RTEMS 5.2
gtethreg.h
1/* $NetBSD: gtethreg.h,v 1.2.10.1 2005/04/29 11:28:55 kent Exp $ */
2
3/*
4 * Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
5 * All rights reserved.
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 * 3. All advertising materials mentioning features or use of this software
16 * must display the following acknowledgement:
17 * This product includes software developed for the NetBSD Project by
18 * Allegro Networks, Inc., and Wasabi Systems, Inc.
19 * 4. The name of Allegro Networks, Inc. may not be used to endorse
20 * or promote products derived from this software without specific prior
21 * written permission.
22 * 5. The name of Wasabi Systems, Inc. may not be used to endorse
23 * or promote products derived from this software without specific prior
24 * written permission.
25 *
26 * THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
27 * WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
28 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
29 * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
30 * IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
31 * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _DEV_GTETHREG_H_
41#define _DEV_GTETHREG_H_
42
43#define ETH__BIT(bit) (1U << (bit))
44#define ETH__LLBIT(bit) (1LLU << (bit))
45#define ETH__MASK(bit) (ETH__BIT(bit) - 1)
46#define ETH__LLMASK(bit) (ETH__LLBIT(bit) - 1)
47#define ETH__GEN(n, off) (0x2400+((n) << 10)+(ETH__ ## off))
48#define ETH__EXT(data, bit, len) (((data) >> (bit)) & ETH__MASK(len))
49#define ETH__LLEXT(data, bit, len) (((data) >> (bit)) & ETH__LLMASK(len))
50#define ETH__CLR(data, bit, len) ((data) &= ~(ETH__MASK(len) << (bit)))
51#define ETH__INS(new, bit) ((new) << (bit))
52#define ETH__LLINS(new, bit) ((uint64_t)(new) << (bit))
53
54/*
55 * Descriptors used for both receive & transmit data. Note that the descriptor
56 * must start on a 4LW boundary. Since the GT accesses the descriptor as
57 * two 64-bit quantities, we must present them 32bit quantities in the right
58 * order based on endianess.
59 */
60
62#if defined(BYTE_ORDER) && BYTE_ORDER == BIG_ENDIAN
63 u_int32_t ed_lencnt; /* length is hi 16 bits; count (rx) is lo 16 */
64 u_int32_t ed_cmdsts; /* command (hi16)/status (lo16) bits */
65 u_int32_t ed_nxtptr; /* next descriptor (must be 4LW aligned) */
66 u_int32_t ed_bufptr; /* pointer to packet buffer */
67#endif
68#if defined(BYTE_ORDER) && BYTE_ORDER == LITTLE_ENDIAN
69 u_int32_t ed_cmdsts; /* command (hi16)/status (lo16) bits */
70 u_int32_t ed_lencnt; /* length is hi 16 bits; count (rx) is lo 16 */
71 u_int32_t ed_bufptr; /* pointer to packet buffer */
72 u_int32_t ed_nxtptr; /* next descriptor (must be 4LW aligned) */
73#endif
74};
75
76/* Table 578: Ethernet TX Descriptor - Command/Status word
77 * All bits except F, EI, AM, O are only valid if TX_CMD_L is also set,
78 * otherwise should be 0 (tx).
79 */
80#define TX_STS_LC ETH__BIT(5) /* Late Collision */
81#define TX_STS_UR ETH__BIT(6) /* Underrun error */
82#define TX_STS_RL ETH__BIT(8) /* Retransmit Limit (excession coll) */
83#define TX_STS_COL ETH__BIT(9) /* Collision Occurred */
84#define TX_STS_RC(v) ETH__GETBITS(v, 10, 4) /* Retransmit Count */
85#define TX_STS_ES ETH__BIT(15) /* Error Summary (LC|UR|RL) */
86#define TX_CMD_L ETH__BIT(16) /* Last - End Of Packet */
87#define TX_CMD_F ETH__BIT(17) /* First - Start Of Packet */
88#define TX_CMD_P ETH__BIT(18) /* Pad Packet */
89#define TX_CMD_GC ETH__BIT(22) /* Generate CRC */
90#define TX_CMD_EI ETH__BIT(23) /* Enable Interrupt */
91#define TX_CMD_AM ETH__BIT(30) /* Auto Mode */
92#define TX_CMD_O ETH__BIT(31) /* Ownership (1=GT 0=CPU) */
93
94#define TX_CMD_FIRST (TX_CMD_F|TX_CMD_O)
95#define TX_CMD_LAST (TX_CMD_L|TX_CMD_GC|TX_CMD_P|TX_CMD_O)
96
97/* Table 582: Ethernet RX Descriptor - Command/Status Word
98 * All bits except F, EI, AM, O are only valid if RX_CMD_L is also set,
99 * otherwise should be ignored (rx).
