21#if !defined (_RTEMS_RFS_FILE_SYSTEM_H_)
22#define _RTEMS_RFS_FILE_SYSTEM_H_
29#define RTEMS_RFS_SB_OFFSET_MAGIC (0)
30#define RTEMS_RFS_SB_MAGIC (0x28092001)
31#define RTEMS_RFS_SB_OFFSET_VERSION (RTEMS_RFS_SB_OFFSET_MAGIC + 4)
32#define RTEMS_RFS_SB_OFFSET_BLOCK_SIZE (RTEMS_RFS_SB_OFFSET_VERSION + 4)
33#define RTEMS_RFS_SB_OFFSET_BLOCKS (RTEMS_RFS_SB_OFFSET_BLOCK_SIZE + 4)
34#define RTEMS_RFS_SB_OFFSET_BAD_BLOCKS (RTEMS_RFS_SB_OFFSET_BLOCKS + 4)
35#define RTEMS_RFS_SB_OFFSET_MAX_NAME_LENGTH (RTEMS_RFS_SB_OFFSET_BAD_BLOCKS + 4)
36#define RTEMS_RFS_SB_OFFSET_GROUPS (RTEMS_RFS_SB_OFFSET_MAX_NAME_LENGTH + 4)
37#define RTEMS_RFS_SB_OFFSET_GROUP_BLOCKS (RTEMS_RFS_SB_OFFSET_GROUPS + 4)
38#define RTEMS_RFS_SB_OFFSET_GROUP_INODES (RTEMS_RFS_SB_OFFSET_GROUP_BLOCKS + 4)
39#define RTEMS_RFS_SB_OFFSET_INODE_SIZE (RTEMS_RFS_SB_OFFSET_GROUP_INODES + 4)
44#define RTEMS_RFS_VERSION (0x00000000)
50#define RTEMS_RFS_VERSION_MASK INT32_C(0x00000000)
56#define RTEMS_RFS_ROOT_INO (1)
61#define RTEMS_RFS_EMPTY_INO (0)
67#define RTEMS_RFS_INODE_BLOCKS (5)
74#define RTEMS_RFS_INODE_OVERHEAD_PERCENTAGE (1)
80#define RTEMS_RFS_SUPERBLOCK_SIZE (1)
85#define RTEMS_RFS_FS_MAX_HELD_BUFFERS (5)
100#define RTEMS_RFS_FS_BITMAPS_HOLD (1 << 0)
103#define RTEMS_RFS_FS_NO_LOCAL_CACHE (1 << 1)
107#define RTEMS_RFS_FS_FORCE_OPEN (1 << 2)
109#define RTEMS_RFS_FS_READ_ONLY (1 << 3)
140#if RTEMS_RFS_USE_LIBBLOCK
267#define rtems_rfs_fs_flags(_f) ((_f)->flags)
273#define rtems_rfs_fs_release_bitmaps(_f) (!((_f)->flags & RTEMS_RFS_FS_BITMAPS_HOLD))
280#define rtems_rfs_fs_no_local_cache(_f) ((_f)->flags & RTEMS_RFS_FS_NO_LOCAL_CACHE)
287#if RTEMS_RFS_USE_LIBBLOCK
288#define rtems_rfs_fs_device(_fs) ((_fs)->disk)
290#define rtems_rfs_fs_device(_fs) ((_fs)->device)
298#define rtems_rfs_fs_blocks(_fs) ((_fs)->blocks)
305#define rtems_rfs_fs_block_size(_fs) ((_fs)->block_size)
312#define rtems_rfs_fs_inodes(_fs) ((_fs)->inodes)
323#define rtems_rfs_fs_block(_fs, _grp, _blk) \
324 ((((_fs)->group_blocks) * (_grp)) + (_blk) + 1)
331#if RTEMS_RFS_USE_LIBBLOCK
332#define rtems_rfs_fs_media_blocks(_fs) ((_fs)->disk->size)
334#define rtems_rfs_fs_media_blocks(_fs) ((_fs)->media_size)
343#if RTEMS_RFS_USE_LIBBLOCK
344#define rtems_rfs_fs_media_block_size(_fs) ((_fs)->disk->media_block_size)
346#define rtems_rfs_fs_media_block_size(_fs) (1)
352#define rtems_rfs_fs_max_name(_fs) ((_fs)->max_name_length)
359#define rtems_rfs_fs_max_block_map_blocks(_fs) ((_fs)->block_map_doubly_blocks)
364#define rtems_rfs_fs_user(_fs) ((_fs)->user)
397 uint32_t max_held_buffers,
uint64_t rtems_rfs_fs_size(rtems_rfs_file_system *fs)
Definition: rtems-rfs-file-system.c:32
int rtems_rfs_fs_open(const char *name, void *user, uint32_t flags, uint32_t max_held_buffers, rtems_rfs_file_system **fs)
Definition: rtems-rfs-file-system.c:196
uint64_t rtems_rfs_fs_media_size(rtems_rfs_file_system *fs)
Definition: rtems-rfs-file-system.c:40
uint64_t rtems_rfs_pos
Definition: rtems-rfs-file-system.h:90
int rtems_rfs_fs_close(rtems_rfs_file_system *fs)
Definition: rtems-rfs-file-system.c:310
int64_t rtems_rfs_pos_rel
Definition: rtems-rfs-file-system.h:95
RTEMS File Systems Group Management.
Definition: rtems-rfs-file-system.h:116
uint32_t release_count
Definition: rtems-rfs-file-system.h:237
rtems_chain_control file_shares
Definition: rtems-rfs-file-system.h:254
uint32_t release_modified_count
Definition: rtems-rfs-file-system.h:248
size_t inodes_per_block
Definition: rtems-rfs-file-system.h:193
rtems_chain_control release
Definition: rtems-rfs-file-system.h:232
rtems_rfs_group * groups
Definition: rtems-rfs-file-system.h:173
uint32_t buffers_count
Definition: rtems-rfs-file-system.h:226
size_t blocks_per_block
Definition: rtems-rfs-file-system.h:198
size_t block_map_doubly_blocks
Definition: rtems-rfs-file-system.h:211
size_t block_map_singly_blocks
Definition: rtems-rfs-file-system.h:204
Definition: rtems-rfs-file-system.h:216
size_t size
Definition: rtems-rfs-file-system.h:151
void * user
Definition: rtems-rfs-file-system.h:259
int device
Definition: rtems-rfs-file-system.h:138
size_t blocks
Definition: rtems-rfs-file-system.h:127
uint32_t flags
Definition: rtems-rfs-file-system.h:120
size_t group_blocks
Definition: rtems-rfs-file-system.h:183
uint32_t bad_blocks
Definition: rtems-rfs-file-system.h:163
int group_count
Definition: rtems-rfs-file-system.h:178
size_t block_size
Definition: rtems-rfs-file-system.h:133
uint32_t inodes
Definition: rtems-rfs-file-system.h:157
uint32_t max_name_length
Definition: rtems-rfs-file-system.h:168
rtems_chain_control release_modified
Definition: rtems-rfs-file-system.h:243
size_t group_inodes
Definition: rtems-rfs-file-system.h:188
rtems_chain_control buffers
Definition: rtems-rfs-file-system.h:221
Creates bit allocator for blocks in the group simpler.
Definition: rtems-rfs-group.h:52
Description of a disk device (logical and physical disks).
Definition: diskdevs.h:157
