RTEMS 5.2
component_smc.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAME70_SMC_COMPONENT_
31#define _SAME70_SMC_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __IO uint32_t SMC_SETUP;
43 __IO uint32_t SMC_PULSE;
44 __IO uint32_t SMC_CYCLE;
45 __IO uint32_t SMC_MODE;
48#define SMCCS_NUMBER_NUMBER 4
49typedef struct {
50 SmcCs_number SMC_CS_NUMBER[SMCCS_NUMBER_NUMBER];
51 __I uint32_t Reserved1[16];
52 __IO uint32_t SMC_OCMS;
53 __O uint32_t SMC_KEY1;
54 __O uint32_t SMC_KEY2;
55 __I uint32_t Reserved2[22];
56 __IO uint32_t SMC_WPMR;
57 __I uint32_t SMC_WPSR;
58} Smc;
59#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
60/* -------- SMC_SETUP : (SMC Offset: N/A) SMC Setup Register -------- */
61#define SMC_SETUP_NWE_SETUP_Pos 0
62#define SMC_SETUP_NWE_SETUP_Msk (0x3fu << SMC_SETUP_NWE_SETUP_Pos)
63#define SMC_SETUP_NWE_SETUP(value) ((SMC_SETUP_NWE_SETUP_Msk & ((value) << SMC_SETUP_NWE_SETUP_Pos)))
64#define SMC_SETUP_NCS_WR_SETUP_Pos 8
65#define SMC_SETUP_NCS_WR_SETUP_Msk (0x3fu << SMC_SETUP_NCS_WR_SETUP_Pos)
66#define SMC_SETUP_NCS_WR_SETUP(value) ((SMC_SETUP_NCS_WR_SETUP_Msk & ((value) << SMC_SETUP_NCS_WR_SETUP_Pos)))
67#define SMC_SETUP_NRD_SETUP_Pos 16
68#define SMC_SETUP_NRD_SETUP_Msk (0x3fu << SMC_SETUP_NRD_SETUP_Pos)
69#define SMC_SETUP_NRD_SETUP(value) ((SMC_SETUP_NRD_SETUP_Msk & ((value) << SMC_SETUP_NRD_SETUP_Pos)))
70#define SMC_SETUP_NCS_RD_SETUP_Pos 24
71#define SMC_SETUP_NCS_RD_SETUP_Msk (0x3fu << SMC_SETUP_NCS_RD_SETUP_Pos)
72#define SMC_SETUP_NCS_RD_SETUP(value) ((SMC_SETUP_NCS_RD_SETUP_Msk & ((value) << SMC_SETUP_NCS_RD_SETUP_Pos)))
73/* -------- SMC_PULSE : (SMC Offset: N/A) SMC Pulse Register -------- */
74#define SMC_PULSE_NWE_PULSE_Pos 0
75#define SMC_PULSE_NWE_PULSE_Msk (0x7fu << SMC_PULSE_NWE_PULSE_Pos)
76#define SMC_PULSE_NWE_PULSE(value) ((SMC_PULSE_NWE_PULSE_Msk & ((value) << SMC_PULSE_NWE_PULSE_Pos)))
77#define SMC_PULSE_NCS_WR_PULSE_Pos 8
78#define SMC_PULSE_NCS_WR_PULSE_Msk (0x7fu << SMC_PULSE_NCS_WR_PULSE_Pos)
79#define SMC_PULSE_NCS_WR_PULSE(value) ((SMC_PULSE_NCS_WR_PULSE_Msk & ((value) << SMC_PULSE_NCS_WR_PULSE_Pos)))
80#define SMC_PULSE_NRD_PULSE_Pos 16
81#define SMC_PULSE_NRD_PULSE_Msk (0x7fu << SMC_PULSE_NRD_PULSE_Pos)
82#define SMC_PULSE_NRD_PULSE(value) ((SMC_PULSE_NRD_PULSE_Msk & ((value) << SMC_PULSE_NRD_PULSE_Pos)))
83#define SMC_PULSE_NCS_RD_PULSE_Pos 24
84#define SMC_PULSE_NCS_RD_PULSE_Msk (0x7fu << SMC_PULSE_NCS_RD_PULSE_Pos)
85#define SMC_PULSE_NCS_RD_PULSE(value) ((SMC_PULSE_NCS_RD_PULSE_Msk & ((value) << SMC_PULSE_NCS_RD_PULSE_Pos)))
86/* -------- SMC_CYCLE : (SMC Offset: N/A) SMC Cycle Register -------- */
87#define SMC_CYCLE_NWE_CYCLE_Pos 0
88#define SMC_CYCLE_NWE_CYCLE_Msk (0x1ffu << SMC_CYCLE_NWE_CYCLE_Pos)
89#define SMC_CYCLE_NWE_CYCLE(value) ((SMC_CYCLE_NWE_CYCLE_Msk & ((value) << SMC_CYCLE_NWE_CYCLE_Pos)))
90#define SMC_CYCLE_NRD_CYCLE_Pos 16
91#define SMC_CYCLE_NRD_CYCLE_Msk (0x1ffu << SMC_CYCLE_NRD_CYCLE_Pos)
92#define SMC_CYCLE_NRD_CYCLE(value) ((SMC_CYCLE_NRD_CYCLE_Msk & ((value) << SMC_CYCLE_NRD_CYCLE_Pos)))
93/* -------- SMC_MODE : (SMC Offset: N/A) SMC MODE Register -------- */
94#define SMC_MODE_READ_MODE (0x1u << 0)
95#define SMC_MODE_WRITE_MODE (0x1u << 1)
96#define SMC_MODE_EXNW_MODE_Pos 4
97#define SMC_MODE_EXNW_MODE_Msk (0x3u << SMC_MODE_EXNW_MODE_Pos)
