RTEMS 5.2
imx_i2creg.h
1/*
2 * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <info@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef IMX_I2CREG_H
16#define IMX_I2CREG_H
17
18#include <bsp/utility.h>
19
20typedef struct {
21 uint16_t iadr;
22#define IMX_I2C_IADR_ADR(val) BSP_FLD16(val, 1, 7)
23#define IMX_I2C_IADR_ADR_GET(reg) BSP_FLD16GET(reg, 1, 7)
24#define IMX_I2C_IADR_ADR_SET(reg, val) BSP_FLD16SET(reg, val, 1, 7)
25 uint16_t reserved_02;
26 uint16_t ifdr;
27#define IMX_I2C_IFDR_IC(val) BSP_FLD16(val, 0, 5)
28#define IMX_I2C_IFDR_IC_GET(reg) BSP_FLD16GET(reg, 0, 5)
29#define IMX_I2C_IFDR_IC_SET(reg, val) BSP_FLD16SET(reg, val, 0, 5)
30 uint16_t reserved_06;
31 uint16_t i2cr;
32#define IMX_I2C_I2CR_IEN BSP_BIT16(7)
33#define IMX_I2C_I2CR_IIEN BSP_BIT16(6)
34#define IMX_I2C_I2CR_MSTA BSP_BIT16(5)
35#define IMX_I2C_I2CR_MTX BSP_BIT16(4)
36#define IMX_I2C_I2CR_TXAK BSP_BIT16(3)
37#define IMX_I2C_I2CR_RSTA BSP_BIT16(2)
38 uint16_t reserved_0a;
39 uint16_t i2sr;
40#define IMX_I2C_I2SR_ICF BSP_BIT16(7)
41#define IMX_I2C_I2SR_IAAS BSP_BIT16(6)
42#define IMX_I2C_I2SR_IBB BSP_BIT16(5)
43#define IMX_I2C_I2SR_IAL BSP_BIT16(4)
44#define IMX_I2C_I2SR_SRW BSP_BIT16(2)
45#define IMX_I2C_I2SR_IIF BSP_BIT16(1)
46#define IMX_I2C_I2SR_RXAK BSP_BIT16(0)
47 uint16_t reserved_0e;
48 uint16_t i2dr;
49#define IMX_I2C_I2DR_DATA(val) BSP_FLD16(val, 0, 7)
50#define IMX_I2C_I2DR_DATA_GET(reg) BSP_FLD16GET(reg, 0, 7)
51#define IMX_I2C_I2DR_DATA_SET(reg, val) BSP_FLD16SET(reg, val, 0, 7)
52} imx_i2c;
53
54#endif /* IMX_I2CREG_H */
Utility macros.
Definition: imx_i2creg.h:20
