RTEMS 5.2
system_conf.h
1
9/* system_conf.h
10 * Global System conf
11 *
12 * Milkymist port of RTEMS
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 *
18 * COPYRIGHT (c) 2010, 2011 Sebastien Bourdeauducq
19 */
20
21#ifndef __SYSTEM_CONFIG_H_
22#define __SYSTEM_CONFIG_H_
23
24#define UART_BAUD_RATE (115200)
25
26/* Clock frequency */
27#define MM_FREQUENCY (0xe0001074)
28
29/* FML bridge */
30#define FMLBRG_FLUSH_BASE (0xc8000000)
31#define FMLBRG_LINE_LENGTH (32)
32#define FMLBRG_LINE_COUNT (512)
33
34/* UART */
35#define MM_UART_RXTX (0xe0000000)
36#define MM_UART_DIV (0xe0000004)
37#define MM_UART_STAT (0xe0000008)
38#define MM_UART_CTRL (0xe000000c)
39
40#define UART_STAT_THRE (0x1)
41#define UART_STAT_RX_EVT (0x2)
42#define UART_STAT_TX_EVT (0x4)
43
44#define UART_CTRL_RX_INT (0x1)
45#define UART_CTRL_TX_INT (0x2)
46#define UART_CTRL_THRU (0x4)
47
48/* Timers */
49#define MM_TIMER1_COMPARE (0xe0001024)
50#define MM_TIMER1_COUNTER (0xe0001028)
51#define MM_TIMER1_CONTROL (0xe0001020)
52
53#define MM_TIMER0_COMPARE (0xe0001014)
54#define MM_TIMER0_COUNTER (0xe0001018)
55#define MM_TIMER0_CONTROL (0xe0001010)
56
57#define TIMER_ENABLE (0x01)
58#define TIMER_AUTORESTART (0x02)
59
60/* GPIO */
61#define MM_GPIO_IN (0xe0001000)
62#define MM_GPIO_OUT (0xe0001004)
63#define MM_GPIO_INTEN (0xe0001008)
64
65#define GPIO_BTN1 (0x00000001)
66#define GPIO_BTN2 (0x00000002)
67#define GPIO_BTN3 (0x00000004)
68#define GPIO_PCBREV0 (0x00000008)
69#define GPIO_PCBREV1 (0x00000010)
70#define GPIO_PCBREV2 (0x00000020)
71#define GPIO_PCBREV3 (0x00000040)
72#define GPIO_LED1 (0x00000001)
73#define GPIO_LED2 (0x00000002)
74
75/* System ID and reset */
76#define MM_SYSTEM_ID (0xe000107c)
77
78/* ICAP */
79#define MM_ICAP (0xe0001040)
80
81#define ICAP_READY (0x01)
82#define ICAP_CE (0x10000)
83#define ICAP_WRITE (0x20000)
84
85/* VGA */
86#define MM_VGA_RESET (0xe0003000)
87
88#define MM_VGA_HRES (0xe0003004)
89#define MM_VGA_HSYNC_START (0xe0003008)
90#define MM_VGA_HSYNC_END (0xe000300C)
91#define MM_VGA_HSCAN (0xe0003010)
92
93#define MM_VGA_VRES (0xe0003014)
94#define MM_VGA_VSYNC_START (0xe0003018)
95#define MM_VGA_VSYNC_END (0xe000301C)
96#define MM_VGA_VSCAN (0xe0003020)
97
98#define MM_VGA_BASEADDRESS (0xe0003024)
99#define MM_VGA_BASEADDRESS_ACT (0xe0003028)
100
101#define MM_VGA_BURST_COUNT (0xe000302C)
102
103#define MM_VGA_DDC (0xe0003030)
104
105#define MM_VGA_CLKSEL (0xe0003034)
106
107#define VGA_RESET (0x01)
108#define VGA_DDC_SDAIN (0x1)
109#define VGA_DDC_SDAOUT (0x2)
110#define VGA_DDC_SDAOE (0x4)
111#define VGA_DDC_SDC (0x8)
112
113/* Ethernet */
114#define MM_MINIMAC_SETUP (0xe0008000)
115#define MM_MINIMAC_MDIO (0xe0008004)
116
117#define MM_MINIMAC_STATE0 (0xe0008008)
118#define MM_MINIMAC_COUNT0 (0xe000800C)
119#define MM_MINIMAC_STATE1 (0xe0008010)
120#define MM_MINIMAC_COUNT1 (0xe0008014)
121
122#define MM_MINIMAC_TXCOUNT (0xe0008018)
123
124#define MINIMAC_RX0_BASE (0xb0000000)
125#define MINIMAC_RX1_BASE (0xb0000800)
