RTEMS 5.2
Data Structures | Macros | Typedefs
struct  ALT_QSPI_CFG_s
struct  ALT_QSPI_DEVRD_s
struct  ALT_QSPI_DEVWR_s
struct  ALT_QSPI_DELAY_s
struct  ALT_QSPI_RDDATACAP_s
struct  ALT_QSPI_DEVSZ_s
struct  ALT_QSPI_SRAMPART_s
struct  ALT_QSPI_INDADDRTRIG_s
struct  ALT_QSPI_DMAPER_s
struct  ALT_QSPI_REMAPADDR_s
struct  ALT_QSPI_MODBIT_s
struct  ALT_QSPI_SRAMFILL_s
struct  ALT_QSPI_TXTHRESH_s
struct  ALT_QSPI_RXTHRESH_s
struct  ALT_QSPI_IRQSTAT_s
struct  ALT_QSPI_IRQMSK_s
struct  ALT_QSPI_LOWWRPROT_s
struct  ALT_QSPI_UPPWRPROT_s
struct  ALT_QSPI_WRPROT_s
struct  ALT_QSPI_INDRD_s
struct  ALT_QSPI_INDRDWATER_s
struct  ALT_QSPI_INDRDSTADDR_s
struct  ALT_QSPI_INDRDCNT_s
struct  ALT_QSPI_INDWR_s
struct  ALT_QSPI_INDWRWATER_s
struct  ALT_QSPI_INDWRSTADDR_s
struct  ALT_QSPI_INDWRCNT_s
struct  ALT_QSPI_FLSHCMD_s
struct  ALT_QSPI_FLSHCMDADDR_s
struct  ALT_QSPI_FLSHCMDRDDATALO_s
struct  ALT_QSPI_FLSHCMDRDDATAUP_s
struct  ALT_QSPI_FLSHCMDWRDATALO_s
struct  ALT_QSPI_FLSHCMDWRDATAUP_s
struct  ALT_QSPI_MODULEID_s
struct  ALT_QSPI_s
struct  ALT_QSPI_raw_s
#define ALT_QSPI_CFG_EN_E_DIS   0x0
#define ALT_QSPI_CFG_EN_E_EN   0x1
#define ALT_QSPI_CFG_EN_LSB   0
#define ALT_QSPI_CFG_EN_MSB   0
#define ALT_QSPI_CFG_EN_WIDTH   1
#define ALT_QSPI_CFG_EN_SET_MSK   0x00000001
#define ALT_QSPI_CFG_EN_CLR_MSK   0xfffffffe
#define ALT_QSPI_CFG_EN_RESET   0x0
#define ALT_QSPI_CFG_EN_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_QSPI_CFG_EN_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_QSPI_CFG_SELCLKPOL_E_LOW   0x1
#define ALT_QSPI_CFG_SELCLKPOL_E_HIGH   0x0
#define ALT_QSPI_CFG_SELCLKPOL_LSB   1
#define ALT_QSPI_CFG_SELCLKPOL_MSB   1
#define ALT_QSPI_CFG_SELCLKPOL_WIDTH   1
#define ALT_QSPI_CFG_SELCLKPOL_SET_MSK   0x00000002
#define ALT_QSPI_CFG_SELCLKPOL_CLR_MSK   0xfffffffd
#define ALT_QSPI_CFG_SELCLKPOL_RESET   0x0
#define ALT_QSPI_CFG_SELCLKPOL_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_QSPI_CFG_SELCLKPOL_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_QSPI_CFG_SELCLKPHASE_E_ACT   0x0
#define ALT_QSPI_CFG_SELCLKPHASE_E_INACT   0x1
#define ALT_QSPI_CFG_SELCLKPHASE_LSB   2
#define ALT_QSPI_CFG_SELCLKPHASE_MSB   2
#define ALT_QSPI_CFG_SELCLKPHASE_WIDTH   1
#define ALT_QSPI_CFG_SELCLKPHASE_SET_MSK   0x00000004
#define ALT_QSPI_CFG_SELCLKPHASE_CLR_MSK   0xfffffffb
#define ALT_QSPI_CFG_SELCLKPHASE_RESET   0x0
#define ALT_QSPI_CFG_SELCLKPHASE_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_QSPI_CFG_SELCLKPHASE_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_QSPI_CFG_ENDIRACC_E_DIS   0x0
#define ALT_QSPI_CFG_ENDIRACC_E_EN   0x1
#define ALT_QSPI_CFG_ENDIRACC_LSB   7
#define ALT_QSPI_CFG_ENDIRACC_MSB   7
#define ALT_QSPI_CFG_ENDIRACC_WIDTH   1
#define ALT_QSPI_CFG_ENDIRACC_SET_MSK   0x00000080
#define ALT_QSPI_CFG_ENDIRACC_CLR_MSK   0xffffff7f
#define ALT_QSPI_CFG_ENDIRACC_RESET   0x0
#define ALT_QSPI_CFG_ENDIRACC_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_QSPI_CFG_ENDIRACC_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_QSPI_CFG_ENLEGACYIP_E_LEGMOD   0x1
#define ALT_QSPI_CFG_ENLEGACYIP_E_DIMOD   0x0
#define ALT_QSPI_CFG_ENLEGACYIP_LSB   8
#define ALT_QSPI_CFG_ENLEGACYIP_MSB   8
#define ALT_QSPI_CFG_ENLEGACYIP_WIDTH   1
#define ALT_QSPI_CFG_ENLEGACYIP_SET_MSK   0x00000100
#define ALT_QSPI_CFG_ENLEGACYIP_CLR_MSK   0xfffffeff
#define ALT_QSPI_CFG_ENLEGACYIP_RESET   0x0
#define ALT_QSPI_CFG_ENLEGACYIP_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_QSPI_CFG_ENLEGACYIP_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_QSPI_CFG_PERSELDEC_E_SEL4TO16   0x1
#define ALT_QSPI_CFG_PERSELDEC_E_SEL1OF4   0x0
#define ALT_QSPI_CFG_PERSELDEC_LSB   9
#define ALT_QSPI_CFG_PERSELDEC_MSB   9
#define ALT_QSPI_CFG_PERSELDEC_WIDTH   1
#define ALT_QSPI_CFG_PERSELDEC_SET_MSK   0x00000200
#define ALT_QSPI_CFG_PERSELDEC_CLR_MSK   0xfffffdff
#define ALT_QSPI_CFG_PERSELDEC_RESET   0x0
#define ALT_QSPI_CFG_PERSELDEC_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_QSPI_CFG_PERSELDEC_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_QSPI_CFG_PERCSLINES_LSB   10
#define ALT_QSPI_CFG_PERCSLINES_MSB   13
#define ALT_QSPI_CFG_PERCSLINES_WIDTH   4
#define ALT_QSPI_CFG_PERCSLINES_SET_MSK   0x00003c00
#define ALT_QSPI_CFG_PERCSLINES_CLR_MSK   0xffffc3ff
#define ALT_QSPI_CFG_PERCSLINES_RESET   0x0
#define ALT_QSPI_CFG_PERCSLINES_GET(value)   (((value) & 0x00003c00) >> 10)
#define ALT_QSPI_CFG_PERCSLINES_SET(value)   (((value) << 10) & 0x00003c00)
#define ALT_QSPI_CFG_WP_E_WRPROTON   0x1
#define ALT_QSPI_CFG_WP_E_WRTPROTOFF   0x0
#define ALT_QSPI_CFG_WP_LSB   14
#define ALT_QSPI_CFG_WP_MSB   14
#define ALT_QSPI_CFG_WP_WIDTH   1
#define ALT_QSPI_CFG_WP_SET_MSK   0x00004000
#define ALT_QSPI_CFG_WP_CLR_MSK   0xffffbfff
#define ALT_QSPI_CFG_WP_RESET   0x0
#define ALT_QSPI_CFG_WP_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_QSPI_CFG_WP_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_QSPI_CFG_ENDMA_E_EN   0x1
#define ALT_QSPI_CFG_ENDMA_E_DIS   0x0
#define ALT_QSPI_CFG_ENDMA_LSB   15
#define ALT_QSPI_CFG_ENDMA_MSB   15
#define ALT_QSPI_CFG_ENDMA_WIDTH   1
#define ALT_QSPI_CFG_ENDMA_SET_MSK   0x00008000
#define ALT_QSPI_CFG_ENDMA_CLR_MSK   0xffff7fff
#define ALT_QSPI_CFG_ENDMA_RESET   0x0
#define ALT_QSPI_CFG_ENDMA_GET(value)   (((value) & 0x00008000) >> 15)
#define ALT_QSPI_CFG_ENDMA_SET(value)   (((value) << 15) & 0x00008000)
#define ALT_QSPI_CFG_ENAHBREMAP_E_EN   0x1
#define ALT_QSPI_CFG_ENAHBREMAP_E_DIS   0x0
#define ALT_QSPI_CFG_ENAHBREMAP_LSB   16
#define ALT_QSPI_CFG_ENAHBREMAP_MSB   16
#define ALT_QSPI_CFG_ENAHBREMAP_WIDTH   1
#define ALT_QSPI_CFG_ENAHBREMAP_SET_MSK   0x00010000
#define ALT_QSPI_CFG_ENAHBREMAP_CLR_MSK   0xfffeffff
#define ALT_QSPI_CFG_ENAHBREMAP_RESET   0x0
#define ALT_QSPI_CFG_ENAHBREMAP_GET(value)   (((value) & 0x00010000) >> 16)
#define ALT_QSPI_CFG_ENAHBREMAP_SET(value)   (((value) << 16) & 0x00010000)
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_E_EN   0x1
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_E_DIS   0x0
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_LSB   17
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_MSB   17
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_WIDTH   1
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_SET_MSK   0x00020000
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_CLR_MSK   0xfffdffff
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_RESET   0x0
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_GET(value)   (((value) & 0x00020000) >> 17)
#define ALT_QSPI_CFG_ENTERXIPNEXTRD_SET(value)   (((value) << 17) & 0x00020000)
#define ALT_QSPI_CFG_ENTERXIPIMM_E_EN   0x1
#define ALT_QSPI_CFG_ENTERXIPIMM_E_DIS   0x0
#define ALT_QSPI_CFG_ENTERXIPIMM_LSB   18
#define ALT_QSPI_CFG_ENTERXIPIMM_MSB   18
#define ALT_QSPI_CFG_ENTERXIPIMM_WIDTH   1
#define ALT_QSPI_CFG_ENTERXIPIMM_SET_MSK   0x00040000
#define ALT_QSPI_CFG_ENTERXIPIMM_CLR_MSK   0xfffbffff
#define ALT_QSPI_CFG_ENTERXIPIMM_RESET   0x0
#define ALT_QSPI_CFG_ENTERXIPIMM_GET(value)   (((value) & 0x00040000) >> 18)
#define ALT_QSPI_CFG_ENTERXIPIMM_SET(value)   (((value) << 18) & 0x00040000)
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD2   0x0
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD4   0x1
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD6   0x2
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD8   0x3
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD10   0x4
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD12   0x5
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD14   0x6
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD16   0x7
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD18   0x8
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD20   0x9
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD22   0xa
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD24   0xb
