RTEMS 5.2
open_eth.h
1/* Opencores ethernet MAC driver */
2/* adapted from linux driver by Jiri Gaisler */
3
4#ifndef _OPEN_ETH_
5#define _OPEN_ETH_
6
7
8/* Configuration Information */
9
10typedef struct {
11 void *base_address;
12 uint32_t vector;
13 uint32_t txd_count;
14 uint32_t rxd_count;
15 uint32_t en100MHz;
17
18
19/* Ethernet buffer descriptor */
20
21typedef struct _oeth_rxtxdesc {
22 volatile uint32_t len_status; /* Length and status */
23 volatile uint32_t *addr; /* Buffer pointer */
25
26/* Ethernet configuration registers */
27
28typedef struct _oeth_regs {
29 volatile uint32_t moder; /* Mode Register */
30 volatile uint32_t int_src; /* Interrupt Source Register */
31 volatile uint32_t int_mask; /* Interrupt Mask Register */
32 volatile uint32_t ipgt; /* Back to Bak Inter Packet Gap Register */
33 volatile uint32_t ipgr1; /* Non Back to Back Inter Packet Gap Register 1 */
34 volatile uint32_t ipgr2; /* Non Back to Back Inter Packet Gap Register 2 */
35 volatile uint32_t packet_len; /* Packet Length Register (min. and max.) */
36 volatile uint32_t collconf; /* Collision and Retry Configuration Register */
37 volatile uint32_t tx_bd_num; /* Transmit Buffer Descriptor Number Register */
38 volatile uint32_t ctrlmoder; /* Control Module Mode Register */
39 volatile uint32_t miimoder; /* MII Mode Register */
40 volatile uint32_t miicommand; /* MII Command Register */
41 volatile uint32_t miiaddress; /* MII Address Register */
42 volatile uint32_t miitx_data; /* MII Transmit Data Register */
43 volatile uint32_t miirx_data; /* MII Receive Data Register */
44 volatile uint32_t miistatus; /* MII Status Register */
45 volatile uint32_t mac_addr0; /* MAC Individual Address Register 0 */
46 volatile uint32_t mac_addr1; /* MAC Individual Address Register 1 */
47 volatile uint32_t hash_addr0; /* Hash Register 0 */
48 volatile uint32_t hash_addr1; /* Hash Register 1 */
49 volatile uint32_t txctrl; /* Transmitter control register */
50 uint32_t empty[235]; /* Unused space */
51 oeth_rxtxdesc xd[128]; /* TX & RX descriptors */
52} oeth_regs;
53
54#define OETH_TOTAL_BD 128
55#define OETH_MAXBUF_LEN 0x610
56
57/* Tx BD */
58#define OETH_TX_BD_READY 0x8000 /* Tx BD Ready */
59#define OETH_TX_BD_IRQ 0x4000 /* Tx BD IRQ Enable */
60#define OETH_TX_BD_WRAP 0x2000 /* Tx BD Wrap (last BD) */
61#define OETH_TX_BD_PAD 0x1000 /* Tx BD Pad Enable */
62#define OETH_TX_BD_CRC 0x0800 /* Tx BD CRC Enable */
63
64#define OETH_TX_BD_UNDERRUN 0x0100 /* Tx BD Underrun Status */
65#define OETH_TX_BD_RETRY 0x00F0 /* Tx BD Retry Status */
66#define OETH_TX_BD_RETLIM 0x0008 /* Tx BD Retransmission Limit Status */
67#define OETH_TX_BD_LATECOL 0x0004 /* Tx BD Late Collision Status */
68#define OETH_TX_BD_DEFER 0x0002 /* Tx BD Defer Status */
69#define OETH_TX_BD_CARRIER 0x0001 /* Tx BD Carrier Sense Lost Status */
70#define OETH_TX_BD_STATS (OETH_TX_BD_UNDERRUN | \
71 OETH_TX_BD_RETRY | \
72 OETH_TX_BD_RETLIM | \
73 OETH_TX_BD_LATECOL | \
74 OETH_TX_BD_DEFER | \
75 OETH_TX_BD_CARRIER)
76
77/* Rx BD */
78#define OETH_RX_BD_EMPTY 0x8000 /* Rx BD Empty */
79#define OETH_RX_BD_IRQ 0x4000 /* Rx BD IRQ Enable */
80#define OETH_RX_BD_WRAP 0x2000 /* Rx BD Wrap (last BD) */
81
82#define OETH_RX_BD_MISS 0x0080 /* Rx BD Miss Status */
83#define OETH_RX_BD_OVERRUN 0x0040 /* Rx BD Overrun Status */
84#define OETH_RX_BD_INVSIMB 0x0020 /* Rx BD Invalid Symbol Status */
85#define OETH_RX_BD_DRIBBLE 0x0010 /* Rx BD Dribble Nibble Status */
86#define OETH_RX_BD_TOOLONG 0x0008 /* Rx BD Too Long Status */
87#define OETH_RX_BD_SHORT 0x0004 /* Rx BD Too Short Frame Status */
88#define OETH_RX_BD_CRCERR 0x0002 /* Rx BD CRC Error Status */
89#define OETH_RX_BD_LATECOL 0x0001 /* Rx BD Late Collision Status */
