RTEMS 5.2
region.h
1
9/* COPYRIGHT (c) 1989-2013.
10 * On-Line Applications Research Corporation (OAR).
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef _RTEMS_RTEMS_REGION_H
18#define _RTEMS_RTEMS_REGION_H
19
20#include <rtems/rtems/attr.h>
21#include <rtems/rtems/options.h>
22#include <rtems/rtems/status.h>
23#include <rtems/rtems/types.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
53 rtems_name name,
54 void *starting_address,
55 uintptr_t length,
56 uintptr_t page_size,
57 rtems_attribute attribute_set,
58 rtems_id *id
59);
60
78 rtems_id id,
79 void *starting_address,
80 uintptr_t length
81);
82
100 rtems_name name,
101 rtems_id *id
102);
103
118 rtems_id id,
119 Heap_Information_block *the_info
120);
121
139 rtems_id id,
140 Heap_Information_block *the_info
141);
142
157 rtems_id id
158);
159
183 rtems_id id,
184 uintptr_t size,
185 rtems_option option_set,
186 rtems_interval timeout,
187 void **segment
188);
189
206 rtems_id id,
207 void *segment,
208 uintptr_t *size
209);
210
228 rtems_id id,
229 void *segment
230);
231
256 rtems_id id,
257 void *segment,
258 uintptr_t size,
259 uintptr_t *old_size
260);
261
264#ifdef __cplusplus
265}
266#endif
267
268#endif
269/* end of include file */
uint32_t rtems_attribute
Definition: attr.h:41
uint32_t rtems_option
Definition: options.h:42
rtems_status_code rtems_region_create(rtems_name name, void *starting_address, uintptr_t length, uintptr_t page_size, rtems_attribute attribute_set, rtems_id *id)
rtems_region_create
Definition: regioncreate.c:29
rtems_status_code rtems_region_return_segment(rtems_id id, void *segment)
RTEMS Return Region Segment.
Definition: regionreturnsegment.c:23
rtems_status_code rtems_region_get_information(rtems_id id, Heap_Information_block *the_info)
RTEMS Get Region Information.
Definition: regiongetinfo.c:23
rtems_status_code rtems_region_get_free_information(rtems_id id, Heap_Information_block *the_info)
RTEMS Get Region Free Information.
Definition: regiongetfreeinfo.c:25
rtems_status_code rtems_region_delete(rtems_id id)
RTEMS Delete Region.
Definition: regiondelete.c:23
rtems_status_code rtems_region_ident(rtems_name name, rtems_id *id)
RTEMS Region Name to Id.
Definition: regionident.c:28
rtems_status_code rtems_region_get_segment_size(rtems_id id, void *segment, uintptr_t *size)
RTEMS Get Region Segment Size.
Definition: regiongetsegmentsize.c:23
rtems_status_code rtems_region_get_segment(rtems_id id, uintptr_t size, rtems_option option_set, rtems_interval timeout, void **segment)
RTEMS Get Region Segment.
Definition: regiongetsegment.c:47
rtems_status_code rtems_region_resize_segment(rtems_id id, void *segment, uintptr_t size, uintptr_t *old_size)
Resize RTEMS Region Segment.
Definition: regionresizesegment.c:23
rtems_status_code rtems_region_extend(rtems_id id, void *starting_address, uintptr_t length)
RTEMS Extend Region.
Definition: regionextend.c:23
rtems_status_code
Classic API Status.
Definition: status.h:43
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:127
Information block returned by _Heap_Get_information().
Definition: heapinfo.h:145
unsigned size
Definition: tte.h:1
