RTEMS 5.2
pnp.h
1/* 11/02/95 */
2/*----------------------------------------------------------------------------*/
3/* Plug and Play header definitions */
4/*----------------------------------------------------------------------------*/
5
6/* Structure map for PnP on PowerPC Reference Platform */
7/* See Plug and Play ISA Specification, Version 1.0, May 28, 1993. It */
8/* (or later versions) is available on Compuserve in the PLUGPLAY area. */
9/* This code has extensions to that specification, namely new short and */
10/* long tag types for platform dependent information */
11
12/* Warning: LE notation used throughout this file */
13
14/* For enum's: if given in hex then they are bit significant, i.e. */
15/* only one bit is on for each enum */
16
17
18#ifndef _PNP_
19#define _PNP_
20
21#ifndef ASM
22#define MAX_MEM_REGISTERS 9
23#define MAX_IO_PORTS 20
24#define MAX_IRQS 7
25/*#define MAX_DMA_CHANNELS 7*/
26
27/* Interrupt controllers */
28
29#define PNPinterrupt0 "PNP0000" /* AT Interrupt Controller */
30#define PNPinterrupt1 "PNP0001" /* EISA Interrupt Controller */
31#define PNPinterrupt2 "PNP0002" /* MCA Interrupt Controller */
32#define PNPinterrupt3 "PNP0003" /* APIC */
33#define PNPExtInt "IBM000D" /* PowerPC Extended Interrupt Controller */
34
35/* Timers */
36
37#define PNPtimer0 "PNP0100" /* AT Timer */
38#define PNPtimer1 "PNP0101" /* EISA Timer */
39#define PNPtimer2 "PNP0102" /* MCA Timer */
40
41/* DMA controllers */
42
43#define PNPdma0 "PNP0200" /* AT DMA Controller */
44#define PNPdma1 "PNP0201" /* EISA DMA Controller */
45#define PNPdma2 "PNP0202" /* MCA DMA Controller */
46
47/* start of August 15, 1994 additions */
48/* CMOS */
49#define PNPCMOS "IBM0009" /* CMOS */
50
51/* L2 Cache */
52#define PNPL2 "IBM0007" /* L2 Cache */
53
54/* NVRAM */
55#define PNPNVRAM "IBM0008" /* NVRAM */
56
57/* Power Management */
58#define PNPPM "IBM0005" /* Power Management */
59/* end of August 15, 1994 additions */
60
61/* Keyboards */
62
63#define PNPkeyboard0 "PNP0300" /* IBM PC/XT KB Cntlr (83 key, no mouse) */
64#define PNPkeyboard1 "PNP0301" /* Olivetti ICO (102 key) */
65#define PNPkeyboard2 "PNP0302" /* IBM PC/AT KB Cntlr (84 key) */
66#define PNPkeyboard3 "PNP0303" /* IBM Enhanced (101/2 key, PS/2 mouse) */
67#define PNPkeyboard4 "PNP0304" /* Nokia 1050 KB Cntlr */
68#define PNPkeyboard5 "PNP0305" /* Nokia 9140 KB Cntlr */
69#define PNPkeyboard6 "PNP0306" /* Standard Japanese KB Cntlr */
70#define PNPkeyboard7 "PNP0307" /* Microsoft Windows (R) KB Cntlr */
71
72/* Parallel port controllers */
73
74#define PNPparallel0 "PNP0400" /* Standard LPT Parallel Port */
75#define PNPparallel1 "PNP0401" /* ECP Parallel Port */
76#define PNPepp "IBM001C" /* EPP Parallel Port */
77
78/* Serial port controllers */
79
80#define PNPserial0 "PNP0500" /* Standard PC Serial port */
81#define PNPSerial1 "PNP0501" /* 16550A Compatible Serial port */
82
83/* Disk controllers */
84
85#define PNPdisk0 "PNP0600" /* Generic ESDI/IDE/ATA Compat HD Cntlr */
86#define PNPdisk1 "PNP0601" /* Plus Hardcard II */
87#define PNPdisk2 "PNP0602" /* Plus Hardcard IIXL/EZ */
88
89/* Diskette controllers */
90
91#define PNPdiskette0 "PNP0700" /* PC Standard Floppy Disk Controller */
