RTEMS 5.2
rtl-alloc-heap.h
1/*
2 * COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj@rtems.org>
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
16#if !defined (_RTEMS_RTL_ALLOC_HEAP_H_)
17#define _RTEMS_RTL_ALLOC_HEAP_H_
18
20
21#ifdef __cplusplus
22extern "C" {
23#endif /* __cplusplus */
24
40 void** address,
41 size_t size);
42
43#ifdef __cplusplus
44}
45#endif /* __cplusplus */
46
47#endif
void rtems_rtl_alloc_heap(rtems_rtl_alloc_cmd cmd, rtems_rtl_alloc_tag tag, void **address, size_t size)
Definition: rtl-alloc-heap.c:23
RTEMS Run-Time Linker Allocator.
enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag
Definition: rtl-allocator.h:45
rtems_rtl_alloc_cmd
Definition: rtl-allocator.h:50
unsigned size
Definition: tte.h:1
