RTEMS 5.2
kd.h
1
9/*
10 * by: Rosimildo da Silva: rdasilva@connecttel.com
11 *
12 *
13 */
14
15#ifndef _LINUX_KD_H
16#define _LINUX_KD_H
17#include <sys/types.h>
18
19/* 0x4B is 'K', to avoid collision with termios and vt */
20
21#define KIOCSOUND 0x4B2F /* start sound generation (0 for off) */
22#define KDMKTONE 0x4B30 /* generate tone */
23
24#define KDGETLED 0x4B31 /* return current led state */
25#define KDSETLED 0x4B32 /* set led state [lights, not flags] */
26#define LED_SCR 0x01 /* scroll lock led */
27#define LED_CAP 0x04 /* caps lock led */
28#define LED_NUM 0x02 /* num lock led */
29
30#define KDGKBTYPE 0x4B33 /* get keyboard type */
31#define KB_84 0x01
32#define KB_101 0x02 /* this is what we always answer */
33#define KB_OTHER 0x03
34
35#define KDSETMODE 0x4B3A /* set text/graphics mode */
36#define KD_TEXT 0x00
37#define KD_GRAPHICS 0x01
38#define KD_TEXT0 0x02 /* obsolete */
39#define KD_TEXT1 0x03 /* obsolete */
40#define KDGETMODE 0x4B3B /* get current mode */
41
42#define K_RAW 0x00
43#define K_XLATE 0x01
44#define K_MEDIUMRAW 0x02
45#define K_UNICODE 0x03
46#define KDGKBMODE 0x4B44 /* gets current keyboard mode */
47#define KDSKBMODE 0x4B45 /* sets current keyboard mode */
48
49#define K_METABIT 0x03
50#define K_ESCPREFIX 0x04
51#define KDGKBMETA 0x4B62 /* gets meta key handling mode */
52#define KDSKBMETA 0x4B63 /* sets meta key handling mode */
53
54#define K_SCROLLLOCK 0x01
55#define K_CAPSLOCK 0x02
56#define K_NUMLOCK 0x04
57#define KDGKBLED 0x4B64 /* get led flags (not lights) */
58#define KDSKBLED 0x4B65 /* set led flags (not lights) */
59
60struct kbentry {
61 unsigned char kb_table;
62 unsigned char kb_index;
63 unsigned short kb_value;
64};
65#define K_NORMTAB 0x00
66#define K_SHIFTTAB 0x01
67#define K_ALTTAB 0x02
68#define K_ALTSHIFTTAB 0x03
69
70#define KDGKBENT 0x4B46 /* gets one entry in translation table */
71#define KDSKBENT 0x4B47 /* sets one entry in translation table */
72
73struct kbsentry {
74 unsigned char kb_func;
75 unsigned char kb_string[512];
76};
77
78struct kbdiacr {
79 unsigned char diacr, base, result;
80};
81struct kbdiacrs {
82 unsigned int kb_cnt; /* number of entries in following array */
83 struct kbdiacr kbdiacr[256]; /* MAX_DIACR from keyboard.h */
84};
85#define KDGKBDIACR 0x4B4A /* read kernel accent table */
86#define KDSKBDIACR 0x4B4B /* write kernel accent table */
87
88struct kbkeycode {
89 unsigned int scancode, keycode;
90};
91#define KDGETKEYCODE 0x4B4C /* read kernel keycode table entry */
92#define KDSETKEYCODE 0x4B4D /* write kernel keycode table entry */
93
94#define KDSIGACCEPT 0x4B4E /* accept kbd generated signals */
95
96#define KDGHWCLK 0x4B50 /* get hardware clock */
97#define KDSHWCLK 0x4B51 /* set hardware clock */
98
99struct kbd_repeat {
100 int delay; /* in msec; <= 0: don't change */
101 int rate; /* in msec; <= 0: don't change */
102};
103
104#define KDKBDREP 0x4B52 /* set keyboard delay/repeat rate;
105 * actually used values are returned */
106
107/* note: 0x4B00-0x4B4E all have had a value at some time;
108 don't reuse for the time being */
109/* note: 0x4B60-0x4B6D, 0x4B70-0x4B72 used above */
110
111#endif /* _LINUX_KD_H */
Definition: kd.h:99
Definition: kd.h:78
Definition: kd.h:81
Definition: kd.h:60
Definition: kd.h:88
Definition: kd.h:73