92
93/* Display controllers */
94
95#define PNPdisplay0 "PNP0900" /* VGA Compatible */
96#define PNPdisplay1 "PNP0901" /* Video Seven VGA */
97#define PNPdisplay2 "PNP0902" /* 8514/A Compatible */
98#define PNPdisplay3 "PNP0903" /* Trident VGA */
99#define PNPdisplay4 "PNP0904" /* Cirrus Logic Laptop VGA */
100#define PNPdisplay5 "PNP0905" /* Cirrus Logic VGA */
101#define PNPdisplay6 "PNP0906" /* Tseng ET4000 or ET4000/W32 */
102#define PNPdisplay7 "PNP0907" /* Western Digital VGA */
103#define PNPdisplay8 "PNP0908" /* Western Digital Laptop VGA */
104#define PNPdisplay9 "PNP0909" /* S3 */
105#define PNPdisplayA "PNP090A" /* ATI Ultra Pro/Plus (Mach 32) */
106#define PNPdisplayB "PNP090B" /* ATI Ultra (Mach 8) */
107#define PNPdisplayC "PNP090C" /* XGA Compatible */
108#define PNPdisplayD "PNP090D" /* ATI VGA Wonder */
109#define PNPdisplayE "PNP090E" /* Weitek P9000 Graphics Adapter */
110#define PNPdisplayF "PNP090F" /* Oak Technology VGA */
111
112/* Peripheral busses */
113
114#define PNPbuses0 "PNP0A00" /* ISA Bus */
115#define PNPbuses1 "PNP0A01" /* EISA Bus */
116#define PNPbuses2 "PNP0A02" /* MCA Bus */
117#define PNPbuses3 "PNP0A03" /* PCI Bus */
118#define PNPbuses4 "PNP0A04" /* VESA/VL Bus */
119
120/* RTC, BIOS, planar devices */
121
122#define PNPspeaker0 "PNP0800" /* AT Style Speaker Sound */
123#define PNPrtc0 "PNP0B00" /* AT RTC */
124#define PNPpnpbios0 "PNP0C00" /* PNP BIOS (only created by root enum) */
125#define PNPpnpbios1 "PNP0C01" /* System Board Memory Device */
126#define PNPpnpbios2 "PNP0C02" /* Math Coprocessor */
127#define PNPpnpbios3 "PNP0C03" /* PNP BIOS Event Notification Interrupt */
128
129/* PCMCIA controller */
130
131#define PNPpcmcia0 "PNP0E00" /* Intel 82365 Compatible PCMCIA Cntlr */
132
133/* Mice */
134
135#define PNPmouse0 "PNP0F00" /* Microsoft Bus Mouse */
136#define PNPmouse1 "PNP0F01" /* Microsoft Serial Mouse */
137#define PNPmouse2 "PNP0F02" /* Microsoft Inport Mouse */
138#define PNPmouse3 "PNP0F03" /* Microsoft PS/2 Mouse */
139#define PNPmouse4 "PNP0F04" /* Mousesystems Mouse */
140#define PNPmouse5 "PNP0F05" /* Mousesystems 3 Button Mouse - COM2 */
141#define PNPmouse6 "PNP0F06" /* Genius Mouse - COM1 */
142#define PNPmouse7 "PNP0F07" /* Genius Mouse - COM2 */
143#define PNPmouse8 "PNP0F08" /* Logitech Serial Mouse */
144#define PNPmouse9 "PNP0F09" /* Microsoft Ballpoint Serial Mouse */
145#define PNPmouseA "PNP0F0A" /* Microsoft PNP Mouse */
146#define PNPmouseB "PNP0F0B" /* Microsoft PNP Ballpoint Mouse */
147
148/* Modems */
149
150#define PNPmodem0 "PNP9000" /* Specific IDs TBD */
151
152/* Network controllers */
153
154#define PNPnetworkC9 "PNP80C9" /* IBM Token Ring */
155#define PNPnetworkCA "PNP80CA" /* IBM Token Ring II */
156#define PNPnetworkCB "PNP80CB" /* IBM Token Ring II/Short */
157#define PNPnetworkCC "PNP80CC" /* IBM Token Ring 4/16Mbs */
158#define PNPnetwork27 "PNP8327" /* IBM Token Ring (All types) */
159#define PNPnetworket "IBM0010" /* IBM Ethernet used by Power PC */
160#define PNPneteisaet "IBM2001" /* IBM Ethernet EISA adapter */
161#define PNPAMD79C970 "IBM0016" /* AMD 79C970 (PCI Ethernet) */
162
163/* SCSI controllers */
