RTEMS 5.2
lan91c11x.h
1
17/*
18 * Header file for SMSC LAN91C11x ethernet devices
19 *
20 * Copyright (c) 2004 by Cogent Computer Systems
21 * Written by Jay Monkman <jtm@lopingdog.com>
22 *
23 * The license and distribution terms for this file may be
24 * found in the file LICENSE in this distribution or at
25 * http://www.rtems.org/license/LICENSE.
26 */
27#ifndef __LAN91C11X_H__
28#define __LAN91C11X_H__
29
30#include <rtems.h>
31#include <bsp.h>
32
33uint16_t lan91c11x_read_reg(int);
34void lan91c11x_write_reg(int, uint16_t);
35uint16_t lan91c11x_read_reg_fast(int);
36void lan91c11x_write_reg_fast(int, uint16_t);
37void lan91c11x_write_phy_reg(int , uint16_t);
38uint16_t lan91c11x_read_phy_reg(int);
39void lan91c11x_unlock(void);
40void lan91c11x_lock(void);
41
42#define LAN91C11X_BASE_ADDR 0x12000000
43
44#define LAN91C11X_REG(_b_, _r_) ((((_b_) & 0xf) << 4) | ((_r_) & 0xf))
45
46
47#define LAN91C11X_TCR (LAN91C11X_REG(0, 0x0))
48#define LAN91C11X_EPHSTAT (LAN91C11X_REG(0, 0x2))
49#define LAN91C11X_RCR (LAN91C11X_REG(0, 0x4))
50#define LAN91C11X_CNTR (LAN91C11X_REG(0, 0x6))
51#define LAN91C11X_MIR (LAN91C11X_REG(0, 0x8))
52#define LAN91C11X_RPCR (LAN91C11X_REG(0, 0xa))
53#define LAN91C11X_BANK (LAN91C11X_REG(0, 0xe))
54#define LAN91C11X_CONFIG (LAN91C11X_REG(1, 0x0))
55#define LAN91C11X_BASE (LAN91C11X_REG(1, 0x2))
56#define LAN91C11X_IA0 (LAN91C11X_REG(1, 0x4))
57#define LAN91C11X_IA2 (LAN91C11X_REG(1, 0x6))
58#define LAN91C11X_IA4 (LAN91C11X_REG(1, 0x8))
59#define LAN91C11X_GNRL (LAN91C11X_REG(1, 0xa))
60#define LAN91C11X_CTRL (LAN91C11X_REG(1, 0xc))
61#define LAN91C11X_MMUCMD (LAN91C11X_REG(2, 0x0))
62#define LAN91C11X_PNR (LAN91C11X_REG(2, 0x2))
63#define LAN91C11X_FIFO (LAN91C11X_REG(2, 0x4))
64#define LAN91C11X_PTR (LAN91C11X_REG(2, 0x6))
65#define LAN91C11X_DATA (LAN91C11X_REG(2, 0x8))
66#define LAN91C11X_INT (LAN91C11X_REG(2, 0xc))
67#define LAN91C11X_MT0 (LAN91C11X_REG(3, 0x0))
68#define LAN91C11X_MT2 (LAN91C11X_REG(3, 0x2))
69#define LAN91C11X_MT4 (LAN91C11X_REG(3, 0x4))
70#define LAN91C11X_MT6 (LAN91C11X_REG(3, 0x6))
71#define LAN91C11X_MGMT (LAN91C11X_REG(3, 0x8))
72#define LAN91C11X_REV (LAN91C11X_REG(3, 0xa))
73#define LAN91C11X_ERCV (LAN91C11X_REG(3, 0xc))
74
75
76#define LAN91C11X_TCR_TXENA (bit(0))
77#define LAN91C11X_TCR_LOOP (bit(1))
78#define LAN91C11X_TCR_FORCOL (bit(2))
79#define LAN91C11X_TCR_PADEN (bit(7))
80#define LAN91C11X_TCR_NOCRC (bit(8))
81#define LAN91C11X_TCR_MONCSN (bit(10))
82#define LAN91C11X_TCR_FDUPLX (bit(11))
83#define LAN91C11X_TCR_STPSQET (bit(12))
84#define LAN91C11X_TCR_EPHLOOP (bit(13))
85#define LAN91C11X_TCR_SWFDUP (bit(15))
86