100 */
101#define RX_STS_CE ETH__BIT(0) /* CRC Error */
102#define RX_STS_COL ETH__BIT(1) /* Collision sensed during reception */
103#define RX_STS_LC ETH__BIT(5) /* Late Collision (Reserved) */
104#define RX_STS_OR ETH__BIT(6) /* Overrun Error */
105#define RX_STS_MFL ETH__BIT(7) /* Max Frame Len Error */
106#define RX_STS_SF ETH__BIT(8) /* Short Frame Error (< 64 bytes) */
107#define RX_STS_FT ETH__BIT(11) /* Frame Type (1 = 802.3) */
108#define RX_STS_M ETH__BIT(12) /* Missed Frame */
109#define RX_STS_HE ETH__BIT(13) /* Hash Expired (manual match) */
110#define RX_STS_IGMP ETH__BIT(14) /* IGMP Packet */
111#define RX_STS_ES ETH__BIT(15) /* Error Summary (CE|COL|LC|OR|MFL|SF) */
112#define RX_CMD_L ETH__BIT(16) /* Last - End Of Packet */
113#define RX_CMD_F ETH__BIT(17) /* First - Start Of Packet */
114#define RX_CMD_EI ETH__BIT(23) /* Enable Interrupt */
115#define RX_CMD_AM ETH__BIT(30) /* Auto Mode */
116#define RX_CMD_O ETH__BIT(31) /* Ownership (1=GT 0=CPU) */
117
118/* Table 586: Hash Table Entry Fields
119 */
120#define HSH_V ETH__LLBIT(0) /* Entry is valid */
121#define HSH_S ETH__LLBIT(1) /* Skip this entry */
122#define HSH_RD ETH__LLBIT(2) /* Receive(1) / Discard (0) */
123#define HSH_R ETH__LLBIT(2) /* Receive(1) */
124#define HSH_PRIO_GET(v) ETH__LLEXT(v, 51, 2)
125#define HSH_PRIO_INS(v) ETH__LLINS(v, 51)
126#define HSH_ADDR_MASK 0x7fffff8LLU
127#define HSH_LIMIT 12
128
129
130#define ETH_EPAR 0x2000 /* PHY Address Register */
131#define ETH_ESMIR 0x2010 /* SMI Register */
132
133#define ETH_BASE_ETH0 0x2400 /* Ethernet0 Register Base */
134#define ETH_BASE_ETH1 0x2800 /* Ethernet1 Register Base */
135#define ETH_BASE_ETH2 0x2c00 /* Ethernet2 Register Base */
136#define ETH_SIZE 0x0400 /* Register Space */
137
138#define ETH__EBASE 0x0000 /* Base of Registers */
139#define ETH__EPCR 0x0000 /* Port Config. Register */
140#define ETH__EPCXR 0x0008 /* Port Config. Extend Reg */
141#define ETH__EPCMR 0x0010 /* Port Command Register */
142#define ETH__EPSR 0x0018 /* Port Status Register */
143#define ETH__ESPR 0x0020 /* Port Serial Parameters Reg */
144#define ETH__EHTPR 0x0028 /* Port Hash Table Pointer Reg*/
145#define ETH__EFCSAL 0x0030 /* Flow Control Src Addr Low */
146#define ETH__EFCSAH 0x0038 /* Flow Control Src Addr High */
147#define ETH__ESDCR 0x0040 /* SDMA Configuration Reg */
148#define ETH__ESDCMR 0x0048 /* SDMA Command Register */
149#define ETH__EICR 0x0050 /* Interrupt Cause Register */
150#define ETH__EIMR 0x0058 /* Interrupt Mask Register */
151#define ETH__EFRDP0 0x0080 /* First Rx Desc Pointer 0 */
152#define ETH__EFRDP1 0x0084 /* First Rx Desc Pointer 1 */
153#define ETH__EFRDP2 0x0088 /* First Rx Desc Pointer 2 */
154#define ETH__EFRDP3 0x008c /* First Rx Desc Pointer 3 */
155#define ETH__ECRDP0 0x00a0 /* Current Rx Desc Pointer 0 */
156#define ETH__ECRDP1 0x00a4 /* Current Rx Desc Pointer 1 */
157#define ETH__ECRDP2 0x00a8 /* Current Rx Desc Pointer 2 */
158#define ETH__ECRDP3 0x00ac /* Current Rx Desc Pointer 3 */
159#define ETH__ECTDP0 0x00e0 /* Current Tx Desc Pointer 0 */
160#define ETH__ECTDP1 0x00e4 /* Current Tx Desc Pointer 1 */
161#define ETH__EDSCP2P0L 0x0060 /* IP Differentiated Services
162 CodePoint to Priority0 low */
163#define ETH__EDSCP2P0H 0x0064 /* IP Differentiated Services
164 CodePoint to Priority0 high*/
165#define ETH__EDSCP2P1L 0x0068 /* IP Differentiated Services
166 CodePoint to Priority1 low */
167#define ETH__EDSCP2P1H 0x006c /* IP Differentiated Services
168 CodePoint to Priority1 high*/
169#define ETH__EVPT2P 0x0068 /* VLAN Prio. Tag to Priority */
170#define ETH__EMIBCTRS 0x0100 /* MIB Counters */
171
172#define ETH_BASE(n) ETH__GEN(n, EBASE)
173#define ETH_EPCR(n) ETH__GEN(n, EPCR) /* Port Config. Register */
174#define ETH_EPCXR(n) ETH__GEN(n, EPCXR) /* Port Config. Extend Reg */
175#define ETH_EPCMR(n) ETH__GEN(n, EPCMR) /* Port Command Register */
176#define ETH_EPSR(n) ETH__GEN(n, EPSR) /* Port Status Register */
177#define ETH_ESPR(n) ETH__GEN(n, ESPR) /* Port Serial Parameters Reg */
178#define ETH_EHTPR(n) ETH__GEN(n, EHPTR) /* Port Hash Table Pointer Reg*/
179#define ETH_EFCSAL(n) ETH__GEN(n, EFCSAL) /* Flow Control Src Addr Low */
180#define ETH_EFCSAH(n) ETH__GEN(n, EFCSAH) /* Flow Control Src Addr High */
