u << 7)
1151#define GMAC_ST2CW118_OFFSSTRT_TCP_UDP (0x3u << 7)
1152/* -------- GMAC_ST2CW019 : (GMAC Offset: 0x798) Screening Type 2 Compare Word 0 Register (index = 19) -------- */
1153#define GMAC_ST2CW019_MASKVAL_Pos 0
1154#define GMAC_ST2CW019_MASKVAL_Msk (0xffffu << GMAC_ST2CW019_MASKVAL_Pos)
1155#define GMAC_ST2CW019_MASKVAL(value) ((GMAC_ST2CW019_MASKVAL_Msk & ((value) << GMAC_ST2CW019_MASKVAL_Pos)))
1156#define GMAC_ST2CW019_COMPVAL_Pos 16
1157#define GMAC_ST2CW019_COMPVAL_Msk (0xffffu << GMAC_ST2CW019_COMPVAL_Pos)
1158#define GMAC_ST2CW019_COMPVAL(value) ((GMAC_ST2CW019_COMPVAL_Msk & ((value) << GMAC_ST2CW019_COMPVAL_Pos)))
1159/* -------- GMAC_ST2CW119 : (GMAC Offset: 0x79C) Screening Type 2 Compare Word 1 Register (index = 19) -------- */
1160#define GMAC_ST2CW119_OFFSVAL_Pos 0
1161#define GMAC_ST2CW119_OFFSVAL_Msk (0x7fu << GMAC_ST2CW119_OFFSVAL_Pos)
1162#define GMAC_ST2CW119_OFFSVAL(value) ((GMAC_ST2CW119_OFFSVAL_Msk & ((value) << GMAC_ST2CW119_OFFSVAL_Pos)))
1163#define GMAC_ST2CW119_OFFSSTRT_Pos 7
1164#define GMAC_ST2CW119_OFFSSTRT_Msk (0x3u << GMAC_ST2CW119_OFFSSTRT_Pos)
1165#define GMAC_ST2CW119_OFFSSTRT(value) ((GMAC_ST2CW119_OFFSSTRT_Msk & ((value) << GMAC_ST2CW119_OFFSSTRT_Pos)))
1166#define GMAC_ST2CW119_OFFSSTRT_FRAMESTART (0x0u << 7)
1167#define GMAC_ST2CW119_OFFSSTRT_ETHERTYPE (0x1u << 7)
1168#define GMAC_ST2CW119_OFFSSTRT_IP (0x2u << 7)
1169#define GMAC_ST2CW119_OFFSSTRT_TCP_UDP (0x3u << 7)
1170/* -------- GMAC_ST2CW020 : (GMAC Offset: 0x7A0) Screening Type 2 Compare Word 0 Register (index = 20) -------- */
1171#define GMAC_ST2CW020_MASKVAL_Pos 0
1172#define GMAC_ST2CW020_MASKVAL_Msk (0xffffu << GMAC_ST2CW020_MASKVAL_Pos)
1173#define GMAC_ST2CW020_MASKVAL(value) ((GMAC_ST2CW020_MASKVAL_Msk & ((value) << GMAC_ST2CW020_MASKVAL_Pos)))
1174#define GMAC_ST2CW020_COMPVAL_Pos 16
1175#define GMAC_ST2CW020_COMPVAL_Msk (0xffffu << GMAC_ST2CW020_COMPVAL_Pos)
1176#define GMAC_ST2CW020_COMPVAL(value) ((GMAC_ST2CW020_COMPVAL_Msk & ((value) << GMAC_ST2CW020_COMPVAL_Pos)))
1177/* -------- GMAC_ST2CW120 : (GMAC Offset: 0x7A4) Screening Type 2 Compare Word 1 Register (index = 20) -------- */
1178#define GMAC_ST2CW120_OFFSVAL_Pos 0
1179#define GMAC_ST2CW120_OFFSVAL_Msk (0x7fu << GMAC_ST2CW120_OFFSVAL_Pos)
1180#define GMAC_ST2CW120_OFFSVAL(value) ((GMAC_ST2CW120_OFFSVAL_Msk & ((value) << GMAC_ST2CW120_OFFSVAL_Pos)))
1181#define GMAC_ST2CW120_OFFSSTRT_Pos 7
1182#define GMAC_ST2CW120_OFFSSTRT_Msk (0x3u << GMAC_ST2CW120_OFFSSTRT_Pos)