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD26   0xc
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD28   0xd
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD30   0xe
#define ALT_QSPI_CFG_BAUDDIV_E_BAUD32   0xf
#define ALT_QSPI_CFG_BAUDDIV_LSB   19
#define ALT_QSPI_CFG_BAUDDIV_MSB   22
#define ALT_QSPI_CFG_BAUDDIV_WIDTH   4
#define ALT_QSPI_CFG_BAUDDIV_SET_MSK   0x00780000
#define ALT_QSPI_CFG_BAUDDIV_CLR_MSK   0xff87ffff
#define ALT_QSPI_CFG_BAUDDIV_RESET   0xf
#define ALT_QSPI_CFG_BAUDDIV_GET(value)   (((value) & 0x00780000) >> 19)
#define ALT_QSPI_CFG_BAUDDIV_SET(value)   (((value) << 19) & 0x00780000)
#define ALT_QSPI_CFG_IDLE_E_SET   0x1
#define ALT_QSPI_CFG_IDLE_E_NOTSET   0x0
#define ALT_QSPI_CFG_IDLE_LSB   31
#define ALT_QSPI_CFG_IDLE_MSB   31
#define ALT_QSPI_CFG_IDLE_WIDTH   1
#define ALT_QSPI_CFG_IDLE_SET_MSK   0x80000000
#define ALT_QSPI_CFG_IDLE_CLR_MSK   0x7fffffff
#define ALT_QSPI_CFG_IDLE_RESET   0x0
#define ALT_QSPI_CFG_IDLE_GET(value)   (((value) & 0x80000000) >> 31)
#define ALT_QSPI_CFG_IDLE_SET(value)   (((value) << 31) & 0x80000000)
#define ALT_QSPI_CFG_OFST   0x0
#define ALT_QSPI_DEVRD_RDOPCODE_E_RD   0x3
#define ALT_QSPI_DEVRD_RDOPCODE_E_FASTRD   0xb
#define ALT_QSPI_DEVRD_RDOPCODE_LSB   0
#define ALT_QSPI_DEVRD_RDOPCODE_MSB   7
#define ALT_QSPI_DEVRD_RDOPCODE_WIDTH   8
#define ALT_QSPI_DEVRD_RDOPCODE_SET_MSK   0x000000ff
#define ALT_QSPI_DEVRD_RDOPCODE_CLR_MSK   0xffffff00
#define ALT_QSPI_DEVRD_RDOPCODE_RESET   0x3
#define ALT_QSPI_DEVRD_RDOPCODE_GET(value)   (((value) & 0x000000ff) >> 0)
#define ALT_QSPI_DEVRD_RDOPCODE_SET(value)   (((value) << 0) & 0x000000ff)
#define ALT_QSPI_DEVRD_INSTWIDTH_E_SINGLE   0x0
#define ALT_QSPI_DEVRD_INSTWIDTH_E_DUAL   0x1
#define ALT_QSPI_DEVRD_INSTWIDTH_E_QUAD   0x2
#define ALT_QSPI_DEVRD_INSTWIDTH_LSB   8
#define ALT_QSPI_DEVRD_INSTWIDTH_MSB   9
#define ALT_QSPI_DEVRD_INSTWIDTH_WIDTH   2
#define ALT_QSPI_DEVRD_INSTWIDTH_SET_MSK   0x00000300
#define ALT_QSPI_DEVRD_INSTWIDTH_CLR_MSK   0xfffffcff
#define ALT_QSPI_DEVRD_INSTWIDTH_RESET   0x0
#define ALT_QSPI_DEVRD_INSTWIDTH_GET(value)   (((value) & 0x00000300) >> 8)
#define ALT_QSPI_DEVRD_INSTWIDTH_SET(value)   (((value) << 8) & 0x00000300)
#define ALT_QSPI_DEVRD_ADDRWIDTH_E_SINGLE   0x0
#define ALT_QSPI_DEVRD_ADDRWIDTH_E_DUAL   0x1
#define ALT_QSPI_DEVRD_ADDRWIDTH_E_QUAD   0x2
#define ALT_QSPI_DEVRD_ADDRWIDTH_LSB   12
#define ALT_QSPI_DEVRD_ADDRWIDTH_MSB   13
#define ALT_QSPI_DEVRD_ADDRWIDTH_WIDTH   2
#define ALT_QSPI_DEVRD_ADDRWIDTH_SET_MSK   0x00003000
#define ALT_QSPI_DEVRD_ADDRWIDTH_CLR_MSK   0xffffcfff
#define ALT_QSPI_DEVRD_ADDRWIDTH_RESET   0x0
#define ALT_QSPI_DEVRD_ADDRWIDTH_GET(value)   (((value) & 0x00003000) >> 12)
#define ALT_QSPI_DEVRD_ADDRWIDTH_SET(value)   (((value) << 12) & 0x00003000)
#define ALT_QSPI_DEVRD_DATAWIDTH_E_SINGLE   0x0
#define ALT_QSPI_DEVRD_DATAWIDTH_E_DUAL   0x1
#define ALT_QSPI_DEVRD_DATAWIDTH_E_QUAD   0x2
#define ALT_QSPI_DEVRD_DATAWIDTH_LSB   16
#define ALT_QSPI_DEVRD_DATAWIDTH_MSB   17
#define ALT_QSPI_DEVRD_DATAWIDTH_WIDTH   2
#define ALT_QSPI_DEVRD_DATAWIDTH_SET_MSK   0x00030000
#define ALT_QSPI_DEVRD_DATAWIDTH_CLR_MSK   0xfffcffff
#define ALT_QSPI_DEVRD_DATAWIDTH_RESET   0x0
#define ALT_QSPI_DEVRD_DATAWIDTH_GET(value)   (((value) & 0x00030000) >> 16)
#define ALT_QSPI_DEVRD_DATAWIDTH_SET(value)   (((value) << 16) & 0x00030000)
#define ALT_QSPI_DEVRD_ENMODBITS_E_NOORDER   0x0
#define ALT_QSPI_DEVRD_ENMODBITS_E_ORDER   0x1
#define ALT_QSPI_DEVRD_ENMODBITS_LSB   20
#define ALT_QSPI_DEVRD_ENMODBITS_MSB   20
#define ALT_QSPI_DEVRD_ENMODBITS_WIDTH   1
#define ALT_QSPI_DEVRD_ENMODBITS_SET_MSK   0x00100000
#define ALT_QSPI_DEVRD_ENMODBITS_CLR_MSK   0xffefffff
#define ALT_QSPI_DEVRD_ENMODBITS_RESET   0x0
#define ALT_QSPI_DEVRD_ENMODBITS_GET(value)   (((value) & 0x00100000) >> 20)
#define ALT_QSPI_DEVRD_ENMODBITS_SET(value)   (((value) << 20) & 0x00100000)
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_LSB   24
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_MSB   28
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_WIDTH   5
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_SET_MSK   0x1f000000
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_CLR_MSK   0xe0ffffff
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_RESET   0x0
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_GET(value)   (((value) & 0x1f000000) >> 24)
#define ALT_QSPI_DEVRD_DUMMYRDCLKS_SET(value)   (((value) << 24) & 0x1f000000)
#define ALT_QSPI_DEVRD_OFST   0x4
#define ALT_QSPI_DEVWR_WROPCODE_LSB   0
#define ALT_QSPI_DEVWR_WROPCODE_MSB   7
#define ALT_QSPI_DEVWR_WROPCODE_WIDTH   8
#define ALT_QSPI_DEVWR_WROPCODE_SET_MSK   0x000000ff
#define ALT_QSPI_DEVWR_WROPCODE_CLR_MSK   0xffffff00
#define ALT_QSPI_DEVWR_WROPCODE_RESET   0x2
#define ALT_QSPI_DEVWR_WROPCODE_GET(value)   (((value) & 0x000000ff) >> 0)
#define ALT_QSPI_DEVWR_WROPCODE_SET(value)   (((value) << 0) & 0x000000ff)
#define ALT_QSPI_DEVWR_ADDRWIDTH_E_SINGLE   0x0
#define ALT_QSPI_DEVWR_ADDRWIDTH_E_DUAL   0x1
#define ALT_QSPI_DEVWR_ADDRWIDTH_E_QUAD   0x2
#define ALT_QSPI_DEVWR_ADDRWIDTH_LSB   12
#define ALT_QSPI_DEVWR_ADDRWIDTH_MSB   13
#define ALT_QSPI_DEVWR_ADDRWIDTH_WIDTH   2
#define ALT_QSPI_DEVWR_ADDRWIDTH_SET_MSK   0x00003000
#define ALT_QSPI_DEVWR_ADDRWIDTH_CLR_MSK   0xffffcfff
#define ALT_QSPI_DEVWR_ADDRWIDTH_RESET   0x0
#define ALT_QSPI_DEVWR_ADDRWIDTH_GET(value)   (((value) & 0x00003000) >> 12)
#define ALT_QSPI_DEVWR_ADDRWIDTH_SET(value)   (((value) << 12) & 0x00003000)
#define ALT_QSPI_DEVWR_DATAWIDTH_E_SINGLE   0x0
#define ALT_QSPI_DEVWR_DATAWIDTH_E_DUAL   0x1
#define ALT_QSPI_DEVWR_DATAWIDTH_E_QUAD   0x2
#define ALT_QSPI_DEVWR_DATAWIDTH_LSB   16
#define ALT_QSPI_DEVWR_DATAWIDTH_MSB   17
#define ALT_QSPI_DEVWR_DATAWIDTH_WIDTH   2
#define ALT_QSPI_DEVWR_DATAWIDTH_SET_MSK   0x00030000
#define ALT_QSPI_DEVWR_DATAWIDTH_CLR_MSK   0xfffcffff
#define ALT_QSPI_DEVWR_DATAWIDTH_RESET   0x0
#define ALT_QSPI_DEVWR_DATAWIDTH_GET(value)   (((value) & 0x00030000) >> 16)
#define ALT_QSPI_DEVWR_DATAWIDTH_SET(value)   (((value) << 16) & 0x00030000)
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_LSB   24
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_MSB   28
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_WIDTH   5
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_SET_MSK   0x1f000000
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_CLR_MSK   0xe0ffffff
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_RESET   0x0
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_GET(value)   (((value) & 0x1f000000) >> 24)
#define ALT_QSPI_DEVWR_DUMMYWRCLKS_SET(value)   (((value) << 24) & 0x1f000000)
#define ALT_QSPI_DEVWR_OFST   0x8
#define ALT_QSPI_DELAY_INIT_LSB   0
#define ALT_QSPI_DELAY_INIT_MSB   7
#define ALT_QSPI_DELAY_INIT_WIDTH   8
#define ALT_QSPI_DELAY_INIT_SET_MSK   0x000000ff
#define ALT_QSPI_DELAY_INIT_CLR_MSK   0xffffff00
#define ALT_QSPI_DELAY_INIT_RESET   0x0
#define ALT_QSPI_DELAY_INIT_GET(value)   (((value) & 0x000000ff) >> 0)
#define ALT_QSPI_DELAY_INIT_SET(value)   (((value) << 0) & 0x000000ff)
#define ALT_QSPI_DELAY_AFTER_LSB   8
#define ALT_QSPI_DELAY_AFTER_MSB   15
#define ALT_QSPI_DELAY_AFTER_WIDTH   8
#define ALT_QSPI_DELAY_AFTER_SET_MSK   0x0000ff00
#define ALT_QSPI_DELAY_AFTER_CLR_MSK   0xffff00ff
#define ALT_QSPI_DELAY_AFTER_RESET   0x0
#define ALT_QSPI_DELAY_AFTER_GET(value)   (((value) & 0x0000ff00) >> 8)
#define ALT_QSPI_DELAY_AFTER_SET(value)   (((value) << 8) & 0x0000ff00)
#define ALT_QSPI_DELAY_BTWN_LSB   16
#define ALT_QSPI_DELAY_BTWN_MSB   23
#define ALT_QSPI_DELAY_BTWN_WIDTH   8
#define ALT_QSPI_DELAY_BTWN_SET_MSK   0x00ff0000
#define ALT_QSPI_DELAY_BTWN_CLR_MSK   0xff00ffff
#define ALT_QSPI_DELAY_BTWN_RESET   0x0
#define ALT_QSPI_DELAY_BTWN_GET(value)   (((value) & 0x00ff0000) >> 16)
