RTEMS 5.2
reg_efuse.h
1/* The header file is generated by make_header.py from EFUSE.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_EFUSE
40#define LIBBSP_ARM_TMS570_EFUSE
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t EFCBOUND; /*EFC Boundary Control Register*/
46 uint8_t reserved1 [12];
47 uint32_t EFCPINS; /*EFC Pins Register*/
48 uint8_t reserved2 [12];
49 uint32_t EFC_ERR_STAT; /*EFC Error Status Register*/
50 uint8_t reserved3 [8];
51 uint32_t EFC_ST_CY; /*EFC Self Test Cycles Register*/
52 uint32_t EFC_ST_SIG; /*EFC Self Test Signature Register*/
54
55
56/*-------------------TMS570_EFUSE_EFCBOUND-------------------*/
57/* field: EFC_Self_Test_Error - This bit drives the self test error signal when bit 17 (Self Test Error OE) is high. */
58#define TMS570_EFUSE_EFCBOUND_EFC_Self_Test_Error BSP_BIT32(21)
59
60/* field: EFC_Single_Bit_Error - This bit drives the single bit error signal when bit 16 (Single bit Error OE) is high. */
61#define TMS570_EFUSE_EFCBOUND_EFC_Single_Bit_Error BSP_BIT32(20)
62
63/* field: EFC_Instruction_Error - This bit drives the instruction error signal when bit 15 (Instruction Error OE) is high. */
64#define TMS570_EFUSE_EFCBOUND_EFC_Instruction_Error BSP_BIT32(19)
65
66/* field: EFC_Autoload_Error - This bit drives the Autoload Error signal when bit 14 (Autoload Error OE) is high. */
67#define TMS570_EFUSE_EFCBOUND_EFC_Autoload_Error BSP_BIT32(18)
68
69/* field: Self_Test_Error_OE - The Self Test Error Output Enable bit determines if the EFC Self Test signal comes from the */
70#define TMS570_EFUSE_EFCBOUND_Self_Test_Error_OE BSP_BIT32(17)
71
72/* field: Single_Bit_Error_OE - The single bit error output enable signal determines if the EFC Single Bit Error signal comes */
73#define TMS570_EFUSE_EFCBOUND_Single_Bit_Error_OE BSP_BIT32(16)
74
75/* field: Instruction_Error_OE - comes from the eFuse controller or from bit 19 of the boundary register. */
76#define TMS570_EFUSE_EFCBOUND_Instruction_Error_OE BSP_BIT32(15)
77
78/* field: Autoload_Error_OE - The autoload error output enable signal determines if the EFC Autoload Error signal comes */
79#define TMS570_EFUSE_EFCBOUND_Autoload_Error_OE BSP_BIT32(14)
80
81/* field: EFC_ECC_Selftest - The eFuse Controller ECC Selftest Enable bit starts the selftest of the ECC logic if the four */
82#define TMS570_EFUSE_EFCBOUND_EFC_ECC_Selftest BSP_BIT32(13)
83
84/* field: Input_Enable - The eFuse Controller ECC Selftest Enable bit starts the selftest of the ECC logic if the four */
85#define TMS570_EFUSE_EFCBOUND_Input_Enable(val) BSP_FLD32(val,0, 3)
86#define TMS570_EFUSE_EFCBOUND_Input_Enable_GET(reg) BSP_FLD32GET(reg,0, 3)
87#define TMS570_EFUSE_EFCBOUND_Input_Enable_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
88
89
90/*--------------------TMS570_EFUSE_EFCPINS--------------------*/
91/* field: EFC_Selftest_Done - This bit can be polled to determine when the EFC ECC selftest is complete */
92#define TMS570_EFUSE_EFCPINS_EFC_Selftest_Done BSP_BIT32(15)
93
94/* field: EFC_Selftest_Error - This bit indicates the pass/fail status of the EFC ECC Selftest once the EFC Selftest Done */
95#define TMS570_EFUSE_EFCPINS_EFC_Selftest_Error BSP_BIT32(14)
96
97/* field: EFC_Single_Bit_Error - This bit indicates if a single bit error was corrected by the ECC logic during the autoload */
98#define TMS570_EFUSE_EFCPINS_EFC_Single_Bit_Error BSP_BIT32(12)
99
100/* field: EFC_Instruction_Error - This bit indicates an error occured during a factory test or program operation. */
101#define TMS570_EFUSE_EFCPINS_EFC_Instruction_Error BSP_BIT32(11)
102
103/* field: EFC_Autoload_Error - This bit indicates that some non-correctable error occurred during the autoload sequence */
104#define TMS570_EFUSE_EFCPINS_EFC_Autoload_Error BSP_BIT32(10)
105
106
107/*-----------------TMS570_EFUSE_EFC_ERR_STAT-----------------*/
108/* field: Instruc_Done - Instruction done. */
109#define TMS570_EFUSE_EFC_ERR_STAT_Instruc_Done BSP_BIT32(5)
110
111/* field: Error_Code - The error status of the last instruction executed by the eFuse Controller */
112#define TMS570_EFUSE_EFC_ERR_STAT_Error_Code(val) BSP_FLD32(val,0, 4)
113#define TMS570_EFUSE_EFC_ERR_STAT_Error_Code_GET(reg) BSP_FLD32GET(reg,0, 4)
114#define TMS570_EFUSE_EFC_ERR_STAT_Error_Code_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
115
116
117/*-------------------TMS570_EFUSE_EFC_ST_CY-------------------*/
118/* field: Cycles - This register is used to determine the number of cycles to run the eFuse controller ECC logic self test. */
119/* Whole 32 bits */
120
121/*------------------TMS570_EFUSE_EFC_ST_SIG------------------*/
122/* field: Signature - This register is used to hold the expected signature for the eFuse ECC logic self test. */
123/* Whole 32 bits */
124
125
126#endif /* LIBBSP_ARM_TMS570_EFUSE */
Utility macros.
Definition: reg_efuse.h:44