90#define OETH_RX_BD_STATS (OETH_RX_BD_MISS | \
91 OETH_RX_BD_OVERRUN | \
92 OETH_RX_BD_INVSIMB | \
93 OETH_RX_BD_DRIBBLE | \
94 OETH_RX_BD_TOOLONG | \
95 OETH_RX_BD_SHORT | \
96 OETH_RX_BD_CRCERR | \
97 OETH_RX_BD_LATECOL)
98
99/* MODER Register */
100#define OETH_MODER_RXEN 0x00000001 /* Receive Enable */
101#define OETH_MODER_TXEN 0x00000002 /* Transmit Enable */
102#define OETH_MODER_NOPRE 0x00000004 /* No Preamble */
103#define OETH_MODER_BRO 0x00000008 /* Reject Broadcast */
104#define OETH_MODER_IAM 0x00000010 /* Use Individual Hash */
105#define OETH_MODER_PRO 0x00000020 /* Promiscuous (receive all) */
106#define OETH_MODER_IFG 0x00000040 /* Min. IFG not required */
107#define OETH_MODER_LOOPBCK 0x00000080 /* Loop Back */
108#define OETH_MODER_NOBCKOF 0x00000100 /* No Backoff */
109#define OETH_MODER_EXDFREN 0x00000200 /* Excess Defer */
110#define OETH_MODER_FULLD 0x00000400 /* Full Duplex */
111#define OETH_MODER_RST 0x00000800 /* Reset MAC */
112#define OETH_MODER_DLYCRCEN 0x00001000 /* Delayed CRC Enable */
113#define OETH_MODER_CRCEN 0x00002000 /* CRC Enable */
114#define OETH_MODER_HUGEN 0x00004000 /* Huge Enable */
115#define OETH_MODER_PAD 0x00008000 /* Pad Enable */
116#define OETH_MODER_RECSMALL 0x00010000 /* Receive Small */
117
118/* Interrupt Source Register */
119#define OETH_INT_TXB 0x00000001 /* Transmit Buffer IRQ */
120#define OETH_INT_TXE 0x00000002 /* Transmit Error IRQ */
121#define OETH_INT_RXF 0x00000004 /* Receive Frame IRQ */
122#define OETH_INT_RXE 0x00000008 /* Receive Error IRQ */
123#define OETH_INT_BUSY 0x00000010 /* Busy IRQ */
124#define OETH_INT_TXC 0x00000020 /* Transmit Control Frame IRQ */
125#define OETH_INT_RXC 0x00000040 /* Received Control Frame IRQ */
126
127/* Interrupt Mask Register */
128#define OETH_INT_MASK_TXB 0x00000001 /* Transmit Buffer IRQ Mask */
129#define OETH_INT_MASK_TXE 0x00000002 /* Transmit Error IRQ Mask */
130#define OETH_INT_MASK_RXF 0x00000004 /* Receive Frame IRQ Mask */
131#define OETH_INT_MASK_RXE 0x00000008 /* Receive Error IRQ Mask */
132#define OETH_INT_MASK_BUSY 0x00000010 /* Busy IRQ Mask */
133#define OETH_INT_MASK_TXC 0x00000020 /* Transmit Control Frame IRQ Mask */
134#define OETH_INT_MASK_RXC 0x00000040 /* Received Control Frame IRQ Mask */
135
136/* Control Module Mode Register */
137#define OETH_CTRLMODER_PASSALL 0x00000001 /* Pass Control Frames */
138#define OETH_CTRLMODER_RXFLOW 0x00000002 /* Receive Control Flow Enable */
139#define OETH_CTRLMODER_TXFLOW 0x00000004 /* Transmit Control Flow Enable */
140
141/* MII Mode Register */
142#define OETH_MIIMODER_CLKDIV 0x000000FF /* Clock Divider */
143#define OETH_MIIMODER_NOPRE 0x00000100 /* No Preamble */
144#define OETH_MIIMODER_RST 0x00000200 /* MIIM Reset */
145
146/* MII Command Register */
147#define OETH_MIICOMMAND_SCANSTAT 0x00000001 /* Scan Status */
148#define OETH_MIICOMMAND_RSTAT 0x00000002 /* Read Status */
149#define OETH_MIICOMMAND_WCTRLDATA 0x00000004 /* Write Control Data */
150
151/* MII Address Register */
152#define OETH_MIIADDRESS_FIAD 0x0000001F /* PHY Address */
153#define OETH_MIIADDRESS_RGAD 0x00001F00 /* RGAD Address */
154
155/* MII Status Register */
156#define OETH_MIISTATUS_LINKFAIL 0x00000001 /* Link Fail */
157#define OETH_MIISTATUS_BUSY 0x00000002 /* MII Busy */
158#define OETH_MIISTATUS_NVALID 0x00000004 /* Data in MII Status Register is invalid */
159
160/* Attatch routine */
161
162int rtems_open_eth_driver_attach (
163 struct rtems_bsdnet_ifconfig *config,
165);
166
167/*
168#ifdef CPU_U32_FIX
169void ipalign(struct mbuf *m);
170#endif
171
172*/
173#endif /* _OPEN_ETH_ */
Definition: open_eth.h:28
Definition: open_eth.h:21
Definition: deflate.c:115
Definition: open_eth.h:10
