RTEMS 5.2
reg_flash.h
1/* The header file is generated by make_header.py from FLASH.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_FLASH
40#define LIBBSP_ARM_TMS570_FLASH
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t FRDCNTL; /*Flash Option Control Register*/
46 uint8_t reserved1 [4];
47 uint32_t FEDACTRL1; /*Flash Error Detection and Correction Control Register 1*/
48 uint32_t FEDACTRL2; /*Flash Error Detection and Correction Control Register 2*/
49 uint32_t FCORERRCNT; /*Flash Correctable Error Count Register*/
50 uint32_t FCORERRADD; /*Flash Correctable Error Address Register*/
51 uint32_t FCORERRPOS; /*Flash Correctable Error Position Register*/
52 uint32_t FEDACSTATUS; /*Flash Error Detection and Correction Status Register*/
53 uint32_t FUNCERRADD; /*Flash Un-Correctable Error Address Register*/
54 uint32_t FEDACSDIS; /*Flash Error Detection and Correction Sector Disable Register*/
55 uint32_t FPRIMADDTAG; /*Flash Primary Address Tag Register*/
56 uint32_t FDUPADDTAG; /*Flash Duplicate Address Tag Register*/
57 uint32_t FBPROT; /*Flash Bank Protection Register*/
58 uint32_t FBSE; /*Flash Bank Sector Enable Register*/
59 uint32_t FBBUSY; /*Flash Bank Busy Register*/
60 uint32_t FBAC; /*Flash Bank Access Control Register*/
61 uint32_t FBFALLBACK; /*Flash Bank Fallback Power Register*/
62 uint32_t FBPRDY; /*Flash Bank/Pump Ready Register*/
63 uint32_t FPAC1; /*Flash Pump Access Control Register 1*/
64 uint32_t FPAC2; /*Flash Pump Access Control Register 2*/
65 uint32_t FMAC; /*Flash Module Access Control Register*/
66 uint32_t FMSTAT; /*Flash Module Status Register*/
67 uint32_t FEMUDMSW; /*EEPROM Emulation Data MSW Register*/
68 uint32_t FEMUDLSW; /*EEPROM Emulation Data LSW Register*/
69 uint32_t FEMUECC; /*EEPROM Emulation ECC Register*/
70 uint8_t reserved2 [4];
71 uint32_t FEMUADDR; /*EEPROM Emulation Address Register*/
72 uint32_t FDIAGCTRL; /*Diagnostic Control Register*/
73 uint32_t FRAWDATAH; /*Uncorrected Raw Data High Register*/
74 uint32_t FRAWDATAL; /*Uncorrected Raw Data Low Register*/
75 uint32_t FRAWECC; /*Uncorrected Raw ECC Register*/
76 uint32_t FPAROVR; /*Parity Override Register*/
77 uint8_t reserved3 [64];
78 uint32_t FEDACSDIS2; /*Flash Error Detection and Correction Sector Disable Register 2*/
79 uint8_t reserved4 [452];
80 uint32_t FSMWRENA; /*FSM Register Write Enable*/
81 uint8_t reserved5 [24];
82 uint32_t FSMSECTOR; /*FSM Sector Register*/
83 uint8_t reserved6 [16];
84 uint32_t EEPROMCONFIG; /*EEPROM Emulation Configuration Register*/
85 uint8_t reserved7 [76];
86 uint32_t EECTRL1; /*EEPROM Emulation Error Detection and Correction Control Register 1*/
87 uint32_t EECTRL2; /*EEPROM Emulation Error Detection and Correction Control Register 2*/
88 uint32_t EECORERRCNT; /*EEPROM Emulation Correctable Error Count Register*/
89 uint32_t EECORERRADD; /*EEPROM Emulation Correctable Error Address Register*/
90 uint32_t EECORERRPOS; /*EEPROM Emulation Correctable Error Bit Position Register*/
91 uint32_t EESTATUS; /*EEPROM Emulation Error Status Register*/
92 uint32_t EEUNCERRADD; /*EEPROM Emulation Un-Correctable Error Address Register*/
93 uint8_t reserved8 [220];
94 uint32_t FCFGBANK; /*Flash Bank Configuration Register*/
96
97
98/*--------------------TMS570_FLASH_FRDCNTL--------------------*/
99/* field: RWAIT - Random/data Read Wait State */
100#define TMS570_FLASH_FRDCNTL_RWAIT(val) BSP_FLD32(val,8, 11)
101#define TMS570_FLASH_FRDCNTL_RWAIT_GET(reg) BSP_FLD32GET(reg,8, 11)
102#define TMS570_FLASH_FRDCNTL_RWAIT_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
103
104/* field: ASWSTEN - Address Setup Wait State Enable */
105#define TMS570_FLASH_FRDCNTL_ASWSTEN BSP_BIT32(4)
106
107/* field: ENPIPE - Enable Pipeline Mode */
108#define TMS570_FLASH_FRDCNTL_ENPIPE BSP_BIT32(0)
109
110
111/*-------------------TMS570_FLASH_FEDACTRL1-------------------*/
112/* field: SUSP_IGNR - Suspend Ignore. */
113#define TMS570_FLASH_FEDACTRL1_SUSP_IGNR BSP_BIT32(24)
