RTEMS 5.2
same70.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAME70_
31#define _SAME70_
32
33#if defined __SAME70J19__
34 #include "same70j19.h"
35#elif defined __SAME70J20__
36 #include "same70j20.h"
37#elif defined __SAME70J21__
38 #include "same70j21.h"
39#elif defined __SAME70N19__
40 #include "same70n19.h"
41#elif defined __SAME70N20__
42 #include "same70n20.h"
43#elif defined __SAME70N21__
44 #include "same70n21.h"
45#elif defined __SAME70Q19__
46 #include "same70q19.h"
47#elif defined __SAME70Q20__
48 #include "same70q20.h"
49#elif defined __SAME70Q21__
50 #include "same70q21.h"
51#else
52 #error Library does not support the specified device.
53#endif
54
55#endif /* _SAME70_ */
