RTEMS 5.2
imx_srcreg.h
1/*
2 * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <info@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef IMX_SRCREG_H
16#define IMX_SRCREG_H
17
18#include <bsp/utility.h>
19
20typedef struct {
21 uint32_t scr;
22#define IMX_SRC_SCR_DOM_EN BSP_BIT32(31)
23#define IMX_SRC_SCR_LOCK BSP_BIT32(30)
24#define IMX_SRC_SCR_DOMAIN3 BSP_BIT32(27)
25#define IMX_SRC_SCR_DOMAIN2 BSP_BIT32(26)
26#define IMX_SRC_SCR_DOMAIN1 BSP_BIT32(25)
27#define IMX_SRC_SCR_DOMAIN0 BSP_BIT32(24)
28#define IMX_SRC_SCR_MASK_TEMPSENSE_RESET(val) BSP_FLD32(val, 4, 7)
29#define IMX_SRC_SCR_MASK_TEMPSENSE_RESET_GET(reg) BSP_FLD32GET(reg, 4, 7)
30#define IMX_SRC_SCR_MASK_TEMPSENSE_RESET_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
31 uint32_t a7rcr0;
32#define IMX_SRC_A7RCR0_DOM_EN BSP_BIT32(31)
33#define IMX_SRC_A7RCR0_LOCK BSP_BIT32(30)
34#define IMX_SRC_A7RCR0_DOMAIN3 BSP_BIT32(27)
35#define IMX_SRC_A7RCR0_DOMAIN2 BSP_BIT32(26)
36#define IMX_SRC_A7RCR0_DOMAIN1 BSP_BIT32(25)
37#define IMX_SRC_A7RCR0_DOMAIN0 BSP_BIT32(24)
38#define IMX_SRC_A7RCR0_A7_L2RESET BSP_BIT32(21)
39#define IMX_SRC_A7RCR0_A7_SOC_DBG_RESET BSP_BIT32(20)
40#define IMX_SRC_A7RCR0_MASK_WDOG1_RST(val) BSP_FLD32(val, 16, 19)
41#define IMX_SRC_A7RCR0_MASK_WDOG1_RST_GET(reg) BSP_FLD32GET(reg, 16, 19)
42#define IMX_SRC_A7RCR0_MASK_WDOG1_RST_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
43#define IMX_SRC_A7RCR0_A7_ETM_RESET1 BSP_BIT32(13)
44#define IMX_SRC_A7RCR0_A7_ETM_RESET0 BSP_BIT32(12)
45#define IMX_SRC_A7RCR0_A7_DBG_RESET1 BSP_BIT32(9)
46#define IMX_SRC_A7RCR0_A7_DBG_RESET0 BSP_BIT32(8)
47#define IMX_SRC_A7RCR0_A7_CORE_RESET1 BSP_BIT32(5)
48#define IMX_SRC_A7RCR0_A7_CORE_RESET0 BSP_BIT32(4)
49#define IMX_SRC_A7RCR0_A7_CORE_POR_RESET1 BSP_BIT32(1)
50#define IMX_SRC_A7RCR0_A7_CORE_POR_RESET0 BSP_BIT32(0)
51 uint32_t a7rcr1;
52#define IMX_SRC_A7RCR1_DOM_EN BSP_BIT32(31)
53#define IMX_SRC_A7RCR1_LOCK BSP_BIT32(30)
54#define IMX_SRC_A7RCR1_DOMAIN3 BSP_BIT32(27)
55#define IMX_SRC_A7RCR1_DOMAIN2 BSP_BIT32(26)
56#define IMX_SRC_A7RCR1_DOMAIN1 BSP_BIT32(25)
57#define IMX_SRC_A7RCR1_DOMAIN0 BSP_BIT32(24)
58#define IMX_SRC_A7RCR1_A7_CORE1_ENABLE BSP_BIT32(1)
59 uint32_t m4rcr;
60#define IMX_SRC_M4RCR_DOM_EN BSP_BIT32(31)
61#define IMX_SRC_M4RCR_LOCK BSP_BIT32(30)
62#define IMX_SRC_M4RCR_DOMAIN3 BSP_BIT32(27)
63#define IMX_SRC_M4RCR_DOMAIN2 BSP_BIT32(26)
64#define IMX_SRC_M4RCR_DOMAIN1 BSP_BIT32(25)
65#define IMX_SRC_M4RCR_DOMAIN0 BSP_BIT32(24)
66#define IMX_SRC_M4RCR_WDOG3_RST_OPTION BSP_BIT32(9)
67#define IMX_SRC_M4RCR_WDOG3_RST_OPTION_M4 BSP_BIT32(8)
68#define IMX_SRC_M4RCR_MASK_WDOG3_RST(val) BSP_FLD32(val, 4, 7)
69#define IMX_SRC_M4RCR_MASK_WDOG3_RST_GET(reg) BSP_FLD32GET(reg, 4, 7)
70#define IMX_SRC_M4RCR_MASK_WDOG3_RST_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
71#define IMX_SRC_M4RCR_ENABLE_M4 BSP_BIT32(3)
72#define IMX_SRC_M4RCR_SW_M4P_RST BSP_BIT32(2)
73#define IMX_SRC_M4RCR_SW_M4C_RST BSP_BIT32(1)
74#define IMX_SRC_M4RCR_SW_M4C_NON_SCLR_RST BSP_BIT32(0)
75 uint32_t reserved_10;
76 uint32_t ercr;
77 uint32_t reserved_18;
78 uint32_t hsicphy_rcr;
79 uint32_t usbophy1_rcr;
80 uint32_t usbophy2_rcr;
81 uint32_t mipiphy_rcr;
82 uint32_t pciephy_rcr;
83 uint32_t reserved_30[10];
84 uint32_t sbmr1;
85 uint32_t srsr;
86 uint32_t reserved_60[2];
87 uint32_t sisr;
88 uint32_t simr;
89 uint32_t sbmr2;
90 uint32_t gpr1;
91 uint32_t gpr2;
92 uint32_t gpr3;
93 uint32_t gpr4;
94 uint32_t gpr5;
95 uint32_t gpr6;
96 uint32_t gpr7;
97 uint32_t gpr8;
98 uint32_t gpr9;
99 uint32_t gpr10;
100 uint32_t reserved_9c[985];
101 uint32_t ddrc_rcr;
102} imx_src;
103
104#endif /* IMX_SRCREG_H */
Utility macros.
Definition: imx_srcreg.h:20