181#define ETH_ESDCR(n) ETH__GEN(n, ESDCR) /* SDMA Configuration Reg */
182#define ETH_ESDCMR(n) ETH__GEN(n, ESDCMR) /* SDMA Command Register */
183#define ETH_EICR(n) ETH__GEN(n, EICR) /* Interrupt Cause Register */
184#define ETH_EIMR(n) ETH__GEN(n, EIMR) /* Interrupt Mask Register */
185#define ETH_EFRDP0(n) ETH__GEN(n, EFRDP0) /* First Rx Desc Pointer 0 */
186#define ETH_EFRDP1(n) ETH__GEN(n, EFRDP1) /* First Rx Desc Pointer 1 */
187#define ETH_EFRDP2(n) ETH__GEN(n, EFRDP2) /* First Rx Desc Pointer 2 */
188#define ETH_EFRDP3(n) ETH__GEN(n, EFRDP3) /* First Rx Desc Pointer 3 */
189#define ETH_ECRDP0(n) ETH__GEN(n, ECRDP0) /* Current Rx Desc Pointer 0 */
190#define ETH_ECRDP1(n) ETH__GEN(n, ECRDP1) /* Current Rx Desc Pointer 1 */
191#define ETH_ECRDP2(n) ETH__GEN(n, ECRDP2) /* Current Rx Desc Pointer 2 */
192#define ETH_ECRDP3(n) ETH__GEN(n, ECRDP3) /* Current Rx Desc Pointer 3 */
193#define ETH_ECTDP0(n) ETH__GEN(n, ECTDP0) /* Current Tx Desc Pointer 0 */
194#define ETH_ECTDP1(n) ETH__GEN(n, ECTDP1) /* Current Tx Desc Pointer 1 */
195#define ETH_EDSCP2P0L(n) ETH__GEN(n, EDSCP2P0L) /* IP Differentiated Services
196 CodePoint to Priority0 low */
197#define ETH_EDSCP2P0H(n) ETH__GEN(n, EDSCP2P0H) /* IP Differentiated Services
198 CodePoint to Priority0 high*/
199#define ETH_EDSCP2P1L(n) ETH__GEN(n, EDSCP2P1L) /* IP Differentiated Services
200 CodePoint to Priority1 low */
201#define ETH_EDSCP2P1H(n) ETH__GEN(n, EDSCP1P1H) /* IP Differentiated Services
202 CodePoint to Priority1 high*/
203#define ETH_EVPT2P(n) ETH__GEN(n, EVPT2P) /* VLAN Prio. Tag to Priority */
204#define ETH_EMIBCTRS(n) ETH__GEN(n, EMIBCTRS) /* MIB Counters */
205
206#define ETH_EPAR_PhyAD_GET(v, n) (((v) >> ((n) * 5)) & 0x1f)
207
208#define ETH_ESMIR_READ(phy, reg) (ETH__INS(phy, 16)|\
209 ETH__INS(reg, 21)|\
210 ETH_ESMIR_ReadOpcode)
211#define ETH_ESMIR_WRITE(phy, reg, val) (ETH__INS(phy, 16)|\
212 ETH__INS(reg, 21)|\
213 ETH__INS(val, 0)|\
214 ETH_ESMIR_WriteOpcode)
215#define ETH_ESMIR_Value_GET(v) ETH__EXT(v, 0, 16)
216#define ETH_ESMIR_WriteOpcode 0
217#define ETH_ESMIR_ReadOpcode ETH__BIT(26)
218#define ETH_ESMIR_ReadValid ETH__BIT(27)
219#define ETH_ESMIR_Busy ETH__BIT(28)
220
221/*
222 * Table 597: Port Configuration Register (PCR)
223 * 00:00 PM Promiscuous mode
224 * 0: Normal mode (Frames are only received if the
225 * destination address is found in the hash
226 * table)
227 * 1: Promiscuous mode (Frames are received
228 * regardless of their destination address.
229 * Errored frames are discarded unless the Port
230 * Configuration register's PBF bit is set)
231 * 01:01 RBM Reject Broadcast Mode
232 * 0: Receive broadcast address
233 * 1: Reject frames with broadcast address
234 * Overridden by the promiscuous mode.
235 * 02:02 PBF Pass Bad Frames
236 * (0: Normal mode, 1: Pass bad Frames)
237 * The Ethernet receiver passes to the CPU errored
238 * frames (like fragments and collided packets)
239 * that are normally rejected.
240 * NOTE: Frames are only passed if they
241 * successfully pass address filtering.
242 * 06:03 Reserved
243 * 07:07 EN Enable (0: Disabled, 1: Enable)
244 * When enabled, the ethernet port is ready to
245 * transmit/receive.
246 * 09:08 LPBK Loop Back Mode
247 * 00: Normal mode
248 * 01: Internal loop back mode (TX data is looped
249 * back to the RX lines. No transition is seen
250 * on the interface pins)
251 * 10: External loop back mode (TX data is looped
252 * back to the RX lines and also transmitted
253 * out to the MII interface pins)
254 * 11: Reserved
255 * 10:10 FC Force Collision
256 * 0: Normal mode.
257 * 1: Force Collision on any TX frame.
258 * For RXM test (in Loopback mode).
259 * 11:11 Reserved.
260 * 12:12 HS Hash Size
261 * 0: 8K address filtering
262 * (256KB of memory space required).
263 * 1: 512 address filtering
264 * ( 16KB of memory space required).
265 * 13:13 HM Hash Mode (0: Hash Func. 0; 1: Hash Func. 1)
266 * 14:14 HDM Hash Default Mode
267 * 0: Discard addresses not found in address table
268 * 1: Pass addresses not found in address table
269 * 15:15 HD Duplex Mode (0: Half Duplex, 1: Full Duplex)
270 * NOTE: Valid only when auto-negotiation for
271 * duplex mode is disabled.
