RTEMS 5.2
i82586reg.h
1/* $NetBSD: i82586reg.h,v 1.7 1998/02/28 01:07:45 pk Exp $ */
2
3/*-
4 * Copyright (c) 1998 The NetBSD Foundation, Inc.
5 * All rights reserved.
6 *
7 * This code is derived from software contributed to The NetBSD Foundation
8 * by Paul Kranenburg.
9 *
10 * Redistribution and use in source and binary forms, with or without
11 * modification, are permitted provided that the following conditions
12 * are met:
13 * 1. Redistributions of source code must retain the above copyright
14 * notice, this list of conditions and the following disclaimer.
15 * 2. Redistributions in binary form must reproduce the above copyright
16 * notice, this list of conditions and the following disclaimer in the
17 * documentation and/or other materials provided with the distribution.
18 * 3. All advertising materials mentioning features or use of this software
19 * must display the following acknowledgement:
20 * This product includes software developed by the NetBSD
21 * Foundation, Inc. and its contributors.
22 * 4. Neither the name of The NetBSD Foundation nor the names of its
23 * contributors may be used to endorse or promote products derived
24 * from this software without specific prior written permission.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
27 * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
28 * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
29 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
30 * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39/*-
40 * Copyright (c) 1992, University of Vermont and State Agricultural College.
41 * Copyright (c) 1992, Garrett A. Wollman.
42 * All rights reserved.
43 *
44 * Redistribution and use in source and binary forms, with or without
45 * modification, are permitted provided that the following conditions
46 * are met:
47 * 1. Redistributions of source code must retain the above copyright
48 * notice, this list of conditions and the following disclaimer.
49 * 2. Redistributions in binary form must reproduce the above copyright
50 * notice, this list of conditions and the following disclaimer in the
51 * documentation and/or other materials provided with the distribution.
52 * 3. All advertising materials mentioning features or use of this software
53 * must display the following acknowledgement:
54 * This product includes software developed by the University of
55 * Vermont and State Agricultural College and Garrett A. Wollman.
56 * 4. Neither the name of the University nor the name of the author
57 * may be used to endorse or promote products derived from this software
58 * without specific prior written permission.
59 *
60 * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
61 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
62 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
63 * ARE DISCLAIMED. IN NO EVENT SHALL THE UNIVERSITY OR AUTHOR BE LIABLE
64 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
65 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
66 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
67 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
68 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
69 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
70 * SUCH DAMAGE.
71 */
72
73/*
74 * Intel 82586 Ethernet chip
75 * Register, bit, and structure definitions.
76 *
77 * Written by GAW with reference to the Clarkson Packet Driver code for this
78 * chip written by Russ Nelson and others.
79 */
80
81/*
82 * NOTE, the structure definitions in here are for reference only.
83 * We use integer offsets exclusively to access the i82586 data structures.
84 */
85
86
87#if 0
88/*
89 * This is the master configuration block.
90 * It tells the hardware where all the rest of the stuff is.
91 */
92struct __ie_sys_conf_ptr {
93 u_int16_t mbz; /* must be zero */
94 u_int8_t ie_bus_use; /* true if 8-bit only */
95 u_int8_t mbz2[5]; /* must be zero */
96 u_int32_t ie_iscp_ptr; /* 24-bit physaddr of ISCP */
97};
98#endif
99#define IE_SCP_SZ 12
100#define IE_SCP_BUS_USE(base) ((base) + 2)
101#define IE_SCP_ISCP(base) ((base) + 8)
102
103/*
104 * Note that this is wired in hardware; the SCP is always located here, no
105 * matter what.
106 */
107#define IE_SCP_ADDR 0xfffff4
108
109#if 0
110/*
111 * The tells the hardware where all the rest of the stuff is, too.
112 * FIXME: some of these should be re-commented after we figure out their
113 * REAL function.
114 */
115struct __ie_int_sys_conf_ptr {
116 u_int8_t ie_busy; // zeroed after init
117 u_int8_t mbz;
118 u_int16_t ie_scb_offset; // 16-bit physaddr of next struct
119 caddr_t ie_base; // 24-bit physaddr for all 16-bit vars
120};
121#endif
122#define IE_ISCP_SZ 8
123#define IE_ISCP_BUSY(base) ((base) + 0)
124#define IE_ISCP_SCB(base) ((base) + 2)
125#define IE_ISCP_BASE(base) ((base) + 4)
126
127#if 0
128/*
129 * This FINALLY tells the hardware what to do and where to put it.
