RTEMS 5.2
rtemspppd.h
1/*
2 * COPYRIGHT (c) 2001, Michael Siers <mikes@poliac.com>.
3 * Poliac Research, Burnsville, Minnesota USA.
4 * COPYRIGHT (c) 2001, On-Line Applications Research Corporation (OAR).
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef RTEMSPPPD_H
12#define RTEMSPPPD_H
13
14#ifdef __cplusplus
15extern "C" {
16#endif /* __cplusplus */
17
18/* define hook function identifiers */
19#define RTEMS_PPPD_LINKUP_HOOK 1
20#define RTEMS_PPPD_LINKDOWN_HOOK 2
21#define RTEMS_PPPD_IPUP_HOOK 3
22#define RTEMS_PPPD_IPDOWN_HOOK 4
23#define RTEMS_PPPD_ERROR_HOOK 5
24#define RTEMS_PPPD_EXIT_HOOK 6
25
26/* define hook function pointer prototype */
27typedef void (*rtems_pppd_hookfunction)(void);
28typedef int (*rtems_pppd_dialerfunction)(int tty, int mode, char *pScript);
29
30
31/* define pppd function prototyes */
32int rtems_pppd_initialize(void);
33int rtems_pppd_terminate(void);
34int rtems_pppd_reset_options(void);
35int rtems_pppd_set_hook(int id, rtems_pppd_hookfunction hookfp);
36int rtems_pppd_set_dialer(rtems_pppd_dialerfunction dialerfp);
37int rtems_pppd_set_option(const char *pOption, const char *pValue);
38int rtems_pppd_connect(void);
39int rtems_pppd_disconnect(void);
40
41struct rtems_bsdnet_ifconfig;
42
43int rtems_ppp_driver_attach(struct rtems_bsdnet_ifconfig *config, int attaching);
44
45#ifdef __cplusplus
46}
47#endif /* __cplusplus */
48
49#endif
Definition: deflate.c:115