#define ALT_QSPI_DELAY_BTWN_SET(value)   (((value) << 16) & 0x00ff0000)
#define ALT_QSPI_DELAY_NSS_LSB   24
#define ALT_QSPI_DELAY_NSS_MSB   31
#define ALT_QSPI_DELAY_NSS_WIDTH   8
#define ALT_QSPI_DELAY_NSS_SET_MSK   0xff000000
#define ALT_QSPI_DELAY_NSS_CLR_MSK   0x00ffffff
#define ALT_QSPI_DELAY_NSS_RESET   0x0
#define ALT_QSPI_DELAY_NSS_GET(value)   (((value) & 0xff000000) >> 24)
#define ALT_QSPI_DELAY_NSS_SET(value)   (((value) << 24) & 0xff000000)
#define ALT_QSPI_DELAY_OFST   0xc
#define ALT_QSPI_RDDATACAP_BYP_E_NOBYPASS   0x0
#define ALT_QSPI_RDDATACAP_BYP_E_BYPASS   0x1
#define ALT_QSPI_RDDATACAP_BYP_LSB   0
#define ALT_QSPI_RDDATACAP_BYP_MSB   0
#define ALT_QSPI_RDDATACAP_BYP_WIDTH   1
#define ALT_QSPI_RDDATACAP_BYP_SET_MSK   0x00000001
#define ALT_QSPI_RDDATACAP_BYP_CLR_MSK   0xfffffffe
#define ALT_QSPI_RDDATACAP_BYP_RESET   0x1
#define ALT_QSPI_RDDATACAP_BYP_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_QSPI_RDDATACAP_BYP_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_QSPI_RDDATACAP_DELAY_LSB   1
#define ALT_QSPI_RDDATACAP_DELAY_MSB   4
#define ALT_QSPI_RDDATACAP_DELAY_WIDTH   4
#define ALT_QSPI_RDDATACAP_DELAY_SET_MSK   0x0000001e
#define ALT_QSPI_RDDATACAP_DELAY_CLR_MSK   0xffffffe1
#define ALT_QSPI_RDDATACAP_DELAY_RESET   0x0
#define ALT_QSPI_RDDATACAP_DELAY_GET(value)   (((value) & 0x0000001e) >> 1)
#define ALT_QSPI_RDDATACAP_DELAY_SET(value)   (((value) << 1) & 0x0000001e)
#define ALT_QSPI_RDDATACAP_OFST   0x10
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_LSB   0
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_MSB   3
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_WIDTH   4
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_SET_MSK   0x0000000f
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_CLR_MSK   0xfffffff0
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_RESET   0x2
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_GET(value)   (((value) & 0x0000000f) >> 0)
#define ALT_QSPI_DEVSZ_NUMADDRBYTES_SET(value)   (((value) << 0) & 0x0000000f)
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_LSB   4
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_MSB   15
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_WIDTH   12
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_SET_MSK   0x0000fff0
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_CLR_MSK   0xffff000f
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_RESET   0x100
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_GET(value)   (((value) & 0x0000fff0) >> 4)
#define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_SET(value)   (((value) << 4) & 0x0000fff0)
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_LSB   16
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_MSB   20
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_WIDTH   5
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_SET_MSK   0x001f0000
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_CLR_MSK   0xffe0ffff
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_RESET   0x10
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_GET(value)   (((value) & 0x001f0000) >> 16)
#define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_SET(value)   (((value) << 16) & 0x001f0000)
#define ALT_QSPI_DEVSZ_OFST   0x14
#define ALT_QSPI_SRAMPART_ADDR_LSB   0
#define ALT_QSPI_SRAMPART_ADDR_MSB   6
#define ALT_QSPI_SRAMPART_ADDR_WIDTH   7
#define ALT_QSPI_SRAMPART_ADDR_SET_MSK   0x0000007f
#define ALT_QSPI_SRAMPART_ADDR_CLR_MSK   0xffffff80
#define ALT_QSPI_SRAMPART_ADDR_RESET   0x40
#define ALT_QSPI_SRAMPART_ADDR_GET(value)   (((value) & 0x0000007f) >> 0)
#define ALT_QSPI_SRAMPART_ADDR_SET(value)   (((value) << 0) & 0x0000007f)
#define ALT_QSPI_SRAMPART_OFST   0x18
#define ALT_QSPI_INDADDRTRIG_ADDR_LSB   0
#define ALT_QSPI_INDADDRTRIG_ADDR_MSB   31
#define ALT_QSPI_INDADDRTRIG_ADDR_WIDTH   32
#define ALT_QSPI_INDADDRTRIG_ADDR_SET_MSK   0xffffffff
#define ALT_QSPI_INDADDRTRIG_ADDR_CLR_MSK   0x00000000
#define ALT_QSPI_INDADDRTRIG_ADDR_RESET   0x0
#define ALT_QSPI_INDADDRTRIG_ADDR_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_INDADDRTRIG_ADDR_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_INDADDRTRIG_OFST   0x1c
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_LSB   0
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_MSB   3
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_WIDTH   4
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_SET_MSK   0x0000000f
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_CLR_MSK   0xfffffff0
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_RESET   0x0
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_GET(value)   (((value) & 0x0000000f) >> 0)
#define ALT_QSPI_DMAPER_NUMSGLREQBYTES_SET(value)   (((value) << 0) & 0x0000000f)
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_LSB   8
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_MSB   11
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_WIDTH   4
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_SET_MSK   0x00000f00
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_CLR_MSK   0xfffff0ff
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_RESET   0x0
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_GET(value)   (((value) & 0x00000f00) >> 8)
#define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_SET(value)   (((value) << 8) & 0x00000f00)
#define ALT_QSPI_DMAPER_OFST   0x20
#define ALT_QSPI_REMAPADDR_VALUE_LSB   0
#define ALT_QSPI_REMAPADDR_VALUE_MSB   31
#define ALT_QSPI_REMAPADDR_VALUE_WIDTH   32
#define ALT_QSPI_REMAPADDR_VALUE_SET_MSK   0xffffffff
#define ALT_QSPI_REMAPADDR_VALUE_CLR_MSK   0x00000000
#define ALT_QSPI_REMAPADDR_VALUE_RESET   0x0
#define ALT_QSPI_REMAPADDR_VALUE_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_REMAPADDR_VALUE_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_REMAPADDR_OFST   0x24
#define ALT_QSPI_MODBIT_MOD_LSB   0
#define ALT_QSPI_MODBIT_MOD_MSB   7
#define ALT_QSPI_MODBIT_MOD_WIDTH   8
#define ALT_QSPI_MODBIT_MOD_SET_MSK   0x000000ff
#define ALT_QSPI_MODBIT_MOD_CLR_MSK   0xffffff00
#define ALT_QSPI_MODBIT_MOD_RESET   0x0
#define ALT_QSPI_MODBIT_MOD_GET(value)   (((value) & 0x000000ff) >> 0)
#define ALT_QSPI_MODBIT_MOD_SET(value)   (((value) << 0) & 0x000000ff)
#define ALT_QSPI_MODBIT_OFST   0x28
#define ALT_QSPI_SRAMFILL_INDRDPART_LSB   0
#define ALT_QSPI_SRAMFILL_INDRDPART_MSB   15
#define ALT_QSPI_SRAMFILL_INDRDPART_WIDTH   16
#define ALT_QSPI_SRAMFILL_INDRDPART_SET_MSK   0x0000ffff
#define ALT_QSPI_SRAMFILL_INDRDPART_CLR_MSK   0xffff0000
#define ALT_QSPI_SRAMFILL_INDRDPART_RESET   0x0
#define ALT_QSPI_SRAMFILL_INDRDPART_GET(value)   (((value) & 0x0000ffff) >> 0)
#define ALT_QSPI_SRAMFILL_INDRDPART_SET(value)   (((value) << 0) & 0x0000ffff)
#define ALT_QSPI_SRAMFILL_INDWRPART_LSB   16
#define ALT_QSPI_SRAMFILL_INDWRPART_MSB   31
#define ALT_QSPI_SRAMFILL_INDWRPART_WIDTH   16
#define ALT_QSPI_SRAMFILL_INDWRPART_SET_MSK   0xffff0000
#define ALT_QSPI_SRAMFILL_INDWRPART_CLR_MSK   0x0000ffff
#define ALT_QSPI_SRAMFILL_INDWRPART_RESET   0x0
#define ALT_QSPI_SRAMFILL_INDWRPART_GET(value)   (((value) & 0xffff0000) >> 16)
#define ALT_QSPI_SRAMFILL_INDWRPART_SET(value)   (((value) << 16) & 0xffff0000)
#define ALT_QSPI_SRAMFILL_OFST   0x2c
#define ALT_QSPI_TXTHRESH_LEVEL_LSB   0
#define ALT_QSPI_TXTHRESH_LEVEL_MSB   3
#define ALT_QSPI_TXTHRESH_LEVEL_WIDTH   4
#define ALT_QSPI_TXTHRESH_LEVEL_SET_MSK   0x0000000f
#define ALT_QSPI_TXTHRESH_LEVEL_CLR_MSK   0xfffffff0
#define ALT_QSPI_TXTHRESH_LEVEL_RESET   0x1
#define ALT_QSPI_TXTHRESH_LEVEL_GET(value)   (((value) & 0x0000000f) >> 0)
#define ALT_QSPI_TXTHRESH_LEVEL_SET(value)   (((value) << 0) & 0x0000000f)
#define ALT_QSPI_TXTHRESH_OFST   0x30
#define ALT_QSPI_RXTHRESH_LEVEL_LSB   0
#define ALT_QSPI_RXTHRESH_LEVEL_MSB   3