114
115/* field: EDACMODE - Error Correction Mode. */
116#define TMS570_FLASH_FEDACTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
117#define TMS570_FLASH_FEDACTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
118#define TMS570_FLASH_FEDACTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
119
120/* field: EOFEN - Event on Ones Fail Enable */
121#define TMS570_FLASH_FEDACTRL1_EOFEN BSP_BIT32(10)
122
123/* field: EZFEN - Event on Zeros Fail Enable */
124#define TMS570_FLASH_FEDACTRL1_EZFEN BSP_BIT32(9)
125
126/* field: EPEN - Error Profiling Enable. */
127#define TMS570_FLASH_FEDACTRL1_EPEN BSP_BIT32(8)
128
129/* field: EDACEN - Error Detection and Correction Enable */
130#define TMS570_FLASH_FEDACTRL1_EDACEN(val) BSP_FLD32(val,0, 3)
131#define TMS570_FLASH_FEDACTRL1_EDACEN_GET(reg) BSP_FLD32GET(reg,0, 3)
132#define TMS570_FLASH_FEDACTRL1_EDACEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
133
134
135/*-------------------TMS570_FLASH_FEDACTRL2-------------------*/
136/* field: SEC_THRESHOLD - Single Error Correction Threshold */
137#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
138#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
139#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
140
141
142/*------------------TMS570_FLASH_FCORERRCNT------------------*/
143/* field: FERRCNT - Single Error Correction Count */
144#define TMS570_FLASH_FCORERRCNT_FERRCNT(val) BSP_FLD32(val,0, 15)
145#define TMS570_FLASH_FCORERRCNT_FERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
146#define TMS570_FLASH_FCORERRCNT_FERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
147
148
149/*------------------TMS570_FLASH_FCORERRADD------------------*/
150/* field: COR_ERR_ADD - Correctable Error Address */
151#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
152#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
153#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
154
155/* field: B_OFF - Byte Offset */
156#define TMS570_FLASH_FCORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
157#define TMS570_FLASH_FCORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
158#define TMS570_FLASH_FCORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
159
160
161/*------------------TMS570_FLASH_FCORERRPOS------------------*/
162/* field: BUS2 - Bus 2 Error */
163#define TMS570_FLASH_FCORERRPOS_BUS2 BSP_BIT32(9)
164
165/* field: TYPE - ErrorType */
166#define TMS570_FLASH_FCORERRPOS_TYPE BSP_BIT32(8)
167
168/* field: ERR_POS - The bit address of the single bit error */
169#define TMS570_FLASH_FCORERRPOS_ERR_POS(val) BSP_FLD32(val,0, 7)
170#define TMS570_FLASH_FCORERRPOS_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
171#define TMS570_FLASH_FCORERRPOS_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
172
173
174/*------------------TMS570_FLASH_FEDACSTATUS------------------*/
175/* field: Reserved - Read returns 0. Writes have no effect. */
176#define TMS570_FLASH_FEDACSTATUS_Reserved(val) BSP_FLD32(val,26, 31)
177#define TMS570_FLASH_FEDACSTATUS_Reserved_GET(reg) BSP_FLD32GET(reg,26, 31)
178#define TMS570_FLASH_FEDACSTATUS_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,26, 31)
179
180/* field: FSM_DONE - Flash State Machine Done */
181#define TMS570_FLASH_FEDACSTATUS_FSM_DONE BSP_BIT32(24)
182
183/* field: COMB2_MAL_G - Bus 2 Compare Malfunction Flag. */
184#define TMS570_FLASH_FEDACSTATUS_COMB2_MAL_G BSP_BIT32(19)
185
186/* field: ECC_B2_MAL_ - Bus 2 ECC Malfunction Error Flag */
187#define TMS570_FLASH_FEDACSTATUS_ECC_B2_MAL_ BSP_BIT32(18)
188
189/* field: B2_UNC_ERR - Bus 2 uncorrectable error */
190#define TMS570_FLASH_FEDACSTATUS_B2_UNC_ERR BSP_BIT32(17)
191
192/* field: B2_COR_ERR - Bus 2 Correctable Error */
193#define TMS570_FLASH_FEDACSTATUS_B2_COR_ERR BSP_BIT32(16)
194
195/* field: D_UNC_ERR - Diagnostic Uncorrectable Error */
196#define TMS570_FLASH_FEDACSTATUS_D_UNC_ERR BSP_BIT32(12)
197
