RTEMS 5.2
pic.h
1/*
2 * Copyright (c) 2018.
3 * Amaan Cheval <amaan.cheval@gmail.com>
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 *
14 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24 * SUCH DAMAGE.
25 */
26
27#ifndef _AMD64_PIC_H
28#define _AMD64_PIC_H
29
30#ifdef __cplusplus
31extern "C" {
32#endif
33
34#define PIC1 0x20 /* IO base address for master PIC */
35#define PIC2 0xA0 /* IO base address for slave PIC */
36#define PIC1_COMMAND PIC1
37#define PIC1_DATA (PIC1+1)
38#define PIC2_COMMAND PIC2
39#define PIC2_DATA (PIC2+1)
40
41/* reinitialize the PIC controllers, giving them specified vector offsets
42 rather than 8h and 70h, as configured by default */
43
44#define PIC_ICW1_ICW4 0x01 /* ICW4 (not) needed */
45#define PIC_ICW1_SINGLE 0x02 /* Single (cascade) mode */
46#define PIC_ICW1_INTERVAL4 0x04 /* Call address interval 4 (8) */
47#define PIC_ICW1_LEVEL 0x08 /* Level triggered (edge) mode */
48#define PIC_ICW1_INIT 0x10 /* Initialization - required! */
49
50#define PIC_ICW4_8086 0x01 /* 8086/88 (MCS-80/85) mode */
51#define PIC_ICW4_AUTO 0x02 /* Auto (normal) EOI */
52#define PIC_ICW4_BUF_SLAVE 0x08 /* Buffered mode/slave */
53#define PIC_ICW4_BUF_MASTER 0x0C /* Buffered mode/master */
54#define PIC_ICW4_SFNM 0x10 /* Special fully nested (not) */
55
56/* This remaps IRQ0 to vector number 0x20 and so on (i.e. IDT[32]) */
57#define PIC1_REMAP_DEST 0x20
58#define PIC2_REMAP_DEST 0x28
59
60/* Remap PIC1's interrupts to offset1 and PIC2's to offset2 */
61void pic_remap(uint8_t offset1, uint8_t offset2);
62
69void pic_disable(void);
70
71#ifdef __cplusplus
72}
73#endif
74
75#endif /* _AMD64_PIC_H */
