RTEMS 5.2
ps2_mouse.h
1
9/*
10 * include/linux/pc_keyb.h
11 * PC Keyboard And Keyboard Controller
12 * (c) 1997 Martin Mares <mj@atrey.karlin.mff.cuni.cz>
13 *
14 * RTEMS port: by Rosimildo da Silva.
15 *
16 * This module was ported from Linux.
17 *
18 */
19
20/*
21 * Configuration Switches
22 */
23
24#undef KBD_REPORT_ERR /* Report keyboard errors */
25#define KBD_REPORT_UNKN /* Report unknown scan codes */
26#define KBD_REPORT_TIMEOUTS /* Report keyboard timeouts */
27#undef KBD_IS_FOCUS_9000 /* We have the brain-damaged FOCUS-9000 keyboard */
28#undef INITIALIZE_MOUSE /* Define if your PS/2 mouse needs initialization. */
29
30#define KBD_INIT_TIMEOUT 1000 /* Timeout in ms for initializing the keyboard */
31#define KBC_TIMEOUT 250 /* Timeout in ms for sending to keyboard controller */
32#define KBD_TIMEOUT 1000 /* Timeout in ms for keyboard command acknowledge */
33
34/*
35 * Internal variables of the driver
36 */
37
38extern unsigned char pckbd_read_mask;
39extern unsigned char aux_device_present;
40
41/*
42 * Keyboard Controller Registers on normal PCs.
43 */
44
45#define KBD_STATUS_REG 0x64 /* Status register (R) */
46#define KBD_CNTL_REG 0x64 /* Controller command register (W) */
47#define KBD_DATA_REG 0x60 /* Keyboard data register (R/W) */
48
49/*
50 * Keyboard Controller Commands
51 */
52
53#define KBD_CCMD_READ_MODE 0x20 /* Read mode bits */
54#define KBD_CCMD_WRITE_MODE 0x60 /* Write mode bits */
55#define KBD_CCMD_GET_VERSION 0xA1 /* Get controller version */
56#define KBD_CCMD_MOUSE_DISABLE 0xA7 /* Disable mouse interface */
57#define KBD_CCMD_MOUSE_ENABLE 0xA8 /* Enable mouse interface */
58#define KBD_CCMD_TEST_MOUSE 0xA9 /* Mouse interface test */
59#define KBD_CCMD_SELF_TEST 0xAA /* Controller self test */
60#define KBD_CCMD_KBD_TEST 0xAB /* Keyboard interface test */
61#define KBD_CCMD_KBD_DISABLE 0xAD /* Keyboard interface disable */
62#define KBD_CCMD_KBD_ENABLE 0xAE /* Keyboard interface enable */
63#define KBD_CCMD_WRITE_AUX_OBUF 0xD3 /* Write to output buffer as if
64 initiated by the auxiliary device */
65#define KBD_CCMD_WRITE_MOUSE 0xD4 /* Write the following byte to the mouse */
66
67/*
68 * Keyboard Commands
69 */
70
71#define KBD_CMD_SET_LEDS 0xED /* Set keyboard leds */
72#define KBD_CMD_SET_RATE 0xF3 /* Set typematic rate */
73#define KBD_CMD_ENABLE 0xF4 /* Enable scanning */
74#define KBD_CMD_DISABLE 0xF5 /* Disable scanning */
75#define KBD_CMD_RESET 0xFF /* Reset */
76
77/*
78 * Keyboard Replies
79 */
80
81#define KBD_REPLY_POR 0xAA /* Power on reset */
82#define KBD_REPLY_ACK 0xFA /* Command ACK */
83#define KBD_REPLY_RESEND 0xFE /* Command NACK, send the cmd again */
84
85/*
86 * Status Register Bits
87 */
88
89#define KBD_STAT_OBF 0x01 /* Keyboard output buffer full */
90#define KBD_STAT_IBF 0x02 /* Keyboard input buffer full */
91#define KBD_STAT_SELFTEST 0x04 /* Self test successful */
92#define KBD_STAT_CMD 0x08 /* Last write was a command write (0=data) */
93#define KBD_STAT_UNLOCKED 0x10 /* Zero if keyboard locked */
94#define KBD_STAT_MOUSE_OBF 0x20 /* Mouse output buffer full */
95#define KBD_STAT_GTO 0x40 /* General receive/xmit timeout */
96#define KBD_STAT_PERR 0x80 /* Parity error */
97
98#define AUX_STAT_OBF (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF)
99
100/*
101 * Controller Mode Register Bits
102 */
103
104#define KBD_MODE_KBD_INT 0x01 /* Keyboard data generate IRQ1 */
105#define KBD_MODE_MOUSE_INT 0x02 /* Mouse data generate IRQ12 */
106#define KBD_MODE_SYS 0x04 /* The system flag (?) */
107#define KBD_MODE_NO_KEYLOCK 0x08 /* The keylock doesn't affect the keyboard if set */
108#define KBD_MODE_DISABLE_KBD 0x10 /* Disable keyboard interface */
109#define KBD_MODE_DISABLE_MOUSE 0x20 /* Disable mouse interface */
110#define KBD_MODE_KCC 0x40 /* Scan code conversion to PC format */
111#define KBD_MODE_RFU 0x80
112
113/*
114 * Mouse Commands
115 */
116
117#define AUX_SET_RES 0xE8 /* Set resolution */
118#define AUX_SET_SCALE11 0xE6 /* Set 1:1 scaling */
119#define AUX_SET_SCALE21 0xE7 /* Set 2:1 scaling */
120#define AUX_GET_SCALE 0xE9 /* Get scaling factor */
121#define AUX_SET_STREAM 0xEA /* Set stream mode */
122#define AUX_SET_SAMPLE 0xF3 /* Set sample rate */
123#define AUX_ENABLE_DEV 0xF4 /* Enable aux device */
124#define AUX_DISABLE_DEV 0xF5 /* Disable aux device */
125#define AUX_RESET 0xFF /* Reset aux device */
126#define AUX_ACK 0xFA /* Command byte ACK. */
127
128#define AUX_BUF_SIZE 512 /* This might be better divisible by
129 three to make overruns stay in sync
130 but then the read function would need
131 a lock etc - ick */
132
133struct aux_queue {
134 unsigned long head;
135 unsigned long tail;
136 struct wait_queue *proc_list;
137 struct fasync_struct *fasync;
138 unsigned char buf[AUX_BUF_SIZE];
139};
140
141/* How to access the keyboard macros on this platform. */
142#define kbd_read_input() inb(KBD_DATA_REG)
143#define kbd_read_status() inb(KBD_STATUS_REG)
144#define kbd_write_output(val) outb(val, KBD_DATA_REG)
145#define kbd_write_command(val) outb(val, KBD_CNTL_REG)
146
147/*
148 * Machine specific bits for the PS/2 driver
149 */
150
151#define AUX_IRQ 12
Definition: ps2_mouse.h:129
