RTEMS 5.2
obsolete.h
2
11/*
12 * Copyright (C) 2017, 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_OBSOLETE_H
37#define _RTEMS_CONFDEFS_OBSOLETE_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
45/*
46 * Please keep the list of obsolete configuration options alphabetically sorted.
47 *
48 * Use #warning for renamed options and define the new option accordingly.
49 *
50 * Use #warning for obsolete options which are now superfluous, e.g. because
51 * the objects are now self-contained.
52 *
53 * Use #error for options which require now a different configuration approach,
54 * e.g. options for an own configuration table.
55 *
56 * Mention the RTEMS release which obsoleted the configuration option in the
57 * message.
58 */
59
60#ifdef CONFIGURE_BDBUF_BUFFER_SIZE
61 #error "The CONFIGURE_BDBUF_BUFFER_SIZE configuration option is obsolete since RTEMS 4.10.0"
62#endif
63
64#ifdef CONFIGURE_BDBUF_BUFFER_COUNT
65 #error "The CONFIGURE_BDBUF_BUFFER_COUNT configuration option is obsolete since RTEMS 4.10.0"
66#endif
67
68#ifdef CONFIGURE_MAXIMUM_DEVICES
69 #warning "The CONFIGURE_MAXIMUM_DEVICES configuration option is obsolete since RTEMS 5.1"
70#endif
71
72#ifdef CONFIGURE_ENABLE_GO
73 #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
74#endif
75
76#ifdef CONFIGURE_GNAT_RTEMS
77 #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1"
78#endif
79
80#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
81 #error "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
82#endif
83
84#ifdef CONFIGURE_HAS_OWN_BDBUF_TABLE
85 #error "The CONFIGURE_HAS_BDBUF_TABLE configuration option is obsolete since RTEMS 4.10.0"
86#endif
87
88#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
89 #error "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
90#endif
91
92#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
93 #error "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
94#endif
95
96#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
97 #error "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1"
98#endif
99
100#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
101 #error "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
102#endif
103
104#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
105 #error "The CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE configuration option is obsolete since RTEMS 5.1"
106#endif
107
108#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
109 #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
110 #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
111#endif
112
113#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
114 #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
115#endif
116
117#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
118 #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
119#endif
120
121#ifdef CONFIGURE_MAXIMUM_FIFOS
122 #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
123 #if CONFIGURE_MAXIMUM_FIFOS > 0
124 #define CONFIGURE_IMFS_ENABLE_MKFIFO
125 #endif
126#endif
127
128#ifdef CONFIGURE_MAXIMUM_GOROUTINES
129 #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
130#endif
131
132#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
133 #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
134#endif
135
136#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
137 #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1"
138#endif
139
140#ifdef CONFIGURE_MAXIMUM_PIPES
141 #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
142 #if CONFIGURE_MAXIMUM_PIPES > 0
143 #define CONFIGURE_IMFS_ENABLE_MKFIFO
144 #endif
145#endif
146
147#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
148 #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1"
149#endif
150
151#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
152 #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1"
153#endif
154
155#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
156 #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1"
157#endif
158
159#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
160 #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1"
161#endif
162
163#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
164 #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1"
165#endif
166
167#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
168 #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1"
169#endif
170
171#ifdef CONFIGURE_MAXIMUM_PTYS
172 #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
173#endif
174
175#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
176 #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
177#endif
178
179#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
180 #error "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
181#endif
182
183#ifdef CONFIGURE_SCHEDULER_CONTEXT
184 #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
185 #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
186#endif
187
188#ifdef CONFIGURE_SCHEDULER_CONTROLS
189 #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
190 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
191#endif
192
193#ifdef CONFIGURE_SMP_APPLICATION
194 #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
195#endif
196
197#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
198 #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
199 #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
200#endif
201
202#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
203 #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
204 #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
205#endif
206
207#ifdef CONFIGURE_TERMIOS_DISABLED
208 #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
209#endif
210
211#ifdef CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
212 #error "The CONFIGURE_TEST_NEEDS_CLOCK_DRIVER configuration option is obsolete since at least RTEMS 4.5.0"
213#endif
214
215#ifdef CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
216 #error "The CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
217#endif
218
219#ifdef CONFIGURE_TEST_NEEDS_RTC_DRIVER
220 #error "The CONFIGURE_TEST_NEEDS_RTC_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
221#endif
222
223#ifdef CONFIGURE_TEST_NEEDS_STUB_DRIVER
224 #error "The CONFIGURE_TEST_NEEDS_STUB_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
225#endif
226
227#ifdef CONFIGURE_TEST_NEEDS_TIMER_DRIVER
228 #error "The CONFIGURE_TEST_NEEDS_TIMER_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
229#endif
230
231#ifdef STACK_CHECKER_ON
232 #warning "STACK_CHECKER_ON has been renamed to CONFIGURE_STACK_CHECKER_ENABLED since RTEMS 4.10.0"
233 #define CONFIGURE_STACK_CHECKER_ENABLED
234#endif
235
236#endif /* CONFIGURE_INIT */
237
238#endif /* _RTEMS_CONFDEFS_OBSOLETE_H */
