RTEMS 5.2
ide_part_table.h
1
7/*
8 * Copyright (C) 2002 OKTET Ltd., St.-Petersburg, Russia
9 *
10 * Author: Konstantin Abramenko <Konstantin.Abramenko@oktet.ru>
11 * Alexander Kukuta <Alexander.Kukuta@oktet.ru>
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 *
17 *****************************************************************************/
18
19#ifndef _RTEMS_IDE_PART_TABLE_H
20#define _RTEMS_IDE_PART_TABLE_H
21
22#include <rtems/chain.h>
23#include <stdio.h>
24#include <stdlib.h>
25#include <string.h>
26#include <errno.h>
27#include <sys/ioctl.h>
28#include <sys/types.h>
29#include <sys/endian.h>
30#include <sys/stat.h>
31#include <unistd.h>
32#include <fcntl.h>
33#include <rtems.h>
34#include <rtems/blkdev.h>
35#include <rtems/libio.h>
36#include <rtems/libio_.h>
37#include <rtems/bdbuf.h>
38#include <rtems/seterr.h>
39
40/* Minor base number for all logical devices */
41#define RTEMS_IDE_SECTOR_BITS 9
42#define RTEMS_IDE_SECTOR_SIZE 512
43#define RTEMS_IDE_PARTITION_DESCRIPTOR_SIZE 16
44#define RTEMS_IDE_PARTITION_MAX_PARTITION_NUMBER 63
45#define RTEMS_IDE_PARTITION_MAX_SUB_PARTITION_NUMBER 4
46#define RTEMS_IDE_PARTITION_DEV_NAME_LENGTH_MAX 16
47
48#define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA1 0x55
49#define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA2 0xaa
50#define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_OFFSET 0x1fe
51#define RTEMS_IDE_PARTITION_TABLE_OFFSET 0x1be
52#define RTEMS_IDE_PARTITION_TABLE_SIZE (4 * 16)
53#define RTEMS_IDE_PARTITION_BOOTABLE_OFFSET 0
54#define RTEMS_IDE_PARTITION_SYS_TYPE_OFFSET 4
55#define RTEMS_IDE_PARTITION_START_OFFSET 8
56#define RTEMS_IDE_PARTITION_SIZE_OFFSET 12
57
58/*
59 * Conversion from and to little-endian byte order. (no-op on i386/i486)
60 */
61#define LE_TO_CPU_U16(v) le16toh(v)
62#define LE_TO_CPU_U32(v) le32toh(v)
63#define CPU_TO_LE_U16(v) htole16(v)
64#define CPU_TO_LE_U32(v) htole32(v)
65
66/*
67 * sector_data_t --
68 * corresponds to the sector on the device
69 */
70typedef struct rtems_sector_data_s
71{
72 uint32_t sector_num; /* sector number on the device */
73 uint8_t data[RTEMS_ZERO_LENGTH_ARRAY]; /* raw sector data */
75
76
77/*
78 * Enum partition types
79 * see list at http://ata-atapi.com/hiwtab.htm
80 *
81 * @todo Should these have RTEMS before them.
