RTEMS
5.2
bsps
mips
shared
gdbstub
memlimits.h
1
7
8
* limits.h - definition of machine & system dependent address limits
9
10
* THIS SOFTWARE IS NOT COPYRIGHTED
11
12
* The following software is offered for use in the public domain.
13
* There is no warranty with regard to this software or its performance
14
* and the user must accept the software "AS IS" with all faults.
15
16
* THE CONTRIBUTORS DISCLAIM ANY WARRANTIES, EXPRESS OR IMPLIED, WITH
17
* REGARD TO THIS SOFTWARE INCLUDING BUT NOT LIMITED TO THE WARRANTIES
18
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
19
20
21
#ifndef _MEMLIMITS_H_
22
#define _MEMLIMITS_H_
23
24
25
* The macros in this file are specific to a given implementation.
26
* The general rules for their construction are as follows:
27
28
* 1.) is_readable(addr,length) should be true if and only if the
29
* region starting at the given virtual address can be read
30
* _without_ causing an exception or other fatal error. Note
31
* that the stub will use the strictest alignment satisfied
32
* by _both_ addr and length (e.g., if both are divisible by
33
* 8 then the region will be read in double-word chunks).
34
35
* 2.) is_writeable(addr,length) should be true if and only if the
36
* region starting at the given virtual address can be written
37
38
39
40
* 8 then the region will be written in double-word chunks).
41
42
* 3.) is-steppable(ptr) whould be true if and only if ptr is the
43
* address of a writeable region of memory which may contain
44
* an executable instruction. At a minimum this requires that
45
* ptr be word-aligned (divisible by 4) and not point to EPROM
46
* or memory-mapped I/O.
47
48
* Note: in order to satisfy constraints related to cacheability
49
* of certain memory subsystems it may be necessary for regions
50
* of kseg0 and kseg1 which map to the same physical addresses
51
* to have different readability and/or writeability attributes.
52
53
61
62
#define K0_LIMIT_FOR_READ (K0BASE+0x18000000)
63
#define K1_LIMIT_FOR_READ (K1BASE+K1SIZE)
64
65
#define is_readable(addr,length) \
66
(((K0BASE <= addr) && ((addr + length) <= K0_LIMIT_FOR_READ)) \
67
|| ((K1BASE <= addr) && ((addr + length) <= K1_LIMIT_FOR_READ)))
68
69
#define K0_LIMIT_FOR_WRITE (K0BASE+0x08000000)
70
#define K1_LIMIT_FOR_WRITE (K1BASE+0x1e000000)
71
72
#define is_writeable(addr,length) \
73
(((K0BASE <= addr) && ((addr + length) <= K0_LIMIT_FOR_WRITE)) \
74
|| ((K1BASE <= addr) && ((addr + length) <= K1_LIMIT_FOR_WRITE)))
75
76
#define K0_LIMIT_FOR_STEP (K0BASE+0x08000000)
77
#define K1_LIMIT_FOR_STEP (K1BASE+0x08000000)
78
79
#define is_steppable(ptr) \
80
((((int)ptr & 0x3) == 0) \
81
&& (((K0BASE <= (int)ptr) && ((int)ptr < K0_LIMIT_FOR_STEP)) \
82
|| ((K1BASE <= (int)ptr) && ((int)ptr < K1_LIMIT_FOR_STEP))))
83
84
struct memseg
85
86
unsigned begin, end, opts;
87
88
89
#define MEMOPT_READABLE 1
90
#define MEMOPT_WRITEABLE 2
91
92
#define NUM_MEMSEGS 10
93
94
int add_memsegment(unsigned,unsigned,int);
95
int is_readable(unsigned,unsigned);
96
int is_writeable(unsigned,unsigned);
97
int is_steppable(unsigned);
98
99
100
#endif
/* _MEMLIMITS_H_ */