#define ALT_QSPI_RXTHRESH_LEVEL_WIDTH   4
#define ALT_QSPI_RXTHRESH_LEVEL_SET_MSK   0x0000000f
#define ALT_QSPI_RXTHRESH_LEVEL_CLR_MSK   0xfffffff0
#define ALT_QSPI_RXTHRESH_LEVEL_RESET   0x1
#define ALT_QSPI_RXTHRESH_LEVEL_GET(value)   (((value) & 0x0000000f) >> 0)
#define ALT_QSPI_RXTHRESH_LEVEL_SET(value)   (((value) << 0) & 0x0000000f)
#define ALT_QSPI_RXTHRESH_OFST   0x34
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_E_UNDERFLOW   0x1
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_E_NOUNDERFLOW   0x0
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_LSB   1
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_MSB   1
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_WIDTH   1
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_SET_MSK   0x00000002
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_CLR_MSK   0xfffffffd
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_RESET   0x0
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_QSPI_IRQSTAT_UNDERFLOWDET_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_QSPI_IRQSTAT_INDOPDONE_E_INDIRECTOP   0x1
#define ALT_QSPI_IRQSTAT_INDOPDONE_E_NOINDIRECTOP   0x0
#define ALT_QSPI_IRQSTAT_INDOPDONE_LSB   2
#define ALT_QSPI_IRQSTAT_INDOPDONE_MSB   2
#define ALT_QSPI_IRQSTAT_INDOPDONE_WIDTH   1
#define ALT_QSPI_IRQSTAT_INDOPDONE_SET_MSK   0x00000004
#define ALT_QSPI_IRQSTAT_INDOPDONE_CLR_MSK   0xfffffffb
#define ALT_QSPI_IRQSTAT_INDOPDONE_RESET   0x0
#define ALT_QSPI_IRQSTAT_INDOPDONE_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_QSPI_IRQSTAT_INDOPDONE_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_QSPI_IRQSTAT_INDRDREJECT_E_INDIRECTREQ   0x1
#define ALT_QSPI_IRQSTAT_INDRDREJECT_E_NOINDIRECTREQ   0x0
#define ALT_QSPI_IRQSTAT_INDRDREJECT_LSB   3
#define ALT_QSPI_IRQSTAT_INDRDREJECT_MSB   3
#define ALT_QSPI_IRQSTAT_INDRDREJECT_WIDTH   1
#define ALT_QSPI_IRQSTAT_INDRDREJECT_SET_MSK   0x00000008
#define ALT_QSPI_IRQSTAT_INDRDREJECT_CLR_MSK   0xfffffff7
#define ALT_QSPI_IRQSTAT_INDRDREJECT_RESET   0x0
#define ALT_QSPI_IRQSTAT_INDRDREJECT_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_QSPI_IRQSTAT_INDRDREJECT_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_E_WRPROT   0x1
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_E_NOWRPROT   0x0
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_LSB   4
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_MSB   4
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_WIDTH   1
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_SET_MSK   0x00000010
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_CLR_MSK   0xffffffef
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_RESET   0x0
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_QSPI_IRQSTAT_ILLEGALACC_E_ILLEGALAHB   0x1
#define ALT_QSPI_IRQSTAT_ILLEGALACC_E_NOILLEGALAHB   0x0
#define ALT_QSPI_IRQSTAT_ILLEGALACC_LSB   5
#define ALT_QSPI_IRQSTAT_ILLEGALACC_MSB   5
#define ALT_QSPI_IRQSTAT_ILLEGALACC_WIDTH   1
#define ALT_QSPI_IRQSTAT_ILLEGALACC_SET_MSK   0x00000020
#define ALT_QSPI_IRQSTAT_ILLEGALACC_CLR_MSK   0xffffffdf
#define ALT_QSPI_IRQSTAT_ILLEGALACC_RESET   0x0
#define ALT_QSPI_IRQSTAT_ILLEGALACC_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_QSPI_IRQSTAT_ILLEGALACC_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_QSPI_IRQSTAT_INDXFRLVL_E_WATERLEVL   0x1
#define ALT_QSPI_IRQSTAT_INDXFRLVL_E_NOWATERLVL   0x0
#define ALT_QSPI_IRQSTAT_INDXFRLVL_LSB   6
#define ALT_QSPI_IRQSTAT_INDXFRLVL_MSB   6
#define ALT_QSPI_IRQSTAT_INDXFRLVL_WIDTH   1
#define ALT_QSPI_IRQSTAT_INDXFRLVL_SET_MSK   0x00000040
#define ALT_QSPI_IRQSTAT_INDXFRLVL_CLR_MSK   0xffffffbf
#define ALT_QSPI_IRQSTAT_INDXFRLVL_RESET   0x0
#define ALT_QSPI_IRQSTAT_INDXFRLVL_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_QSPI_IRQSTAT_INDXFRLVL_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_QSPI_IRQSTAT_RXOVER_E_RCVOVER   0x1
#define ALT_QSPI_IRQSTAT_RXOVER_E_NORCVOVER   0x0
#define ALT_QSPI_IRQSTAT_RXOVER_LSB   7
#define ALT_QSPI_IRQSTAT_RXOVER_MSB   7
#define ALT_QSPI_IRQSTAT_RXOVER_WIDTH   1
#define ALT_QSPI_IRQSTAT_RXOVER_SET_MSK   0x00000080
#define ALT_QSPI_IRQSTAT_RXOVER_CLR_MSK   0xffffff7f
#define ALT_QSPI_IRQSTAT_RXOVER_RESET   0x0
#define ALT_QSPI_IRQSTAT_RXOVER_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_QSPI_IRQSTAT_RXOVER_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_E_GT   0x0
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_E_LE   0x1
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_LSB   8
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_MSB   8
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_WIDTH   1
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_SET_MSK   0x00000100
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_CLR_MSK   0xfffffeff
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_RESET   0x1
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_QSPI_IRQSTAT_TXTHRESHCMP_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_QSPI_IRQSTAT_TXFULL_E_NOTFULL   0x0
#define ALT_QSPI_IRQSTAT_TXFULL_E_FULL   0x1
#define ALT_QSPI_IRQSTAT_TXFULL_LSB   9
#define ALT_QSPI_IRQSTAT_TXFULL_MSB   9
#define ALT_QSPI_IRQSTAT_TXFULL_WIDTH   1
#define ALT_QSPI_IRQSTAT_TXFULL_SET_MSK   0x00000200
#define ALT_QSPI_IRQSTAT_TXFULL_CLR_MSK   0xfffffdff
#define ALT_QSPI_IRQSTAT_TXFULL_RESET   0x0
#define ALT_QSPI_IRQSTAT_TXFULL_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_QSPI_IRQSTAT_TXFULL_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_E_LE   0x0
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_E_GT   0x1
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_LSB   10
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_MSB   10
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_WIDTH   1
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_SET_MSK   0x00000400
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_CLR_MSK   0xfffffbff
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_RESET   0x0
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_GET(value)   (((value) & 0x00000400) >> 10)
#define ALT_QSPI_IRQSTAT_RXTHRESHCMP_SET(value)   (((value) << 10) & 0x00000400)
#define ALT_QSPI_IRQSTAT_RXFULL_E_NOTFULL   0x0
#define ALT_QSPI_IRQSTAT_RXFULL_E_FULL   0x1
#define ALT_QSPI_IRQSTAT_RXFULL_LSB   11
#define ALT_QSPI_IRQSTAT_RXFULL_MSB   11
#define ALT_QSPI_IRQSTAT_RXFULL_WIDTH   1
#define ALT_QSPI_IRQSTAT_RXFULL_SET_MSK   0x00000800
#define ALT_QSPI_IRQSTAT_RXFULL_CLR_MSK   0xfffff7ff
#define ALT_QSPI_IRQSTAT_RXFULL_RESET   0x0
#define ALT_QSPI_IRQSTAT_RXFULL_GET(value)   (((value) & 0x00000800) >> 11)
#define ALT_QSPI_IRQSTAT_RXFULL_SET(value)   (((value) << 11) & 0x00000800)
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_E_RDPARTFULL   0x1
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_E_RDPARTNOTFULL   0x0
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_LSB   12
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_MSB   12
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_WIDTH   1
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_SET_MSK   0x00001000
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_CLR_MSK   0xffffefff
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_RESET   0x0
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_GET(value)   (((value) & 0x00001000) >> 12)
#define ALT_QSPI_IRQSTAT_INDSRAMFULL_SET(value)   (((value) << 12) & 0x00001000)
#define ALT_QSPI_IRQSTAT_OFST   0x40
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_E_DISD   0x0
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_E_END   0x1
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_LSB   1
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_MSB   1
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_WIDTH   1
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_SET_MSK   0x00000002
