RTEMS 5.2
monlib.h
1
10/* Based upon code from MicroMonitor 1.17 from http://www.umonfw.com/
11 * which includes this notice:
12 *
13 **************************************************************************
14 * General notice:
15 * This code is part of a boot-monitor package developed as a generic base
16 * platform for embedded system designs. As such, it is likely to be
17 * distributed to various projects beyond the control of the original
18 * author. Please notify the author of any enhancements made or bugs found
19 * so that all may benefit from the changes. In addition, notification back
20 * to the author will allow the new user to pick up changes that may have
21 * been made by other users after this version of the code was distributed.
22 *
23 * Note1: the majority of this code was edited with 4-space tabs.
24 * Note2: as more and more contributions are accepted, the term "author"
25 * is becoming a mis-representation of credit.
26 *
27 * Original author: Ed Sutter
28 * Email: esutter@alcatel-lucent.com
29 * Phone: 908-582-2351
30 **************************************************************************
31 *
32 * Ed Sutter has been informed that this code is being used in RTEMS.
33 *
34 * This code was reformatted by Joel Sherrill from OAR Corporation and
35 * Fernando Nicodemos <fgnicodemos@terra.com.br> from NCB - Sistemas
36 * Embarcados Ltda. (Brazil) to be more compliant with RTEMS coding
37 * standards and to eliminate C++ style comments.
38 */
39
40#ifndef _MONLIB_H_
41#define _MONLIB_H_
42
43#include <umon/tfs.h>
44#include <umon/cli.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
66extern int monConnect(int (*monptr)(int,void *,void *,void *),
67 void (*lock)(void),void (*unlock)(void));
68extern void mon_getargv(int *argc,char ***argv);
69extern void mon_intsrestore(unsigned long oldval);
70extern void mon_appexit(int exit_value);
71extern void mon_free(char *buffer);
72extern void mon_profiler(void *pdata);
73extern void mon_bbc(char *filename, int linenum);
74extern void mon_warmstart(unsigned long mask);
75extern void mon_delay(long msec);
76extern void mon_printpkt(char *buf, int size, int incoming);
77extern void mon_printmem(char *mem, int size, int ascii);
78
79
80extern int mon_com(int cmd,void *arg1,void *arg2,void *arg3);
81extern int mon_timer(int cmd, void * arg);
82extern int mon_setenv(char *varname,char *value);
83extern int mon_putchar(char c);
84extern int mon_getchar(void);
85extern int mon_gotachar(void);
86extern int mon_getbytes(char *buf,int count,int block);
87extern int mon_restart(int restart_value);
88extern int mon_tfsinit(void);
89extern int mon_tfsunlink(char *filename);
90extern int mon_tfslink(char *source, char *target);
91extern int mon_tfsrun(char **arglist,int verbosity);
92extern int mon_tfsfstat(char *filename,struct tfshdr *tfp);
93extern int mon_tfseof(int file_descriptor);
94extern int mon_tfstruncate(int file_descriptor,long length);
95extern int mon_tfsread(int file_descriptor,char *buffer,int size);
96extern int mon_tfswrite(int file_descriptor,char *buffer,int size);
97extern int mon_tfsopen(char *filename,long mode,char *buffer);
98extern int mon_tfsclose(int file_descriptor,char *info);
