RTEMS 5.2
mpc55xx-config.h
1
9/*
10 * Copyright (c) 2008-2012 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Obere Lagerstr. 30
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H
24#define LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H
25
26#include <stddef.h>
27
29
30#include <bsp/start.h>
31
32#include <mpc55xx/regs.h>
33#include <mpc55xx/regs-mmu.h>
34#include <mpc55xx/siu.h>
35
36#ifdef __cplusplus
37extern "C" {
38#endif /* __cplusplus */
39
40typedef struct {
41 uint32_t index : 10;
42 uint32_t count : 10;
43 uint32_t output : 1;
44 union SIU_PCR_tag pcr;
46
47extern BSP_START_DATA_SECTION const mpc55xx_siu_pcr_config
48 mpc55xx_start_config_siu_pcr [];
49
50extern BSP_START_DATA_SECTION const size_t
51 mpc55xx_start_config_siu_pcr_count [];
52
53extern BSP_START_DATA_SECTION const struct
54 MMU_tag mpc55xx_start_config_mmu_early [];
55
56extern BSP_START_DATA_SECTION const size_t
57 mpc55xx_start_config_mmu_early_count [];
58
59extern BSP_START_DATA_SECTION const struct
60 MMU_tag mpc55xx_start_config_mmu [];
61
62extern BSP_START_DATA_SECTION const size_t
63 mpc55xx_start_config_mmu_count [];
64
65#ifdef MPC55XX_HAS_FMPLL
66 typedef struct {
67 union FMPLL_SYNCR_tag syncr_tmp;
68 union FMPLL_SYNCR_tag syncr_final;
69 } mpc55xx_clock_config;
70#endif
71
72#ifdef MPC55XX_HAS_FMPLL_ENHANCED
73 typedef struct {
74 union FMPLL_ESYNCR2_tag esyncr2_tmp;
75 union FMPLL_ESYNCR2_tag esyncr2_final;
76 union FMPLL_ESYNCR1_tag esyncr1_final;
77 } mpc55xx_clock_config;
78#endif
79
80#ifdef MPC55XX_HAS_MODE_CONTROL
81 typedef struct {
82 struct {
85 } fmpll [2];
87 CGM_OCDS_SC_32B_tag ocds_sc;
88 CGM_SC_DC0_3_32B_tag sc_dc0_3;
89 CGM_AUXCLK_tag auxclk [5];
90 } mpc55xx_clock_config;
91#endif
92
93extern BSP_START_DATA_SECTION const mpc55xx_clock_config
94 mpc55xx_start_config_clock [];
95
96#ifdef MPC55XX_HAS_EBI
97 typedef struct {
98 union EBI_MCR_tag ebi_mcr;
99 uint32_t siu_eccr_ebdf;
100 } mpc55xx_ebi_config;
101
102 extern BSP_START_DATA_SECTION const mpc55xx_ebi_config
103 mpc55xx_start_config_ebi [];
104
105 extern BSP_START_DATA_SECTION const size_t
106 mpc55xx_start_config_ebi_count [];
107
108 extern BSP_START_DATA_SECTION const struct EBI_CS_tag
109 mpc55xx_start_config_ebi_cs [];
110
111 extern BSP_START_DATA_SECTION const size_t
112 mpc55xx_start_config_ebi_cs_count [];
113
114 extern BSP_START_DATA_SECTION const struct EBI_CAL_CS_tag
115 mpc55xx_start_config_ebi_cal_cs [];
116
117 extern BSP_START_DATA_SECTION const size_t
118 mpc55xx_start_config_ebi_cal_cs_count [];
119#endif
120
134void mpc55xx_start_prologue(void);
135
136void mpc55xx_start_early(void);
137
138void mpc55xx_start_flash(void);
139
140void mpc55xx_start_cache(void);
141
142void mpc55xx_start_clock(void);
143
144void mpc55xx_start_watchdog(void);
145
146void mpc55xx_start_mmu_apply_config(const struct MMU_tag *config, size_t count);
147
148uint32_t mpc55xx_get_system_clock(void);
149
150LINKER_SYMBOL(bsp_ram_start)
151LINKER_SYMBOL(bsp_ram_end)
152LINKER_SYMBOL(bsp_ram_size)
153
154LINKER_SYMBOL(bsp_ram_1_start)
155LINKER_SYMBOL(bsp_ram_1_end)
156LINKER_SYMBOL(bsp_ram_1_size)
157
158LINKER_SYMBOL(bsp_rom_start)
159LINKER_SYMBOL(bsp_rom_end)
160LINKER_SYMBOL(bsp_rom_size)
161
162#ifdef MPC55XX_BOOTFLAGS
163 extern uint32_t mpc55xx_bootflag_0 [];
164#endif
165
166#ifdef __cplusplus
167}
168#endif /* __cplusplus */
169
170#endif /* LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H */
Start prologue.
Definition: start-prologue.c:25
General purpose assembler macros, linker command file support and some inline functions for direct re...
Register definitions for the MPC55xx and MPC56xx microcontroller family.
System Integration Unit Access (SIU).
Definition: fsl-mpc564xL.h:4916
Definition: fsl-mpc551x.h:479
Definition: fsl-mpc551x.h:447
Definition: regs-mmu.h:66
Definition: deflate.c:115
Definition: mpc55xx-config.h:40
Definition: fsl-mpc564xL.h:4834
Definition: fsl-mpc564xL.h:4823
Definition: fsl-mpc564xL.h:4859
Definition: fsl-mpc564xL.h:4663
Definition: fsl-mpc564xL.h:4684
Definition: fsl-mpc564xL.h:966
