RTEMS 5.2
reg_stc.h
1/* The header file is generated by make_header.py from STC.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_STC
40#define LIBBSP_ARM_TMS570_STC
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t STCGCR0; /*STC Global Control Register 0*/
46 uint32_t STCGCR1; /*STCGlobal Control Register 1*/
47 uint32_t STCTPR; /*Self-Test Run Timeout Counter Preload Register*/
48 uint32_t STC_CADDR; /*STC Current ROM Address Register*/
49 uint32_t STCCICR; /*STC Current Interval Count Register*/
50 uint32_t STCGSTAT; /*Self-Test Global Status Register*/
51 uint32_t STCFSTAT; /*Self-Test Fail Status Register*/
52 uint32_t CPU1_CURMISR3; /*CPU1 Current MISR Register 3*/
53 uint32_t CPU1_CURMISR2; /*CPU1 Current MISR Register 2*/
54 uint32_t CPU1_CURMISR1; /*CPU1 Current MISR Register 1*/
55 uint32_t CPU1_CURMISR0; /*CPU1 Current MISR Register 0*/
56 uint32_t CPU2_CURMISR3; /*CPU2 Current MISR Register 3*/
57 uint32_t CPU2_CURMISR2; /*CPU2 Current MISR Register 2*/
58 uint32_t CPU2_CURMISR1; /*CPU2 Current MISR Register 1*/
59 uint32_t CPU2_CURMISR0; /*CPU2 Current MISR Register 0*/
60 uint32_t STCSCSCR; /*Signature Compare Self-Check Register*/
62
63
64/*---------------------TMS570_STC_STCGCR0---------------------*/
65/* field: INTCOUNT - Number of intervals of self-test run */
66#define TMS570_STC_STCGCR0_INTCOUNT(val) BSP_FLD32(val,16, 31)
67#define TMS570_STC_STCGCR0_INTCOUNT_GET(reg) BSP_FLD32GET(reg,16, 31)
68#define TMS570_STC_STCGCR0_INTCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
69
70/* field: RS_CNT - Restart or Continue */
71#define TMS570_STC_STCGCR0_RS_CNT BSP_BIT32(0)
72
73
74/*---------------------TMS570_STC_STCGCR1---------------------*/
75/* field: STC_ENA - Self-test run enable key */
76#define TMS570_STC_STCGCR1_STC_ENA(val) BSP_FLD32(val,0, 3)
77#define TMS570_STC_STCGCR1_STC_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
78#define TMS570_STC_STCGCR1_STC_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
79
80
81/*---------------------TMS570_STC_STCTPR---------------------*/
82/* field: RTOD - Self-test timeout count preload */
83/* Whole 32 bits */
84
85/*--------------------TMS570_STC_STC_CADDR--------------------*/
86/* field: ADDR - Current ROM Address */
87/* Whole 32 bits */
88
89/*---------------------TMS570_STC_STCCICR---------------------*/
90/* field: N - Interval Number */
91#define TMS570_STC_STCCICR_N(val) BSP_FLD32(val,0, 15)
92#define TMS570_STC_STCCICR_N_GET(reg) BSP_FLD32GET(reg,0, 15)
93#define TMS570_STC_STCCICR_N_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
94
95
96/*--------------------TMS570_STC_STCGSTAT--------------------*/
97/* field: TEST_FAIL - Test Fail */
98#define TMS570_STC_STCGSTAT_TEST_FAIL BSP_BIT32(1)
99
100/* field: TEST_DONE - Test Done */
101#define TMS570_STC_STCGSTAT_TEST_DONE BSP_BIT32(0)
102
103
104/*--------------------TMS570_STC_STCFSTAT--------------------*/
105/* field: TO_ERR - Timeout Error */
106#define TMS570_STC_STCFSTAT_TO_ERR BSP_BIT32(2)
107
108/* field: CPU2_FAIL - CPU2 failure info */
109#define TMS570_STC_STCFSTAT_CPU2_FAIL BSP_BIT32(1)
110
111/* field: CPU1_FAIL - CPU1 failure info */
112#define TMS570_STC_STCFSTAT_CPU1_FAIL BSP_BIT32(0)
113
114
115/*------------------TMS570_STC_CPU1_CURMISR3------------------*/
116/* field: MISR - MISR data from CPU1 */
117/* Whole 32 bits */
118
119/*------------------TMS570_STC_CPU1_CURMISR2------------------*/
120/* field: MISR - MISR data from CPU1 */
121/* Whole 32 bits */
122
123/*------------------TMS570_STC_CPU1_CURMISR1------------------*/
124/* field: MISR - MISR data from CPU1 */
125/* Whole 32 bits */
126
127/*------------------TMS570_STC_CPU1_CURMISR0------------------*/
128/* field: MISR - MISR data from CPU1 */
129/* Whole 32 bits */
130
131/*------------------TMS570_STC_CPU2_CURMISR3------------------*/
132/* field: MISR - MISR data from CPU2 */
133/* Whole 32 bits */
134
135/*------------------TMS570_STC_CPU2_CURMISR2------------------*/
136/* field: MISR - MISR data from CPU2 */
137/* Whole 32 bits */
138
139/*------------------TMS570_STC_CPU2_CURMISR1------------------*/
140/* field: MISR - MISR data from CPU2 */
141/* Whole 32 bits */
142
143/*------------------TMS570_STC_CPU2_CURMISR0------------------*/
144/* field: MISR - MISR data from CPU2 */
145/* Whole 32 bits */
146
147/*--------------------TMS570_STC_STCSCSCR--------------------*/
148/* field: FAULT_INS - Enable / Disable fault insertion. */
149#define TMS570_STC_STCSCSCR_FAULT_INS BSP_BIT32(4)
150
151/* field: SELF_CHECK_KEY - Signature compare logic self-check enable key */
152#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY(val) BSP_FLD32(val,0, 3)
153#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
154#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
155
156
157
158#endif /* LIBBSP_ARM_TMS570_STC */
Utility macros.
Definition: reg_stc.h:44
