RTEMS 5.2
component_icm.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAME70_ICM_COMPONENT_
31#define _SAME70_ICM_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __IO uint32_t ICM_CFG;
43 __O uint32_t ICM_CTRL;
44 __O uint32_t ICM_SR;
45 __I uint32_t Reserved1[1];
46 __O uint32_t ICM_IER;
47 __O uint32_t ICM_IDR;
48 __I uint32_t ICM_IMR;
49 __I uint32_t ICM_ISR;
50 __I uint32_t ICM_UASR;
51 __I uint32_t Reserved2[3];
52 __IO uint32_t ICM_DSCR;
53 __IO uint32_t ICM_HASH;
54 __O uint32_t ICM_UIHVAL[8];
55} Icm;
56#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
57/* -------- ICM_CFG : (ICM Offset: 0x00) Configuration Register -------- */
58#define ICM_CFG_WBDIS (0x1u << 0)
59#define ICM_CFG_EOMDIS (0x1u << 1)
60#define ICM_CFG_SLBDIS (0x1u << 2)
61#define ICM_CFG_BBC_Pos 4
62#define ICM_CFG_BBC_Msk (0xfu << ICM_CFG_BBC_Pos)
63#define ICM_CFG_BBC(value) ((ICM_CFG_BBC_Msk & ((value) << ICM_CFG_BBC_Pos)))
64#define ICM_CFG_ASCD (0x1u << 8)
65#define ICM_CFG_DUALBUFF (0x1u << 9)
66#define ICM_CFG_UIHASH (0x1u << 12)
67#define ICM_CFG_UALGO_Pos 13
68#define ICM_CFG_UALGO_Msk (0x7u << ICM_CFG_UALGO_Pos)
69#define ICM_CFG_UALGO(value) ((ICM_CFG_UALGO_Msk & ((value) << ICM_CFG_UALGO_Pos)))
70#define ICM_CFG_UALGO_SHA1 (0x0u << 13)
71#define ICM_CFG_UALGO_SHA256 (0x1u << 13)
72#define ICM_CFG_UALGO_SHA224 (0x4u << 13)
73#define ICM_CFG_HAPROT_Pos 16
74#define ICM_CFG_HAPROT_Msk (0x3fu << ICM_CFG_HAPROT_Pos)
75#define ICM_CFG_HAPROT(value) ((ICM_CFG_HAPROT_Msk & ((value) << ICM_CFG_HAPROT_Pos)))
76#define ICM_CFG_DAPROT_Pos 24
77#define ICM_CFG_DAPROT_Msk (0x3fu << ICM_CFG_DAPROT_Pos)
78#define ICM_CFG_DAPROT(value) ((ICM_CFG_DAPROT_Msk & ((value) << ICM_CFG_DAPROT_Pos)))
79/* -------- ICM_CTRL : (ICM Offset: 0x04) Control Register -------- */
80#define ICM_CTRL_ENABLE (0x1u << 0)
81#define ICM_CTRL_DISABLE (0x1u << 1)
82#define ICM_CTRL_SWRST (0x1u << 2)
83#define ICM_CTRL_REHASH_Pos 4
84#define ICM_CTRL_REHASH_Msk (0xfu << ICM_CTRL_REHASH_Pos)
85#define ICM_CTRL_REHASH(value) ((ICM_CTRL_REHASH_Msk & ((value) << ICM_CTRL_REHASH_Pos)))
86#define ICM_CTRL_RMDIS_Pos 8
87#define ICM_CTRL_RMDIS_Msk (0xfu << ICM_CTRL_RMDIS_Pos)
88#define ICM_CTRL_RMDIS(value) ((ICM_CTRL_RMDIS_Msk & ((value) << ICM_CTRL_RMDIS_Pos)))
89#define ICM_CTRL_RMEN_Pos 12
90#define ICM_CTRL_RMEN_Msk (0xfu << ICM_CTRL_RMEN_Pos)
91#define ICM_CTRL_RMEN(value) ((ICM_CTRL_RMEN_Msk & ((value) << ICM_CTRL_RMEN_Pos)))
92/* -------- ICM_SR : (ICM Offset: 0x08) Status Register -------- */
93#define ICM_SR_ENABLE (0x1u << 0)
94#define ICM_SR_RAWRMDIS_Pos 8
95#define ICM_SR_RAWRMDIS_Msk (0xfu << ICM_SR_RAWRMDIS_Pos)
96#define ICM_SR_RAWRMDIS(value) ((ICM_SR_RAWRMDIS_Msk & ((value) << ICM_SR_RAWRMDIS_Pos)))
97#define ICM_SR_RMDIS_Pos 12
98#define ICM_SR_RMDIS_Msk (0xfu << ICM_SR_RMDIS_Pos)
99#define ICM_SR_RMDIS(value) ((ICM_SR_RMDIS_Msk & ((value) << ICM_SR_RMDIS_Pos)))
