RTEMS 5.2
Header file for timer functions. More...
| rtems_status_code | mpc83xx_gtm_initialize (int timer, int clock) |
| rtems_status_code | mpc83xx_gtm_enable_restart (int timer, bool enable) |
| rtems_status_code | mpc83xx_gtm_set_clock (int timer, int clock) |
| rtems_status_code | mpc83xx_gtm_get_clock (int timer, int *clock) |
| rtems_status_code | mpc83xx_gtm_start (int timer) |
| rtems_status_code | mpc83xx_gtm_stop (int timer) |
| rtems_status_code | mpc83xx_gtm_set_value (int timer, uint16_t value) |
| rtems_status_code | mpc83xx_gtm_get_value (int timer, uint16_t *value) |
| rtems_status_code | mpc83xx_gtm_set_reference (int timer, uint16_t reference) |
| rtems_status_code | mpc83xx_gtm_get_reference (int timer, uint16_t *reference) |
| rtems_status_code | mpc83xx_gtm_set_prescale (int timer, uint8_t prescale) |
| rtems_status_code | mpc83xx_gtm_get_prescale (int timer, uint8_t *prescale) |
| rtems_status_code | mpc83xx_gtm_interrupt_get_vector (int timer, rtems_vector_number *vector) |
| rtems_status_code | mpc83xx_gtm_interrupt_enable (int timer) |
| rtems_status_code | mpc83xx_gtm_interrupt_disable (int timer) |
| rtems_status_code | mpc83xx_gtm_interrupt_clear (int timer) |