87#define LAN91C11X_EPHSTAT_TXSUC (bit(0))
88#define LAN91C11X_EPHSTAT_SNGLCOL (bit(1))
89#define LAN91C11X_EPHSTAT_MULCOL (bit(2))
90#define LAN91C11X_EPHSTAT_LTXMUL (bit(3))
91#define LAN91C11X_EPHSTAT_16COL (bit(4))
92#define LAN91C11X_EPHSTAT_SQET (bit(5))
93#define LAN91C11X_EPHSTAT_LTXBRD (bit(6))
94#define LAN91C11X_EPHSTAT_TXDFR (bit(7))
95#define LAN91C11X_EPHSTAT_LATCOL (bit(9))
96#define LAN91C11X_EPHSTAT_LOST (bit(10))
97#define LAN91C11X_EPHSTAT_EXCDEF (bit(11))
98#define LAN91C11X_EPHSTAT_CTRROL (bit(12))
99#define LAN91C11X_EPHSTAT_LINK (bit(14))
100#define LAN91C11X_EPHSTAT_TXUNRN (bit(15))
101
102#define LAN91C11X_RCR_RXABT (bit(0))
103#define LAN91C11X_RCR_PRMS (bit(1))
104#define LAN91C11X_RCR_ALMUL (bit(2))
105#define LAN91C11X_RCR_RXEN (bit(8))
106#define LAN91C11X_RCR_STRIP (bit(9))
107#define LAN91C11X_RCR_ABTENB (bit(13))
108#define LAN91C11X_RCR_FILT (bit(14))
109#define LAN91C11X_RCR_RST (bit(15))
110
111#define LAN91C11X_RPCR_LS0B (bit(2))
112#define LAN91C11X_RPCR_LS1B (bit(3))
113#define LAN91C11X_RPCR_LS2B (bit(4))
114#define LAN91C11X_RPCR_LS0A (bit(5))
115#define LAN91C11X_RPCR_LS1A (bit(6))
116#define LAN91C11X_RPCR_LS2A (bit(7))
117#define LAN91C11X_RPCR_ANEG (bit(11))
118#define LAN91C11X_RPCR_DPLX (bit(12))
119#define LAN91C11X_RPCR_SPEED (bit(13))
120
121#define LAN91C11X_CONFIG_EXTPHY (bit(9))
122#define LAN91C11X_CONFIG_GPCTRL (bit(10))
123#define LAN91C11X_CONFIG_NOWAIT (bit(12))
124#define LAN91C11X_CONFIG_PWR (bit(15))
125
126#define LAN91C11X_CTRL_STORE (bit(0))
127#define LAN91C11X_CTRL_RELOAD (bit(1))
128#define LAN91C11X_CTRL_EEPROM (bit(2))
129#define LAN91C11X_CTRL_TEEN (bit(5))
130#define LAN91C11X_CTRL_CREN (bit(6))
131#define LAN91C11X_CTRL_LEEN (bit(7))
132#define LAN91C11X_CTRL_AUTO (bit(11))
133#define LAN91C11X_CTRL_RCVBAD (bit(14))
134
135#define LAN91C11X_MMUCMD_BUSY (bit(0))
136#define LAN91C11X_MMUCMD_NOOP (0 << 5)
137#define LAN91C11X_MMUCMD_ALLOCTX (1 << 5)
138#define LAN91C11X_MMUCMD_RESETMMU (2 << 5)
139#define LAN91C11X_MMUCMD_REMFRM (3 << 5)
140#define LAN91C11X_MMUCMD_REMTOP (4 << 5)
141#define LAN91C11X_MMUCMD_RELEASE (5 << 5)
142#define LAN91C11X_MMUCMD_ENQUEUE (6 << 5)
143#define LAN91C11X_MMUCMD_RESETTX (7 << 5)
144
145#define LAN91C11X_PTR_MASK (0x7ff)
146#define LAN91C11X_PTR_NE (bit(11))
147#define LAN91C11X_PTR_ETEN (bit(12))
148#define LAN91C11X_PTR_READ (bit(13))
149#define LAN91C11X_PTR_AUTOINC (bit(14))
150#define LAN91C11X_PTR_RCV (bit(15))
151
152#define LAN91C11X_INT_RX (bit(0))
153#define LAN91C11X_INT_TX (bit(1))
154#define LAN91C11X_INT_TXE (bit(2))
155#define LAN91C11X_INT_ALLOC (bit(3))