272 * 30:16 Reserved
273 * 31:31 ACCS Accelerate Slot Time
274 * (0: Normal mode, 1: Reserved)
275 */
276#define ETH_EPCR_PM ETH__BIT(0)
277#define ETH_EPCR_RBM ETH__BIT(1)
278#define ETH_EPCR_PBF ETH__BIT(2)
279#define ETH_EPCR_EN ETH__BIT(7)
280#define ETH_EPCR_LPBK_GET(v) ETH__BIT(v, 8, 2)
281#define ETH_EPCR_LPBK_Normal 0
282#define ETH_EPCR_LPBK_Internal 1
283#define ETH_EPCR_LPBK_External 2
284#define ETH_EPCR_FC ETH__BIT(10)
285
286#define ETH_EPCR_HS ETH__BIT(12)
287#define ETH_EPCR_HS_8K 0
288#define ETH_EPCR_HS_512 ETH_EPCR_HS
289
290#define ETH_EPCR_HM ETH__BIT(13)
291#define ETH_EPCR_HM_0 0
292#define ETH_EPCR_HM_1 ETH_EPCR_HM
293
294#define ETH_EPCR_HDM ETH__BIT(14)
295#define ETH_EPCR_HDM_Discard 0
296#define ETH_EPCR_HDM_Pass ETH_EPCR_HDM
297
298#define ETH_EPCR_HD_Half 0
299#define ETH_EPCR_HD_Full ETH_EPCR_HD_Full
300
301#define ETH_EPCR_ACCS ETH__BIT(31)
302
303
304
305/*
306 * Table 598: Port Configuration Extend Register (PCXR)
307 * 00:00 IGMP IGMP Packets Capture Enable
308 * 0: IGMP packets are treated as normal Multicast
309 * packets.
310 * 1: IGMP packets on IPv4/Ipv6 over Ethernet/802.3
311 * are trapped and sent to high priority RX
312 * queue.
313 * 01:01 SPAN Spanning Tree Packets Capture Enable
314 * 0: BPDU (Bridge Protocol Data Unit) packets are
315 * treated as normal Multicast packets.
316 * 1: BPDU packets are trapped and sent to high
317 * priority RX queue.
318 * 02:02 PAR Partition Enable (0: Normal, 1: Partition)
319 * When more than 61 collisions occur while
320 * transmitting, the port enters Partition mode.
321 * It waits for the first good packet from the
322 * wire and then goes back to Normal mode. Under
323 * Partition mode it continues transmitting, but
324 * it does not receive.
325 * 05:03 PRIOtx Priority weight in the round-robin between high
326 * and low priority TX queues.
327 * 000: 1 pkt from HIGH, 1 pkt from LOW.
328 * 001: 2 pkt from HIGH, 1 pkt from LOW.
329 * 010: 4 pkt from HIGH, 1 pkt from LOW.
330 * 011: 6 pkt from HIGH, 1 pkt from LOW.
331 * 100: 8 pkt from HIGH, 1 pkt from LOW.
332 * 101: 10 pkt from HIGH, 1 pkt from LOW.
333 * 110: 12 pkt from HIGH, 1 pkt from LOW.
334 * 111: All pkt from HIGH, 0 pkt from LOW. LOW is
335 * served only if HIGH is empty.
336 * NOTE: If the HIGH queue is emptied before
337 * finishing the count, the count is reset
338 * until the next first HIGH comes in.
339 * 07:06 PRIOrx Default Priority for Packets Received on this
340 * Port (00: Lowest priority, 11: Highest priority)
341 * 08:08 PRIOrx_Override Override Priority for Packets Received on this
342 * Port (0: Do not override, 1: Override with
343 * <PRIOrx> field)
344 * 09:09 DPLXen Enable Auto-negotiation for Duplex Mode
345 * (0: Enable, 1: Disable)
346 * 11:10 FCTLen Enable Auto-negotiation for 802.3x Flow-control
347 * 0: Enable; When enabled, 1 is written (through
348 * SMI access) to the PHY's register 4 bit 10
349 * to advertise flow-control capability.
350 * 1: Disable; Only enables flow control after the
351 * PHY address is set by the CPU. When changing
352 * the PHY address the flow control
353 * auto-negotiation must be disabled.
354 * 11:11 FLP Force Link Pass
355 * (0: Force Link Pass, 1: Do NOT Force Link pass)
356 * 12:12 FCTL 802.3x Flow-Control Mode (0: Enable, 1: Disable)
357 * NOTE: Only valid when auto negotiation for flow
358 * control is disabled.
359 * 13:13 Reserved
360 * 15:14 MFL Max Frame Length
361 * Maximum packet allowed for reception (including
362 * CRC): 00: 1518 bytes, 01: 1536 bytes,
363 * 10: 2048 bytes, 11: 64K bytes
364 * 16:16 MIBclrMode MIB Counters Clear Mode (0: Clear, 1: No effect)
365 * 17:17 MIBctrMode Reserved. (MBZ)
366 * 18:18 Speed Port Speed (0: 10Mbit/Sec, 1: 100Mbit/Sec)
367 * NOTE: Only valid if SpeedEn bit is set.
368 * 19:19 SpeedEn Enable Auto-negotiation for Speed
369 * (0: Enable, 1: Disable)
370 * 20:20 RMIIen RMII enable
371 * 0: Port functions as MII port
372 * 1: Port functions as RMII port
373 * 21:21 DSCPen DSCP enable
374 * 0: IP DSCP field decoding is disabled.
375 * 1: IP DSCP field decoding is enabled.
