RTEMS 5.2
irq-info.h
2
12/*
13 * Copyright (C) 2008, 2009 embedded brains GmbH (http://www.embedded-brains.de)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_SHARED_IRQ_INFO_H
38#define LIBBSP_SHARED_IRQ_INFO_H
39
40#include <rtems/shell.h>
41#include <rtems/print.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
52 const rtems_printer *printer
53);
54
58void bsp_interrupt_report(void);
59
64
67#ifdef __cplusplus
68}
69#endif /* __cplusplus */
70
71#endif /* LIBBSP_SHARED_IRQ_INFO_H */
void bsp_interrupt_report_with_plugin(const rtems_printer *printer)
Prints interrupt information via the printk plugin print with the context context.
Definition: irq-info.c:71
struct rtems_shell_cmd_tt bsp_interrupt_shell_command
Shell command entry for interrupt information.
Definition: irq-shell.c:53
Prints interrupt information via the default printk plugin.
Definition: irq-info.c:105
User print interface to the bspIO print plug in.
Instantatiate a New Terminal Shell.
Definition: printer.h:55
Definition: shell.h:80
