RTEMS 5.2
rtemscompat_defs.h
1#ifndef RTEMS_COMPAT_DEFS_H
2#define RTEMS_COMPAT_DEFS_H
3
4/* Number of device instances the driver should support
5 * - may be limited to 1 depending on IRQ API
6 * (braindamaged PC586 and powerpc)
7 */
8#define NETDRIVER_SLOTS 1
9
10/* String name to print with error messages */
11#define NETDRIVER "em"
12/* Name snippet used to make global symbols unique to this driver */
13#define NETDRIVER_PREFIX em
14
15#define adapter em_softc
16#define interface_data arpcom
17
18/* Define according to endianness of the *ethernet*chip*
19 * (not the CPU - most probably are LE)
20 * This must be either NET_CHIP_LE or NET_CHIP_BE
21 */
22
23#define NET_CHIP_LE
24#undef NET_CHIP_BE
25
26/* Define either NET_CHIP_MEM_IO or NET_CHIP_PORT_IO,
27 * depending whether the CPU sees it in memory address space
28 * or (e.g. x86) uses special I/O instructions.
29 */
30#define NET_CHIP_MEM_IO
31#undef NET_CHIP_PORT_IO
32
33/* The name of the hijacked 'bus handle' field in the softc
34 * structure. We use this field to store the chip's base address.
35 */
36#define NET_SOFTC_BHANDLE_FIELD osdep.mem_bus_space_handle
37
38/* define the names of the 'if_XXXreg.h' and 'if_XXXvar.h' headers
39 * (only if present, i.e., if the BSDNET driver has no respective
40 * header, leave this undefined).
41 *
42 */
43#define IF_REG_HEADER "../if_em/if_em.h"
44#undef IF_VAR_HEADER
45
46/* define if a pci device */
47#define NETDRIVER_PCI <bsp/pci.h>
48
49/* Macros to disable and enable interrupts, respectively.
50 * The 'disable' macro is expanded in the ISR, the 'enable'
51 * macro is expanded in the driver task.
52 * The global network semaphore usually provides mutex
53 * protection of the device registers.
54 * Special care must be taken when coding the 'disable' macro,
55 * however to MAKE SURE THERE ARE NO OTHER SIDE EFFECTS such
56 * as:
57 * - macro must not clear any status flags
58 * - macro must save/restore any context information
59 * (e.g., a address register pointer or a bank switch register)
60 *
61 * ARGUMENT: the macro arg is a pointer to the driver's 'softc' structure
62 */
63
64#define NET_ENABLE_IRQS(sc) do { \
65 E1000_WRITE_REG(&sc->hw, IMS, (IMS_ENABLE_MASK)); \
66 } while (0)
67
68#define NET_DISABLE_IRQS(sc) do { \
69 E1000_WRITE_REG(&sc->hw, IMC, 0xffffffff); \
70 } while (0)
71
72#define KASSERT(a...) do {} while (0)
73
74/* dmamap stuff; these are defined just to work with the current version
75 * of this driver and the implementation must be carefully checked if
76 * a newer version is merged.!
77 *
78 * The more cumbersome routines have been commented in the source, the
79 * simpler ones are defined to be NOOPs here so the source gets less
80 * cluttered...
81 *
82 * ASSUMPTIONS:
83 *
84 * -> dmamap_sync cannot sync caches; assume we have HW snooping
85 *
86 */
87
88typedef unsigned bus_size_t;
89typedef unsigned bus_addr_t;
90
91typedef struct {
92 unsigned ds_addr;
93 unsigned ds_len;
95
96#define bus_dma_tag_destroy(args...) do {} while(0)
97
98#define bus_dmamap_destroy(args...) do {} while(0)
99
100#define bus_dmamap_unload(args...) do {} while (0)
101
102#ifdef __PPC__
103#define bus_dmamap_sync(args...) do { __asm__ volatile("sync":::"memory"); } while (0)
104#else
105#define bus_dmamap_sync(args...) do {} while (0)
106#endif
107
108#define BUS_DMA_NOWAIT 0xdeadbeef /* unused */
109
110#define em_adapter_list _bsd_em_adapter_list
111#define em_arc_subsystem_valid _bsd_em_arc_subsystem_valid
112#define em_check_downshift _bsd_em_check_downshift
113#define em_check_for_link _bsd_em_check_for_link
114#define em_check_mng_mode _bsd_em_check_mng_mode
115#define em_check_phy_reset_block _bsd_em_check_phy_reset_block
116#define em_check_polarity _bsd_em_check_polarity
117#define em_cleanup_led _bsd_em_cleanup_led
118#define em_clear_hw_cntrs _bsd_em_clear_hw_cntrs
119#define em_clear_vfta _bsd_em_clear_vfta
120#define em_commit_shadow_ram _bsd_em_commit_shadow_ram
121#define em_config_collision_dist _bsd_em_config_collision_dist
