RTEMS 5.2
pte121.h
1#ifndef _LIBCPU_PTE121_H
2#define _LIBCPU_PTE121_H
3
4/*
5 * Authorship
6 * ----------
7 * This software was created by
8 * Till Straumann <strauman@slac.stanford.edu>, 4/2002, 2003, 2004,
9 * Stanford Linear Accelerator Center, Stanford University.
10 *
11 * Acknowledgement of sponsorship
12 * ------------------------------
13 * This software was produced by
14 * the Stanford Linear Accelerator Center, Stanford University,
15 * under Contract DE-AC03-76SFO0515 with the Department of Energy.
16 *
17 * Government disclaimer of liability
18 * ----------------------------------
19 * Neither the United States nor the United States Department of Energy,
20 * nor any of their employees, makes any warranty, express or implied, or
21 * assumes any legal liability or responsibility for the accuracy,
22 * completeness, or usefulness of any data, apparatus, product, or process
23 * disclosed, or represents that its use would not infringe privately owned
24 * rights.
25 *
26 * Stanford disclaimer of liability
27 * --------------------------------
28 * Stanford University makes no representations or warranties, express or
29 * implied, nor assumes any liability for the use of this software.
30 *
31 * Stanford disclaimer of copyright
32 * --------------------------------
33 * Stanford University, owner of the copyright, hereby disclaims its
34 * copyright and all other rights in this software. Hence, anyone may
35 * freely use it for any purpose without restriction.
36 *
37 * Maintenance of notices
38 * ----------------------
39 * In the interest of clarity regarding the origin and status of this
40 * SLAC software, this and all the preceding Stanford University notices
41 * are to remain affixed to any copy or derivative of this software made
42 * or distributed by the recipient and are to be affixed to any copy of
43 * software made or distributed by the recipient that contains a copy or
44 * derivative of this software.
45 *
46 * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
47 */
48
49/* Rudimentary page/hash table support for Powerpc
50 *
51 * A simple, static (i.e. no 'per-process' virtual
52 * address space etc.) page table providing
53 * one-to-one effective <-> virtual <-> physical
54 * address mapping.
55 *
56 * PURPOSE:
57 * 1) allow write-protection of text/read-only data areas
58 * 2) provide more effective-address space in case
59 * the BATs are not enough
60 * 3) allow 'alias' mappings. Such aliases can only use
61 * the upper bits of the VSID since VSID & 0xf and the
62 * PI are always mapped 1:1 to the RPN.
63 * LIMITATIONS:
64 * - no PTE replacement (makes no sense in a real-time
65 * environment, anyway) -> the page table just MUST
66 * be big enough!.
67 * - only one page table supported.
68 * - no locking implemented. If multiple threads modify
69 * the page table, it is the user's responsibility to
70 * implement exclusive access.
71 */
72
73
74/* I don't include mmu.h here because it says it's derived from linux
75 * and I want to avoid licensing problems
76 */
77
78/* Abstract handle for a page table */
79typedef struct Triv121PgTblRec_ *Triv121PgTbl;
80
81/* A PTE entry */
82typedef struct PTERec_ {
83 volatile unsigned long v:1, vsid:24, h:1, api: 6;
84 volatile unsigned long rpn:20, pad: 3, r:1, c:1, wimg:4, marked:1, pp:2;
85} PTERec, *APte;
86
87/* Initialize a trivial page table
88 * using 2^ldSize bytes of memory starting at
89 * 'base'.
90 *
91 * RETURNS: a handle to the internal data structure
92 * used to manage the page table. NULL on
93 * error.
94 *
95 * NOTES: - 'base' must be aligned to the size
96 * - minimal ldSize is 16 (== 64k)
97 * - this routine maps the page table itself
98 * with read-only access. While this prevents
99 * the CPU from overwriting the page table,
100 * it can still be corrupted by PCI bus masters
101 * (like DMA engines, [VME] bridges etc.) and
102 * even by this CPU if either the MMU is off
103 * or if there is a DBAT mapping granting write
104 * access...
105 */
107triv121PgTblInit(unsigned long base, unsigned ldSize);
108
109/* get the log2 of the minimal page table size needed
110 * for mapping 'size' bytes.
111 *
112 * EXAMPLE: create a page table which maps the entire
113 * physical memory. The page table itself shall
114 * be allocated at the top of the available
115 * memory (assuming 'memsize' is a power of two):
116 *
117 * ldSize = triv121PgTblLdMinSize(memsize);
118 * memsize -= (1<<ldSize); / * reduce memory available to RTEMS * /
119 * pgTbl = triv121PgTblInit(memsize,ldSize);
120 *
121 */
122unsigned long
123triv121PgTblLdMinSize(unsigned long size);
124
125/* Map an address range 1:1 in pgTbl with the given protection;
126 *
127 * RETURNS: -1 (TRIV121_MAP_SUCCESS) on success; the page index
128 * for which no PTE could be allocated, on failure.