376 * 31:22 Reserved
377 */
378#define ETH_EPCXR_IGMP ETH__BIT(0)
379#define ETH_EPCXR_SPAN ETH__BIT(1)
380#define ETH_EPCXR_PAR ETH__BIT(2)
381#define ETH_EPCXR_PRIOtx_GET(v) ETH__EXT(v, 3, 3)
382#define ETH_EPCXR_PRIOrx_GET(v) ETH__EXT(v, 3, 3)
383#define ETH_EPCXR_PRIOrx_Override ETH__BIT(8)
384#define ETH_EPCXR_DLPXen ETH__BIT(9)
385#define ETH_EPCXR_FCTLen ETH__BIT(10)
386#define ETH_EPCXR_FLP ETH__BIT(11)
387#define ETH_EPCXR_FCTL ETH__BIT(12)
388#define ETH_EPCXR_MFL_GET(v) ETH__EXT(v, 14, 2)
389#define ETH_EPCXR_MFL_1518 0
390#define ETH_EPCXR_MFL_1536 1
391#define ETH_EPCXR_MFL_2084 2
392#define ETH_EPCXR_MFL_64K 3
393#define ETH_EPCXR_MIBclrMode ETH__BIT(16)
394#define ETH_EPCXR_MIBctrMode ETH__BIT(17)
395#define ETH_EPCXR_Speed ETH__BIT(18)
396#define ETH_EPCXR_SpeedEn ETH__BIT(19)
397#define ETH_EPCXR_RMIIEn ETH__BIT(20)
398#define ETH_EPCXR_DSCPEn ETH__BIT(21)
399
400
401
402/*
403 * Table 599: Port Command Register (PCMR)
404 * 14:00 Reserved
405 * 15:15 FJ Force Jam / Flow Control
406 * When in half-duplex mode, the CPU uses this bit
407 * to force collisions on the Ethernet segment.
408 * When the CPU recognizes that it is going to run
409 * out of receive buffers, it can force the
410 * transmitter to send jam frames, forcing
411 * collisions on the wire. To allow transmission
412 * on the Ethernet segment, the CPU must clear the
413 * FJ bit when more resources are available. When
414 * in full-duplex and flow-control is enabled, this
415 * bit causes the port's transmitter to send
416 * flow-control PAUSE packets. The CPU must reset
417 * this bit when more resources are available.
418 * 31:16 Reserved
419 */
420
421#define ETH_EPCMR_FJ ETH__BIT(15)
422
423
424/*
425 * Table 600: Port Status Register (PSR) -- Read Only
426 * 00:00 Speed Indicates Port Speed (0: 10Mbs, 1: 100Mbs)
427 * 01:01 Duplex Indicates Port Duplex Mode (0: Half, 1: Full)
428 * 02:02 Fctl Indicates Flow-control Mode
429 * (0: enabled, 1: disabled)
430 * 03:03 Link Indicates Link Status (0: down, 1: up)
431 * 04:04 Pause Indicates that the port is in flow-control
432 * disabled state. This bit is set when an IEEE
433 * 802.3x flow-control PAUSE (XOFF) packet is
434 * received (assuming that flow-control is
435 * enabled and the port is in full-duplex mode).
436 * Reset when XON is received, or when the XOFF
437 * timer has expired.
438 * 05:05 TxLow Tx Low Priority Status
439 * Indicates the status of the low priority
440 * transmit queue: (0: Stopped, 1: Running)
441 * 06:06 TxHigh Tx High Priority Status
442 * Indicates the status of the high priority
443 * transmit queue: (0: Stopped, 1: Running)
444 * 07:07 TXinProg TX in Progress
445 * Indicates that the port's transmitter is in an
446 * active transmission state.
447 * 31:08 Reserved
448 */
449#define ETH_EPSR_Speed ETH__BIT(0)
450#define ETH_EPSR_Duplex ETH__BIT(1)
451#define ETH_EPSR_Fctl ETH__BIT(2)
452#define ETH_EPSR_Link ETH__BIT(3)
453#define ETH_EPSR_Pause ETH__BIT(4)
454#define ETH_EPSR_TxLow ETH__BIT(5)
455#define ETH_EPSR_TxHigh ETH__BIT(6)
456#define ETH_EPSR_TXinProg ETH__BIT(7)
457
458
459/*
460 * Table 601: Serial Parameters Register (SPR)
461 * 01:00 JAM_LENGTH Two bits to determine the JAM Length
462 * (in Backpressure) as follows:
463 * 00 = 12K bit-times
464 * 01 = 24K bit-times
465 * 10 = 32K bit-times
466 * 11 = 48K bit-times
467 * 06:02 JAM_IPG Five bits to determine the JAM IPG.
468 * The step is four bit-times. The value may vary
469 * between 4 bit time to 124.
470 * 11:07 IPG_JAM_TO_DATA Five bits to determine the IPG JAM to DATA.
471 * The step is four bit-times. The value may vary
472 * between 4 bit time to 124.
473 * 16:12 IPG_DATA Inter-Packet Gap (IPG)
474 * The step is four bit-times. The value may vary
475 * between 12 bit time to 124.
476 * NOTE: These bits may be changed only when the
477 * Ethernet ports is disabled.
478 * 21:17 Data_Blind Data Blinder
479 * The number of nibbles from the beginning of the
480 * IPG, in which the IPG counter is restarted when
481 * detecting a carrier activity. Following this
482 * value, the port enters the Data Blinder zone and
483 * does not reset the IPG counter. This ensures
484 * fair access to the medium.
485 * The default is 10 hex (64 bit times - 2/3 of the
486 * default IPG). The step is 4 bit-times. Valid
487 * range is 3 to 1F hex nibbles.
488 * NOTE: These bits may be only changed when the
489 * Ethernet port is disabled.
490 * 22:22 Limit4 The number of consecutive packet collisions that
491 * occur before the collision counter is reset.
492 * 0: The port resets its collision counter after
493 * 16 consecutive retransmit trials and
494 * restarts the Backoff algorithm.
495 * 1: The port resets its collision counter and
496 * restarts the Backoff algorithm after 4
497 * consecutive transmit trials.