164
165#define PNPscsi0 "PNPA000" /* Adaptec 154x Compatible SCSI Cntlr */
166#define PNPscsi1 "PNPA001" /* Adaptec 174x Compatible SCSI Cntlr */
167#define PNPscsi2 "PNPA002" /* Future Domain 16-700 Compat SCSI Cntlr*/
168#define PNPscsi3 "PNPA003" /* Panasonic CDROM Adapter (SBPro/SB16) */
169#define PNPscsiF "IBM000F" /* NCR 810 SCSI Controller */
170#define PNPscsi825 "IBM001B" /* NCR 825 SCSI Controller */
171#define PNPscsi875 "IBM0018" /* NCR 875 SCSI Controller */
172
173/* Sound/Video, Multimedia */
174
175#define PNPmm0 "PNPB000" /* Sound Blaster Compatible Sound Device */
176#define PNPmm1 "PNPB001" /* MS Windows Sound System Compat Device */
177#define PNPmmF "IBM000E" /* Crystal CS4231 Audio Device */
178#define PNPv7310 "IBM0015" /* ASCII V7310 Video Capture Device */
179#define PNPmm4232 "IBM0017" /* Crystal CS4232 Audio Device */
180#define PNPpmsyn "IBM001D" /* YMF 289B chip (Yamaha) */
181#define PNPgp4232 "IBM0012" /* Crystal CS4232 Game Port */
182#define PNPmidi4232 "IBM0013" /* Crystal CS4232 MIDI */
183
184/* Operator Panel */
185#define PNPopctl "IBM000B" /* Operator's panel */
186
187/* Service Processor */
188#define PNPsp "IBM0011" /* IBM Service Processor */
189#define PNPLTsp "IBM001E" /* Lightning/Terlingua Support Processor */
190#define PNPLTmsp "IBM001F" /* Lightning/Terlingua Mini-SP */
191
192/* Memory Controller */
193#define PNPmemctl "IBM000A" /* Memory controller */
194
195/* Graphics Assist */
196#define PNPg_assist "IBM0014" /* Graphics Assist */
197
198/* Miscellaneous Device Controllers */
199#define PNPtablet "IBM0019" /* IBM Tablet Controller */
200
201/* PNP Packet Handles */
202
203#define S1_Packet 0x0A /* Version resource */
204#define S2_Packet 0x15 /* Logical DEVID (without flags) */
205#define S2_Packet_flags 0x16 /* Logical DEVID (with flags) */
206#define S3_Packet 0x1C /* Compatible device ID */
207#define S4_Packet 0x22 /* IRQ resource (without flags) */
208#define S4_Packet_flags 0x23 /* IRQ resource (with flags) */
209#define S5_Packet 0x2A /* DMA resource */
210#define S6_Packet 0x30 /* Depend funct start (w/o priority) */
211#define S6_Packet_priority 0x31 /* Depend funct start (w/ priority) */
212#define S7_Packet 0x38 /* Depend funct end */
213#define S8_Packet 0x47 /* I/O port resource (w/o fixed loc) */
214#define S9_Packet_fixed 0x4B /* I/O port resource (w/ fixed loc) */
215#define S14_Packet 0x71 /* Vendor defined */
216#define S15_Packet 0x78 /* End of resource (w/o checksum) */
217#define S15_Packet_checksum 0x79 /* End of resource (w/ checksum) */
218#define L1_Packet 0x81 /* Memory range */
219#define L1_Shadow 0x20 /* Memory is shadowable */
220#define L1_32bit_mem 0x18 /* 32-bit memory only */
221#define L1_8_16bit_mem 0x10 /* 8- and 16-bit supported */
222#define L1_Decode_Hi 0x04 /* decode supports high address */
223#define L1_Cache 0x02 /* read cacheable, write-through */
224#define L1_Writeable 0x01 /* Memory is writeable */
225#define L2_Packet 0x82 /* ANSI ID string */
226#define L3_Packet 0x83 /* Unicode ID string */
227#define L4_Packet 0x84 /* Vendor defined */
228#define L5_Packet 0x85 /* Large I/O */
229#define L6_Packet 0x86 /* 32-bit Fixed Loc Mem Range Desc */