130 */
131struct __ie_sys_ctl_block {
132 u_int16_t ie_status; // status word
133 u_int16_t ie_command; // command word
134 u_int16_t ie_command_list; // 16-pointer to command block list
135 u_int16_t ie_recv_list; // 16-pointer to receive frame list
136 u_int16_t ie_err_crc; // CRC errors
137 u_int16_t ie_err_align; // Alignment errors
138 u_int16_t ie_err_resource; // Resource errors
139 u_int16_t ie_err_overrun; // Overrun errors
140};
141#endif
142#define IE_SCB_SZ 16
143#define IE_SCB_STATUS(base) ((base) + 0)
144#define IE_SCB_CMD(base) ((base) + 2)
145#define IE_SCB_CMDLST(base) ((base) + 4)
146#define IE_SCB_RCVLST(base) ((base) + 6)
147#define IE_SCB_ERRCRC(base) ((base) + 8)
148#define IE_SCB_ERRALN(base) ((base) + 10)
149#define IE_SCB_ERRRES(base) ((base) + 12)
150#define IE_SCB_ERROVR(base) ((base) + 14)
151
152/* Command values */
153#define IE_RUC_MASK 0x0070 /* mask for RU command */
154#define IE_RUC_NOP 0 /* for completeness */
155#define IE_RUC_START 0x0010 /* start receive unit command */
156#define IE_RUC_RESUME 0x0020 /* resume a suspended receiver command */
157#define IE_RUC_SUSPEND 0x0030 /* suspend receiver command */
158#define IE_RUC_ABORT 0x0040 /* abort current receive operation */
159
160#define IE_CUC_MASK 0x0700 /* mask for CU command */
161#define IE_CUC_NOP 0 /* included for completeness */
162#define IE_CUC_START 0x0100 /* do-command command */
163#define IE_CUC_RESUME 0x0200 /* resume a suspended cmd list */
164#define IE_CUC_SUSPEND 0x0300 /* suspend current command */
165#define IE_CUC_ABORT 0x0400 /* abort current command */
166
167#define IE_ACK_COMMAND 0xf000 /* mask for ACK command */
168#define IE_ACK_CX 0x8000 /* ack IE_ST_CX */
169#define IE_ACK_FR 0x4000 /* ack IE_ST_FR */
170#define IE_ACK_CNA 0x2000 /* ack IE_ST_CNA */
171#define IE_ACK_RNR 0x1000 /* ack IE_ST_RNR */
172
173#define IE_ACTION_COMMAND(x) (((x) & IE_CUC_MASK) == IE_CUC_START)
174 /* is this command an action command? */
175
176/* Status values */
177#define IE_ST_WHENCE 0xf000 /* mask for cause of interrupt */
178#define IE_ST_CX 0x8000 /* command with I bit completed */
179#define IE_ST_FR 0x4000 /* frame received */
180#define IE_ST_CNA 0x2000 /* all commands completed */
181#define IE_ST_RNR 0x1000 /* receive not ready */
182
183#define IE_CUS_MASK 0x0700 /* mask for command unit status */
184#define IE_CUS_ACTIVE 0x0200 /* command unit is active */
185#define IE_CUS_SUSPEND 0x0100 /* command unit is suspended */
186
187#define IE_RUS_MASK 0x0070 /* mask for receiver unit status */
188#define IE_RUS_SUSPEND 0x0010 /* receiver is suspended */
189#define IE_RUS_NOSPACE 0x0020 /* receiver has no resources */
190#define IE_RUS_READY 0x0040 /* receiver is ready */
191
192#if 0
193/*
194 * This is filled in partially by the chip, partially by us.
