RTEMS 5.2
math.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _MATH_
31#define _MATH_
32
33/*------------------------------------------------------------------------------
34 * Exported functions
35 *------------------------------------------------------------------------------*/
36
37extern uint32_t min(uint32_t dwA, uint32_t dwB);
38extern uint32_t absv(int32_t lValue);
39extern uint32_t power(uint32_t dwX, uint32_t dwY);
40
41#endif /* #ifndef _MATH_ */
42