230#define END_TAG 0x78 /* End of resource */
231#define DF_START_TAG 0x30 /* Dependent function start */
232#define DF_START_TAG_priority 0x31 /* Dependent function start */
233#define DF_END_TAG 0x38 /* Dependent function end */
234#define SUBOPTIMAL_CONFIGURATION 0x2 /* Priority byte sub optimal config */
235
236/* Device Base Type Codes */
237
238typedef enum _PnP_BASE_TYPE {
239 Reserved = 0,
240 MassStorageDevice = 1,
241 NetworkInterfaceController = 2,
242 DisplayController = 3,
243 MultimediaController = 4,
244 MemoryController = 5,
245 BridgeController = 6,
246 CommunicationsDevice = 7,
247 SystemPeripheral = 8,
248 InputDevice = 9,
249 ServiceProcessor = 0x0A, /* 11/2/95 */
250 } PnP_BASE_TYPE;
251
252/* Device Sub Type Codes */
253
254typedef enum _PnP_SUB_TYPE {
255 SCSIController = 0,
256 IDEController = 1,
257 FloppyController = 2,
258 IPIController = 3,
259 OtherMassStorageController = 0x80,
260
261 EthernetController = 0,
262 TokenRingController = 1,
263 FDDIController = 2,
264 OtherNetworkController = 0x80,
265
266 VGAController= 0,
267 SVGAController= 1,
268 XGAController= 2,
269 OtherDisplayController = 0x80,
270
271 VideoController = 0,
272 AudioController = 1,
273 OtherMultimediaController = 0x80,
274
275 RAM = 0,
276 FLASH = 1,
277 OtherMemoryDevice = 0x80,
278
279 HostProcessorBridge = 0,
280 ISABridge = 1,
281 EISABridge = 2,
282 MicroChannelBridge = 3,
283 PCIBridge = 4,
284 PCMCIABridge = 5,
285 VMEBridge = 6,
286 OtherBridgeDevice = 0x80,
287
288 RS232Device = 0,
289 ATCompatibleParallelPort = 1,
290 OtherCommunicationsDevice = 0x80,
291
292 ProgrammableInterruptController = 0,
293 DMAController = 1,
294 SystemTimer = 2,
295 RealTimeClock = 3,
296 L2Cache = 4,
297 NVRAM = 5,
298 PowerManagement = 6,
299 CMOS = 7,
300 OperatorPanel = 8,
301 ServiceProcessorClass1 = 9,
302 ServiceProcessorClass2 = 0xA,
303 ServiceProcessorClass3 = 0xB,
304 GraphicAssist = 0xC,
305 SystemPlanar = 0xF, /* 10/5/95 */
306 OtherSystemPeripheral = 0x80,
307
308 KeyboardController = 0,
309 Digitizer = 1,
310 MouseController = 2,
311 TabletController = 3, /* 10/27/95 */
312 OtherInputController = 0x80,
313
314 GeneralMemoryController = 0,
315 } PnP_SUB_TYPE;
316
317/* Device Interface Type Codes */
318
319typedef enum _PnP_INTERFACE {
320 General = 0,
321 GeneralSCSI = 0,
322 GeneralIDE = 0,
323 ATACompatible = 1,
324
325 GeneralFloppy = 0,
326 Compatible765 = 1,
327 NS398_Floppy = 2, /* NS Super I/O wired to use index
328 register at port 398 and data
329 register at port 399 */
330 NS26E_Floppy = 3, /* Ports 26E and 26F */
331 NS15C_Floppy = 4, /* Ports 15C and 15D */
332 NS2E_Floppy = 5, /* Ports 2E and 2F */
333 CHRP_Floppy = 6, /* CHRP Floppy in PR*P system */
334
335 GeneralIPI = 0,
336
337 GeneralEther = 0,
338 GeneralToken = 0,
339 GeneralFDDI = 0,
340
341 GeneralVGA = 0,
342 GeneralSVGA = 0,
343 GeneralXGA = 0,
344
345 GeneralVideo = 0,
346 GeneralAudio = 0,
347 CS4232Audio = 1, /* CS 4232 Plug 'n Play Configured */
348
349 GeneralRAM = 0,
350 GeneralFLASH = 0,
351 PCIMemoryController = 0, /* PCI Config Method */
352 RS6KMemoryController = 1, /* RS6K Config Method */
353
354 GeneralHostBridge = 0,