195 */
196struct __ie_recv_frame_desc {
197 u_int16_t ie_fd_status; // status for this frame
198 u_int16_t ie_fd_last; // end of frame list flag
199 u_int16_t ie_fd_next; // 16-pointer to next RFD
200 u_int16_t ie_fd_buf_desc; // 16-pointer to list of buffer descs
201 struct __ie_en_addr dest; // destination ether
202 struct __ie_en_addr src; // source ether
203 u_int16_t ie_length; // 802 length/Ether type
204 u_short mbz; // must be zero
205};
206#endif
207#define IE_RFRAME_SZ 24
208#define IE_RFRAME_ADDR(base,i) ((base) + (i) * IE_RFRAME_SZ)
209#define IE_RFRAME_STATUS(b,i) (IE_RFRAME_ADDR(b,i) + 0)
210#define IE_RFRAME_LAST(b,i) (IE_RFRAME_ADDR(b,i) + 2)
211#define IE_RFRAME_NEXT(b,i) (IE_RFRAME_ADDR(b,i) + 4)
212#define IE_RFRAME_BUFDESC(b,i) (IE_RFRAME_ADDR(b,i) + 6)
213#define IE_RFRAME_EDST(b,i) (IE_RFRAME_ADDR(b,i) + 8)
214#define IE_RFRAME_ESRC(b,i) (IE_RFRAME_ADDR(b,i) + 14)
215#define IE_RFRAME_ELEN(b,i) (IE_RFRAME_ADDR(b,i) + 20)
216
217/* "last" bits */
218#define IE_FD_EOL 0x8000 /* last rfd in list */
219#define IE_FD_SUSP 0x4000 /* suspend RU after receipt */
220
221/* status field bits */
222#define IE_FD_COMPLETE 0x8000 /* frame is complete */
223#define IE_FD_BUSY 0x4000 /* frame is busy */
224#define IE_FD_OK 0x2000 /* frame is ok */
225#define IE_FD_CRC 0x0800 /* CRC error */
226#define IE_FD_ALGN 0x0400 /* Alignment error */
227#define IE_FD_RNR 0x0200 /* receiver out of resources here */
228#define IE_FD_OVR 0x0100 /* DMA overrun */
229#define IE_FD_SHORT 0x0080 /* Short frame */
230#define IE_FD_NOEOF 0x0040 /* no EOF (?) */
231#define IE_FD_ERRMASK /* all error bits */ \
232 (IE_FD_CRC|IE_FD_ALGN|IE_FD_RNR|IE_FD_OVR|IE_FD_SHORT|IE_FD_NOEOF)
233#define IE_FD_STATUSBITS \
234 "\20\20COMPLT\17BUSY\16OK\14CRC\13ALGN\12RNR\11OVR\10SHORT\7NOEOF"
235
236#if 0
237/*
238 * linked list of buffers...
239 */
240struct __ie_recv_buf_desc {
241 u_int16_t ie_rbd_status; // status for this buffer
242 u_int16_t ie_rbd_next; // 16-pointer to next RBD
243 caddr_t ie_rbd_buffer; // 24-pointer to buffer for this RBD
244 u_int16_t ie_rbd_length; // length of the buffer
245 u_int16_t mbz; // must be zero
246};
247#endif
248#define IE_RBD_SZ 12
249#define IE_RBD_ADDR(base,i) ((base) + (i) * IE_RBD_SZ)
250#define IE_RBD_STATUS(b,i) (IE_RBD_ADDR(b,i) + 0)
251#define IE_RBD_NEXT(b,i) (IE_RBD_ADDR(b,i) + 2)
252#define IE_RBD_BUFADDR(b,i) (IE_RBD_ADDR(b,i) + 4)
253#define IE_RBD_BUFLEN(b,i) (IE_RBD_ADDR(b,i) + 8)
254
255/* RBD status fields */
256#define IE_RBD_LAST 0x8000 /* last buffer */
257#define IE_RBD_USED 0x4000 /* this buffer has data */
258#define IE_RBD_CNTMASK 0x3fff /* byte count of buffer data */
259
260/* RDB `End Of List' flag; encoded in `buffer length' field */
261#define IE_RBD_EOL 0x8000 /* last buffer */
262
263
264#if 0
265/*
266 * All commands share this in common.
267 */
268struct __ie_cmd_common {
269 u_int16_t ie_cmd_status; // status of this command
270 u_int16_t ie_cmd_cmd; // command word
271 u_int16_t ie_cmd_link; // link to next command
272};
273#endif
274#define IE_CMD_COMMON_SZ 6
275#define IE_CMD_COMMON_STATUS(base) ((base) + 0)
276#define IE_CMD_COMMON_CMD(base) ((base) + 2)
277#define IE_CMD_COMMON_LINK(base) ((base) + 4)
278
279#define IE_STAT_COMPL 0x8000 /* command is completed */
280#define IE_STAT_BUSY 0x4000 /* command is running now */
281#define IE_STAT_OK 0x2000 /* command completed successfully */
282#define IE_STAT_ABORT 0x1000 /* command was aborted */
283
284#define IE_CMD_NOP 0x0000 /* NOP */
285#define IE_CMD_IASETUP 0x0001 /* initial address setup */
286#define IE_CMD_CONFIG 0x0002 /* configure command */
287#define IE_CMD_MCAST 0x0003 /* multicast setup command */
288#define IE_CMD_XMIT 0x0004 /* transmit command */
289#define IE_CMD_TDR 0x0005 /* time-domain reflectometer command */
290#define IE_CMD_DUMP 0x0006 /* dump command */
291#define IE_CMD_DIAGNOSE 0x0007 /* diagnostics command */
292
293#define IE_CMD_LAST 0x8000 /* this is the last command in the list */
294#define IE_CMD_SUSPEND 0x4000 /* suspend CU after this command */
295#define IE_CMD_INTR 0x2000 /* post an interrupt after completion */
296
297/*
298 * No-op commands; just like COMMON but "indexable"
299 */
300#define IE_CMD_NOP_SZ IE_CMD_COMMON_SZ
301#define IE_CMD_NOP_ADDR(base,i) ((base) + (i) * IE_CMD_NOP_SZ)
302#define IE_CMD_NOP_STATUS(b,i) (IE_CMD_NOP_ADDR(b,i) + 0)
303#define IE_CMD_NOP_CMD(b,i) (IE_CMD_NOP_ADDR(b,i) + 2)
304#define IE_CMD_NOP_LINK(b,i) (IE_CMD_NOP_ADDR(b,i) + 4)
305
306
307#if 0
308/*
309 * This is the command to transmit a frame.
