RTEMS 5.2
iodrivers.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_IODRIVERS_H
37#define _RTEMS_CONFDEFS_IODRIVERS_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
45#if defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS) \
46 || defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) \
47 || defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) \
48 || defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) \
49 || defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) \
50 || defined(CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER) \
51 || defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) \
52 || defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) \
53 || defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) \
54 || CONFIGURE_MAXIMUM_DRIVERS > 0
55
56#include <rtems/ioimpl.h>
57#include <rtems/sysinit.h>
58
59#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
60 #if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
61 || defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
62 #error "CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER, CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER, and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive"
63 #endif
64
65 #include <rtems/console.h>
66#endif
67
68#ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
69 #include <rtems/rtc.h>
70#endif
71
72#ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
73 #include <rtems/watchdogdrv.h>
74#endif
75
76#ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
77 #include <rtems/framebuffer.h>
78#endif
79
80#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
81 #include <rtems/devnull.h>
82#endif
83
84#ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
85 #include <rtems/devzero.h>
86#endif
87
88#ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
89 #ifndef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
90 #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
91 #endif
92
93 #include <libchip/ide_ctrl.h>
94#endif
95
96#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
97 #include <libchip/ata.h>
98#endif
99
100#ifndef CONFIGURE_MAXIMUM_DRIVERS
101 #define CONFIGURE_MAXIMUM_DRIVERS
102#endif
103
104#define NULL_DRIVER_TABLE_ENTRY { NULL, NULL, NULL, NULL, NULL, NULL }
105
106#ifdef __cplusplus
107extern "C" {
108#endif
109
111_IO_Driver_address_table[ CONFIGURE_MAXIMUM_DRIVERS ] = {
112 #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
113 CONFIGURE_BSP_PREREQUISITE_DRIVERS,
114 #endif
115 #ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
116 CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
117 #endif
118 #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
120 #endif
121 #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
123 #endif
124 #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
126 #endif
127 #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
128 DEVNULL_DRIVER_TABLE_ENTRY,
129 #endif
130 #ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
131 DEVZERO_DRIVER_TABLE_ENTRY,
132 #endif
133 #ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
134 IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
135 #endif
136 #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
137 ATA_DRIVER_TABLE_ENTRY,
138 #endif
139 #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
141 #endif
142 #ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS
143 CONFIGURE_APPLICATION_EXTRA_DRIVERS,
144 #endif
145 #if defined(CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER) \
146 || ( !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) \
147 && !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) \
148 && !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) \
149 && !defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) \
150 && !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) \
151 && !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) \
152 && !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) \
153 && !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS) )
154 NULL_DRIVER_TABLE_ENTRY
155 #endif
156};
157
158const size_t _IO_Number_of_drivers =
159 RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
160
161RTEMS_SYSINIT_ITEM(
163 RTEMS_SYSINIT_DEVICE_DRIVERS,
164 RTEMS_SYSINIT_ORDER_MIDDLE
165);
166
167#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
168 #ifndef CONFIGURE_ATA_DRIVER_TASK_PRIORITY
169 #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY ATA_DRIVER_TASK_DEFAULT_PRIORITY
170 #endif
171
172 rtems_task_priority rtems_ata_driver_task_priority
173 = CONFIGURE_ATA_DRIVER_TASK_PRIORITY;
174#endif
175
176#ifdef __cplusplus
177}
178#endif
179
180#endif /* CONFIGURE_APPLICATION_EXTRA_DRIVERS
181 || CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
182 || CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
183 || CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
184 || CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
185 || CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
186 || CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
187 || CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
188 || CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
189 || CONFIGURE_MAXIMUM_DRIVERS */
190
191#endif /* CONFIGURE_INIT */
192
193#endif /* _RTEMS_CONFDEFS_IODRIVERS_H */
Console Driver for all Boards.
#define CONSOLE_DRIVER_TABLE_ENTRY
Definition: console.h:38
Real-Time Clock Driver Interface.
RTEMS /dev/null Device Driver.
RTEMS /dev/zero Device Driver.
Frame Buffer Device Driver for all Boards.
#define FRAME_BUFFER_DRIVER_TABLE_ENTRY
Definition: framebuffer.h:45
uint32_t rtems_task_priority
Definition: tasks.h:55
#define RTC_DRIVER_TABLE_ENTRY
Definition: rtc.h:45
Classic Input/Output Manager Implementation API.
void _IO_Initialize_all_drivers(void)
Initialization of all device drivers.
Definition: io.c:26
Definition: io.h:48
#define WATCHDOG_DRIVER_TABLE_ENTRY
Definition: watchdogdrv.h:30