355 GeneralISABridge = 0,
356 GeneralEISABridge = 0,
357 GeneralMCABridge = 0,
358 GeneralPCIBridge = 0,
359 PCIBridgeDirect = 0,
360 PCIBridgeIndirect = 1,
361 PCIBridgeRS6K = 2,
362 GeneralPCMCIABridge = 0,
363 GeneralVMEBridge = 0,
364
365 GeneralRS232 = 0,
366 COMx = 1,
367 Compatible16450 = 2,
368 Compatible16550 = 3,
369 NS398SerPort = 4, /* NS Super I/O wired to use index
370 register at port 398 and data
371 register at port 399 */
372 NS26ESerPort = 5, /* Ports 26E and 26F */
373 NS15CSerPort = 6, /* Ports 15C and 15D */
374 NS2ESerPort = 7, /* Ports 2E and 2F */
375
376 GeneralParPort = 0,
377 LPTx = 1,
378 NS398ParPort = 2, /* NS Super I/O wired to use index
379 register at port 398 and data
380 register at port 399 */
381 NS26EParPort = 3, /* Ports 26E and 26F */
382 NS15CParPort = 4, /* Ports 15C and 15D */
383 NS2EParPort = 5, /* Ports 2E and 2F */
384
385 GeneralPIC = 0,
386 ISA_PIC = 1,
387 EISA_PIC = 2,
388 MPIC = 3,
389 RS6K_PIC = 4,
390
391 GeneralDMA = 0,
392 ISA_DMA = 1,
393 EISA_DMA = 2,
394
395 GeneralTimer = 0,
396 ISA_Timer = 1,
397 EISA_Timer = 2,
398 GeneralRTC = 0,
399 ISA_RTC = 1,
400
401 StoreThruOnly = 1,
402 StoreInEnabled = 2,
403 RS6KL2Cache = 3,
404
405 IndirectNVRAM = 0, /* Indirectly addressed */
406 DirectNVRAM = 1, /* Memory Mapped */
407 IndirectNVRAM24 = 2, /* Indirectly addressed - 24 bit */
408
409 GeneralPowerManagement = 0,
410 EPOWPowerManagement = 1,
411 PowerControl = 2, /* d1378 */
412
413 GeneralCMOS = 0,
414
415 GeneralOPPanel = 0,
416 HarddiskLight = 1,
417 CDROMLight = 2,
418 PowerLight = 3,
419 KeyLock = 4,
420 ANDisplay = 5, /* AlphaNumeric Display */
421 SystemStatusLED = 6, /* 3 digit 7 segment LED */
422 CHRP_SystemStatusLED = 7, /* CHRP LEDs in PR*P system */
423
424 GeneralServiceProcessor = 0,
425
426 TransferData = 1,
427 IGMC32 = 2,
428 IGMC64 = 3,
429
430 GeneralSystemPlanar = 0, /* 10/5/95 */
431
432 } PnP_INTERFACE;
433
434/* PnP resources */
435
436/* Compressed ASCII is 5 bits per char; 00001=A ... 11010=Z */
437
438typedef struct _SERIAL_ID {
439 unsigned char VendorID0; /* Bit(7)=0 */
440 /* Bits(6:2)=1st character in */
441 /* compressed ASCII */
442 /* Bits(1:0)=2nd character in */
443 /* compressed ASCII bits(4:3) */
444 unsigned char VendorID1; /* Bits(7:5)=2nd character in */
445 /* compressed ASCII bits(2:0) */
446 /* Bits(4:0)=3rd character in */
447 /* compressed ASCII */
448 unsigned char VendorID2; /* Product number - vendor assigned */
449 unsigned char VendorID3; /* Product number - vendor assigned */
450
451/* Serial number is to provide uniqueness if more than one board of same */
452/* type is in system. Must be "FFFFFFFF" if feature not supported. */
453
454 unsigned char Serial0; /* Unique serial number bits (7:0) */
455 unsigned char Serial1; /* Unique serial number bits (15:8) */
456 unsigned char Serial2; /* Unique serial number bits (23:16) */
457 unsigned char Serial3; /* Unique serial number bits (31:24) */
458 unsigned char Checksum;
459 } SERIAL_ID;
460
461typedef enum _PnPItemName {
462 Unused = 0,
463 PnPVersion = 1,
464 LogicalDevice = 2,
465 CompatibleDevice = 3,
466 IRQFormat = 4,
467 DMAFormat = 5,
468 StartDepFunc = 6,