82 */
83enum {
84 EMPTY_PARTITION = 0x00,
85 DOS_FAT12_PARTITION = 0x01,
86 DOS_FAT16_PARTITION = 0x04,
87 EXTENDED_PARTITION = 0x05,
88 DOS_P32MB_PARTITION = 0x06,
89 FAT32_PARTITION = 0x0B,
90 FAT32_LBA_PARTITION = 0x0C,
91 FAT16_LBA_PARTITION = 0x0E,
92 DM6_PARTITION = 0x54,
93 EZD_PARTITION = 0x55,
94 DM6_AUX1PARTITION = 0x51,
95 DM6_AUX3PARTITION = 0x53,
96 LINUX_SWAP = 0x82,
97 LINUX_NATIVE = 0x83,
98 LINUX_EXTENDED = 0x85
99};
100
101
102/* Forward declaration */
103struct rtems_disk_desc_s;
104
105/*
106 * part_desc_t --
107 * contains all neccessary information about partition
108 */
109typedef struct rtems_part_desc_s {
110 uint8_t bootable; /* is the partition active */
111 uint8_t sys_type; /* type of partition */
112 uint8_t log_id; /* logical number of partition */
113 uint32_t start; /* first partition sector, in absolute
114 * numeration */
115 uint32_t size; /* size in sectors */
116 uint32_t end; /* last partition sector, end = start + size - 1 */
117 struct rtems_disk_desc_s *disk_desc; /* descriptor of disk, partition
118 * contains in */
119 struct rtems_part_desc_s *ext_part; /* extended partition containing this
120 * one */
121
122 /* partitions, containing in this one */
123 struct rtems_part_desc_s *sub_part[RTEMS_IDE_PARTITION_MAX_SUB_PARTITION_NUMBER];
125
126
127
128typedef struct rtems_disk_desc_s {
129 /* device name in /dev filesystem */
130 char dev_name[RTEMS_IDE_PARTITION_DEV_NAME_LENGTH_MAX];
131
132 uint32_t sector_size; /* size of sector */
133 uint32_t sector_bits; /* the base-2 logarithm of sector_size */
134 uint32_t lba_size; /* total amount of sectors in lba address mode */
135 int last_log_id; /* used for logical disks enumerating */
136
137 /* primary partition descriptors */
138 rtems_part_desc_t *partitions[RTEMS_IDE_PARTITION_MAX_PARTITION_NUMBER];
140
141#ifdef __cplusplus
142extern "C" {
143#endif
144
145/*
146 * rtems_ide_part_table_free --
147 * frees disk descriptor structure
148 *
149 * PARAMETERS:
150 * disk_desc - disc descriptor structure to free
151 *
152 * RETURNS:
153 * N/A
154 */
159 rtems_disk_desc_t *disk_desc
161
162
163/*
164 * rtems_ide_part_table_get --
165 * reads partition table structure from the device
166 * and creates disk description structure
167 *
168 * PARAMETERS:
169 * dev_name - path to physical device in /dev filesystem
170 * disk_desc - returned disc description structure
171 *
172 * RETURNS:
173 * RTEMS_SUCCESSFUL if success, or -1 and corresponding errno else
174 */
179 const char *dev_name,
180 rtems_disk_desc_t *disk_desc
182
183
184/*
185 * rtems_ide_part_table_initialize --
186 * initializes logical devices on the physical IDE drive
187 *
188 * PARAMETERS:
189 * dev_name - path to physical device in /dev filesystem
190 *
191 * RETURNS:
192 * RTEMS_SUCCESSFUL if success, or -1 and corresponding errno else
193 */
198 const char *dev_name
200
201#ifdef __cplusplus
202}
203#endif
204
205#endif /* _RTEMS_IDE_PART_TABLE_H */
Block Device Buffer Management.
Block Device Management.
Chain API.
rtems_status_code
Classic API Status.
Definition: status.h:43
#define RTEMS_DEPRECATED
Public name for task floating point context area.
Definition: basedefs.h:141
void rtems_ide_part_table_free(rtems_disk_desc_t *disk_desc) RTEMS_DEPRECATED
Definition: ide_part_table.c:512
rtems_status_code rtems_ide_part_table_get(const char *dev_name, rtems_disk_desc_t *disk_desc) RTEMS_DEPRECATED
Definition: ide_part_table.c:531
rtems_status_code rtems_ide_part_table_initialize(const char *dev_name) RTEMS_DEPRECATED
Definition: ide_part_table.c:550
Basic IO API.
LibIO Internal Interface.
Data which Ease the Burden of Consistently Setting Errno.
Definition: ide_part_table.h:128
Definition: ide_part_table.h:109
Definition: ide_part_table.h:71