99extern int mon_tfsseek(int file_descriptor,int offset,int whence);
100extern int mon_tfsgetline(int file_descriptor,char *buffer,int bufsize);
101extern int mon_tfsipmod(char *name,char *buffer,int offset,int size);
102extern int mon_addcommand(struct monCommand *command_list,char *);
103extern int mon_docommand(char *cmdline,int verbosity);
104extern int mon_getline(char *buffer,int max,int ledit);
105extern int mon_decompress(char *src,int srcsize,char *dest);
106extern int mon_heapextend(char *base,int size);
107extern int mon_pcicfgwrite(int interface,int bus,int dev,int func,int reg,
108 unsigned long val);
109extern int mon_tfsadd(char *filename, char *info, char *flags,
110 unsigned char *src, int size);
111extern int mon_i2cwrite(int interface, int bigaddr, unsigned char *data,
112 int len);
113extern int mon_i2cread(int interface, int bigaddr, unsigned char *data,
114 int len);
115extern int mon_sendenetpkt(char *pkt, int len);
116extern int mon_recvenetpkt(char *pkt, int len);
117extern int mon_flashoverride(void *flashinfo, int get, int bank);
118extern int mon_flasherase(int snum);
119extern int mon_flashwrite(char *dest,char *src, int bytecnt);
120extern int mon_flashinfo(int snum,int *size, char **base);
121extern int mon_watchdog(void);
122extern int mon_timeofday(int cmd, void *arg);
123
124extern char *mon_getsym(char *symname, char *buf, int bufsize);
125extern char *mon_getenv(char *varname);
126extern char *mon_getenvp(void);
127extern char *mon_version(void);
128#ifdef MALLOC_DEBUG
129extern char *mon_malloc(int size,char *file, int line);
130extern char *mon_realloc(char *buf,int size,char *file, int line);
131#else
132extern char *mon_malloc(int size);
133extern char *mon_realloc(char *buf,int size);
134#endif
135
136extern long mon_tfsctrl(int command,long arg1,long arg2);
137extern long mon_tfstell(int file_descriptor);
138extern long mon_portcmd(int cmd, void *arg);
139
140extern unsigned short mon_xcrc16(char *buffer,long length);
141
142extern unsigned long mon_intsoff(void);
143
144extern unsigned long mon_pcicfgread(int interface,int bus,int dev,
145 int func,int reg);
146
147extern unsigned long mon_pcictrl(int interface, int cmd,
148 unsigned long arg1, unsigned long arg2);
149
150extern unsigned long mon_i2cctrl(int interface, int cmd,
151 unsigned long arg1, unsigned long arg2);
152
153extern unsigned long mon_assignhandler(long hnum,
154 unsigned long arg1,unsigned long arg2);
155
156extern struct tfshdr *mon_tfsnext(struct tfshdr *tfp);
157extern struct tfshdr *mon_tfsstat(char *filename);
158
159/*
160 * The external caller should see these as variable argument methods but
161 * they are not implemented that way, so let monlib.c prototype them internally
162 * when building that file.
163 */
164#ifndef _INSIDE_MONLIB
165extern void mon_memtrace(char *fmt, ...);
166extern int mon_printf(char *fmt, ...);
167extern int mon_cprintf(char *fmt, ...);
168extern int mon_sprintf(char *,char *fmt, ...);
169#endif
170
171#ifdef __cplusplus
172}
173#endif
174
175
176/* defines used by monConnect():
177 */
178#define GETMONFUNC_PUTCHAR 1
179#define GETMONFUNC_GETCHAR 2
180#define GETMONFUNC_GOTACHAR 3
181#define GETMONFUNC_GETBYTES 4
182#define GETMONFUNC_PRINTF 5