498 * 31:23 Reserved
499 */
500#define ETH_ESPR_JAM_LENGTH_GET(v) ETH__EXT(v, 0, 2)
501#define ETH_ESPR_JAM_IPG_GET(v) ETH__EXT(v, 2, 5)
502#define ETH_ESPR_IPG_JAM_TO_DATA_GET(v) ETH__EXT(v, 7, 5)
503#define ETH_ESPR_IPG_DATA_GET(v) ETH__EXT(v, 12, 5)
504#define ETH_ESPR_Data_Bilnd_GET(v) ETH__EXT(v, 17, 5)
505#define ETH_ESPR_Limit4(v) ETH__BIT(22)
506
507/*
508 * Table 602: Hash Table Pointer Register (HTPR)
509 * 31:00 HTP 32-bit pointer to the address table.
510 * Bits [2:0] must be set to zero.
511 */
512
513/*
514 * Table 603: Flow Control Source Address Low (FCSAL)
515 * 15:0 SA[15:0] Source Address
516 * The least significant bits of the source
517 * address for the port. This address is used for
518 * Flow Control.
519 * 31:16 Reserved
520 */
521
522/*
523 * Table 604: Flow Control Source Address High (FCSAH)
524 * 31:0 SA[47:16] Source Address
525 * The most significant bits of the source address
526 * for the port. This address is used for Flow
527 * Control.
528 */
529
530
531/*
532 * Table 605: SDMA Configuration Register (SDCR)
533 * 01:00 Reserved
534 * 05:02 RC Retransmit Count
535 * Sets the maximum number of retransmits per
536 * packet. After executing retransmit for RC
537 * times, the TX SDMA closes the descriptor with a
538 * Retransmit Limit error indication and processes
539 * the next packet. When RC is set to 0, the
540 * number of retransmits is unlimited. In this
541 * case, the retransmit process is only terminated
542 * if CPU issues an Abort command.
543 * 06:06 BLMR Big/Little Endian Receive Mode
544 * The DMA supports Big or Little Endian
545 * configurations on a per channel basis. The BLMR
546 * bit only affects data transfer to memory.
547 * 0: Big Endian
548 * 1: Little Endian
549 * 07:07 BLMT Big/Little Endian Transmit Mode
550 * The DMA supports Big or Little Endian
551 * configurations on a per channel basis. The BLMT
552 * bit only affects data transfer from memory.
553 * 0: Big Endian
554 * 1: Little Endian
555 * 08:08 POVR PCI Override
556 * When set, causes the SDMA to direct all its
557 * accesses in PCI_0 direction and overrides
558 * normal address decoding process.
559 * 09:09 RIFB Receive Interrupt on Frame Boundaries
560 * When set, the SDMA Rx generates interrupts only
561 * on frame boundaries (i.e. after writing the
562 * frame status to the descriptor).
563 * 11:10 Reserved
564 * 13:12 BSZ Burst Size
565 * Sets the maximum burst size for SDMA
566 * transactions:
567 * 00: Burst is limited to 1 64bit words.
568 * 01: Burst is limited to 2 64bit words.
569 * 10: Burst is limited to 4 64bit words.
570 * 11: Burst is limited to 8 64bit words.
571 * 31:14 Reserved
572 */
573#define ETH_ESDCR_RC_GET(v) ETH__EXT(v, 2, 4)
574#define ETH_ESDCR_BLMR ETH__BIT(6)
575#define ETH_ESDCR_BLMT ETH__BIT(7)
576#define ETH_ESDCR_POVR ETH__BIT(8)
577#define ETH_ESDCR_RIFB ETH__BIT(9)
578#define ETH_ESDCR_BSZ_GET(v) ETH__EXT(v, 12, 2)
579#define ETH_ESDCR_BSZ_SET(v, n) (ETH__CLR(v, 12, 2),\
580 (v) |= ETH__INS(n, 12))
581#define ETH_ESDCR_BSZ_1 0
582#define ETH_ESDCR_BSZ_2 1
583#define ETH_ESDCR_BSZ_4 2
584#define ETH_ESDCR_BSZ_8 3
585
586#define ETH_ESDCR_BSZ_Strings { "1 64-bit word", "2 64-bit words", \
587 "4 64-bit words", "8 64-bit words" }
588
589/*
590 * Table 606: SDMA Command Register (SDCMR)
591 * 06:00 Reserved
592 * 07:07 ERD Enable RX DMA.
593 * Set to 1 by the CPU to cause the SDMA to start
594 * a receive process. Cleared when the CPU issues
595 * an Abort Receive command.
596 * 14:08 Reserved
597 * 15:15 AR Abort Receive
598 * Set to 1 by the CPU to abort a receive SDMA
599 * operation. When the AR bit is set, the SDMA
600 * aborts its current operation and moves to IDLE.
601 * No descriptor is closed. The AR bit is cleared
602 * upon entering IDLE. After setting the AR bit,
603 * the CPU must poll the bit to verify that the
604 * abort sequence is completed.
605 * 16:16 STDH Stop TX High
606 * Set to 1 by the CPU to stop the transmission
607 * process from the high priority queue at the end
608 * of the current frame. An interrupt is generated
609 * when the stop command has been executed.
610 * Writing 1 to STDH resets TXDH bit.
611 * Writing 0 to this bit has no effect.
612 * 17:17 STDL Stop TX Low
613 * Set to 1 by the CPU to stop the transmission
614 * process from the low priority queue at the end
615 * of the current frame. An interrupt is generated
616 * when the stop command has been executed.
617 * Writing 1 to STDL resets TXDL bit.
618 * Writing 0 to this bit has no effect.
619 * 22:18 Reserved
620 * 23:23 TXDH Start Tx High
621 * Set to 1 by the CPU to cause the SDMA to fetch
622 * the first descriptor and start a transmit
623 * process from the high priority Tx queue.