100/* -------- ICM_IER : (ICM Offset: 0x10) Interrupt Enable Register -------- */
101#define ICM_IER_RHC_Pos 0
102#define ICM_IER_RHC_Msk (0xfu << ICM_IER_RHC_Pos)
103#define ICM_IER_RHC(value) ((ICM_IER_RHC_Msk & ((value) << ICM_IER_RHC_Pos)))
104#define ICM_IER_RDM_Pos 4
105#define ICM_IER_RDM_Msk (0xfu << ICM_IER_RDM_Pos)
106#define ICM_IER_RDM(value) ((ICM_IER_RDM_Msk & ((value) << ICM_IER_RDM_Pos)))
107#define ICM_IER_RBE_Pos 8
108#define ICM_IER_RBE_Msk (0xfu << ICM_IER_RBE_Pos)
109#define ICM_IER_RBE(value) ((ICM_IER_RBE_Msk & ((value) << ICM_IER_RBE_Pos)))
110#define ICM_IER_RWC_Pos 12
111#define ICM_IER_RWC_Msk (0xfu << ICM_IER_RWC_Pos)
112#define ICM_IER_RWC(value) ((ICM_IER_RWC_Msk & ((value) << ICM_IER_RWC_Pos)))
113#define ICM_IER_REC_Pos 16
114#define ICM_IER_REC_Msk (0xfu << ICM_IER_REC_Pos)
115#define ICM_IER_REC(value) ((ICM_IER_REC_Msk & ((value) << ICM_IER_REC_Pos)))
116#define ICM_IER_RSU_Pos 20
117#define ICM_IER_RSU_Msk (0xfu << ICM_IER_RSU_Pos)
118#define ICM_IER_RSU(value) ((ICM_IER_RSU_Msk & ((value) << ICM_IER_RSU_Pos)))
119#define ICM_IER_URAD (0x1u << 24)
120/* -------- ICM_IDR : (ICM Offset: 0x14) Interrupt Disable Register -------- */
121#define ICM_IDR_RHC_Pos 0
122#define ICM_IDR_RHC_Msk (0xfu << ICM_IDR_RHC_Pos)
123#define ICM_IDR_RHC(value) ((ICM_IDR_RHC_Msk & ((value) << ICM_IDR_RHC_Pos)))
124#define ICM_IDR_RDM_Pos 4
125#define ICM_IDR_RDM_Msk (0xfu << ICM_IDR_RDM_Pos)
126#define ICM_IDR_RDM(value) ((ICM_IDR_RDM_Msk & ((value) << ICM_IDR_RDM_Pos)))
127#define ICM_IDR_RBE_Pos 8
128#define ICM_IDR_RBE_Msk (0xfu << ICM_IDR_RBE_Pos)
129#define ICM_IDR_RBE(value) ((ICM_IDR_RBE_Msk & ((value) << ICM_IDR_RBE_Pos)))
130#define ICM_IDR_RWC_Pos 12
131#define ICM_IDR_RWC_Msk (0xfu << ICM_IDR_RWC_Pos)
132#define ICM_IDR_RWC(value) ((ICM_IDR_RWC_Msk & ((value) << ICM_IDR_RWC_Pos)))
133#define ICM_IDR_REC_Pos 16
134#define ICM_IDR_REC_Msk (0xfu << ICM_IDR_REC_Pos)
135#define ICM_IDR_REC(value) ((ICM_IDR_REC_Msk & ((value) << ICM_IDR_REC_Pos)))
136#define ICM_IDR_RSU_Pos 20
137#define ICM_IDR_RSU_Msk (0xfu << ICM_IDR_RSU_Pos)
138#define ICM_IDR_RSU(value) ((ICM_IDR_RSU_Msk & ((value) << ICM_IDR_RSU_Pos)))
139#define ICM_IDR_URAD (0x1u << 24)
140/* -------- ICM_IMR : (ICM Offset: 0x18) Interrupt Mask Register -------- */
141#define ICM_IMR_RHC_Pos 0
142#define ICM_IMR_RHC_Msk (0xfu << ICM_IMR_RHC_Pos)
143#define ICM_IMR_RDM_Pos 4
144#define ICM_IMR_RDM_Msk (0xfu << ICM_IMR_RDM_Pos)
145#define ICM_IMR_RBE_Pos 8
146#define ICM_IMR_RBE_Msk (0xfu << ICM_IMR_RBE_Pos)
147#define ICM_IMR_RWC_Pos 12
148#define ICM_IMR_RWC_Msk (0xfu << ICM_IMR_RWC_Pos)
149#define ICM_IMR_REC_Pos 16
150#define ICM_IMR_REC_Msk (0xfu << ICM_IMR_REC_Pos)
151#define ICM_IMR_RSU_Pos 20
152#define ICM_IMR_RSU_Msk (0xfu << ICM_IMR_RSU_Pos)
153#define ICM_IMR_URAD (0x1u << 24)
154/* -------- ICM_ISR : (ICM Offset: 0x1C) Interrupt Status Register -------- */