183#define GETMONFUNC_CPRINTF 6
184#define GETMONFUNC_SPRINTF 7
185#define GETMONFUNC_RESTART 8
186#define GETMONFUNC_GETENV 9
187#define GETMONFUNC_SETENV 10
188#define GETMONFUNC_TFSINIT 11
189#define GETMONFUNC_TFSADD 12
190#define GETMONFUNC_TFSUNLINK 13
191#define GETMONFUNC_TFSRUN 14
192#define GETMONFUNC_TFSNEXT 15
193#define GETMONFUNC_TFSSTAT 16
194#define GETMONFUNC_TFSREAD 17
195#define GETMONFUNC_TFSWRITE 18
196#define GETMONFUNC_TFSOPEN 19
197#define GETMONFUNC_TFSCLOSE 20
198#define GETMONFUNC_TFSSEEK 21
199#define GETMONFUNC_TFSGETLINE 22
200#define GETMONFUNC_TFSIPMOD 23
201#define GETMONFUNC_TFSCTRL 24
202#define GETMONFUNC_ADDCOMMAND 25
203#define GETMONFUNC_DOCOMMAND 26
204#define GETMONFUNC_GETARGV 27
205#define GETMONFUNC_CRC16 28
206#define GETMONFUNC_CRC32 29
207#define GETMONFUNC_PIOGET 30 /* NA (removed as of 1.0) */
208#define GETMONFUNC_PIOSET 31 /* NA (removed as of 1.0) */
209#define GETMONFUNC_PIOCLR 32 /* NA (removed as of 1.0) */
210#define GETMONFUNC_INTSOFF 33
211#define GETMONFUNC_INTSRESTORE 34
212#define GETMONFUNC_APPEXIT 35
213#define GETMONFUNC_MALLOC 36
214#define GETMONFUNC_FREE 37
215#define GETMONFUNC_GETLINE 38
216#define GETMONFUNC_TFSFSTAT 39
217#define GETMONFUNC_TFSEOF 40
218#define GETMONFUNC_DECOMPRESS 41
219#define GETMONFUNC_TFSTRUNCATE 42
220#define GETMONFUNC_HEAPXTEND 43
221#define GETMONFUNC_PROFILER 44
222#define GETMONFUNC_TFSLINK 45
223#define GETMONFUNC_BBC 46
224#define GETMONFUNC_MEMTRACE 47
225#define GETMONFUNC_TFSTELL 48
226#define GETMONFUNC_VERSION 49
227#define GETMONFUNC_WARMSTART 50
228#define GETMONFUNC_PCICFGREAD 51
229#define GETMONFUNC_PCICFGWRITE 52
230#define GETMONFUNC_PCICONTROL 53
231#define GETMONFUNC_I2CREAD 54
232#define GETMONFUNC_I2CWRITE 55
233#define GETMONFUNC_I2CCONTROL 56
234#define GETMONFUNC_MONDELAY 57
235#define GETMONFUNC_GETENVP 58
236#define GETMONFUNC_REALLOC 59
237#define GETMONFUNC_SENDENETPKT 60
238#define GETMONFUNC_RECVENETPKT 61
239#define GETMONFUNC_GETSYM 62
240#define GETMONFUNC_PRINTPKT 63
241#define GETMONFUNC_FLASHWRITE 64
242#define GETMONFUNC_FLASHERASE 65
243#define GETMONFUNC_FLASHINFO 66
244#define GETMONFUNC_ASSIGNHDLR 67
245#define GETMONFUNC_WATCHDOG 68
246#define GETMONFUNC_PRINTMEM 69
247#define GETMONFUNC_PORTCMD 70
248#define GETMONFUNC_TIMEOFDAY 71
249#define GETMONFUNC_TIMER 72
250#define GETMONFUNC_FLASHOVRRD 73
251
252#define CACHEFTYPE_DFLUSH 200
253#define CACHEFTYPE_IINVALIDATE 201
254
255#define CHARFUNC_PUTCHAR 300
256#define CHARFUNC_GETCHAR 301
257#define CHARFUNC_GOTACHAR 302
258#define CHARFUNC_RAWMODEON 303
259#define CHARFUNC_RAWMODEOFF 304
260
261#define ASSIGNFUNC_GETUSERLEVEL 400
262
263
264/* Defines used by mon_warmstart():
265 */
266#define WARMSTART_IOINIT 0x00000001
267#define WARMSTART_BSSINIT 0x00000002
268#define WARMSTART_RUNMONRC 0x00000004
269#define WARMSTART_MONHEADER 0x00000008
270#define WARMSTART_TFSAUTOBOOT 0x00000010
271#define WARMSTART_BOARDINFO 0x00000020
272#define WARMSTART_ALL 0xffffffff
273#endif
Header file for Command Line Interface related stuff.
Definition: mongoose.c:442
Definition: cli.h:54
Definition: tfs.h:138
unsigned size
Definition: tte.h:1
Header file for TFS transactions, used by both application and monnitor.