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_CLR_MSK   0xfffffffd
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_RESET   0x0
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_QSPI_IRQMSK_UNDERFLOWDET_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_QSPI_IRQMSK_INDOPDONE_E_DISD   0x0
#define ALT_QSPI_IRQMSK_INDOPDONE_E_END   0x1
#define ALT_QSPI_IRQMSK_INDOPDONE_LSB   2
#define ALT_QSPI_IRQMSK_INDOPDONE_MSB   2
#define ALT_QSPI_IRQMSK_INDOPDONE_WIDTH   1
#define ALT_QSPI_IRQMSK_INDOPDONE_SET_MSK   0x00000004
#define ALT_QSPI_IRQMSK_INDOPDONE_CLR_MSK   0xfffffffb
#define ALT_QSPI_IRQMSK_INDOPDONE_RESET   0x0
#define ALT_QSPI_IRQMSK_INDOPDONE_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_QSPI_IRQMSK_INDOPDONE_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_QSPI_IRQMSK_INDRDREJECT_E_DISD   0x0
#define ALT_QSPI_IRQMSK_INDRDREJECT_E_END   0x1
#define ALT_QSPI_IRQMSK_INDRDREJECT_LSB   3
#define ALT_QSPI_IRQMSK_INDRDREJECT_MSB   3
#define ALT_QSPI_IRQMSK_INDRDREJECT_WIDTH   1
#define ALT_QSPI_IRQMSK_INDRDREJECT_SET_MSK   0x00000008
#define ALT_QSPI_IRQMSK_INDRDREJECT_CLR_MSK   0xfffffff7
#define ALT_QSPI_IRQMSK_INDRDREJECT_RESET   0x0
#define ALT_QSPI_IRQMSK_INDRDREJECT_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_QSPI_IRQMSK_INDRDREJECT_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_E_DISD   0x0
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_E_END   0x1
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_LSB   4
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_MSB   4
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_WIDTH   1
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_SET_MSK   0x00000010
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_CLR_MSK   0xffffffef
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_RESET   0x0
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_QSPI_IRQMSK_PROTWRATTEMPT_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_QSPI_IRQMSK_ILLEGALACC_E_DISD   0x0
#define ALT_QSPI_IRQMSK_ILLEGALACC_E_END   0x1
#define ALT_QSPI_IRQMSK_ILLEGALACC_LSB   5
#define ALT_QSPI_IRQMSK_ILLEGALACC_MSB   5
#define ALT_QSPI_IRQMSK_ILLEGALACC_WIDTH   1
#define ALT_QSPI_IRQMSK_ILLEGALACC_SET_MSK   0x00000020
#define ALT_QSPI_IRQMSK_ILLEGALACC_CLR_MSK   0xffffffdf
#define ALT_QSPI_IRQMSK_ILLEGALACC_RESET   0x0
#define ALT_QSPI_IRQMSK_ILLEGALACC_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_QSPI_IRQMSK_ILLEGALACC_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_QSPI_IRQMSK_INDXFRLVL_E_DISD   0x0
#define ALT_QSPI_IRQMSK_INDXFRLVL_E_END   0x1
#define ALT_QSPI_IRQMSK_INDXFRLVL_LSB   6
#define ALT_QSPI_IRQMSK_INDXFRLVL_MSB   6
#define ALT_QSPI_IRQMSK_INDXFRLVL_WIDTH   1
#define ALT_QSPI_IRQMSK_INDXFRLVL_SET_MSK   0x00000040
#define ALT_QSPI_IRQMSK_INDXFRLVL_CLR_MSK   0xffffffbf
#define ALT_QSPI_IRQMSK_INDXFRLVL_RESET   0x0
#define ALT_QSPI_IRQMSK_INDXFRLVL_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_QSPI_IRQMSK_INDXFRLVL_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_QSPI_IRQMSK_RXOVER_E_DISD   0x0
#define ALT_QSPI_IRQMSK_RXOVER_E_END   0x1
#define ALT_QSPI_IRQMSK_RXOVER_LSB   7
#define ALT_QSPI_IRQMSK_RXOVER_MSB   7
#define ALT_QSPI_IRQMSK_RXOVER_WIDTH   1
#define ALT_QSPI_IRQMSK_RXOVER_SET_MSK   0x00000080
#define ALT_QSPI_IRQMSK_RXOVER_CLR_MSK   0xffffff7f
#define ALT_QSPI_IRQMSK_RXOVER_RESET   0x0
#define ALT_QSPI_IRQMSK_RXOVER_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_QSPI_IRQMSK_RXOVER_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_E_DISD   0x0
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_E_END   0x1
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_LSB   8
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_MSB   8
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_WIDTH   1
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_SET_MSK   0x00000100
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_CLR_MSK   0xfffffeff
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_RESET   0x0
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_QSPI_IRQMSK_TXTHRESHCMP_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_QSPI_IRQMSK_TXFULL_E_DISD   0x0
#define ALT_QSPI_IRQMSK_TXFULL_E_END   0x1
#define ALT_QSPI_IRQMSK_TXFULL_LSB   9
#define ALT_QSPI_IRQMSK_TXFULL_MSB   9
#define ALT_QSPI_IRQMSK_TXFULL_WIDTH   1
#define ALT_QSPI_IRQMSK_TXFULL_SET_MSK   0x00000200
#define ALT_QSPI_IRQMSK_TXFULL_CLR_MSK   0xfffffdff
#define ALT_QSPI_IRQMSK_TXFULL_RESET   0x0
#define ALT_QSPI_IRQMSK_TXFULL_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_QSPI_IRQMSK_TXFULL_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_E_DISD   0x0
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_E_END   0x1
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_LSB   10
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_MSB   10
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_WIDTH   1
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_SET_MSK   0x00000400
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_CLR_MSK   0xfffffbff
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_RESET   0x0
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_GET(value)   (((value) & 0x00000400) >> 10)
#define ALT_QSPI_IRQMSK_RXTHRESHCMP_SET(value)   (((value) << 10) & 0x00000400)
#define ALT_QSPI_IRQMSK_RXFULL_E_DISD   0x0
#define ALT_QSPI_IRQMSK_RXFULL_E_END   0x1
#define ALT_QSPI_IRQMSK_RXFULL_LSB   11
#define ALT_QSPI_IRQMSK_RXFULL_MSB   11
#define ALT_QSPI_IRQMSK_RXFULL_WIDTH   1
#define ALT_QSPI_IRQMSK_RXFULL_SET_MSK   0x00000800
#define ALT_QSPI_IRQMSK_RXFULL_CLR_MSK   0xfffff7ff
#define ALT_QSPI_IRQMSK_RXFULL_RESET   0x0
#define ALT_QSPI_IRQMSK_RXFULL_GET(value)   (((value) & 0x00000800) >> 11)
#define ALT_QSPI_IRQMSK_RXFULL_SET(value)   (((value) << 11) & 0x00000800)
#define ALT_QSPI_IRQMSK_INDSRAMFULL_E_DISD   0x0
#define ALT_QSPI_IRQMSK_INDSRAMFULL_E_END   0x1
#define ALT_QSPI_IRQMSK_INDSRAMFULL_LSB   12
#define ALT_QSPI_IRQMSK_INDSRAMFULL_MSB   12
#define ALT_QSPI_IRQMSK_INDSRAMFULL_WIDTH   1
#define ALT_QSPI_IRQMSK_INDSRAMFULL_SET_MSK   0x00001000
#define ALT_QSPI_IRQMSK_INDSRAMFULL_CLR_MSK   0xffffefff
#define ALT_QSPI_IRQMSK_INDSRAMFULL_RESET   0x0
#define ALT_QSPI_IRQMSK_INDSRAMFULL_GET(value)   (((value) & 0x00001000) >> 12)
#define ALT_QSPI_IRQMSK_INDSRAMFULL_SET(value)   (((value) << 12) & 0x00001000)
#define ALT_QSPI_IRQMSK_OFST   0x44
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_LSB   0
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_MSB   31
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_WIDTH   32
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_SET_MSK   0xffffffff
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_CLR_MSK   0x00000000
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_RESET   0x0
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_LOWWRPROT_SUBSECTOR_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_LOWWRPROT_OFST   0x50
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_LSB   0
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_MSB   31
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_WIDTH   32
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_SET_MSK   0xffffffff
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_CLR_MSK   0x00000000
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_RESET   0x0
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_UPPWRPROT_SUBSECTOR_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_UPPWRPROT_OFST   0x54
#define ALT_QSPI_WRPROT_INV_E_EN   0x1
#define ALT_QSPI_WRPROT_INV_E_DIS   0x0
#define ALT_QSPI_WRPROT_INV_LSB   0
#define ALT_QSPI_WRPROT_INV_MSB   0
#define ALT_QSPI_WRPROT_INV_WIDTH   1
#define ALT_QSPI_WRPROT_INV_SET_MSK   0x00000001
#define ALT_QSPI_WRPROT_INV_CLR_MSK   0xfffffffe