1183#define GMAC_ST2CW120_OFFSSTRT(value) ((GMAC_ST2CW120_OFFSSTRT_Msk & ((value) << GMAC_ST2CW120_OFFSSTRT_Pos)))
1184#define GMAC_ST2CW120_OFFSSTRT_FRAMESTART (0x0u << 7)
1185#define GMAC_ST2CW120_OFFSSTRT_ETHERTYPE (0x1u << 7)
1186#define GMAC_ST2CW120_OFFSSTRT_IP (0x2u << 7)
1187#define GMAC_ST2CW120_OFFSSTRT_TCP_UDP (0x3u << 7)
1188/* -------- GMAC_ST2CW021 : (GMAC Offset: 0x7A8) Screening Type 2 Compare Word 0 Register (index = 21) -------- */
1189#define GMAC_ST2CW021_MASKVAL_Pos 0
1190#define GMAC_ST2CW021_MASKVAL_Msk (0xffffu << GMAC_ST2CW021_MASKVAL_Pos)
1191#define GMAC_ST2CW021_MASKVAL(value) ((GMAC_ST2CW021_MASKVAL_Msk & ((value) << GMAC_ST2CW021_MASKVAL_Pos)))
1192#define GMAC_ST2CW021_COMPVAL_Pos 16
1193#define GMAC_ST2CW021_COMPVAL_Msk (0xffffu << GMAC_ST2CW021_COMPVAL_Pos)
1194#define GMAC_ST2CW021_COMPVAL(value) ((GMAC_ST2CW021_COMPVAL_Msk & ((value) << GMAC_ST2CW021_COMPVAL_Pos)))
1195/* -------- GMAC_ST2CW121 : (GMAC Offset: 0x7AC) Screening Type 2 Compare Word 1 Register (index = 21) -------- */
1196#define GMAC_ST2CW121_OFFSVAL_Pos 0
1197#define GMAC_ST2CW121_OFFSVAL_Msk (0x7fu << GMAC_ST2CW121_OFFSVAL_Pos)
1198#define GMAC_ST2CW121_OFFSVAL(value) ((GMAC_ST2CW121_OFFSVAL_Msk & ((value) << GMAC_ST2CW121_OFFSVAL_Pos)))
1199#define GMAC_ST2CW121_OFFSSTRT_Pos 7
1200#define GMAC_ST2CW121_OFFSSTRT_Msk (0x3u << GMAC_ST2CW121_OFFSSTRT_Pos)
1201#define GMAC_ST2CW121_OFFSSTRT(value) ((GMAC_ST2CW121_OFFSSTRT_Msk & ((value) << GMAC_ST2CW121_OFFSSTRT_Pos)))
1202#define GMAC_ST2CW121_OFFSSTRT_FRAMESTART (0x0u << 7)
1203#define GMAC_ST2CW121_OFFSSTRT_ETHERTYPE (0x1u << 7)
1204#define GMAC_ST2CW121_OFFSSTRT_IP (0x2u << 7)
1205#define GMAC_ST2CW121_OFFSSTRT_TCP_UDP (0x3u << 7)
1206/* -------- GMAC_ST2CW022 : (GMAC Offset: 0x7B0) Screening Type 2 Compare Word 0 Register (index = 22) -------- */
1207#define GMAC_ST2CW022_MASKVAL_Pos 0
1208#define GMAC_ST2CW022_MASKVAL_Msk (0xffffu << GMAC_ST2CW022_MASKVAL_Pos)
1209#define GMAC_ST2CW022_MASKVAL(value) ((GMAC_ST2CW022_MASKVAL_Msk & ((value) << GMAC_ST2CW022_MASKVAL_Pos)))
1210#define GMAC_ST2CW022_COMPVAL_Pos 16
1211#define GMAC_ST2CW022_COMPVAL_Msk (0xffffu << GMAC_ST2CW022_COMPVAL_Pos)
1212#define GMAC_ST2CW022_COMPVAL(value) ((GMAC_ST2CW022_COMPVAL_Msk & ((value) << GMAC_ST2CW022_COMPVAL_Pos)))
1213/* -------- GMAC_ST2CW122 : (GMAC Offset: 0x7B4) Screening Type 2 Compare Word 1 Register (index = 22) -------- */
1214#define GMAC_ST2CW122_OFFSVAL_Pos 0