310 */
311struct __ie_xmit_cmd {
312 struct __ie_cmd_common com; // common part
313#define __ie_xmit_status com.ie_cmd_status
314
315 u_int16_t ie_xmit_desc; // pointer to buffer descriptor
316 struct __ie_en_addr ie_xmit_addr; // destination address
317 u_int16_t ie_xmit_length; // 802.3 length/Ether type field
318};
319#endif
320#define IE_CMD_XMIT_SZ (IE_CMD_COMMON_SZ + 10)
321#define IE_CMD_XMIT_ADDR(base,i) ((base) + (i) * IE_CMD_XMIT_SZ)
322#define IE_CMD_XMIT_STATUS(b,i) \
323 (IE_CMD_XMIT_ADDR(b,i) + 0) /* == CMD_COMMON_STATUS */
324#define IE_CMD_XMIT_CMD(b,i) \
325 (IE_CMD_XMIT_ADDR(b,i) + 2) /* == CMD_COMMON_CMD */
326#define IE_CMD_XMIT_LINK(b,i) \
327 (IE_CMD_XMIT_ADDR(b,i) + 4) /* == CMD_COMMON_LINK */
328#define IE_CMD_XMIT_DESC(b,i) \
329 (IE_CMD_XMIT_ADDR(b,i) + IE_CMD_COMMON_SZ + 0)
330#define IE_CMD_XMIT_EADDR(b,i) \
331 (IE_CMD_XMIT_ADDR(b,i) + IE_CMD_COMMON_SZ + 2)
332#define IE_CMD_XMIT_LEN(b,i) \
333 (IE_CMD_XMIT_ADDR(b,i) + IE_CMD_COMMON_SZ + 8)
334
335#define IE_XS_MAXCOLL 0x000f /* number of collisions during transmit */
336#define IE_XS_EXCMAX 0x0020 /* exceeded maximum number of collisions */
337#define IE_XS_SQE 0x0040 /* SQE positive */
338#define IE_XS_DEFERRED 0x0080 /* transmission deferred */
339#define IE_XS_UNDERRUN 0x0100 /* DMA underrun */
340#define IE_XS_LOSTCTS 0x0200 /* Lost CTS */
341#define IE_XS_NOCARRIER 0x0400 /* No Carrier */
342#define IE_XS_LATECOLL 0x0800 /* Late collision */
343
344#if 0
345/*
346 * This is a buffer descriptor for a frame to be transmitted.
347 */
348struct __ie_xmit_buf {
349 u_int16_t ie_xmit_flags; // see below
350 u_int16_t ie_xmit_next; // 16-pointer to next desc
351 caddr_t ie_xmit_buf; // 24-pointer to the actual buffer
352};
353#endif
354#define IE_XBD_SZ 8
355#define IE_XBD_ADDR(base,i) ((base) + (i) * IE_XBD_SZ)
356#define IE_XBD_FLAGS(b,i) (IE_XBD_ADDR(b,i) + 0)
357#define IE_XBD_NEXT(b,i) (IE_XBD_ADDR(b,i) + 2)
358#define IE_XBD_BUF(b,i) (IE_XBD_ADDR(b,i) + 4)
359
360#define IE_TBD_EOL 0x8000 /* this TBD is the last one */
361#define IE_TBD_CNTMASK 0x3fff /* The rest of the `flags' word
362 is actually the length. */
363
364
365#if 0
366/*
367 * Multicast setup command.
