23#ifndef LIBBSP_ARM_LPC24XX_LPC_ETHERNET_CONFIG_H
24#define LIBBSP_ARM_LPC24XX_LPC_ETHERNET_CONFIG_H
36#define LPC_ETH_CONFIG_INTERRUPT LPC24XX_IRQ_ETHERNET
38#define LPC_ETH_CONFIG_REG_BASE MAC_BASE_ADDR
40#ifdef ARM_MULTILIB_ARCH_V4
41 #define LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT 16
42 #define LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX 54
44 #define LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT 10
45 #define LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX 10
47 #define LPC_ETH_CONFIG_UNIT_MULTIPLE 1U
49 #define LPC24XX_ETH_RAM_BEGIN 0x7fe00000U
50 #define LPC24XX_ETH_RAM_SIZE (16U * 1024U)
52 #define LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT 16
53 #define LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX INT_MAX
55 #define LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT 32
56 #define LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX INT_MAX
58 #define LPC_ETH_CONFIG_UNIT_MULTIPLE 8U
60 #define LPC_ETH_CONFIG_USE_TRANSMIT_DMA
62 #define LPC24XX_ETH_RAM_BEGIN 0x20000000U
63 #define LPC24XX_ETH_RAM_SIZE (32U * 1024U)
66#ifdef LPC24XX_ETHERNET_RMII
67 #define LPC_ETH_CONFIG_RMII
69 static void lpc_eth_config_module_enable(
void)
72 #ifdef LPC24XX_PIN_ETHERNET_POWER_DOWN
73 LPC24XX_PIN_ETHERNET_POWER_DOWN,
75 LPC24XX_PIN_ETHERNET_RMII_0,
76 LPC24XX_PIN_ETHERNET_RMII_1,
77 LPC24XX_PIN_ETHERNET_RMII_2,
78 LPC24XX_PIN_ETHERNET_RMII_3,
82 lpc24xx_module_enable(LPC24XX_MODULE_ETHERNET, LPC24XX_MODULE_PCLK_DEFAULT);
85 #ifdef LPC24XX_PIN_ETHERNET_POWER_DOWN
87 unsigned pin = lpc24xx_pin_get_first_index(&pins[0]);
89 lpc24xx_gpio_config(pin, LPC24XX_GPIO_OUTPUT);
90 lpc24xx_gpio_set(pin);
95 static void lpc_eth_config_module_enable(
void)
98 LPC24XX_PIN_ETHERNET_MII,
102 lpc24xx_module_enable(LPC24XX_MODULE_ETHERNET, LPC24XX_MODULE_PCLK_DEFAULT);
107static void lpc_eth_config_module_disable(
void)
109 lpc24xx_module_disable(LPC24XX_MODULE_ETHERNET);
112static char *lpc_eth_config_alloc_table_area(
size_t size)
114 if (
size < LPC24XX_ETH_RAM_SIZE) {
115 return (
char *) LPC24XX_ETH_RAM_BEGIN;
121static void lpc_eth_config_free_table_area(
char *table_area)
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
rtems_status_code lpc24xx_pin_config(const lpc24xx_pin_range *pins, lpc24xx_pin_action action)
Performs the action with the pins.
Definition: io.c:517
@ LPC24XX_PIN_SET_FUNCTION
Sets the pin function.
Definition: io.h:206
unsigned size
Definition: tte.h:1