1215#define GMAC_ST2CW122_OFFSVAL_Msk (0x7fu << GMAC_ST2CW122_OFFSVAL_Pos)
1216#define GMAC_ST2CW122_OFFSVAL(value) ((GMAC_ST2CW122_OFFSVAL_Msk & ((value) << GMAC_ST2CW122_OFFSVAL_Pos)))
1217#define GMAC_ST2CW122_OFFSSTRT_Pos 7
1218#define GMAC_ST2CW122_OFFSSTRT_Msk (0x3u << GMAC_ST2CW122_OFFSSTRT_Pos)
1219#define GMAC_ST2CW122_OFFSSTRT(value) ((GMAC_ST2CW122_OFFSSTRT_Msk & ((value) << GMAC_ST2CW122_OFFSSTRT_Pos)))
1220#define GMAC_ST2CW122_OFFSSTRT_FRAMESTART (0x0u << 7)
1221#define GMAC_ST2CW122_OFFSSTRT_ETHERTYPE (0x1u << 7)
1222#define GMAC_ST2CW122_OFFSSTRT_IP (0x2u << 7)
1223#define GMAC_ST2CW122_OFFSSTRT_TCP_UDP (0x3u << 7)
1224/* -------- GMAC_ST2CW023 : (GMAC Offset: 0x7B8) Screening Type 2 Compare Word 0 Register (index = 23) -------- */
1225#define GMAC_ST2CW023_MASKVAL_Pos 0
1226#define GMAC_ST2CW023_MASKVAL_Msk (0xffffu << GMAC_ST2CW023_MASKVAL_Pos)
1227#define GMAC_ST2CW023_MASKVAL(value) ((GMAC_ST2CW023_MASKVAL_Msk & ((value) << GMAC_ST2CW023_MASKVAL_Pos)))
1228#define GMAC_ST2CW023_COMPVAL_Pos 16
1229#define GMAC_ST2CW023_COMPVAL_Msk (0xffffu << GMAC_ST2CW023_COMPVAL_Pos)
1230#define GMAC_ST2CW023_COMPVAL(value) ((GMAC_ST2CW023_COMPVAL_Msk & ((value) << GMAC_ST2CW023_COMPVAL_Pos)))
1231/* -------- GMAC_ST2CW123 : (GMAC Offset: 0x7BC) Screening Type 2 Compare Word 1 Register (index = 23) -------- */
1232#define GMAC_ST2CW123_OFFSVAL_Pos 0
1233#define GMAC_ST2CW123_OFFSVAL_Msk (0x7fu << GMAC_ST2CW123_OFFSVAL_Pos)
1234#define GMAC_ST2CW123_OFFSVAL(value) ((GMAC_ST2CW123_OFFSVAL_Msk & ((value) << GMAC_ST2CW123_OFFSVAL_Pos)))
1235#define GMAC_ST2CW123_OFFSSTRT_Pos 7
1236#define GMAC_ST2CW123_OFFSSTRT_Msk (0x3u << GMAC_ST2CW123_OFFSSTRT_Pos)
1237#define GMAC_ST2CW123_OFFSSTRT(value) ((GMAC_ST2CW123_OFFSSTRT_Msk & ((value) << GMAC_ST2CW123_OFFSSTRT_Pos)))
1238#define GMAC_ST2CW123_OFFSSTRT_FRAMESTART (0x0u << 7)
1239#define GMAC_ST2CW123_OFFSSTRT_ETHERTYPE (0x1u << 7)
1240#define GMAC_ST2CW123_OFFSSTRT_IP (0x2u << 7)
1241#define GMAC_ST2CW123_OFFSSTRT_TCP_UDP (0x3u << 7)
1244
1245
1246#endif /* _SAMV71_GMAC_COMPONENT_ */
#define __O
Definition: core_cm7.h:286
#define __IO
Definition: core_cm7.h:287
#define __I
Definition: core_cm7.h:284
GmacSa hardware registers.
Definition: component_gmac.h:41
GmacSt2Compare hardware registers.
Definition: component_gmac.h:47
Definition: component_gmac.h:55
__I uint32_t GMAC_MID
(Gmac Offset: 0x0FC) Module ID Register
Definition: component_gmac.h:98
