RTEMS 5.2
m340uart.h
1
9/*
10 * Header file for console driver
11 * defines for accessing M68340/68349 UART registers
12 *
13 * Author:
14 * Geoffroy Montel
15 * France Telecom - CNET/DSM/TAM/CAT
16 * 4, rue du Clos Courtel
17 * 35512 CESSON-SEVIGNE
18 * FRANCE
19 *
20 * e-mail: g_montel@yahoo.com
21 *
22 *
23 * COPYRIGHT (c) 1989-2008.
24 * On-Line Applications Research Corporation (OAR).
25 *
26 * The license and distribution terms for this file may be
27 * found in the file LICENSE in this distribution or at
28 * http://www.rtems.org/license/LICENSE.
29 */
30
31#ifndef __m340uart_H__
32#define __m340uart_H__
33
34#include <sys/types.h>
35
36/* UART initialisation */
37#define UART_CHANNEL_A 0
38#define UART_CHANNEL_B 1
39#define UART_NUMBER_OF_CHANNELS 2
40#define UART_CONSOLE_NAME "/dev/console"
41#define UART_RAW_IO_NAME "/dev/tty1"
42#define UART_FIFO_FULL 0
43#define UART_CRR 1
44#define UART_INTERRUPTS 0
45#define UART_POLLING 1
46#define UART_TERMIOS_CONSOLE 0
47#define UART_TERMIOS_RAW 1
48#define UART_TERMIOS_MIN_DEFAULT 1
49#define UART_TERMIOS_TIME_DEFAULT 0
50
51void Init_UART_Table(void);
52
53typedef struct {
54 uint8_t enable;
55 uint16_t rx_buffer_size; /* NOT IMPLEMENTED */
56 uint16_t tx_buffer_size; /* NOT IMPLEMENTED */
58
59typedef struct { /* for one channel */
60 uint8_t enable; /* use this channel */
61 char name[64]; /* use UART_CONSOLE_NAME for console purpose */
62 uint8_t parity_mode; /* parity mode, see MR1 section for defines */
63 uint8_t bits_per_char; /* bits per character, see MR1 section for defines */
64 float rx_baudrate; /* Rx baudrate */
65 float tx_baudrate; /* Tx baudrate */
66 uint8_t rx_mode; /* FIFO Full (UART_FIFO_FULL) or ChannelReceiverReady (UART_CRR) */
67 uint8_t mode; /* use interrupts (UART_INTERRUPTS) or polling (UART_POLLING) */
68 uart_termios_config termios;
70
71extern uart_channel_config m340_uart_config[UART_NUMBER_OF_CHANNELS];
72
73typedef struct {
74 int set; /* number of the m340 baud speed set */
75 int rcs; /* RCS for the needed baud set */
76 int tcs; /* TCS for the needed baud set */
78
79typedef struct {
80 t_baud_speed baud_speed_table[2];
81 short nb;
83
85Find_Right_m340_UART_Config(float ChannelA_ReceiverBaudRate, float ChannelA_TransmitterBaudRate, uint8_t enableA,
86 float ChannelB_ReceiverBaudRate, float ChannelB_TransmitterBaudRate, uint8_t enableB);
87
88extern rtems_isr InterruptHandler (rtems_vector_number v);
89
90extern int dbugRead (int minor);
91extern ssize_t dbugWrite (int minor, const char *buf, size_t len);
92
93extern float m340_Baud_Rates_Table[16][2];
94
95/* SR */
96#define m340_Rx_RDY 1
97#define m340_FFULL (1<<1)
98#define m340_Tx_RDY (1<<2)
99#define m340_TxEMP (1<<3)
100#define m340_OE (1<<4)
101#define m340_PE (1<<5)
102#define m340_FE (1<<6)
103#define m340_RB (1<<7)
104
105/* IER */
106#define m340_TxRDYA 1
107#define m340_RxRDYA (1<<1)
108#define m340_TxRxRDYA 0x3
109#define m340_TxRDYB (1<<4)
110#define m340_RxRDYB (1<<5)
111#define m340_TxRxRDYB 0x30
112
113/* CR */
114#define m340_Reset_Error_Status 0x40
115#define m340_Reset_Receiver 0x20
116#define m340_Reset_Transmitter 0x30
117#define m340_Transmitter_Enable (1<<2)
118#define m340_Receiver_Enable 1
119#define m340_Transmitter_Disable (2<<2)
120#define m340_Receiver_Disable 2
121
122/* ACR */
123#define m340_BRG_Set1 0
124#define m340_BRG_Set2 (1<<7)
125
126/* OPCR */
127#define m340_OPCR_Gal 0x0
128#define m340_OPCR_Aux 0xFF
129
130/* ISR */
131#define m340_COS (1<<7)
132#define m340_DBB (1<<6)
133#define m340_XTAL_RDY (1<<3)
134#define m340_DBA (1<<2)
135
136/* MR1 */
137#define m340_RxRTS (1<<7)
138#define m340_R_F (1<<6) /* character or block mode */
139#define m340_ERR (1<<5)
140#define m340_RxRTX (1<<7)
141#define m340_Even_Parity 0
142#define m340_Odd_Parity (1<<2)
143#define m340_Low_Parity (2<<2)
144#define m340_High_Parity (3<<2)
145#define m340_No_Parity (4<<2)
146#define m340_Data_Character (6<<2)
147#define m340_Address_Character (7<<2)
148#define m340_5bpc 0x0
149#define m340_6bpc 0x1
150#define m340_7bpc 0x2
151#define m340_8bpc 0x3
152
153/* MR2 */
154#define m340_normal (0<<6)
155#define m340_automatic_echo (1<<6)
156#define m340_local_loopback (2<<6)
157#define m340_remote_loopback (3<<6)
158#define m340_TxRTS (1<<5)
159#define m340_TxCTS (1<<4)
160
161/* Baud rates for Transmitter/Receiver */
162#define SCLK 1 /* put your own SCLK value here */
163
164#endif
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: m340uart.h:79
Definition: m340uart.h:73
Definition: m340uart.h:59
Definition: m340uart.h:53
unsigned v
Definition: tte.h:0
