RTEMS
5.2
bsps
arm
tms570
include
bsp
ti_herc
reg_tcr.h
1
/* The header file is generated by make_header.py from TCR.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_TCR
40
#define LIBBSP_ARM_TMS570_TCR
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t
TCR
[128];
/*Transfer Configuration RAM*/
46
uint32_t TCR_Parity[128];
/*TCR Parity Test Mode*/
47
tms570_tcr_t
48
49
50
/*-----------------------TMS570_TCR_TCR-----------------------*/
51
/* field: STXR - Set Transmit Request. */
52
#define TMS570_TCR_TCR_STXR BSP_BIT32(18)
53
54
/* field: THTSM - Transfer Header to System Memory. */
55
#define TMS570_TCR_TCR_THTSM BSP_BIT32(17)
56
57
/* field: TPTSM - Transfer Payload to System Memory. */
58
#define TMS570_TCR_TCR_TPTSM BSP_BIT32(16)
59
60
/* field: THTCC - Transfer Header to Communication Controller. */
61
#define TMS570_TCR_TCR_THTCC BSP_BIT32(15)
62
63
/* field: TPTCC - Transfer Payload to Communication Controller. */
64
#define TMS570_TCR_TCR_TPTCC BSP_BIT32(14)
65
66
/* field: TSO - Transfer Start Offset. */
67
#define TMS570_TCR_TCR_TSO(val) BSP_FLD32(val,0, 13)
68
#define TMS570_TCR_TCR_TSO_GET(reg) BSP_FLD32GET(reg,0, 13)
69
#define TMS570_TCR_TCR_TSO_SET(reg,val) BSP_FLD32SET(reg, val,0, 13)
70
71
72
/*-------------------TMS570_TCR_TCR_Parity-------------------*/
73
/* field: PAB2 - Parity Bit for TCRx Byte 2. Parity information for byte 2 of TCRx(18-16). */
74
#define TMS570_TCR_TCR_Parity_PAB2 BSP_BIT32(16)
75
76
/* field: PAB1 - Parity Bit for TCRx Byte 1. Parity information for byte 1 of TCRx(15:8). */
77
#define TMS570_TCR_TCR_Parity_PAB1 BSP_BIT32(8)
78
79
/* field: PAB0 - Parity Bit for Byte 0. */
80
#define TMS570_TCR_TCR_Parity_PAB0 BSP_BIT32(0)
81
82
83
84
#endif
/* LIBBSP_ARM_TMS570_TCR */
TCR
#define TCR
tx configuration reg
Definition:
wd80x3.h:99
utility.h
Utility macros.
tms570_tcr_t
Definition:
reg_tcr.h:44
