RTEMS 5.2
rtt.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
48#ifndef _RTT_
49#define _RTT_
50
51/*----------------------------------------------------------------------------
52 * Headers
53 *----------------------------------------------------------------------------*/
54
55#include "chip.h"
56
57#include <stdint.h>
58
59/*----------------------------------------------------------------------------
60 * Exported functions
61 *----------------------------------------------------------------------------*/
62
63#ifdef __cplusplus
64extern "C" {
65#endif
66
67extern void RTT_SetPrescaler(Rtt *pRtt, uint16_t wPrescaler);
68
69extern uint32_t RTT_GetTime(Rtt *pRtt);
70
71extern void RTT_EnableIT(Rtt *pRtt, uint32_t dwSources);
72
73extern uint32_t RTT_GetStatus(Rtt *pRtt);
74
75extern void RTT_SetAlarm(Rtt *pRtt, uint32_t dwTime);
76
77#ifdef __cplusplus
78}
79#endif
80
81#endif /* #ifndef RTT_H */
82
Enables the specified RTT interrupt sources.
Definition: rtt.c:107
Configures the RTT to generate an alarm at the given time.
Definition: rtt.c:129
Returns the current value of the RTT timer value.
Definition: rtt.c:96
Returns the status register value of the given RTT.
Definition: rtt.c:118
Changes the prescaler value of the given RTT and restarts it.
Definition: rtt.c:86
Rtt hardware registers.
Definition: component_rtt.h:41