469 EndDepFunc = 7,
470 IOPort = 8,
471 FixedIOPort = 9,
472 Res1 = 10,
473 Res2 = 11,
474 Res3 = 12,
475 SmallVendorItem = 14,
476 EndTag = 15,
477 MemoryRange = 1,
478 ANSIIdentifier = 2,
479 UnicodeIdentifier = 3,
480 LargeVendorItem = 4,
481 MemoryRange32 = 5,
482 MemoryRangeFixed32 = 6,
483 } PnPItemName;
484
485/* Define a bunch of access functions for the bits in the tag field */
486
487/* Tag type - 0 = small; 1 = large */
488#define tag_type(t) (((t) & 0x80)>>7)
489#define set_tag_type(t,v) (t = (t & 0x7f) | ((v)<<7))
490
491/* Small item name is 4 bits - one of PnPItemName enum above */
492#define tag_small_item_name(t) (((t) & 0x78)>>3)
493#define set_tag_small_item_name(t,v) (t = (t & 0x07) | ((v)<<3))
494
495/* Small item count is 3 bits - count of further bytes in packet */
496#define tag_small_count(t) ((t) & 0x07)
497#define set_tag_count(t,v) (t = (t & 0x78) | (v))
498
499/* Large item name is 7 bits - one of PnPItemName enum above */
500#define tag_large_item_name(t) ((t) & 0x7f)
501#define set_tag_large_item_name(t,v) (t = (t | 0x80) | (v))
502
503/* a PnP resource is a bunch of contiguous TAG packets ending with an end tag */
504
505typedef union _PnP_TAG_PACKET {
506 struct _S1_Pack{ /* VERSION PACKET */
507 unsigned char Tag; /* small tag = 0x0a */
508 unsigned char Version[2]; /* PnP version, Vendor version */
509 } S1_Pack;
510
511 struct _S2_Pack{ /* LOGICAL DEVICE ID PACKET */
512 unsigned char Tag; /* small tag = 0x15 or 0x16 */
513 unsigned char DevId[4]; /* Logical device id */
514 unsigned char Flags[2]; /* bit(0) boot device; */
515 /* bit(7:1) cmd in range x31-x37 */
516 /* bit(7:0) cmd in range x28-x3f (opt)*/
517 } S2_Pack;
518
519 struct _S3_Pack{ /* COMPATIBLE DEVICE ID PACKET */
520 unsigned char Tag; /* small tag = 0x1c */
521 unsigned char CompatId[4]; /* Compatible device id */
522 } S3_Pack;
523
524 struct _S4_Pack{ /* IRQ PACKET */
525 unsigned char Tag; /* small tag = 0x22 or 0x23 */
526 unsigned char IRQMask[2]; /* bit(0) is IRQ0, ...; */
527 /* bit(0) is IRQ8 ... */
528 unsigned char IRQInfo; /* optional; assume bit(0)=1; else */
529 /* bit(0) - high true edge sensitive */
530 /* bit(1) - low true edge sensitive */
531 /* bit(2) - high true level sensitive*/
532 /* bit(3) - low true level sensitive */
533 /* bit(7:4) - must be 0 */
534 } S4_Pack;
535
536 struct _S5_Pack{ /* DMA PACKET */
537 unsigned char Tag; /* small tag = 0x2a */
538 unsigned char DMAMask; /* bit(0) is channel 0 ... */
539 unsigned char DMAInfo;
540 } S5_Pack;
541
542 struct _S6_Pack{ /* START DEPENDENT FUNCTION PACKET */
543 unsigned char Tag; /* small tag = 0x30 or 0x31 */
544 unsigned char Priority; /* Optional; if missing then x01; else*/
545 /* x00 = best possible */
546 /* x01 = acceptible */
547 /* x02 = sub-optimal but functional */
548 } S6_Pack;
549
550 struct _S7_Pack{ /* END DEPENDENT FUNCTION PACKET */
551 unsigned char Tag; /* small tag = 0x38 */
552 } S7_Pack;
553
554 struct _S8_Pack{ /* VARIABLE I/O PORT PACKET */
555 unsigned char Tag; /* small tag x47 */
556 unsigned char IOInfo; /* x0 = decode only bits(9:0); */
557#define ISAAddr16bit 0x01 /* x01 = decode bits(15:0) */
