RTEMS
5.2
bsps
arm
tms570
include
bsp
ti_herc
reg_mdio.h
1
/* The header file is generated by make_header.py from MDIO.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_MDIO
40
#define LIBBSP_ARM_TMS570_MDIO
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t REVID;
/*MDIO Revision ID Register*/
46
uint32_t CONTROL;
/*MDIO Control Register*/
47
uint32_t ALIVE;
/*PHY Alive Status register*/
48
uint32_t LINK;
/*PHY Link Status Register*/
49
uint32_t LINKINTRAW;
/*MDIO Link Status Change Interrupt (Unmasked) Register*/
50
uint32_t LINKINTMASKED;
/*MDIO Link Status Change Interrupt (Masked) Register*/
51
uint8_t reserved1 [8];
52
uint32_t USERINTRAW;
/*MDIO User Command Complete Interrupt (Unmasked) Register*/
53
uint32_t USERINTMASKED;
/*MDIO User Command Complete Interrupt (Masked) Register*/
54
uint32_t USERINTMASKSET;
/*MDIO User Command Complete Interrupt Mask Set Register*/
55
uint32_t USERINTMASKCLEAR;
/*MDIO User Command Complete Interrupt Mask Clear Register*/
56
uint8_t reserved2 [80];
57
uint32_t USERACCESS0;
/*MDIO User Access Register 0*/
58
uint32_t USERPHYSEL0;
/*MDIO User PHY Select Register 0*/
59
uint32_t USERACCESS1;
/*MDIO User Access Register 1*/
60
uint32_t USERPHYSEL1;
/*MDIO User PHY Select Register 1*/
61
tms570_mdio_t
62
63
64
/*---------------------TMS570_MDIO_REVID---------------------*/
65
/* field: REV - Identifies the MDIO Module revision. */
66
/* Whole 32 bits */
67
68
/*--------------------TMS570_MDIO_CONTROL--------------------*/
69
/* field: IDLE - State machine IDLE status bit. */
70
#define TMS570_MDIO_CONTROL_IDLE BSP_BIT32(31)
71
72
/* field: ENABLE - State machine enable control bit. */
73
#define TMS570_MDIO_CONTROL_ENABLE BSP_BIT32(30)
74
75
/* field: HIGHEST_USER_CHANNEL - Highest user channel that is available in the module. It is currently set to 1. */
76
#define TMS570_MDIO_CONTROL_HIGHEST_USER_CHANNEL(val) BSP_FLD32(val,24, 28)
77
#define TMS570_MDIO_CONTROL_HIGHEST_USER_CHANNEL_GET(reg) BSP_FLD32GET(reg,24, 28)
78
#define TMS570_MDIO_CONTROL_HIGHEST_USER_CHANNEL_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
79
80
/* field: PREAMBLE - Preamble disable */
81
#define TMS570_MDIO_CONTROL_PREAMBLE BSP_BIT32(20)
82
83
/* field: FAULT - Fault indicator. */
84
#define TMS570_MDIO_CONTROL_FAULT BSP_BIT32(19)
85
86
/* field: FAULTENB - Fault detect enable. */
87
#define TMS570_MDIO_CONTROL_FAULTENB BSP_BIT32(18)
88
89
/* field: CLKDIV - Clock Divider bits. */
90
#define TMS570_MDIO_CONTROL_CLKDIV(val) BSP_FLD32(val,0, 15)
91
#define TMS570_MDIO_CONTROL_CLKDIV_GET(reg) BSP_FLD32GET(reg,0, 15)
92
#define TMS570_MDIO_CONTROL_CLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
93
94
95
/*---------------------TMS570_MDIO_ALIVE---------------------*/
96
/* field: ALIVE - MDIO Alive bits. */
97
/* Whole 32 bits */
98
99
/*----------------------TMS570_MDIO_LINK----------------------*/
100
