RTEMS 5.2
mpc83xx_i2cdrv.h
1/*===============================================================*\
2| Project: RTEMS support for MPC83xx |
3+-----------------------------------------------------------------+
4| Copyright (c) 2007 |
5| Embedded Brains GmbH |
6| Obere Lagerstr. 30 |
7| D-82178 Puchheim |
8| Germany |
9| rtems@embedded-brains.de |
10+-----------------------------------------------------------------+
11| The license and distribution terms for this file may be |
12| found in the file LICENSE in this distribution or at |
13| |
14| http://www.rtems.org/license/LICENSE. |
15| |
16+-----------------------------------------------------------------+
17| this file contains the MPC83xx I2C driver declarations |
18\*===============================================================*/
19#ifndef _MPC83XX_I2CDRV_H
20#define _MPC83XX_I2CDRV_H
21
22#include <rtems/libi2c.h>
23#include <rtems/irq.h>
24
25#include <bsp.h>
26
27#ifdef LIBBSP_POWERPC_GEN83XX_BSP_H
28 #include <mpc83xx/mpc83xx.h>
29#endif
30
31#ifdef __cplusplus
32extern "C" {
33#endif
34
35#ifdef LIBBSP_POWERPC_MPC55XXEVB_BSP_H
36 typedef struct {
37 volatile uint8_t i2cadr;
38 volatile uint8_t i2cfdr;
39 volatile uint8_t i2ccr;
40 volatile uint8_t i2csr;
41 volatile uint8_t i2cdr;
42 volatile uint8_t i2cdfsrr;
44#endif
45
46typedef struct mpc83xx_i2c_softc {
47 m83xxI2CRegisters_t *reg_ptr; /* ptr to HW registers */
48 int initialized; /* TRUE: module is initialized */
49 rtems_irq_number irq_number; /* IRQ number used for this module */
50 uint32_t base_frq; /* input frq for baud rate divider */
51 rtems_id irq_sema_id; /* SEMA used for IRQ signalling */
52 void (*probe)(struct mpc83xx_i2c_softc *self);
54
55typedef struct {
56 rtems_libi2c_bus_t bus_desc;
57 struct mpc83xx_i2c_softc softc;
59
60
61extern rtems_libi2c_bus_ops_t mpc83xx_i2c_ops;
62
63#ifdef __cplusplus
64}
65#endif
66
67
68#endif /* _MPC83XX_I2CDRV_H */
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Legacy I2C Library.
Definition: mpc83xx.h:274
Definition: mpc83xx_i2cdrv.h:55
Definition: mpc83xx_i2cdrv.h:46
Definition: libi2c.h:176
Definition: libi2c.h:163