#define ALT_QSPI_WRPROT_INV_RESET   0x0
#define ALT_QSPI_WRPROT_INV_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_QSPI_WRPROT_INV_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_QSPI_WRPROT_EN_E_EN   0x1
#define ALT_QSPI_WRPROT_EN_E_DIS   0x0
#define ALT_QSPI_WRPROT_EN_LSB   1
#define ALT_QSPI_WRPROT_EN_MSB   1
#define ALT_QSPI_WRPROT_EN_WIDTH   1
#define ALT_QSPI_WRPROT_EN_SET_MSK   0x00000002
#define ALT_QSPI_WRPROT_EN_CLR_MSK   0xfffffffd
#define ALT_QSPI_WRPROT_EN_RESET   0x0
#define ALT_QSPI_WRPROT_EN_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_QSPI_WRPROT_EN_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_QSPI_WRPROT_OFST   0x58
#define ALT_QSPI_INDRD_START_E_END   0x1
#define ALT_QSPI_INDRD_START_E_DISD   0x0
#define ALT_QSPI_INDRD_START_LSB   0
#define ALT_QSPI_INDRD_START_MSB   0
#define ALT_QSPI_INDRD_START_WIDTH   1
#define ALT_QSPI_INDRD_START_SET_MSK   0x00000001
#define ALT_QSPI_INDRD_START_CLR_MSK   0xfffffffe
#define ALT_QSPI_INDRD_START_RESET   0x0
#define ALT_QSPI_INDRD_START_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_QSPI_INDRD_START_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_QSPI_INDRD_CANCEL_E_CANCEL   0x1
#define ALT_QSPI_INDRD_CANCEL_E_NOACTION   0x0
#define ALT_QSPI_INDRD_CANCEL_LSB   1
#define ALT_QSPI_INDRD_CANCEL_MSB   1
#define ALT_QSPI_INDRD_CANCEL_WIDTH   1
#define ALT_QSPI_INDRD_CANCEL_SET_MSK   0x00000002
#define ALT_QSPI_INDRD_CANCEL_CLR_MSK   0xfffffffd
#define ALT_QSPI_INDRD_CANCEL_RESET   0x0
#define ALT_QSPI_INDRD_CANCEL_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_QSPI_INDRD_CANCEL_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_QSPI_INDRD_RD_STAT_E_RDOP   0x1
#define ALT_QSPI_INDRD_RD_STAT_E_NOACTION   0x0
#define ALT_QSPI_INDRD_RD_STAT_LSB   2
#define ALT_QSPI_INDRD_RD_STAT_MSB   2
#define ALT_QSPI_INDRD_RD_STAT_WIDTH   1
#define ALT_QSPI_INDRD_RD_STAT_SET_MSK   0x00000004
#define ALT_QSPI_INDRD_RD_STAT_CLR_MSK   0xfffffffb
#define ALT_QSPI_INDRD_RD_STAT_RESET   0x0
#define ALT_QSPI_INDRD_RD_STAT_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_QSPI_INDRD_RD_STAT_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_QSPI_INDRD_SRAM_FULL_E_SRAMFULL   0x1
#define ALT_QSPI_INDRD_SRAM_FULL_E_NOACTION   0x0
#define ALT_QSPI_INDRD_SRAM_FULL_LSB   3
#define ALT_QSPI_INDRD_SRAM_FULL_MSB   3
#define ALT_QSPI_INDRD_SRAM_FULL_WIDTH   1
#define ALT_QSPI_INDRD_SRAM_FULL_SET_MSK   0x00000008
#define ALT_QSPI_INDRD_SRAM_FULL_CLR_MSK   0xfffffff7
#define ALT_QSPI_INDRD_SRAM_FULL_RESET   0x0
#define ALT_QSPI_INDRD_SRAM_FULL_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_QSPI_INDRD_SRAM_FULL_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_QSPI_INDRD_RD_QUEUED_E_QUINDIRECTRD   0x1
#define ALT_QSPI_INDRD_RD_QUEUED_E_NOACTION   0x0
#define ALT_QSPI_INDRD_RD_QUEUED_LSB   4
#define ALT_QSPI_INDRD_RD_QUEUED_MSB   4
#define ALT_QSPI_INDRD_RD_QUEUED_WIDTH   1
#define ALT_QSPI_INDRD_RD_QUEUED_SET_MSK   0x00000010
#define ALT_QSPI_INDRD_RD_QUEUED_CLR_MSK   0xffffffef
#define ALT_QSPI_INDRD_RD_QUEUED_RESET   0x0
#define ALT_QSPI_INDRD_RD_QUEUED_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_QSPI_INDRD_RD_QUEUED_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_E_INDCOMP   0x1
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_E_NOACTION   0x0
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_LSB   5
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_MSB   5
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_WIDTH   1
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_SET_MSK   0x00000020
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_CLR_MSK   0xffffffdf
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_RESET   0x0
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_LSB   6
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_MSB   7
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_WIDTH   2
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_SET_MSK   0x000000c0
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_CLR_MSK   0xffffff3f
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_RESET   0x0
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_GET(value)   (((value) & 0x000000c0) >> 6)
#define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_SET(value)   (((value) << 6) & 0x000000c0)
#define ALT_QSPI_INDRD_OFST   0x60
#define ALT_QSPI_INDRDWATER_LEVEL_LSB   0
#define ALT_QSPI_INDRDWATER_LEVEL_MSB   31
#define ALT_QSPI_INDRDWATER_LEVEL_WIDTH   32
#define ALT_QSPI_INDRDWATER_LEVEL_SET_MSK   0xffffffff
#define ALT_QSPI_INDRDWATER_LEVEL_CLR_MSK   0x00000000
#define ALT_QSPI_INDRDWATER_LEVEL_RESET   0x0
#define ALT_QSPI_INDRDWATER_LEVEL_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_INDRDWATER_LEVEL_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_INDRDWATER_OFST   0x64
#define ALT_QSPI_INDRDSTADDR_ADDR_LSB   0
#define ALT_QSPI_INDRDSTADDR_ADDR_MSB   31
#define ALT_QSPI_INDRDSTADDR_ADDR_WIDTH   32
#define ALT_QSPI_INDRDSTADDR_ADDR_SET_MSK   0xffffffff
#define ALT_QSPI_INDRDSTADDR_ADDR_CLR_MSK   0x00000000
#define ALT_QSPI_INDRDSTADDR_ADDR_RESET   0x0
#define ALT_QSPI_INDRDSTADDR_ADDR_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_INDRDSTADDR_ADDR_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_INDRDSTADDR_OFST   0x68
#define ALT_QSPI_INDRDCNT_VALUE_LSB   0
#define ALT_QSPI_INDRDCNT_VALUE_MSB   31
#define ALT_QSPI_INDRDCNT_VALUE_WIDTH   32
#define ALT_QSPI_INDRDCNT_VALUE_SET_MSK   0xffffffff
#define ALT_QSPI_INDRDCNT_VALUE_CLR_MSK   0x00000000
#define ALT_QSPI_INDRDCNT_VALUE_RESET   0x0
#define ALT_QSPI_INDRDCNT_VALUE_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_INDRDCNT_VALUE_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_INDRDCNT_OFST   0x6c
#define ALT_QSPI_INDWR_START_E_END   0x1
#define ALT_QSPI_INDWR_START_E_DISD   0x0
#define ALT_QSPI_INDWR_START_LSB   0
#define ALT_QSPI_INDWR_START_MSB   0
#define ALT_QSPI_INDWR_START_WIDTH   1
#define ALT_QSPI_INDWR_START_SET_MSK   0x00000001
#define ALT_QSPI_INDWR_START_CLR_MSK   0xfffffffe
#define ALT_QSPI_INDWR_START_RESET   0x0
#define ALT_QSPI_INDWR_START_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_QSPI_INDWR_START_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_QSPI_INDWR_CANCEL_E_CANCEINDWR   0x1
#define ALT_QSPI_INDWR_CANCEL_E_NOACTION   0x0
#define ALT_QSPI_INDWR_CANCEL_LSB   1
#define ALT_QSPI_INDWR_CANCEL_MSB   1
#define ALT_QSPI_INDWR_CANCEL_WIDTH   1
#define ALT_QSPI_INDWR_CANCEL_SET_MSK   0x00000002
#define ALT_QSPI_INDWR_CANCEL_CLR_MSK   0xfffffffd
#define ALT_QSPI_INDWR_CANCEL_RESET   0x0
#define ALT_QSPI_INDWR_CANCEL_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_QSPI_INDWR_CANCEL_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_QSPI_INDWR_RDSTAT_E_INDWRSTAT   0x1
#define ALT_QSPI_INDWR_RDSTAT_E_NOACTION   0x0
#define ALT_QSPI_INDWR_RDSTAT_LSB   2
#define ALT_QSPI_INDWR_RDSTAT_MSB   2
#define ALT_QSPI_INDWR_RDSTAT_WIDTH   1
#define ALT_QSPI_INDWR_RDSTAT_SET_MSK   0x00000004
#define ALT_QSPI_INDWR_RDSTAT_CLR_MSK   0xfffffffb
#define ALT_QSPI_INDWR_RDSTAT_RESET   0x0
#define ALT_QSPI_INDWR_RDSTAT_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_QSPI_INDWR_RDSTAT_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_QSPI_INDWR_SRAMFULL_LSB   3
#define ALT_QSPI_INDWR_SRAMFULL_MSB   3
#define ALT_QSPI_INDWR_SRAMFULL_WIDTH   1
#define ALT_QSPI_INDWR_SRAMFULL_SET_MSK   0x00000008
#define ALT_QSPI_INDWR_SRAMFULL_CLR_MSK   0xfffffff7
#define ALT_QSPI_INDWR_SRAMFULL_RESET   0x0
#define ALT_QSPI_INDWR_SRAMFULL_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_QSPI_INDWR_SRAMFULL_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_QSPI_INDWR_RDQUEUED_E_INDWROP   0x1
#define ALT_QSPI_INDWR_RDQUEUED_E_NOACTION   0x0
#define ALT_QSPI_INDWR_RDQUEUED_LSB   4
#define ALT_QSPI_INDWR_RDQUEUED_MSB   4