198/* field: ADD_TAG_ERR - Address Tag Register Error Flag */
199#define TMS570_FLASH_FEDACSTATUS_ADD_TAG_ERR BSP_BIT32(11)
200
201/* field: ADD_PAR_ERR - Address Parity Error Flag */
202#define TMS570_FLASH_FEDACSTATUS_ADD_PAR_ERR BSP_BIT32(10)
203
204/* field: B1_UNC_ERR - Bus 1 Uncorrectable Error Flag */
205#define TMS570_FLASH_FEDACSTATUS_B1_UNC_ERR BSP_BIT32(8)
206
207/* field: D_CORR_ERR - Diagnostic Correctable Error Status Flag */
208#define TMS570_FLASH_FEDACSTATUS_D_CORR_ERR BSP_BIT32(3)
209
210/* field: ERR_ONE_FLG - Error on One Fail Status Flag */
211#define TMS570_FLASH_FEDACSTATUS_ERR_ONE_FLG BSP_BIT32(2)
212
213/* field: ERR_ZERO__FLG - Error on Zero Fail Status Flag */
214#define TMS570_FLASH_FEDACSTATUS_ERR_ZERO__FLG BSP_BIT32(1)
215
216/* field: ERR_PRF_FLG - Error Profiling Status Flag */
217#define TMS570_FLASH_FEDACSTATUS_ERR_PRF_FLG BSP_BIT32(0)
218
219
220/*------------------TMS570_FLASH_FUNCERRADD------------------*/
221/* field: UNC_ERR_ADD - Un-correctable Error Address */
222#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
223#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
224#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
225
226/* field: B_OFF - Byte offset */
227#define TMS570_FLASH_FUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
228#define TMS570_FLASH_FUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
229#define TMS570_FLASH_FUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
230
231
232/*-------------------TMS570_FLASH_FEDACSDIS-------------------*/
233/* field: BankID1_Inverse - The bank ID inverse bits are used with the bank ID bits to select the bank for which a sector */
234#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse(val) BSP_FLD32(val,29, 31)
235#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
236#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
237
238/* field: SectorID1_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is */
239#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse(val) BSP_FLD32(val,24, 27)
240#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
241#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
242
243/* field: BankID1 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
244#define TMS570_FLASH_FEDACSDIS_BankID1(val) BSP_FLD32(val,21, 23)
245#define TMS570_FLASH_FEDACSDIS_BankID1_GET(reg) BSP_FLD32GET(reg,21, 23)
246#define TMS570_FLASH_FEDACSDIS_BankID1_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
247
248/* field: SectorID1 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
249#define TMS570_FLASH_FEDACSDIS_SectorID1(val) BSP_FLD32(val,16, 19)
250#define TMS570_FLASH_FEDACSDIS_SectorID1_GET(reg) BSP_FLD32GET(reg,16, 19)
251#define TMS570_FLASH_FEDACSDIS_SectorID1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
252
253/* field: BankID0_Inverse - The bank ID inverse bits are used with the bank ID bits to select the bank for which a sector */
254#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse(val) BSP_FLD32(val,13, 15)
255#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
256#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
257
258/* field: SectorID0_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is */
259#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse(val) BSP_FLD32(val,8, 11)
260#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
261#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
262
263/* field: BankID0 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
264#define TMS570_FLASH_FEDACSDIS_BankID0(val) BSP_FLD32(val,5, 7)
265#define TMS570_FLASH_FEDACSDIS_BankID0_GET(reg) BSP_FLD32GET(reg,5, 7)
266#define TMS570_FLASH_FEDACSDIS_BankID0_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
267
268/* field: SectorID0 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
269#define TMS570_FLASH_FEDACSDIS_SectorID0(val) BSP_FLD32(val,0, 3)
270#define TMS570_FLASH_FEDACSDIS_SectorID0_GET(reg) BSP_FLD32GET(reg,0, 3)