368 */
369struct __ie_mcast_cmd {
370 struct __ie_cmd_common com; // common part
371#define ie_mcast_status com.ie_cmd_status
372
373 // size (in bytes) of multicast addresses
374 u_short ie_mcast_bytes;
375 struct __ie_en_addr ie_mcast_addrs[IE_MAXMCAST + 1];// space for them
376};
377#endif
378#define IE_CMD_MCAST_SZ (IE_CMD_COMMON_SZ + 2 /* + XXX */)
379#define IE_CMD_MCAST_BYTES(base) ((base) + IE_CMD_COMMON_SZ + 0)
380#define IE_CMD_MCAST_MADDR(base) ((base) + IE_CMD_COMMON_SZ + 2)
381
382#if 0
383/*
384 * Time Domain Reflectometer command.
385 */
386struct __ie_tdr_cmd {
387 struct __ie_cmd_common com; // common part
388#define ie_tdr_status com.ie_cmd_status
389 u_short ie_tdr_time; // error bits and time
390};
391#endif
392#define IE_CMD_TDR_SZ (IE_CMD_COMMON_SZ + 2)
393#define IE_CMD_TDR_TIME(base) ((base) + IE_CMD_COMMON_SZ + 0)
394
395#define IE_TDR_SUCCESS 0x8000 /* TDR succeeded without error */
396#define IE_TDR_XCVR 0x4000 /* detected a transceiver problem */
397#define IE_TDR_OPEN 0x2000 /* detected an incorrect termination ("open") */
398#define IE_TDR_SHORT 0x1000 /* TDR detected a short circuit */
399#define IE_TDR_TIME 0x07ff /* mask for reflection time */
400
401#if 0
402/*
403 * Initial Address Setup command
404 */
405struct __ie_iasetup_cmd {
406 struct __ie_cmd_common com;
407#define ie_iasetup_status com.ie_cmd_status
408 struct __ie_en_addr ie_address;
409};
410#endif
411#define IE_CMD_IAS_SZ (IE_CMD_COMMON_SZ + 6)
412#define IE_CMD_IAS_EADDR(base) ((base) + IE_CMD_COMMON_SZ + 0)
413
414#if 0
415/*
416 * Configuration command
417 */
418struct __ie_config_cmd {
419 struct __ie_cmd_common com; // common part
420#define ie_config_status com.ie_cmd_status
421
422 u_int8_t ie_config_count; // byte count (0x0c)
423 u_int8_t ie_fifo; // fifo (8)
424 u_int8_t ie_save_bad; // save bad frames (0x40)
425 u_int8_t ie_addr_len; // address length (0x2e) (AL-LOC == 1)
426 u_int8_t ie_priority; // priority and backoff (0x0)
427 u_int8_t ie_ifs; // inter-frame spacing (0x60)
428 u_int8_t ie_slot_low; // slot time, LSB (0x0)
429 u_int8_t ie_slot_high; // slot time, MSN, and retries (0xf2)
430 u_int8_t ie_promisc; // 1 if promiscuous, else 0
431 u_int8_t ie_crs_cdt; // CSMA/CD parameters (0x0)
432 u_int8_t ie_min_len; // min frame length (0x40)
433 u_int8_t ie_junk; // stuff for 82596 (0xff)
434};
435#endif
436#define IE_CMD_CFG_SZ (IE_CMD_COMMON_SZ + 12)
437#define IE_CMD_CFG_CNT(base) ((base) + IE_CMD_COMMON_SZ + 0)
438#define IE_CMD_CFG_FIFO(base) ((base) + IE_CMD_COMMON_SZ + 1)
439#define IE_CMD_CFG_SAVEBAD(base) ((base) + IE_CMD_COMMON_SZ + 2)
440#define IE_CMD_CFG_ADDRLEN(base) ((base) + IE_CMD_COMMON_SZ + 3)
441#define IE_CMD_CFG_PRIORITY(base) ((base) + IE_CMD_COMMON_SZ + 4)
442#define IE_CMD_CFG_IFS(base) ((base) + IE_CMD_COMMON_SZ + 5)
443#define IE_CMD_CFG_SLOT_LOW(base) ((base) + IE_CMD_COMMON_SZ + 6)
444#define IE_CMD_CFG_SLOT_HIGH(base) ((base) + IE_CMD_COMMON_SZ + 7)
445#define IE_CMD_CFG_PROMISC(base) ((base) + IE_CMD_COMMON_SZ + 8)
446#define IE_CMD_CFG_CRSCDT(base) ((base) + IE_CMD_COMMON_SZ + 9)
447#define IE_CMD_CFG_MINLEN(base) ((base) + IE_CMD_COMMON_SZ + 10)
448#define IE_CMD_CFG_JUNK(base) ((base) + IE_CMD_COMMON_SZ + 11)