126#define MINIMAC_TX_BASE (0xb0001000)
127
128#define MINIMAC_SETUP_PHYRST (0x1)
129
130#define MINIMAC_STATE_EMPTY (0x0)
131#define MINIMAC_STATE_LOADED (0x1)
132#define MINIMAC_STATE_PENDING (0x2)
133
134/* AC97 */
135#define MM_AC97_CRCTL (0xe0005000)
136
137#define AC97_CRCTL_RQEN (0x01)
138#define AC97_CRCTL_WRITE (0x02)
139
140#define MM_AC97_CRADDR (0xe0005004)
141#define MM_AC97_CRDATAOUT (0xe0005008)
142#define MM_AC97_CRDATAIN (0xe000500C)
143
144#define MM_AC97_DCTL (0xe0005010)
145#define MM_AC97_DADDRESS (0xe0005014)
146#define MM_AC97_DREMAINING (0xe0005018)
147
148#define MM_AC97_UCTL (0xe0005020)
149#define MM_AC97_UADDRESS (0xe0005024)
150#define MM_AC97_UREMAINING (0xe0005028)
151
152#define AC97_SCTL_EN (0x01)
153
154#define AC97_MAX_DMASIZE (0x3fffc)
155
156/* SoftUSB */
157#define MM_SOFTUSB_CONTROL (0xe000f000)
158
159#define SOFTUSB_CONTROL_RESET (0x1)
160
161#define MM_SOFTUSB_PMEM_BASE (0xa0000000)
162#define MM_SOFTUSB_DMEM_BASE (0xa0020000)
163
164#define SOFTUSB_PMEM_SIZE (1 << 13)
165#define SOFTUSB_DMEM_SIZE (1 << 13)
166
167/* PFPU */
168#define MM_PFPU_CTL (0xe0006000)
169#define PFPU_CTL_START (0x01)
170#define PFPU_CTL_BUSY (0x01)
171
172#define MM_PFPU_MESHBASE (0xe0006004)
173#define MM_PFPU_HMESHLAST (0xe0006008)
174#define MM_PFPU_VMESHLAST (0xe000600C)
175
176#define MM_PFPU_CODEPAGE (0xe0006010)
177
178#define MM_PFPU_DREGBASE (0xe0006400)
179#define MM_PFPU_CODEBASE (0xe0006800)
180
181#define PFPU_PAGESIZE (512)
182#define PFPU_SPREG_COUNT (2)
183#define PFPU_REG_X (0)
184#define PFPU_REG_Y (1)
185
186/* TMU */
187#define MM_TMU_CTL (0xe0007000)
188#define TMU_CTL_START (0x01)
189#define TMU_CTL_BUSY (0x01)
190#define TMU_CTL_CHROMAKEY (0x02)
191
192#define MM_TMU_HMESHLAST (0xe0007004)
193#define MM_TMU_VMESHLAST (0xe0007008)
194#define MM_TMU_BRIGHTNESS (0xe000700C)
195#define MM_TMU_CHROMAKEY (0xe0007010)
196
197#define MM_TMU_VERTICESADR (0xe0007014)
198#define MM_TMU_TEXFBUF (0xe0007018)
199#define MM_TMU_TEXHRES (0xe000701C)
200#define MM_TMU_TEXVRES (0xe0007020)
201#define MM_TMU_TEXHMASK (0xe0007024)
202#define MM_TMU_TEXVMASK (0xe0007028)
203
204#define MM_TMU_DSTFBUF (0xe000702C)
205#define MM_TMU_DSTHRES (0xe0007030)
206#define MM_TMU_DSTVRES (0xe0007034)
207#define MM_TMU_DSTHOFFSET (0xe0007038)
208#define MM_TMU_DSTVOFFSET (0xe000703C)
209#define MM_TMU_DSTSQUAREW (0xe0007040)
210#define MM_TMU_DSTSQUAREH (0xe0007044)
211
212#define MM_TMU_ALPHA (0xe0007048)
213
214/* Memory card */
215#define MM_MEMCARD_CLK2XDIV (0xe0004000)
216
217#define MM_MEMCARD_ENABLE (0xe0004004)
218
219#define MEMCARD_ENABLE_CMD_TX (0x1)
220#define MEMCARD_ENABLE_CMD_RX (0x2)
221#define MEMCARD_ENABLE_DAT_TX (0x4)
222#define MEMCARD_ENABLE_DAT_RX (0x8)
223
224#define MM_MEMCARD_PENDING (0xe0004008)
225
226#define MEMCARD_PENDING_CMD_TX (0x1)
227#define MEMCARD_PENDING_CMD_RX (0x2)
228#define MEMCARD_PENDING_DAT_TX (0x4)
229#define MEMCARD_PENDING_DAT_RX (0x8)
230