129 *
130 * NOTES: - This routine returns MINUS ONE ON SUCCESS
131 * - (parts) of a mapping which overlap with
132 * already existing PTEs are silently ignored.
133 *
134 * Therefore, you can e.g. first create
135 * a couple of write protected maps and
136 * finally map the entire memory r/w. This
137 * will leave the write protected maps
138 * intact.
139 */
140long
141triv121PgTblMap(
142 Triv121PgTbl pgTbl, /* handle, returned by Init or Get */
143
144 long vsid, /* vsid for this mapping (contains topmost 4 bits of EA);
145 *
146 * NOTE: it is allowed to pass a VSID < 0 to tell this
147 * routine it should use a VSID corresponding to a
148 * 1:1:1 effective - virtual - physical mapping
149 */
150
151 unsigned long start, /* segment offset (lowermost 28 bits of EA) of address range
152 *
153 * NOTE: if VSID < 0 (TRIV121_121_VSID), 'start' is inter-
154 * preted as an effective address (EA), i.e. all 32
155 * bits are used - the most significant four going into
156 * to the VSID...
157 */
158
159 unsigned long numPages, /* number of pages to map */
160
161 unsigned wimgAttr, /* 'wimg' attributes
162 * (Write thru, cache Inhibit, coherent Memory,
163 * Guarded memory)
164 */
165
166 unsigned protection /* 'pp' access protection: Super User
167 *
168 * 0 r/w none
169 * 1 r/w ro
170 * 2 r/w r/w
171 * 3 ro ro
172 */
173);
174
175#define TRIV121_ATTR_W 8
176#define TRIV121_ATTR_I 4
177#define TRIV121_ATTR_M 2
178#define TRIV121_ATTR_G 1
179
180/* for I/O pages (e.g. PCI, VME addresses) use cache inhibited
181 * and guarded pages. RTM about the 'eieio' instruction!
182 */
183#define TRIV121_ATTR_IO_PAGE (TRIV121_ATTR_I|TRIV121_ATTR_G)
184
185#define TRIV121_PP_RO_PAGE (1) /* read-only for key = 1, unlocked by key=0 */
186#define TRIV121_PP_RW_PAGE (2) /* read-write for key = 1/0 */
187
188#define TRIV121_121_VSID (-1) /* use 1:1 effective<->virtual address mapping */
189#define TRIV121_SEG_VSID (-2) /* lookup VSID in the segment register */
190
191#define TRIV121_MAP_SUCCESS (-1) /* triv121PgTblMap() returns this on SUCCESS */
192
193/* get a handle to the one and only page table
194 * (must have been initialized/allocated)
195 *
196 * RETURNS: NULL if the page table has not been initialized/allocated.
197 */
199triv121PgTblGet(void);
200
201/*
202 * compute the SDR1 register value for the page table
203 */
204
205unsigned long
206triv121PgTblSDR1(Triv121PgTbl pgTbl);
207
208/*
209 * Activate the page table:
210 * - set up the segment registers for a 1:1 effective <-> virtual address mapping,
211 * give user and supervisor keys.
212 * - set up the SDR1 register
213 * - flush all tlbs
214 * - 'lock' pgTbl, i.e. prevent all further modifications.
215 *
216 * NOTE: This routine does not change any BATs. Since these
217 * have priority over the page table, the user
218 * may have to switch overlapping BATs OFF in order
219 * for the page table mappings to take effect.
220 */
221void triv121PgTblActivate(Triv121PgTbl pgTbl);
222
223/* Find the PTE for a EA and print its contents to stdout
224 * RETURNS: pte for EA or NULL if no entry was found.
225 */
226APte triv121DumpEa(unsigned long ea);
227
228/* Find and return a PTE for a vsid/pi combination
229 * RETURNS: pte or NULL if no entry was found
230 */
231APte triv121FindPte(unsigned long vsid, unsigned long pi);
232
233/*
234 * Unmap an effective address
235 *
236 * RETURNS: pte that mapped the ea or NULL if no
237 * mapping existed.
238 */
239APte triv121UnmapEa(unsigned long ea);
240
241/*
242 * Change the WIMG and PP attributes of the page containing 'ea'
243 *
244 * NOTES: The 'wimg' and 'pp' may be <0 to indicate that no
245 * change is desired.
246 *
247 * RETURNS: Pointer to modified PTE or NULL if 'ea' is not mapped.
248 */
249APte triv121ChangeEaAttributes(unsigned long ea, int wimg, int pp);
250
251/* Make the whole page table writable
252 * NOTES: If the page table has not been initialized yet,
253 * this routine has no effect (i.e., after
254 * initialization the page table will still be read-only).
255 */
256void triv121MakePgTblRW(void);
257
258/* Make the whole page table read-only
259 */
260void triv121MakePgTblRO(void);
261
262/* Dump a pte to stdout */
263long triv121DumpPte(APte pte);
264
265#endif
Definition: pte121.h:82
Definition: pte121.c:211
Definition: mmu.h:130
unsigned size
Definition: tte.h:1