#define ALT_QSPI_INDWR_RDQUEUED_WIDTH   1
#define ALT_QSPI_INDWR_RDQUEUED_SET_MSK   0x00000010
#define ALT_QSPI_INDWR_RDQUEUED_CLR_MSK   0xffffffef
#define ALT_QSPI_INDWR_RDQUEUED_RESET   0x0
#define ALT_QSPI_INDWR_RDQUEUED_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_QSPI_INDWR_RDQUEUED_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_QSPI_INDWR_INDDONE_E_INDCOMPST   0x1
#define ALT_QSPI_INDWR_INDDONE_E_NOACTION   0x0
#define ALT_QSPI_INDWR_INDDONE_LSB   5
#define ALT_QSPI_INDWR_INDDONE_MSB   5
#define ALT_QSPI_INDWR_INDDONE_WIDTH   1
#define ALT_QSPI_INDWR_INDDONE_SET_MSK   0x00000020
#define ALT_QSPI_INDWR_INDDONE_CLR_MSK   0xffffffdf
#define ALT_QSPI_INDWR_INDDONE_RESET   0x0
#define ALT_QSPI_INDWR_INDDONE_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_QSPI_INDWR_INDDONE_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_QSPI_INDWR_INDCNT_LSB   6
#define ALT_QSPI_INDWR_INDCNT_MSB   7
#define ALT_QSPI_INDWR_INDCNT_WIDTH   2
#define ALT_QSPI_INDWR_INDCNT_SET_MSK   0x000000c0
#define ALT_QSPI_INDWR_INDCNT_CLR_MSK   0xffffff3f
#define ALT_QSPI_INDWR_INDCNT_RESET   0x0
#define ALT_QSPI_INDWR_INDCNT_GET(value)   (((value) & 0x000000c0) >> 6)
#define ALT_QSPI_INDWR_INDCNT_SET(value)   (((value) << 6) & 0x000000c0)
#define ALT_QSPI_INDWR_OFST   0x70
#define ALT_QSPI_INDWRWATER_LEVEL_LSB   0
#define ALT_QSPI_INDWRWATER_LEVEL_MSB   31
#define ALT_QSPI_INDWRWATER_LEVEL_WIDTH   32
#define ALT_QSPI_INDWRWATER_LEVEL_SET_MSK   0xffffffff
#define ALT_QSPI_INDWRWATER_LEVEL_CLR_MSK   0x00000000
#define ALT_QSPI_INDWRWATER_LEVEL_RESET   0xffffffff
#define ALT_QSPI_INDWRWATER_LEVEL_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_INDWRWATER_LEVEL_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_INDWRWATER_OFST   0x74
#define ALT_QSPI_INDWRSTADDR_ADDR_LSB   0
#define ALT_QSPI_INDWRSTADDR_ADDR_MSB   31
#define ALT_QSPI_INDWRSTADDR_ADDR_WIDTH   32
#define ALT_QSPI_INDWRSTADDR_ADDR_SET_MSK   0xffffffff
#define ALT_QSPI_INDWRSTADDR_ADDR_CLR_MSK   0x00000000
#define ALT_QSPI_INDWRSTADDR_ADDR_RESET   0x0
#define ALT_QSPI_INDWRSTADDR_ADDR_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_INDWRSTADDR_ADDR_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_INDWRSTADDR_OFST   0x78
#define ALT_QSPI_INDWRCNT_VALUE_LSB   0
#define ALT_QSPI_INDWRCNT_VALUE_MSB   31
#define ALT_QSPI_INDWRCNT_VALUE_WIDTH   32
#define ALT_QSPI_INDWRCNT_VALUE_SET_MSK   0xffffffff
#define ALT_QSPI_INDWRCNT_VALUE_CLR_MSK   0x00000000
#define ALT_QSPI_INDWRCNT_VALUE_RESET   0x0
#define ALT_QSPI_INDWRCNT_VALUE_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_INDWRCNT_VALUE_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_INDWRCNT_OFST   0x7c
#define ALT_QSPI_FLSHCMD_EXECCMD_E_EXECUTE   0x1
#define ALT_QSPI_FLSHCMD_EXECCMD_E_NOACTION   0x0
#define ALT_QSPI_FLSHCMD_EXECCMD_LSB   0
#define ALT_QSPI_FLSHCMD_EXECCMD_MSB   0
#define ALT_QSPI_FLSHCMD_EXECCMD_WIDTH   1
#define ALT_QSPI_FLSHCMD_EXECCMD_SET_MSK   0x00000001
#define ALT_QSPI_FLSHCMD_EXECCMD_CLR_MSK   0xfffffffe
#define ALT_QSPI_FLSHCMD_EXECCMD_RESET   0x0
#define ALT_QSPI_FLSHCMD_EXECCMD_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_QSPI_FLSHCMD_EXECCMD_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_E_EXECUTESTAT   0x1
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_E_NOACTION   0x0
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_LSB   1
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_MSB   1
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_WIDTH   1
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_SET_MSK   0x00000002
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_CLR_MSK   0xfffffffd
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_RESET   0x0
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_QSPI_FLSHCMD_CMDEXECSTAT_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_LSB   7
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_MSB   11
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_WIDTH   5
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_SET_MSK   0x00000f80
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_CLR_MSK   0xfffff07f
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_RESET   0x0
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_GET(value)   (((value) & 0x00000f80) >> 7)
#define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_SET(value)   (((value) << 7) & 0x00000f80)
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE1   0x0
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE2   0x1
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE3   0x2
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE4   0x3
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE5   0x4
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE6   0x5
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE7   0x6
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE8   0x7
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_LSB   12
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_MSB   14
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_WIDTH   3
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_SET_MSK   0x00007000
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_CLR_MSK   0xffff8fff
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_RESET   0x0
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_GET(value)   (((value) & 0x00007000) >> 12)
#define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_SET(value)   (((value) << 12) & 0x00007000)
#define ALT_QSPI_FLSHCMD_ENWRDATA_E_WRDATABYTES   0x1
#define ALT_QSPI_FLSHCMD_ENWRDATA_E_NOACTION   0x0
#define ALT_QSPI_FLSHCMD_ENWRDATA_LSB   15
#define ALT_QSPI_FLSHCMD_ENWRDATA_MSB   15
#define ALT_QSPI_FLSHCMD_ENWRDATA_WIDTH   1
#define ALT_QSPI_FLSHCMD_ENWRDATA_SET_MSK   0x00008000
#define ALT_QSPI_FLSHCMD_ENWRDATA_CLR_MSK   0xffff7fff
#define ALT_QSPI_FLSHCMD_ENWRDATA_RESET   0x0
#define ALT_QSPI_FLSHCMD_ENWRDATA_GET(value)   (((value) & 0x00008000) >> 15)
#define ALT_QSPI_FLSHCMD_ENWRDATA_SET(value)   (((value) << 15) & 0x00008000)
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE1   0x0
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE2   0x1
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE3   0x2
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE4   0x3
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_LSB   16
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_MSB   17
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_WIDTH   2
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_SET_MSK   0x00030000
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_CLR_MSK   0xfffcffff
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_RESET   0x0
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_GET(value)   (((value) & 0x00030000) >> 16)
#define ALT_QSPI_FLSHCMD_NUMADDRBYTES_SET(value)   (((value) << 16) & 0x00030000)
#define ALT_QSPI_FLSHCMD_ENMODBIT_E_END   0x1
#define ALT_QSPI_FLSHCMD_ENMODBIT_E_DISD   0x0
#define ALT_QSPI_FLSHCMD_ENMODBIT_LSB   18
#define ALT_QSPI_FLSHCMD_ENMODBIT_MSB   18
#define ALT_QSPI_FLSHCMD_ENMODBIT_WIDTH   1
#define ALT_QSPI_FLSHCMD_ENMODBIT_SET_MSK   0x00040000
#define ALT_QSPI_FLSHCMD_ENMODBIT_CLR_MSK   0xfffbffff
#define ALT_QSPI_FLSHCMD_ENMODBIT_RESET   0x0
#define ALT_QSPI_FLSHCMD_ENMODBIT_GET(value)   (((value) & 0x00040000) >> 18)
#define ALT_QSPI_FLSHCMD_ENMODBIT_SET(value)   (((value) << 18) & 0x00040000)
#define ALT_QSPI_FLSHCMD_ENCMDADDR_E_END   0x1
#define ALT_QSPI_FLSHCMD_ENCMDADDR_E_DISD   0x0
#define ALT_QSPI_FLSHCMD_ENCMDADDR_LSB   19
#define ALT_QSPI_FLSHCMD_ENCMDADDR_MSB   19
#define ALT_QSPI_FLSHCMD_ENCMDADDR_WIDTH   1
#define ALT_QSPI_FLSHCMD_ENCMDADDR_SET_MSK   0x00080000
#define ALT_QSPI_FLSHCMD_ENCMDADDR_CLR_MSK   0xfff7ffff
#define ALT_QSPI_FLSHCMD_ENCMDADDR_RESET   0x0