558 unsigned char RangeMin[2]; /* Min base address */
559 unsigned char RangeMax[2]; /* Max base address */
560 unsigned char IOAlign; /* base alignmt, incr in 1B blocks */
561 unsigned char IONum; /* number of contiguous I/O ports */
562 } S8_Pack;
563
564 struct _S9_Pack{ /* FIXED I/O PORT PACKET */
565 unsigned char Tag; /* small tag = 0x4b */
566 unsigned char Range[2]; /* base address 10 bits */
567 unsigned char IONum; /* number of contiguous I/O ports */
568 } S9_Pack;
569
570 struct _S14_Pack{ /* VENDOR DEFINED PACKET */
571 unsigned char Tag; /* small tag = 0x7m m = 1-7 */
573 unsigned char Data[7]; /* Vendor defined */
574 struct _S14_PPCPack{ /* Pr*p s14 pack */
575 unsigned char Type; /* 00=non-IBM */
576 unsigned char PPCData[6]; /* Vendor defined */
577 } S14_PPCPack;
578 } S14_Data;
579 } S14_Pack;
580
581 struct _S15_Pack{ /* END PACKET */
582 unsigned char Tag; /* small tag = 0x78 or 0x79 */
583 unsigned char Check; /* optional - checksum */
584 } S15_Pack;
585
586 struct _L1_Pack{ /* MEMORY RANGE PACKET */
587 unsigned char Tag; /* large tag = 0x81 */
588 unsigned char Count0; /* x09 */
589 unsigned char Count1; /* x00 */
590 unsigned char Data[9]; /* a variable array of bytes, */
591 /* count in tag */
592 } L1_Pack;
593
594 struct _L2_Pack{ /* ANSI ID STRING PACKET */
595 unsigned char Tag; /* large tag = 0x82 */
596 unsigned char Count0; /* Length of string */
597 unsigned char Count1;
598 unsigned char Identifier[1]; /* a variable array of bytes, */
599 /* count in tag */
600 } L2_Pack;
601
602 struct _L3_Pack{ /* UNICODE ID STRING PACKET */
603 unsigned char Tag; /* large tag = 0x83 */
604 unsigned char Count0; /* Length + 2 of string */
605 unsigned char Count1;
606 unsigned char Country0; /* TBD */
607 unsigned char Country1; /* TBD */
608 unsigned char Identifier[1]; /* a variable array of bytes, */
609 /* count in tag */
610 } L3_Pack;
611
612 struct _L4_Pack{ /* VENDOR DEFINED PACKET */
613 unsigned char Tag; /* large tag = 0x84 */
614 unsigned char Count0;
615 unsigned char Count1;
616 union _L4_Data{
617 unsigned char Data[1]; /* a variable array of bytes, */
618 /* count in tag */
619 struct _L4_PPCPack{ /* Pr*p L4 packet */
620 unsigned char Type; /* 00=non-IBM */
621 unsigned char PPCData[1]; /* a variable array of bytes, */
622 /* count in tag */
623 } L4_PPCPack;
624 } L4_Data;
625 } L4_Pack;
626
627 struct _L5_Pack{
628 unsigned char Tag; /* large tag = 0x85 */
629 unsigned char Count0; /* Count = 17 */
630 unsigned char Count1;
631 unsigned char Data[17];
632 } L5_Pack;
633
634 struct _L6_Pack{
635 unsigned char Tag; /* large tag = 0x86 */
636 unsigned char Count0; /* Count = 9 */
637 unsigned char Count1;
638 unsigned char Data[9];
639 } L6_Pack;
640
642
643#endif /* ASM */
644#endif /* ndef _PNP_ */
Definition: pnp.h:586
Definition: pnp.h:594
Definition: pnp.h:602
Definition: pnp.h:612
Definition: pnp.h:627
Definition: pnp.h:634
Definition: pnp.h:570
Definition: pnp.h:581
Definition: pnp.h:506
Definition: pnp.h:511
Definition: pnp.h:519
Definition: pnp.h:524
Definition: pnp.h:536
Definition: pnp.h:542
Definition: pnp.h:550
Definition: pnp.h:554
Definition: pnp.h:564
Definition: pnp.h:438
Definition: pnp.h:505