155#define ICM_ISR_RHC_Pos 0
156#define ICM_ISR_RHC_Msk (0xfu << ICM_ISR_RHC_Pos)
157#define ICM_ISR_RDM_Pos 4
158#define ICM_ISR_RDM_Msk (0xfu << ICM_ISR_RDM_Pos)
159#define ICM_ISR_RBE_Pos 8
160#define ICM_ISR_RBE_Msk (0xfu << ICM_ISR_RBE_Pos)
161#define ICM_ISR_RWC_Pos 12
162#define ICM_ISR_RWC_Msk (0xfu << ICM_ISR_RWC_Pos)
163#define ICM_ISR_REC_Pos 16
164#define ICM_ISR_REC_Msk (0xfu << ICM_ISR_REC_Pos)
165#define ICM_ISR_RSU_Pos 20
166#define ICM_ISR_RSU_Msk (0xfu << ICM_ISR_RSU_Pos)
167#define ICM_ISR_URAD (0x1u << 24)
168/* -------- ICM_UASR : (ICM Offset: 0x20) Undefined Access Status Register -------- */
169#define ICM_UASR_URAT_Pos 0
170#define ICM_UASR_URAT_Msk (0x7u << ICM_UASR_URAT_Pos)
171#define ICM_UASR_URAT_UNSPEC_STRUCT_MEMBER (0x0u << 0)
172#define ICM_UASR_URAT_ICM_CFG_MODIFIED (0x1u << 0)
173#define ICM_UASR_URAT_ICM_DSCR_MODIFIED (0x2u << 0)
174#define ICM_UASR_URAT_ICM_HASH_MODIFIED (0x3u << 0)
175#define ICM_UASR_URAT_READ_ACCESS (0x4u << 0)
176/* -------- ICM_DSCR : (ICM Offset: 0x30) Region Descriptor Area Start Address Register -------- */
177#define ICM_DSCR_DASA_Pos 6
178#define ICM_DSCR_DASA_Msk (0x3ffffffu << ICM_DSCR_DASA_Pos)
179#define ICM_DSCR_DASA(value) ((ICM_DSCR_DASA_Msk & ((value) << ICM_DSCR_DASA_Pos)))
180/* -------- ICM_HASH : (ICM Offset: 0x34) Region Hash Area Start Address Register -------- */
181#define ICM_HASH_HASA_Pos 7
182#define ICM_HASH_HASA_Msk (0x1ffffffu << ICM_HASH_HASA_Pos)
183#define ICM_HASH_HASA(value) ((ICM_HASH_HASA_Msk & ((value) << ICM_HASH_HASA_Pos)))
184/* -------- ICM_UIHVAL[8] : (ICM Offset: 0x38) User Initial Hash Value 0 Register -------- */
185#define ICM_UIHVAL_VAL_Pos 0
186#define ICM_UIHVAL_VAL_Msk (0xffffffffu << ICM_UIHVAL_VAL_Pos)
187#define ICM_UIHVAL_VAL(value) ((ICM_UIHVAL_VAL_Msk & ((value) << ICM_UIHVAL_VAL_Pos)))
188
192#endif /* _SAME70_ICM_COMPONENT_ */
#define __O
Definition: core_cm7.h:286
#define __IO
Definition: core_cm7.h:287
#define __I
Definition: core_cm7.h:284
Icm hardware registers.
Definition: component_icm.h:41
(Icm Offset: 0x10) Interrupt Enable Register
Definition: component_icm.h:46
(Icm Offset: 0x30) Region Descriptor Area Start Address Register
Definition: component_icm.h:52
(Icm Offset: 0x00) Configuration Register
Definition: component_icm.h:42
(Icm Offset: 0x34) Region Hash Area Start Address Register
Definition: component_icm.h:53
(Icm Offset: 0x14) Interrupt Disable Register
Definition: component_icm.h:47
(Icm Offset: 0x1C) Interrupt Status Register
Definition: component_icm.h:49
(Icm Offset: 0x18) Interrupt Mask Register
Definition: component_icm.h:48
(Icm Offset: 0x04) Control Register
Definition: component_icm.h:43
(Icm Offset: 0x20) Undefined Access Status Register
Definition: component_icm.h:50
__O uint32_t ICM_SR
(Icm Offset: 0x08) Status Register
Definition: component_icm.h:44
