RTEMS 5.2
component_chipid.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_CHIPID_COMPONENT_
31#define _SAMV71_CHIPID_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __I uint32_t CHIPID_CIDR;
43 __I uint32_t CHIPID_EXID;
44} Chipid;
45#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
46/* -------- CHIPID_CIDR : (CHIPID Offset: 0x0) Chip ID Register -------- */
47#define CHIPID_CIDR_VERSION_Pos 0
48#define CHIPID_CIDR_VERSION_Msk (0x1fu << CHIPID_CIDR_VERSION_Pos)
49#define CHIPID_CIDR_EPROC_Pos 5
50#define CHIPID_CIDR_EPROC_Msk (0x7u << CHIPID_CIDR_EPROC_Pos)
51#define CHIPID_CIDR_EPROC_SAMx7 (0x0u << 5)
52#define CHIPID_CIDR_EPROC_ARM946ES (0x1u << 5)
53#define CHIPID_CIDR_EPROC_ARM7TDMI (0x2u << 5)
54#define CHIPID_CIDR_EPROC_CM3 (0x3u << 5)
55#define CHIPID_CIDR_EPROC_ARM920T (0x4u << 5)
56#define CHIPID_CIDR_EPROC_ARM926EJS (0x5u << 5)
57#define CHIPID_CIDR_EPROC_CA5 (0x6u << 5)
58#define CHIPID_CIDR_EPROC_CM4 (0x7u << 5)
59#define CHIPID_CIDR_NVPSIZ_Pos 8
60#define CHIPID_CIDR_NVPSIZ_Msk (0xfu << CHIPID_CIDR_NVPSIZ_Pos)
61#define CHIPID_CIDR_NVPSIZ_NONE (0x0u << 8)
62#define CHIPID_CIDR_NVPSIZ_8K (0x1u << 8)
63#define CHIPID_CIDR_NVPSIZ_16K (0x2u << 8)
64#define CHIPID_CIDR_NVPSIZ_32K (0x3u << 8)
65#define CHIPID_CIDR_NVPSIZ_64K (0x5u << 8)
66#define CHIPID_CIDR_NVPSIZ_128K (0x7u << 8)
67#define CHIPID_CIDR_NVPSIZ_160K (0x8u << 8)
68#define CHIPID_CIDR_NVPSIZ_256K (0x9u << 8)
69#define CHIPID_CIDR_NVPSIZ_512K (0xAu << 8)
70#define CHIPID_CIDR_NVPSIZ_1024K (0xCu << 8)
71#define CHIPID_CIDR_NVPSIZ_2048K (0xEu << 8)
72#define CHIPID_CIDR_NVPSIZ2_Pos 12
73#define CHIPID_CIDR_NVPSIZ2_Msk (0xfu << CHIPID_CIDR_NVPSIZ2_Pos)
74#define CHIPID_CIDR_NVPSIZ2_NONE (0x0u << 12)
75#define CHIPID_CIDR_NVPSIZ2_8K (0x1u << 12)
76#define CHIPID_CIDR_NVPSIZ2_16K (0x2u << 12)
77#define CHIPID_CIDR_NVPSIZ2_32K (0x3u << 12)
78#define CHIPID_CIDR_NVPSIZ2_64K (0x5u << 12)
79#define CHIPID_CIDR_NVPSIZ2_128K (0x7u << 12)
80#define CHIPID_CIDR_NVPSIZ2_256K (0x9u << 12)
81#define CHIPID_CIDR_NVPSIZ2_512K (0xAu << 12)
82#define CHIPID_CIDR_NVPSIZ2_1024K (0xCu << 12)
83#define CHIPID_CIDR_NVPSIZ2_2048K (0xEu << 12)
84#define CHIPID_CIDR_SRAMSIZ_Pos 16
85#define CHIPID_CIDR_SRAMSIZ_Msk (0xfu << CHIPID_CIDR_SRAMSIZ_Pos)
86#define CHIPID_CIDR_SRAMSIZ_48K (0x0u << 16)
87#define CHIPID_CIDR_SRAMSIZ_192K (0x1u << 16)
88#define CHIPID_CIDR_SRAMSIZ_384K (0x2u << 16)
89#define CHIPID_CIDR_SRAMSIZ_6K (0x3u << 16)
90#define CHIPID_CIDR_SRAMSIZ_24K (0x4u << 16)
91#define CHIPID_CIDR_SRAMSIZ_4K (0x5u << 16)
92#define CHIPID_CIDR_SRAMSIZ_80K (0x6u << 16)
93#define CHIPID_CIDR_SRAMSIZ_160K (0x7u << 16)
94#define CHIPID_CIDR_SRAMSIZ_8K (0x8u << 16)
95#define CHIPID_CIDR_SRAMSIZ_16K (0x9u << 16)
96#define CHIPID_CIDR_SRAMSIZ_32K (0xAu << 16)
97#define CHIPID_CIDR_SRAMSIZ_64K (0xBu << 16)
98#define CHIPID_CIDR_SRAMSIZ_128K (0xCu << 16)
99#define CHIPID_CIDR_SRAMSIZ_256K (0xDu << 16)
100#define CHIPID_CIDR_SRAMSIZ_96K (0xEu << 16)
101#define CHIPID_CIDR_SRAMSIZ_512K (0xFu << 16)
102#define CHIPID_CIDR_ARCH_Pos 20
103#define CHIPID_CIDR_ARCH_Msk (0xffu << CHIPID_CIDR_ARCH_Pos)
104#define CHIPID_CIDR_ARCH_SAME70 (0x10u << 20)
105#define CHIPID_CIDR_ARCH_SAMS70 (0x11u << 20)
106#define CHIPID_CIDR_ARCH_SAMV71 (0x12u << 20)
107#define CHIPID_CIDR_ARCH_SAMV70 (0x13u << 20)
108#define CHIPID_CIDR_NVPTYP_Pos 28
109#define CHIPID_CIDR_NVPTYP_Msk (0x7u << CHIPID_CIDR_NVPTYP_Pos)
110#define CHIPID_CIDR_NVPTYP_ROM (0x0u << 28)
111#define CHIPID_CIDR_NVPTYP_ROMLESS (0x1u << 28)
112#define CHIPID_CIDR_NVPTYP_FLASH (0x2u << 28)
113#define CHIPID_CIDR_NVPTYP_ROM_FLASH (0x3u << 28)
114#define CHIPID_CIDR_NVPTYP_SRAM (0x4u << 28)
115#define CHIPID_CIDR_EXT (0x1u << 31)
116/* -------- CHIPID_EXID : (CHIPID Offset: 0x4) Chip ID Extension Register -------- */
117#define CHIPID_EXID_EXID_Pos 0
118#define CHIPID_EXID_EXID_Msk (0xffffffffu << CHIPID_EXID_EXID_Pos)
121
122
123#endif /* _SAMV71_CHIPID_COMPONENT_ */
#define __I
Definition: core_cm7.h:284
Chipid hardware registers.
Definition: component_chipid.h:41