271#define TMS570_FLASH_FEDACSDIS_SectorID0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
272
273
274/*------------------TMS570_FLASH_FPRIMADDTAG------------------*/
275/* field: PRIM_ADD_TAG - Primary Address Tag Register */
276#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG(val) BSP_FLD32(val,4, 31)
277#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
278#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
279
280/* field: 0 - Always 0000 */
281#define TMS570_FLASH_FPRIMADDTAG_0(val) BSP_FLD32(val,0, 3)
282#define TMS570_FLASH_FPRIMADDTAG_0_GET(reg) BSP_FLD32GET(reg,0, 3)
283#define TMS570_FLASH_FPRIMADDTAG_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
284
285
286/*------------------TMS570_FLASH_FDUPADDTAG------------------*/
287/* field: DUP_ADD_TAG - Primary Address Tag Register */
288#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG(val) BSP_FLD32(val,4, 31)
289#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
290#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
291
292
293/*--------------------TMS570_FLASH_FBPROT--------------------*/
294/* field: PROTL1DIS - PROTL1DIS: Level 1 Protection Disabled */
295#define TMS570_FLASH_FBPROT_PROTL1DIS BSP_BIT32(0)
296
297
298/*---------------------TMS570_FLASH_FBSE---------------------*/
299/* field: BSE - Bank Sector Enable */
300#define TMS570_FLASH_FBSE_BSE(val) BSP_FLD32(val,0, 15)
301#define TMS570_FLASH_FBSE_BSE_GET(reg) BSP_FLD32GET(reg,0, 15)
302#define TMS570_FLASH_FBSE_BSE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
303
304
305/*--------------------TMS570_FLASH_FBBUSY--------------------*/
306/* field: BUSY - Bank Busy */
307#define TMS570_FLASH_FBBUSY_BUSY(val) BSP_FLD32(val,0, 7)
308#define TMS570_FLASH_FBBUSY_BUSY_GET(reg) BSP_FLD32GET(reg,0, 7)
309#define TMS570_FLASH_FBBUSY_BUSY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
310
311
312/*---------------------TMS570_FLASH_FBAC---------------------*/
313/* field: OTPPROTDIS - OTP Sector Protection Disable. */
314#define TMS570_FLASH_FBAC_OTPPROTDIS(val) BSP_FLD32(val,16, 23)
315#define TMS570_FLASH_FBAC_OTPPROTDIS_GET(reg) BSP_FLD32GET(reg,16, 23)
316#define TMS570_FLASH_FBAC_OTPPROTDIS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
317
318/* field: 15_8 - BAGP 0-FFh Bank Active Grace Period. */
319#define TMS570_FLASH_FBAC_15_8(val) BSP_FLD32(val,8, 15)
320#define TMS570_FLASH_FBAC_15_8_GET(reg) BSP_FLD32GET(reg,8, 15)
321#define TMS570_FLASH_FBAC_15_8_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
322
323/* field: VREADST - VREAD Setup. */
324#define TMS570_FLASH_FBAC_VREADST(val) BSP_FLD32(val,0, 7)
325#define TMS570_FLASH_FBAC_VREADST_GET(reg) BSP_FLD32GET(reg,0, 7)
326#define TMS570_FLASH_FBAC_VREADST_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
327
328
329/*------------------TMS570_FLASH_FBFALLBACK------------------*/
330/* field: BANKPWR7 - Bank 7 Fallback Power Mode */
331#define TMS570_FLASH_FBFALLBACK_BANKPWR7(val) BSP_FLD32(val,14, 15)
332#define TMS570_FLASH_FBFALLBACK_BANKPWR7_GET(reg) BSP_FLD32GET(reg,14, 15)
333#define TMS570_FLASH_FBFALLBACK_BANKPWR7_SET(reg,val) BSP_FLD32SET(reg, val,14, 15)
334
335/* field: BANKPWR1 - Bank 1 Fallback Power Mode */
336#define TMS570_FLASH_FBFALLBACK_BANKPWR1(val) BSP_FLD32(val,2, 3)
337#define TMS570_FLASH_FBFALLBACK_BANKPWR1_GET(reg) BSP_FLD32GET(reg,2, 3)
338#define TMS570_FLASH_FBFALLBACK_BANKPWR1_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
339
340/* field: BANKPWR0 - Bank 0 Fallback Power Mode */
341#define TMS570_FLASH_FBFALLBACK_BANKPWR0(val) BSP_FLD32(val,0, 1)
342#define TMS570_FLASH_FBFALLBACK_BANKPWR0_GET(reg) BSP_FLD32GET(reg,0, 1)
343#define TMS570_FLASH_FBFALLBACK_BANKPWR0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
344
345
346/*--------------------TMS570_FLASH_FBPRDY--------------------*/
347/* field: BANKBUSY - Bank busy bits (one bit for each bank) */