624 * Writing 1 to TXDH resets STDH bit.
625 * Writing 0 to this bit has no effect.
626 * 24:24 TXDL Start Tx Low
627 * Set to 1 by the CPU to cause the SDMA to fetch
628 * the first descriptor and start a transmit
629 * process from the low priority Tx queue.
630 * Writing 1 to TXDL resets STDL bit.
631 * Writing 0 to this bit has no effect.
632 * 30:25 Reserved
633 * 31:31 AT Abort Transmit
634 * Set to 1 by the CPU to abort a transmit DMA
635 * operation. When the AT bit is set, the SDMA
636 * aborts its current operation and moves to IDLE.
637 * No descriptor is closed. Cleared upon entering
638 * IDLE. After setting AT bit, the CPU must poll
639 * it in order to verify that the abort sequence
640 * is completed.
641 */
642#define ETH_ESDCMR_ERD ETH__BIT(7)
643#define ETH_ESDCMR_AR ETH__BIT(15)
644#define ETH_ESDCMR_STDH ETH__BIT(16)
645#define ETH_ESDCMR_STDL ETH__BIT(17)
646#define ETH_ESDCMR_TXDH ETH__BIT(23)
647#define ETH_ESDCMR_TXDL ETH__BIT(24)
648#define ETH_ESDCMR_AT ETH__BIT(31)
649
650/*
651 * Table 607: Interrupt Cause Register (ICR)
652 * 00:00 RxBuffer Rx Buffer Return
653 * Indicates an Rx buffer returned to CPU ownership
654 * or that the port finished reception of a Rx
655 * frame in either priority queues.
656 * NOTE: In order to get a Rx Buffer return per
657 * priority queue, use bit 19:16. This bit is
658 * set upon closing any Rx descriptor which
659 * has its EI bit set. To limit the
660 * interrupts to frame (rather than buffer)
661 * boundaries, the user must set SDMA
662 * Configuration register's RIFB bit. When
663 * the RIFB bit is set, an interrupt
664 * generates only upon closing the first
665 * descriptor of a received packet, if this
666 * descriptor has it EI bit set.
667 * 01:01 Reserved
668 * 02:02 TxBufferHigh Tx Buffer for High priority Queue
669 * Indicates a Tx buffer returned to CPU ownership
670 * or that the port finished transmission of a Tx
671 * frame.
672 * NOTE: This bit is set upon closing any Tx
673 * descriptor which has its EI bit set. To
674 * limit the interrupts to frame (rather than
675 * buffer) boundaries, the user must set EI
676 * only in the last descriptor.
677 * 03:03 TxBufferLow Tx Buffer for Low Priority Queue
678 * Indicates a Tx buffer returned to CPU ownership
679 * or that the port finished transmission of a Tx
680 * frame.
681 * NOTE: This bit is set upon closing any Tx
682 * descriptor which has its EI bit set. To
683 * limit the interrupts to frame (rather than
684 * buffer) boundaries, the user must set EI
685 * only in the last descriptor.
686 * 05:04 Reserved
687 * 06:06 TxEndHigh Tx End for High Priority Queue
688 * Indicates that the Tx DMA stopped processing the
689 * high priority queue after stop command, or that
690 * it reached the end of the high priority
691 * descriptor chain.
692 * 07:07 TxEndLow Tx End for Low Priority Queue
693 * Indicates that the Tx DMA stopped processing the
694 * low priority queue after stop command, or that
695 * it reached the end of the low priority
696 * descriptor chain.
697 * 08:08 RxError Rx Resource Error
698 * Indicates a Rx resource error event in one of
699 * the priority queues.
700 * NOTE: To get a Rx Resource Error Indication per
701 * priority queue, use bit 23:20.
702 * 09:09 Reserved
703 * 10:10 TxErrorHigh Tx Resource Error for High Priority Queue
704 * Indicates a Tx resource error event during
705 * packet transmission from the high priority queue
706 * 11:11 TxErrorLow Tx Resource Error for Low Priority Queue
707 * Indicates a Tx resource error event during
708 * packet transmission from the low priority queue
709 * 12:12 RxOVR Rx Overrun
710 * Indicates an overrun event that occurred during
711 * reception of a packet.
712 * 13:13 TxUdr Tx Underrun
713 * Indicates an underrun event that occurred during
714 * transmission of packet from either queue.
715 * 15:14 Reserved
716 * 16:16 RxBuffer-Queue[0] Rx Buffer Return in Priority Queue[0]
717 * Indicates a Rx buffer returned to CPU ownership
718 * or that the port completed reception of a Rx
719 * frame in a receive priority queue[0]
720 * 17:17 RxBuffer-Queue[1] Rx Buffer Return in Priority Queue[1]
721 * Indicates a Rx buffer returned to CPU ownership
722 * or that the port completed reception of a Rx
723 * frame in a receive priority queue[1].
724 * 18:18 RxBuffer-Queue[2] Rx Buffer Return in Priority Queue[2]
725 * Indicates a Rx buffer returned to CPU ownership
726 * or that the port completed reception of a Rx
727 * frame in a receive priority queue[2].
728 * 19:19 RxBuffer-Queue[3] Rx Buffer Return in Priority Queue[3]
729 * Indicates a Rx buffer returned to CPU ownership
730 * or that the port completed reception of a Rx
731 * frame in a receive priority queue[3].
732 * 20:20 RxError-Queue[0] Rx Resource Error in Priority Queue[0]
733 * Indicates a Rx resource error event in receive
734 * priority queue[0].
735 * 21:21 RxError-Queue[1] Rx Resource Error in Priority Queue[1]
736 * Indicates a Rx resource error event in receive
737 * priority queue[1].