/* field: LINK - MDIO Link state bits. This register is updated after a read of the generic status register of a PHY. */
101
/* Whole 32 bits */
102
103
/*-------------------TMS570_MDIO_LINKINTRAW-------------------*/
104
/* field: USERPHY1 - MDIO Link change event, raw value. */
105
#define TMS570_MDIO_LINKINTRAW_USERPHY1 BSP_BIT32(1)
106
107
/* field: USERPHY0 - MDIO Link change event, raw value. */
108
#define TMS570_MDIO_LINKINTRAW_USERPHY0 BSP_BIT32(0)
109
110
111
/*-----------------TMS570_MDIO_LINKINTMASKED-----------------*/
112
/* field: USERPHY1 - MDIO Link change interrupt, masked value. */
113
#define TMS570_MDIO_LINKINTMASKED_USERPHY1 BSP_BIT32(1)
114
115
/* field: USERPHY0 - MDIO Link change interrupt, masked value. */
116
#define TMS570_MDIO_LINKINTMASKED_USERPHY0 BSP_BIT32(0)
117
118
119
/*-------------------TMS570_MDIO_USERINTRAW-------------------*/
120
/* field: USERACCESS1 - MDIO User command complete event bit. */
121
#define TMS570_MDIO_USERINTRAW_USERACCESS1 BSP_BIT32(1)
122
123
/* field: USERACCESS0 - MDIO User command complete event bit. */
124
#define TMS570_MDIO_USERINTRAW_USERACCESS0 BSP_BIT32(0)
125
126
127
/*-----------------TMS570_MDIO_USERINTMASKED-----------------*/
128
/* field: USERACCESS1 - Masked value of MDIO User command complete interrupt. */
129
#define TMS570_MDIO_USERINTMASKED_USERACCESS1 BSP_BIT32(1)
130
131
/* field: USERACCESS0 - Masked value of MDIO User command complete interrupt. */
132
#define TMS570_MDIO_USERINTMASKED_USERACCESS0 BSP_BIT32(0)
133
134
135
/*-----------------TMS570_MDIO_USERINTMASKSET-----------------*/
136
/* field: USERACCESS1 - MDIO user interrupt mask set for USERINTMASKED[1]. */
137
#define TMS570_MDIO_USERINTMASKSET_USERACCESS1 BSP_BIT32(1)
138
139
/* field: USERACCESS0 - MDIO user interrupt mask set for USERINTMASKED[0]. */
140
#define TMS570_MDIO_USERINTMASKSET_USERACCESS0 BSP_BIT32(0)
141
142
143
/*----------------TMS570_MDIO_USERINTMASKCLEAR----------------*/
144
/* field: USERACCESS1 - MDIO user command complete interrupt mask clear for USERINTMASKED[1]. */
145
#define TMS570_MDIO_USERINTMASKCLEAR_USERACCESS1 BSP_BIT32(1)
146
147
/* field: USERACCESS0 - MDIO user command complete interrupt mask clear for USERINTMASKED[0]. */
148
#define TMS570_MDIO_USERINTMASKCLEAR_USERACCESS0 BSP_BIT32(0)
149
150
151
/*------------------TMS570_MDIO_USERACCESS0------------------*/
152
/* field: GO - Go bit. */
153
#define TMS570_MDIO_USERACCESS0_GO BSP_BIT32(31)
154
155
/* field: WRITE - Write enable bit. */
156
#define TMS570_MDIO_USERACCESS0_WRITE BSP_BIT32(30)
157
158
/* field: ACK - Acknowledge bit. This bit is set if the PHY acknowledged the read transaction. */
159
#define TMS570_MDIO_USERACCESS0_ACK BSP_BIT32(29)
160
161
/* field: REGADR - Register address bits. */
162
#define TMS570_MDIO_USERACCESS0_REGADR(val) BSP_FLD32(val,21, 25)
163
#define TMS570_MDIO_USERACCESS0_REGADR_GET(reg) BSP_FLD32GET(reg,21, 25)
164