348#define TMS570_FLASH_FBPRDY_BANKBUSY(val) BSP_FLD32(val,16, 23)
349#define TMS570_FLASH_FBPRDY_BANKBUSY_GET(reg) BSP_FLD32GET(reg,16, 23)
350#define TMS570_FLASH_FBPRDY_BANKBUSY_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
351
352/* field: PUMPRDY - Flash pump ready flag */
353#define TMS570_FLASH_FBPRDY_PUMPRDY BSP_BIT32(15)
354
355/* field: BANKRDY - Bank ready bits (one bit for each bank) */
356#define TMS570_FLASH_FBPRDY_BANKRDY(val) BSP_FLD32(val,0, 7)
357#define TMS570_FLASH_FBPRDY_BANKRDY_GET(reg) BSP_FLD32GET(reg,0, 7)
358#define TMS570_FLASH_FBPRDY_BANKRDY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
359
360
361/*---------------------TMS570_FLASH_FPAC1---------------------*/
362/* field: PSLEEP - Pump Sleep. */
363#define TMS570_FLASH_FPAC1_PSLEEP(val) BSP_FLD32(val,16, 26)
364#define TMS570_FLASH_FPAC1_PSLEEP_GET(reg) BSP_FLD32GET(reg,16, 26)
365#define TMS570_FLASH_FPAC1_PSLEEP_SET(reg,val) BSP_FLD32SET(reg, val,16, 26)
366
367/* field: PUMPPWR - Flash Charge Pump Fallback Power Mode */
368#define TMS570_FLASH_FPAC1_PUMPPWR BSP_BIT32(0)
369
370
371/*---------------------TMS570_FLASH_FPAC2---------------------*/
372/* field: PAGP - Pump Active Grace Period */
373#define TMS570_FLASH_FPAC2_PAGP(val) BSP_FLD32(val,0, 15)
374#define TMS570_FLASH_FPAC2_PAGP_GET(reg) BSP_FLD32GET(reg,0, 15)
375#define TMS570_FLASH_FPAC2_PAGP_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
376
377
378/*---------------------TMS570_FLASH_FMAC---------------------*/
379/* field: BANK - Bank Enable. */
380#define TMS570_FLASH_FMAC_BANK(val) BSP_FLD32(val,0, 2)
381#define TMS570_FLASH_FMAC_BANK_GET(reg) BSP_FLD32GET(reg,0, 2)
382#define TMS570_FLASH_FMAC_BANK_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
383
384
385/*--------------------TMS570_FLASH_FMSTAT--------------------*/
386/* field: ILA - Illegal Address */
387#define TMS570_FLASH_FMSTAT_ILA BSP_BIT32(14)
388
389/* field: PGV - Program Verify */
390#define TMS570_FLASH_FMSTAT_PGV BSP_BIT32(12)
391
392/* field: EV - Erase Verify */
393#define TMS570_FLASH_FMSTAT_EV BSP_BIT32(10)
394
395/* field: BUSY - Busy */
396#define TMS570_FLASH_FMSTAT_BUSY BSP_BIT32(8)
397
398/* field: ERS - Erase Active */
399#define TMS570_FLASH_FMSTAT_ERS BSP_BIT32(7)
400
401/* field: PGM - Program Active */
402#define TMS570_FLASH_FMSTAT_PGM BSP_BIT32(6)
403
404/* field: INVDAT - Invalid Data */
405#define TMS570_FLASH_FMSTAT_INVDAT BSP_BIT32(5)
406
407/* field: CSTAT - Command Status */
408#define TMS570_FLASH_FMSTAT_CSTAT BSP_BIT32(4)
409
410/* field: VOLTSTAT - Core Voltage Status */
411#define TMS570_FLASH_FMSTAT_VOLTSTAT BSP_BIT32(3)
412
413/* field: ESUSP - Erase Suspended */
414#define TMS570_FLASH_FMSTAT_ESUSP BSP_BIT32(2)
415
416/* field: PSUSP - Program Suspended */
417#define TMS570_FLASH_FMSTAT_PSUSP BSP_BIT32(1)
418
419/* field: SLOCK - Sector Lock Status */
420#define TMS570_FLASH_FMSTAT_SLOCK BSP_BIT32(0)
421
422
423/*-------------------TMS570_FLASH_FEMUDMSW-------------------*/
424/* field: EMU_DMSW - EEPROM Emulation Most Significant Data Word */
425/* Whole 32 bits */
426
427/*-------------------TMS570_FLASH_FEMUDLSW-------------------*/
428/* field: EMU_DLSW - EEPROM Emulation Least Significant Data Word */
429/* Whole 32 bits */
430
431/*--------------------TMS570_FLASH_FEMUECC--------------------*/
432/* field: EMU_ECC - This register can be written by the CPU in any mode. */
433#define TMS570_FLASH_FEMUECC_EMU_ECC(val) BSP_FLD32(val,0, 7)
434#define TMS570_FLASH_FEMUECC_EMU_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
435#define TMS570_FLASH_FEMUECC_EMU_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
436
437
438/*-------------------TMS570_FLASH_FEMUADDR-------------------*/
439/* field: EMU_ADDR - EEPROM Emulation Address */
440#define TMS570_FLASH_FEMUADDR_EMU_ADDR(val) BSP_FLD32(val,3, 21)
441#define TMS570_FLASH_FEMUADDR_EMU_ADDR_GET(reg) BSP_FLD32GET(reg,3, 21)