231#define MM_MEMCARD_START (0xe000400c)
232
233#define MEMCARD_START_CMD_RX (0x1)
234#define MEMCARD_START_DAT_RX (0x2)
235
236#define MM_MEMCARD_CMD (0xe0004010)
237#define MM_MEMCARD_DAT (0xe0004014)
238
239/* DMX */
240#define MM_DMX_TX(x) (0xe000c000+4*(x))
241#define MM_DMX_THRU (0xe000c800)
242#define MM_DMX_RX(x) (0xe000d000+4*(x))
243
244/* MIDI */
245#define MM_MIDI_RXTX (0xe000b000)
246#define MM_MIDI_DIV (0xe000b004)
247#define MM_MIDI_STAT (0xe000b008)
248#define MM_MIDI_CTRL (0xe000b00c)
249
250#define MIDI_STAT_THRE (0x1)
251#define MIDI_STAT_RX_EVT (0x2)
252#define MIDI_STAT_TX_EVT (0x4)
253
254#define MIDI_CTRL_RX_INT (0x1)
255#define MIDI_CTRL_TX_INT (0x2)
256#define MIDI_CTRL_THRU (0x4)
257
258/* IR */
259#define MM_IR_RX (0xe000e000)
260
261/* Video input */
262#define MM_BT656_I2C (0xe000a000)
263#define MM_BT656_FILTERSTATUS (0xe000a004)
264#define MM_BT656_BASE (0xe000a008)
265#define MM_BT656_MAXBURSTS (0xe000a00c)
266#define MM_BT656_DONEBURSTS (0xe000a010)
267
268#define BT656_I2C_SDAIN (0x1)
269#define BT656_I2C_SDAOUT (0x2)
270#define BT656_I2C_SDAOE (0x4)
271#define BT656_I2C_SDC (0x8)
272
273#define BT656_FILTER_FIELD1 (0x1)
274#define BT656_FILTER_FIELD2 (0x2)
275#define BT656_FILTER_INFRAME (0x4)
276
277/* Interrupts */
278#define MM_IRQ_UART (0)
279#define MM_IRQ_GPIO (1)
280#define MM_IRQ_TIMER0 (2)
281#define MM_IRQ_TIMER1 (3)
282#define MM_IRQ_AC97CRREQUEST (4)
283#define MM_IRQ_AC97CRREPLY (5)
284#define MM_IRQ_AC97DMAR (6)
285#define MM_IRQ_AC97DMAW (7)
286#define MM_IRQ_PFPU (8)
287#define MM_IRQ_TMU (9)
288#define MM_IRQ_ETHRX (10)
289#define MM_IRQ_ETHTX (11)
290#define MM_IRQ_VIDEOIN (12)
291#define MM_IRQ_MIDI (13)
292#define MM_IRQ_IR (14)
293#define MM_IRQ_USB (15)
294
295/* Flash layout */
296#define FLASH_BASE (0x80000000)
297
298#define FLASH_OFFSET_STANDBY_BITSTREAM (0x80000000)
299
300#define FLASH_OFFSET_RESCUE_BITSTREAM (0x800A0000)
301#define FLASH_OFFSET_RESCUE_BIOS (0x80220000)
302#define FLASH_OFFSET_MAC_ADDRESS (0x802200E0)
303#define FLASH_OFFSET_RESCUE_SPLASH (0x80240000)
304#define FLASH_OFFSET_RESCUE_APP (0x802E0000)
305
306#define FLASH_OFFSET_REGULAR_BITSTREAM (0x806E0000)
307#define FLASH_OFFSET_REGULAR_BIOS (0x80860000)
308#define FLASH_OFFSET_REGULAR_SPLASH (0x80880000)
309#define FLASH_OFFSET_REGULAR_APP (0x80920000)
310
311/* MMIO */
312#define MM_READ(reg) (*((volatile unsigned int *)(reg)))
313#define MM_WRITE(reg, val) *((volatile unsigned int *)(reg)) = val
314
315/* Flash partitions */
316
317#define FLASH_SECTOR_SIZE (128*1024)
318
319#define FLASH_PARTITION_COUNT (5)
320
321#define FLASH_PARTITIONS { \
322 { .start_address = 0x806E0000, .length = 0x0180000 }, \
323 { .start_address = 0x80860000, .length = 0x0020000 }, \
324 { .start_address = 0x80880000, .length = 0x00A0000 }, \
325 { .start_address = 0x80920000, .length = 0x0400000 }, \
326 { .start_address = 0x80D20000, .length = 0x12E0000 }, \
327}
328
329#endif /* __SYSTEM_CONFIG_H_ */