#define ALT_QSPI_FLSHCMD_ENCMDADDR_GET(value)   (((value) & 0x00080000) >> 19)
#define ALT_QSPI_FLSHCMD_ENCMDADDR_SET(value)   (((value) << 19) & 0x00080000)
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE1   0x0
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE2   0x1
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE3   0x2
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE4   0x3
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE5   0x4
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE6   0x5
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE7   0x6
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE8   0x7
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_LSB   20
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_MSB   22
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_WIDTH   3
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_SET_MSK   0x00700000
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_CLR_MSK   0xff8fffff
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_RESET   0x0
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_GET(value)   (((value) & 0x00700000) >> 20)
#define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_SET(value)   (((value) << 20) & 0x00700000)
#define ALT_QSPI_FLSHCMD_ENRDDATA_E_EN   0x1
#define ALT_QSPI_FLSHCMD_ENRDDATA_E_NOACTION   0x0
#define ALT_QSPI_FLSHCMD_ENRDDATA_LSB   23
#define ALT_QSPI_FLSHCMD_ENRDDATA_MSB   23
#define ALT_QSPI_FLSHCMD_ENRDDATA_WIDTH   1
#define ALT_QSPI_FLSHCMD_ENRDDATA_SET_MSK   0x00800000
#define ALT_QSPI_FLSHCMD_ENRDDATA_CLR_MSK   0xff7fffff
#define ALT_QSPI_FLSHCMD_ENRDDATA_RESET   0x0
#define ALT_QSPI_FLSHCMD_ENRDDATA_GET(value)   (((value) & 0x00800000) >> 23)
#define ALT_QSPI_FLSHCMD_ENRDDATA_SET(value)   (((value) << 23) & 0x00800000)
#define ALT_QSPI_FLSHCMD_CMDOPCODE_LSB   24
#define ALT_QSPI_FLSHCMD_CMDOPCODE_MSB   31
#define ALT_QSPI_FLSHCMD_CMDOPCODE_WIDTH   8
#define ALT_QSPI_FLSHCMD_CMDOPCODE_SET_MSK   0xff000000
#define ALT_QSPI_FLSHCMD_CMDOPCODE_CLR_MSK   0x00ffffff
#define ALT_QSPI_FLSHCMD_CMDOPCODE_RESET   0x0
#define ALT_QSPI_FLSHCMD_CMDOPCODE_GET(value)   (((value) & 0xff000000) >> 24)
#define ALT_QSPI_FLSHCMD_CMDOPCODE_SET(value)   (((value) << 24) & 0xff000000)
#define ALT_QSPI_FLSHCMD_OFST   0x90
#define ALT_QSPI_FLSHCMDADDR_ADDR_LSB   0
#define ALT_QSPI_FLSHCMDADDR_ADDR_MSB   31
#define ALT_QSPI_FLSHCMDADDR_ADDR_WIDTH   32
#define ALT_QSPI_FLSHCMDADDR_ADDR_SET_MSK   0xffffffff
#define ALT_QSPI_FLSHCMDADDR_ADDR_CLR_MSK   0x00000000
#define ALT_QSPI_FLSHCMDADDR_ADDR_RESET   0x0
#define ALT_QSPI_FLSHCMDADDR_ADDR_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_FLSHCMDADDR_ADDR_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_FLSHCMDADDR_OFST   0x94
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_LSB   0
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_MSB   31
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_WIDTH   32
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_SET_MSK   0xffffffff
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_CLR_MSK   0x00000000
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_RESET   0x0
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_FLSHCMDRDDATALO_DATA_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_FLSHCMDRDDATALO_OFST   0xa0
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_LSB   0
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_MSB   31
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_WIDTH   32
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_SET_MSK   0xffffffff
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_CLR_MSK   0x00000000
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_RESET   0x0
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_FLSHCMDRDDATAUP_DATA_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_FLSHCMDRDDATAUP_OFST   0xa4
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_LSB   0
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_MSB   31
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_WIDTH   32
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_SET_MSK   0xffffffff
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_CLR_MSK   0x00000000
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_RESET   0x0
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_FLSHCMDWRDATALO_DATA_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_FLSHCMDWRDATALO_OFST   0xa8
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_LSB   0
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_MSB   31
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_WIDTH   32
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_SET_MSK   0xffffffff
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_CLR_MSK   0x00000000
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_RESET   0x0
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_GET(value)   (((value) & 0xffffffff) >> 0)
#define ALT_QSPI_FLSHCMDWRDATAUP_DATA_SET(value)   (((value) << 0) & 0xffffffff)
#define ALT_QSPI_FLSHCMDWRDATAUP_OFST   0xac
#define ALT_QSPI_MODULEID_VALUE_LSB   0
#define ALT_QSPI_MODULEID_VALUE_MSB   24
#define ALT_QSPI_MODULEID_VALUE_WIDTH   25
#define ALT_QSPI_MODULEID_VALUE_SET_MSK   0x01ffffff
#define ALT_QSPI_MODULEID_VALUE_CLR_MSK   0xfe000000
#define ALT_QSPI_MODULEID_VALUE_RESET   0x1001
#define ALT_QSPI_MODULEID_VALUE_GET(value)   (((value) & 0x01ffffff) >> 0)
#define ALT_QSPI_MODULEID_VALUE_SET(value)   (((value) << 0) & 0x01ffffff)
#define ALT_QSPI_MODULEID_OFST   0xfc
typedef volatile struct ALT_QSPI_CFG_s ALT_QSPI_CFG_t
typedef volatile struct ALT_QSPI_DEVRD_s ALT_QSPI_DEVRD_t
typedef volatile struct ALT_QSPI_DEVWR_s ALT_QSPI_DEVWR_t
typedef volatile struct ALT_QSPI_DELAY_s ALT_QSPI_DELAY_t
typedef volatile struct ALT_QSPI_RDDATACAP_s ALT_QSPI_RDDATACAP_t
typedef volatile struct ALT_QSPI_DEVSZ_s ALT_QSPI_DEVSZ_t
typedef volatile struct ALT_QSPI_SRAMPART_s ALT_QSPI_SRAMPART_t
typedef volatile struct ALT_QSPI_INDADDRTRIG_s ALT_QSPI_INDADDRTRIG_t
typedef volatile struct ALT_QSPI_DMAPER_s ALT_QSPI_DMAPER_t
typedef volatile struct ALT_QSPI_REMAPADDR_s ALT_QSPI_REMAPADDR_t
typedef volatile struct ALT_QSPI_MODBIT_s ALT_QSPI_MODBIT_t
typedef volatile struct ALT_QSPI_SRAMFILL_s ALT_QSPI_SRAMFILL_t
typedef volatile struct ALT_QSPI_TXTHRESH_s ALT_QSPI_TXTHRESH_t
typedef volatile struct ALT_QSPI_RXTHRESH_s ALT_QSPI_RXTHRESH_t
typedef volatile struct ALT_QSPI_IRQSTAT_s ALT_QSPI_IRQSTAT_t
typedef volatile struct ALT_QSPI_IRQMSK_s ALT_QSPI_IRQMSK_t
typedef volatile struct ALT_QSPI_LOWWRPROT_s ALT_QSPI_LOWWRPROT_t
typedef volatile struct ALT_QSPI_UPPWRPROT_s ALT_QSPI_UPPWRPROT_t
typedef volatile struct ALT_QSPI_WRPROT_s ALT_QSPI_WRPROT_t
typedef volatile struct ALT_QSPI_INDRD_s ALT_QSPI_INDRD_t
typedef volatile struct ALT_QSPI_INDRDWATER_s ALT_QSPI_INDRDWATER_t
typedef volatile struct ALT_QSPI_INDRDSTADDR_s ALT_QSPI_INDRDSTADDR_t
typedef volatile struct ALT_QSPI_INDRDCNT_s ALT_QSPI_INDRDCNT_t
typedef volatile struct ALT_QSPI_INDWR_s ALT_QSPI_INDWR_t
typedef volatile struct ALT_QSPI_INDWRWATER_s ALT_QSPI_INDWRWATER_t
typedef volatile struct ALT_QSPI_INDWRSTADDR_s ALT_QSPI_INDWRSTADDR_t
typedef volatile struct ALT_QSPI_INDWRCNT_s ALT_QSPI_INDWRCNT_t
typedef volatile struct ALT_QSPI_FLSHCMD_s ALT_QSPI_FLSHCMD_t
typedef volatile struct ALT_QSPI_FLSHCMDADDR_s ALT_QSPI_FLSHCMDADDR_t
typedef volatile struct ALT_QSPI_FLSHCMDRDDATALO_s ALT_QSPI_FLSHCMDRDDATALO_t
typedef volatile struct ALT_QSPI_FLSHCMDRDDATAUP_s ALT_QSPI_FLSHCMDRDDATAUP_t
typedef volatile struct ALT_QSPI_FLSHCMDWRDATALO_s ALT_QSPI_FLSHCMDWRDATALO_t
typedef volatile struct ALT_QSPI_FLSHCMDWRDATAUP_s ALT_QSPI_FLSHCMDWRDATAUP_t
typedef volatile struct ALT_QSPI_MODULEID_s ALT_QSPI_MODULEID_t
typedef volatile struct ALT_QSPI_s ALT_QSPI_t
typedef volatile struct ALT_QSPI_raw_s ALT_QSPI_raw_t