442#define TMS570_FLASH_FEMUADDR_EMU_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,3, 21)
443
444
445/*-------------------TMS570_FLASH_FDIAGCTRL-------------------*/
446/* field: DIAG_TRIG - Diagnostic Trigger */
447#define TMS570_FLASH_FDIAGCTRL_DIAG_TRIG BSP_BIT32(24)
448
449/* field: DIAG_EN_KEY - Diagnostic Enable Key */
450#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY(val) BSP_FLD32(val,16, 19)
451#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
452#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
453
454/* field: DIAG_ECC_SEL - Diagnostic SECDED Select */
455#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL(val) BSP_FLD32(val,12, 14)
456#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET(reg) BSP_FLD32GET(reg,12, 14)
457#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
458
459
460/*-------------------TMS570_FLASH_FRAWDATAH-------------------*/
461/* field: RAW_DATA_ - Uncorrected Raw Data */
462/* Whole 32 bits */
463
464/*-------------------TMS570_FLASH_FRAWDATAL-------------------*/
465/* field: RAW_DATA_ - Uncorrected Raw Data. Same as FRAW_DATAH but stores lower 32 bits. */
466/* Whole 32 bits */
467
468/*--------------------TMS570_FLASH_FRAWECC--------------------*/
469/* field: PIPE_BUF - Error came from pipeline buffer hit */
470#define TMS570_FLASH_FRAWECC_PIPE_BUF BSP_BIT32(8)
471
472/* field: RAW_ECC - Uncorrected Raw ECC */
473#define TMS570_FLASH_FRAWECC_RAW_ECC(val) BSP_FLD32(val,0, 7)
474#define TMS570_FLASH_FRAWECC_RAW_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
475#define TMS570_FLASH_FRAWECC_RAW_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
476
477
478/*--------------------TMS570_FLASH_FPAROVR--------------------*/
479/* field: BNK_INV_PAR - Buffer Invert Parity */
480#define TMS570_FLASH_FPAROVR_BNK_INV_PAR BSP_BIT32(16)
481
482/* field: BUS_PAR_DIS - Disable Bus Parity */
483#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS(val) BSP_FLD32(val,12, 15)
484#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET(reg) BSP_FLD32GET(reg,12, 15)
485#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
486
487/* field: PAR_OVR_KEY - When this value is 101, the selected ADD_INV_PAR and DAT_INV_PAR fields will become active. */
488#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY(val) BSP_FLD32(val,9, 11)
489#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET(reg) BSP_FLD32GET(reg,9, 11)
490#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
491
492/* field: ADD_INV_PAR - Address Odd Parity */
493#define TMS570_FLASH_FPAROVR_ADD_INV_PAR BSP_BIT32(8)
494
495/* field: DAT_INV_PAR - Data Odd Parity */
496#define TMS570_FLASH_FPAROVR_DAT_INV_PAR(val) BSP_FLD32(val,0, 7)
497#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET(reg) BSP_FLD32GET(reg,0, 7)
498#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
499
500
501/*------------------TMS570_FLASH_FEDACSDIS2------------------*/
502/* field: BankID3_Inverse - The bank ID inverse bits are used with the bank ID bits to select the bank for which a sector */
503#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse(val) BSP_FLD32(val,29, 31)
504#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
505#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
506
507/* field: SectorID3_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is disabled. */
508#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse(val) BSP_FLD32(val,24, 27)
509#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
510#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
511
512/* field: BankID3 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
513#define TMS570_FLASH_FEDACSDIS2_BankID3(val) BSP_FLD32(val,21, 23)
514#define TMS570_FLASH_FEDACSDIS2_BankID3_GET(reg) BSP_FLD32GET(reg,21, 23)
515#define TMS570_FLASH_FEDACSDIS2_BankID3_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
516
517/* field: SectorID3 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