122#define em_config_dsp_after_link_change _bsd_em_config_dsp_after_link_change
123#define em_config_fc_after_link_up _bsd_em_config_fc_after_link_up
124#define em_dbg_config _bsd_em_dbg_config
125#define em_detect_gig_phy _bsd_em_detect_gig_phy
126#define em_disable_pciex_master _bsd_em_disable_pciex_master
127#define em_display_debug_stats _bsd_em_display_debug_stats
128#define em_driver_version _bsd_em_driver_version
129#define em_enable_mng_pass_thru _bsd_em_enable_mng_pass_thru
130#define em_enable_pciex_master _bsd_em_enable_pciex_master
131#define em_enable_tx_pkt_filtering _bsd_em_enable_tx_pkt_filtering
132#define em_force_mac_fc _bsd_em_force_mac_fc
133#define em_get_auto_rd_done _bsd_em_get_auto_rd_done
134#define em_get_bus_info _bsd_em_get_bus_info
135#define em_get_cable_length _bsd_em_get_cable_length
136#define em_get_hw_eeprom_semaphore _bsd_em_get_hw_eeprom_semaphore
137#define em_get_phy_cfg_done _bsd_em_get_phy_cfg_done
138#define em_get_speed_and_duplex _bsd_em_get_speed_and_duplex
139#define em_hash_mc_addr _bsd_em_hash_mc_addr
140#define em_hw_early_init _bsd_em_hw_early_init
141#define em_id_led_init _bsd_em_id_led_init
142#define em_init_eeprom_params _bsd_em_init_eeprom_params
143#define em_init_hw _bsd_em_init_hw
144#define em_init_rx_addrs _bsd_em_init_rx_addrs
145#define em_io_read _bsd_em_io_read
146#define em_io_write _bsd_em_io_write
147#define em_is_onboard_nvm_eeprom _bsd_em_is_onboard_nvm_eeprom
148#define em_led_off _bsd_em_led_off
149#define em_led_on _bsd_em_led_on
150#define em_mc_addr_list_update _bsd_em_mc_addr_list_update
151#define em_mng_enable_host_if _bsd_em_mng_enable_host_if
152#define em_mng_host_if_write _bsd_em_mng_host_if_write
153#define em_mng_write_cmd_header _bsd_em_mng_write_cmd_header
154#define em_mng_write_commit _bsd_em_mng_write_commit
155#define em_mng_write_dhcp_info _bsd_em_mng_write_dhcp_info
156#define em_mta_set _bsd_em_mta_set
157#define em_pci_clear_mwi _bsd_em_pci_clear_mwi
158#define em_pci_set_mwi _bsd_em_pci_set_mwi
159#define em_phy_get_info _bsd_em_phy_get_info
160#define em_phy_hw_reset _bsd_em_phy_hw_reset
161#define em_phy_igp_get_info _bsd_em_phy_igp_get_info
162#define em_phy_m88_get_info _bsd_em_phy_m88_get_info
163#define em_phy_reset _bsd_em_phy_reset
164#define em_phy_setup_autoneg _bsd_em_phy_setup_autoneg
165#define em_poll_eerd_eewr_done _bsd_em_poll_eerd_eewr_done
166#define em_put_hw_eeprom_semaphore _bsd_em_put_hw_eeprom_semaphore
167#define em_rar_set _bsd_em_rar_set
168#define em_read_eeprom _bsd_em_read_eeprom
169#define em_read_eeprom_eerd _bsd_em_read_eeprom_eerd
170#define em_read_mac_addr _bsd_em_read_mac_addr
171#define em_read_part_num _bsd_em_read_part_num
172#define em_read_pci_cfg _bsd_em_read_pci_cfg
173#define em_read_phy_reg _bsd_em_read_phy_reg
174#define em_read_reg_io _bsd_em_read_reg_io
175#define em_reset_adaptive _bsd_em_reset_adaptive
176#define em_reset_hw _bsd_em_reset_hw
177#define em_set_d0_lplu_state _bsd_em_set_d0_lplu_state
178#define em_set_d3_lplu_state _bsd_em_set_d3_lplu_state
179#define em_set_mac_type _bsd_em_set_mac_type
180#define em_set_media_type _bsd_em_set_media_type
181#define em_set_pci_express_master_disable _bsd_em_set_pci_express_master_disable
182#define em_setup_led _bsd_em_setup_led
183#define em_setup_link _bsd_em_setup_link
184#define em_tbi_adjust_stats _bsd_em_tbi_adjust_stats
185#define em_update_adaptive _bsd_em_update_adaptive
186#define em_update_eeprom_checksum _bsd_em_update_eeprom_checksum
187#define em_validate_eeprom_checksum _bsd_em_validate_eeprom_checksum
188#define em_validate_mdi_setting _bsd_em_validate_mdi_setting
189#define em_wait_autoneg _bsd_em_wait_autoneg
190#define em_write_eeprom _bsd_em_write_eeprom
191#define em_write_eeprom_eewr _bsd_em_write_eeprom_eewr
192#define em_write_pci_cfg _bsd_em_write_pci_cfg
193#define em_write_phy_reg _bsd_em_write_phy_reg
194#define em_write_reg_io _bsd_em_write_reg_io
195#define em_write_vfta _bsd_em_write_vfta
196#define the_em_devs _bsd_the_em_devs
197
198#endif
Definition: rtemscompat_defs.h:91