738 * 22:22 RxError-Queue[2] Rx Resource Error in Priority Queue[2]
739 * Indicates a Rx resource error event in receive
740 * priority queue[2].
741 * 23:23 RxError-Queue[3] Rx Resource Error in Priority Queue[3]
742 * Indicates a Rx resource error event in receive
743 * priority queue[3].
744 * 27:24 Reserved
745 * 28:29 MIIPhySTC MII PHY Status Change
746 * Indicates a status change reported by the PHY
747 * connected to this port. Set when the MII
748 * management interface block identifies a change
749 * in PHY's register 1.
750 * 29:29 SMIdone SMI Command Done
751 * Indicates that the SMI completed a MII
752 * management command (either read or write) that
753 * was initiated by the CPU writing to the SMI
754 * register.
755 * 30:30 Reserved
756 * 31:31 EtherIntSum Ethernet Interrupt Summary
757 * This bit is a logical OR of the (unmasked) bits
758 * [30:04] in the Interrupt Cause register.
759 */
760
761#define ETH_IR_RxBuffer ETH__BIT(0)
762#define ETH_IR_TxBufferHigh ETH__BIT(2)
763#define ETH_IR_TxBufferLow ETH__BIT(3)
764#define ETH_IR_TxEndHigh ETH__BIT(6)
765#define ETH_IR_TxEndLow ETH__BIT(7)
766#define ETH_IR_RxError ETH__BIT(8)
767#define ETH_IR_TxErrorHigh ETH__BIT(10)
768#define ETH_IR_TxErrorLow ETH__BIT(11)
769#define ETH_IR_RxOVR ETH__BIT(12)
770#define ETH_IR_TxUdr ETH__BIT(13)
771#define ETH_IR_RxBuffer_0 ETH__BIT(16)
772#define ETH_IR_RxBuffer_1 ETH__BIT(17)
773#define ETH_IR_RxBuffer_2 ETH__BIT(18)
774#define ETH_IR_RxBuffer_3 ETH__BIT(19)
775#define ETH_IR_RxBuffer_GET(v) ETH__EXT(v, 16, 4)
776#define ETH_IR_RxError_0 ETH__BIT(20)
777#define ETH_IR_RxError_1 ETH__BIT(21)
778#define ETH_IR_RxError_2 ETH__BIT(22)
779#define ETH_IR_RxError_3 ETH__BIT(23)
780#define ETH_IR_RxError_GET(v) ETH__EXT(v, 20, 4)
781#define ETH_IR_RxBits (ETH_IR_RxBuffer_0|\
782 ETH_IR_RxBuffer_1|\
783 ETH_IR_RxBuffer_2|\
784 ETH_IR_RxBuffer_3|\
785 ETH_IR_RxError_0|\
786 ETH_IR_RxError_1|\
787 ETH_IR_RxError_2|\
788 ETH_IR_RxError_3)
789#define ETH_IR_MIIPhySTC ETH__BIT(28)
790#define ETH_IR_SMIdone ETH__BIT(29)
791#define ETH_IR_EtherIntSum ETH__BIT(31)
792#define ETH_IR_Summary ETH__BIT(31)
793
794/*
795 * Table 608: Interrupt Mask Register (IMR)
796 * 31:00 Various Mask bits for the Interrupt Cause register.
797 */
798
799/*
800 * Table 609: IP Differentiated Services CodePoint to Priority0 low (DSCP2P0L),
801 * 31:00 Priority0_low The LSB priority bits for DSCP[31:0] entries.
802 */
803
804/*
805 * Table 610: IP Differentiated Services CodePoint to Priority0 high (DSCP2P0H)
806 * 31:00 Priority0_high The LSB priority bits for DSCP[63:32] entries.
807 */
808
809/*
810 * Table 611: IP Differentiated Services CodePoint to Priority1 low (DSCP2P1L)
811 * 31:00 Priority1_low The MSB priority bits for DSCP[31:0] entries.
812 */
813
814/*
815 * Table 612: IP Differentiated Services CodePoint to Priority1 high (DSCP2P1H)
816 * 31:00 Priority1_high The MSB priority bit for DSCP[63:32] entries.
817 */
818
819/*
820 * Table 613: VLAN Priority Tag to Priority (VPT2P)
821 * 07:00 Priority0 The LSB priority bits for VLAN Priority[7:0]
822 * entries.
823 * 15:08 Priority1 The MSB priority bits for VLAN Priority[7:0]
824 * entries.
825 * 31:16 Reserved
826 */
827
828/* Address control registers -- these are offsets from the GT base
829 * and NOT from the ethernet port base. <tss>
830 */
831#define ETH_ACTL_0_LO 0xf200
832
833/* Enable hardware cache snooping;
834 * Copyright Shuchen K. Feng <feng1@bnl.gov>, 2004
835 */
836
837/* Ethernet address control (Low) snoop bits */
838#define RxBSnoopEn ETH__BIT(6) /* Rx buffer snoop enable,1=enable*/
839#define TxBSnoopEn ETH__BIT(14) /* Tx buffer snoop enable */
840#define RxDSnoopEn ETH__BIT(22) /* Rx descriptor snoop enable */
841#define TxDSnoopEn ETH__BIT(30) /* Tx descriptor snoop enable */
842
843#define ETH_ACTL_0_HI 0xf204
844/* Ethernet address control (High), snoop bits */
845#define HashSnoopEn ETH__BIT(6) /* Hash Table snoop enable */
846
847
848#define ETH_ACTL_1_LO 0xf220
849#define ETH_ACTL_1_HI 0xf224
850#define ETH_ACTL_2_LO 0xf240
851#define ETH_ACTL_2_HI 0xf244
852
853
854#endif /* _DEV_GTETHREG_H_ */
Definition: gtethreg.h:61