518#define TMS570_FLASH_FEDACSDIS2_SectorID3(val) BSP_FLD32(val,16, 19)
519#define TMS570_FLASH_FEDACSDIS2_SectorID3_GET(reg) BSP_FLD32GET(reg,16, 19)
520#define TMS570_FLASH_FEDACSDIS2_SectorID3_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
521
522/* field: BankID2_Inverse - is disabled. The only bank that supports sector disable is bank 7. */
523#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse(val) BSP_FLD32(val,13, 15)
524#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
525#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
526
527/* field: SectorID2_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is */
528#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse(val) BSP_FLD32(val,8, 11)
529#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
530#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
531
532/* field: BankID2 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
533#define TMS570_FLASH_FEDACSDIS2_BankID2(val) BSP_FLD32(val,5, 7)
534#define TMS570_FLASH_FEDACSDIS2_BankID2_GET(reg) BSP_FLD32GET(reg,5, 7)
535#define TMS570_FLASH_FEDACSDIS2_BankID2_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
536
537/* field: SectorID2 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
538#define TMS570_FLASH_FEDACSDIS2_SectorID2(val) BSP_FLD32(val,0, 3)
539#define TMS570_FLASH_FEDACSDIS2_SectorID2_GET(reg) BSP_FLD32GET(reg,0, 3)
540#define TMS570_FLASH_FEDACSDIS2_SectorID2_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
541
542
543/*-------------------TMS570_FLASH_FSMWRENA-------------------*/
544/* field: WR_ENA - Flash State Machine Write Enable */
545#define TMS570_FLASH_FSMWRENA_WR_ENA(val) BSP_FLD32(val,0, 2)
546#define TMS570_FLASH_FSMWRENA_WR_ENA_GET(reg) BSP_FLD32GET(reg,0, 2)
547#define TMS570_FLASH_FSMWRENA_WR_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
548
549
550/*-------------------TMS570_FLASH_FSMSECTOR-------------------*/
551/* field: SECT_ERASED - Sectors Erased */
552#define TMS570_FLASH_FSMSECTOR_SECT_ERASED(val) BSP_FLD32(val,16, 31)
553#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET(reg) BSP_FLD32GET(reg,16, 31)
554#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
555
556
557/*-----------------TMS570_FLASH_EEPROMCONFIG-----------------*/
558/* field: EWAIT - EEPROM Wait state Counter */
559#define TMS570_FLASH_EEPROMCONFIG_EWAIT(val) BSP_FLD32(val,16, 19)
560#define TMS570_FLASH_EEPROMCONFIG_EWAIT_GET(reg) BSP_FLD32GET(reg,16, 19)
561#define TMS570_FLASH_EEPROMCONFIG_EWAIT_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
562
563/* field: AUTOSUSP_EN - Auto Suspend Enable */
564#define TMS570_FLASH_EEPROMCONFIG_AUTOSUSP_EN BSP_BIT32(8)
565
566/* field: AUTOSTART_GRACE - Auto-suspend Startup Grace Period */
567#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE(val) BSP_FLD32(val,0, 7)
568#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET(reg) BSP_FLD32GET(reg,0, 7)
569#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
570
571
572/*--------------------TMS570_FLASH_EECTRL1--------------------*/
573/* field: EDACMODE - Error Correction Mode. */
574#define TMS570_FLASH_EECTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
575#define TMS570_FLASH_EECTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
576#define TMS570_FLASH_EECTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
577
578/* field: EE_EOFEN - EEPROM Emulation Event on a correctable One's Fail Enable bit */
579#define TMS570_FLASH_EECTRL1_EE_EOFEN BSP_BIT32(10)
580
581/* field: EE_EZFEN - EEPROM Emulation Event on a correctable Zero's Fail Enable bit */
582#define TMS570_FLASH_EECTRL1_EE_EZFEN BSP_BIT32(9)
583
584/* field: EE_EPEN - EEPROM Emulation Error Profiling Enable. */
585#define TMS570_FLASH_EECTRL1_EE_EPEN BSP_BIT32(8)
586
587
588/*--------------------TMS570_FLASH_EECTRL2--------------------*/
589/* field: EE_SEC_THRESHOLD - EEPROM Emulation Single Error Correction Threshold */