156#define LAN91C11X_INT_RXOV (bit(4))
157#define LAN91C11X_INT_EPH (bit(5))
158#define LAN91C11X_INT_ERX (bit(6))
159#define LAN91C11X_INT_MD (bit(7))
160#define LAN91C11X_INT_RXMASK (bit(8))
161#define LAN91C11X_INT_TXMASK (bit(9))
162#define LAN91C11X_INT_TXEMASK (bit(10))
163#define LAN91C11X_INT_ALLOCMASK (bit(11))
164#define LAN91C11X_INT_RXOVMASK (bit(12))
165#define LAN91C11X_INT_EPHMASK (bit(13))
166#define LAN91C11X_INT_ERXMASK (bit(14))
167#define LAN91C11X_INT_MDMASK (bit(15))
168
169#define LAN91C11X_MGMT_MDO (bit(0))
170#define LAN91C11X_MGMT_MDI (bit(1))
171#define LAN91C11X_MGMT_MCLK (bit(2))
172#define LAN91C11X_MGMT_MDOE (bit(3))
173#define LAN91C11X_MGMT_MSKCRS100 (bit(14))
174
175
176#define LAN91C11X_PKT_CTRL_CRC (bit(4))
177#define LAN91C11X_PKT_CTRL_ODD (bit(5))
178
179
180/* PHY Registers */
181#define PHY_CTRL 0x00 /* PHY Control */
182#define PHY_STAT 0x01 /* PHY Status */
183#define PHY_ID1 0x02 /* PHY Identifier 1 */
184#define PHY_ID2 0x03 /* PHY Identifier 2 */
185#define PHY_AD 0x04 /* PHY Auto-negotiate Control */
186#define PHY_RMT 0x05 /* PHY Auto-neg Remote End Cap Register */
187#define PHY_CFG1 0x10 /* PHY Configuration 1 */
188#define PHY_CFG2 0x11 /* PHY Configuration 2 */
189#define PHY_INT 0x12 /* Status Output (Interrupt Status) */
190#define PHY_MASK 0x13 /* Interrupt Mask */
191
192/* PHY Control Register Bit Defines */
193#define PHY_CTRL_RST 0x8000 /* PHY Reset */
194#define PHY_CTRL_LPBK 0x4000 /* PHY Loopback */
195#define PHY_CTRL_SPEED 0x2000 /* 100Mbps, 0=10Mpbs */
196#define PHY_CTRL_ANEGEN 0x1000 /* Enable Auto negotiation */
197#define PHY_CTRL_PDN 0x0800 /* PHY Power Down mode */
198#define PHY_CTRL_MIIDIS 0x0400 /* MII 4 bit interface disabled */
199#define PHY_CTRL_ANEGRST 0x0200 /* Reset Auto negotiate */
200#define PHY_CTRL_DPLX 0x0100 /* Full Duplex, 0=Half Duplex */
201#define PHY_CTRL_COLTST 0x0080 /* MII Colision Test */
202
203#define PHY_STAT_CAPT4 0x8000
204#define PHY_STAT_CAPTXF 0x4000
205#define PHY_STAT_CAPTXH 0x2000
206#define PHY_STAT_CAPTF 0x1000
207#define PHY_STAT_CAPTH 0x0800
208#define PHY_STAT_CAPSUPR 0x0040
209#define PHY_STAT_ANEGACK 0x0020
210#define PHY_STAT_REMFLT 0x0010
211#define PHY_STAT_CAPANEG 0x0008
212#define PHY_STAT_LINK 0x0004
213#define PHY_STAT_JAB 0x0002
214#define PHY_STAT_EXREG 0x0001
215
216#define PHY_ADV_NP 0x8000
217#define PHY_ADV_ACK 0x4000
218#define PHY_ADV_RF 0x2000
219#define PHY_ADV_T4 0x0200
220#define PHY_ADV_TXFDX 0x0100
221#define PHY_ADV_TXHDX 0x0080
222#define PHY_ADV_10FDX 0x0040
223#define PHY_ADV_10HDX 0x0020
224#define PHY_ADV_CSMA 0x0001
225
226
227
228
229#endif /* __LAN91C11X_H__ */