98#define SMC_MODE_EXNW_MODE(value) ((SMC_MODE_EXNW_MODE_Msk & ((value) << SMC_MODE_EXNW_MODE_Pos)))
99#define SMC_MODE_EXNW_MODE_DISABLED (0x0u << 4)
100#define SMC_MODE_EXNW_MODE_FROZEN (0x2u << 4)
101#define SMC_MODE_EXNW_MODE_READY (0x3u << 4)
102#define SMC_MODE_BAT (0x1u << 8)
103#define SMC_MODE_BAT_BYTE_SELECT (0x0u << 8)
104#define SMC_MODE_BAT_BYTE_WRITE (0x1u << 8)
105#define SMC_MODE_DBW (0x1u << 12)
106#define SMC_MODE_DBW_8_BIT (0x0u << 12)
107#define SMC_MODE_DBW_16_BIT (0x1u << 12)
108#define SMC_MODE_TDF_CYCLES_Pos 16
109#define SMC_MODE_TDF_CYCLES_Msk (0xfu << SMC_MODE_TDF_CYCLES_Pos)
110#define SMC_MODE_TDF_CYCLES(value) ((SMC_MODE_TDF_CYCLES_Msk & ((value) << SMC_MODE_TDF_CYCLES_Pos)))
111#define SMC_MODE_TDF_MODE (0x1u << 20)
112#define SMC_MODE_PMEN (0x1u << 24)
113#define SMC_MODE_PS_Pos 28
114#define SMC_MODE_PS_Msk (0x3u << SMC_MODE_PS_Pos)
115#define SMC_MODE_PS(value) ((SMC_MODE_PS_Msk & ((value) << SMC_MODE_PS_Pos)))
116#define SMC_MODE_PS_4_BYTE (0x0u << 28)
117#define SMC_MODE_PS_8_BYTE (0x1u << 28)
118#define SMC_MODE_PS_16_BYTE (0x2u << 28)
119#define SMC_MODE_PS_32_BYTE (0x3u << 28)
120/* -------- SMC_OCMS : (SMC Offset: 0x80) SMC OCMS MODE Register -------- */
121#define SMC_OCMS_SMSE (0x1u << 0)
122/* -------- SMC_KEY1 : (SMC Offset: 0x84) SMC OCMS KEY1 Register -------- */
123#define SMC_KEY1_KEY1_Pos 0
124#define SMC_KEY1_KEY1_Msk (0xffffffffu << SMC_KEY1_KEY1_Pos)
125#define SMC_KEY1_KEY1(value) ((SMC_KEY1_KEY1_Msk & ((value) << SMC_KEY1_KEY1_Pos)))
126/* -------- SMC_KEY2 : (SMC Offset: 0x88) SMC OCMS KEY2 Register -------- */
127#define SMC_KEY2_KEY2_Pos 0
128#define SMC_KEY2_KEY2_Msk (0xffffffffu << SMC_KEY2_KEY2_Pos)
129#define SMC_KEY2_KEY2(value) ((SMC_KEY2_KEY2_Msk & ((value) << SMC_KEY2_KEY2_Pos)))
130/* -------- SMC_WPMR : (SMC Offset: 0xE4) SMC Write Protection Mode Register -------- */
131#define SMC_WPMR_WPEN (0x1u << 0)
132#define SMC_WPMR_WPKEY_Pos 8
133#define SMC_WPMR_WPKEY_Msk (0xffffffu << SMC_WPMR_WPKEY_Pos)
134#define SMC_WPMR_WPKEY(value) ((SMC_WPMR_WPKEY_Msk & ((value) << SMC_WPMR_WPKEY_Pos)))
135#define SMC_WPMR_WPKEY_PASSWD (0x534D43u << 8)
136/* -------- SMC_WPSR : (SMC Offset: 0xE8) SMC Write Protection Status Register -------- */
137#define SMC_WPSR_WPVS (0x1u << 0)
138#define SMC_WPSR_WPVSRC_Pos 8
139#define SMC_WPSR_WPVSRC_Msk (0xffffu << SMC_WPSR_WPVSRC_Pos)
142
143
144#endif /* _SAME70_SMC_COMPONENT_ */
#define __O
Definition: core_cm7.h:286
#define __IO
Definition: core_cm7.h:287
#define __I
Definition: core_cm7.h:284
SmcCs_number hardware registers.
Definition: component_smc.h:41
(SmcCs_number Offset: 0x8) SMC Cycle Register
Definition: component_smc.h:44
(SmcCs_number Offset: 0x0) SMC Setup Register
Definition: component_smc.h:42
(SmcCs_number Offset: 0xC) SMC MODE Register
Definition: component_smc.h:45
(SmcCs_number Offset: 0x4) SMC Pulse Register
Definition: component_smc.h:43
Definition: component_smc.h:49
(Smc Offset: 0x80) SMC OCMS MODE Register
Definition: component_smc.h:52
(Smc Offset: 0xE4) SMC Write Protection Mode Register
Definition: component_smc.h:56
(Smc Offset: 0x88) SMC OCMS KEY2 Register
Definition: component_smc.h:54
(Smc Offset: 0x84) SMC OCMS KEY1 Register
Definition: component_smc.h:53
(Smc Offset: 0xE8) SMC Write Protection Status Register
Definition: component_smc.h:57