#define TMS570_MDIO_USERACCESS0_REGADR_SET(reg,val) BSP_FLD32SET(reg, val,21, 25)
165
166
/* field: PHYADR - PHY address bits. This field specifies the PHY to be accessed for this transaction. */
167
#define TMS570_MDIO_USERACCESS0_PHYADR(val) BSP_FLD32(val,16, 20)
168
#define TMS570_MDIO_USERACCESS0_PHYADR_GET(reg) BSP_FLD32GET(reg,16, 20)
169
#define TMS570_MDIO_USERACCESS0_PHYADR_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
170
171
/* field: DATA - User data bits. */
172
#define TMS570_MDIO_USERACCESS0_DATA(val) BSP_FLD32(val,0, 15)
173
#define TMS570_MDIO_USERACCESS0_DATA_GET(reg) BSP_FLD32GET(reg,0, 15)
174
#define TMS570_MDIO_USERACCESS0_DATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
175
176
177
/*------------------TMS570_MDIO_USERPHYSEL0------------------*/
178
/* field: LINKSEL - Link status determination select bit. */
179
#define TMS570_MDIO_USERPHYSEL0_LINKSEL BSP_BIT32(7)
180
181
/* field: LINKINTENB - Link change interrupt enable. */
182
#define TMS570_MDIO_USERPHYSEL0_LINKINTENB BSP_BIT32(6)
183
184
/* field: PHYADRMON - PHY address whose link status is to be monitored. */
185
#define TMS570_MDIO_USERPHYSEL0_PHYADRMON(val) BSP_FLD32(val,0, 4)
186
#define TMS570_MDIO_USERPHYSEL0_PHYADRMON_GET(reg) BSP_FLD32GET(reg,0, 4)
187
#define TMS570_MDIO_USERPHYSEL0_PHYADRMON_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
188
189
190
/*------------------TMS570_MDIO_USERACCESS1------------------*/
191
192
#define TMS570_MDIO_USERACCESS1_GO BSP_BIT32(31)
193
194
195
#define TMS570_MDIO_USERACCESS1_WRITE BSP_BIT32(30)
196
197
198
#define TMS570_MDIO_USERACCESS1_ACK BSP_BIT32(29)
199
200
201
#define TMS570_MDIO_USERACCESS1_REGADR(val) BSP_FLD32(val,21, 25)
202
#define TMS570_MDIO_USERACCESS1_REGADR_GET(reg) BSP_FLD32GET(reg,21, 25)
203
#define TMS570_MDIO_USERACCESS1_REGADR_SET(reg,val) BSP_FLD32SET(reg, val,21, 25)
204
205
206
#define TMS570_MDIO_USERACCESS1_PHYADR(val) BSP_FLD32(val,16, 20)
207
#define TMS570_MDIO_USERACCESS1_PHYADR_GET(reg) BSP_FLD32GET(reg,16, 20)
208
#define TMS570_MDIO_USERACCESS1_PHYADR_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
209
210
211
#define TMS570_MDIO_USERACCESS1_DATA(val) BSP_FLD32(val,0, 15)
212
#define TMS570_MDIO_USERACCESS1_DATA_GET(reg) BSP_FLD32GET(reg,0, 15)
213
#define TMS570_MDIO_USERACCESS1_DATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
214
215
216
/*------------------TMS570_MDIO_USERPHYSEL1------------------*/
217
218
#define TMS570_MDIO_USERPHYSEL1_LINKSEL BSP_BIT32(7)
219
220
221
#define TMS570_MDIO_USERPHYSEL1_LINKINTENB BSP_BIT32(6)
222
223
224
#define TMS570_MDIO_USERPHYSEL1_PHYADRMON(val) BSP_FLD32(val,0, 4)
225
#define TMS570_MDIO_USERPHYSEL1_PHYADRMON_GET(reg) BSP_FLD32GET(reg,0, 4)
226
#define TMS570_MDIO_USERPHYSEL1_PHYADRMON_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
227
228
229
230
#endif
/* LIBBSP_ARM_TMS570_MDIO */
utility.h
Utility macros.
tms570_mdio_t
Definition:
reg_mdio.h:44