590#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
591#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
592#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
593
594
595/*------------------TMS570_FLASH_EECORERRCNT------------------*/
596/* field: EE_ERRCNT - Single Error Correction Count */
597#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT(val) BSP_FLD32(val,0, 15)
598#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
599#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
600
601
602/*------------------TMS570_FLASH_EECORERRADD------------------*/
603/* field: COR_ERR_ADD - Correctable Error Address */
604#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
605#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
606#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
607
608/* field: B_OFF - Byte offset */
609#define TMS570_FLASH_EECORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
610#define TMS570_FLASH_EECORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
611#define TMS570_FLASH_EECORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
612
613
614/*------------------TMS570_FLASH_EECORERRPOS------------------*/
615/* field: TYPE - ErrorType */
616#define TMS570_FLASH_EECORERRPOS_TYPE BSP_BIT32(8)
617
618/* field: EE_ERR_POS - The bit address of the single bit error */
619#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS(val) BSP_FLD32(val,0, 7)
620#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
621#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
622
623
624/*-------------------TMS570_FLASH_EESTATUS-------------------*/
625/* field: EE_D_UNC_ERR - Diagnostic Mode Uncorrectable Error Status Flag */
626#define TMS570_FLASH_EESTATUS_EE_D_UNC_ERR BSP_BIT32(12)
627
628/* field: EE_UNC_ERR - EEPROM Emulation Uncorrectable Error Flag */
629#define TMS570_FLASH_EESTATUS_EE_UNC_ERR BSP_BIT32(8)
630
631/* field: EE_CMG - EEPROM Emulation Compare Malfunction Good */
632#define TMS570_FLASH_EESTATUS_EE_CMG BSP_BIT32(6)
633
634/* field: EE_CME - . */
635#define TMS570_FLASH_EESTATUS_EE_CME BSP_BIT32(4)
636
637/* field: EE_D_COR_ERR - Diagnostic Correctable Error Flag */
638#define TMS570_FLASH_EESTATUS_EE_D_COR_ERR BSP_BIT32(3)
639
640/* field: EE_ERR_ONE_FLG - Error on One Fail Error Flag */
641#define TMS570_FLASH_EESTATUS_EE_ERR_ONE_FLG BSP_BIT32(2)
642
643/* field: EE_ERR_ZERO_FLG - Error on Zero Fail Error Flag */
644#define TMS570_FLASH_EESTATUS_EE_ERR_ZERO_FLG BSP_BIT32(1)
645
646/* field: EE_ERR_PRF_FLG - Error Profiling Error Flag */
647#define TMS570_FLASH_EESTATUS_EE_ERR_PRF_FLG BSP_BIT32(0)
648
649
650/*------------------TMS570_FLASH_EEUNCERRADD------------------*/
651/* field: UNC_ERR_ADD - Un-correctable Error Address */
652#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
653#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
654#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
655
656/* field: B_OFF - Byte offset */
657#define TMS570_FLASH_EEUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
658#define TMS570_FLASH_EEUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
659#define TMS570_FLASH_EEUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
660
661
662/*-------------------TMS570_FLASH_FCFGBANK-------------------*/
663/* field: EE_BANK_WIDTH - Bank 7 width (144 bits wide) */
664#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH(val) BSP_FLD32(val,20, 31)
665#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,20, 31)
666#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,20, 31)
667
668/* field: MAIN_BANK_WIDTH - Width of main flash banks (144 bits wide) */
669#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH(val) BSP_FLD32(val,4, 15)
670#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,4, 15)
671#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,4, 15)
672
673
674
675#endif /* LIBBSP_ARM_TMS570_FLASH */
Utility macros.
Definition: reg_flash.h:44
