RTEMS 5.2
Files | Data Structures
LCD support. More...
file  lpc-lcd.h
 LCD support API.
struct  lpc_cursor
struct  lpc_lcd
LCD Configuration Register
#define LCD_CFG_CLKDIV(val)   BSP_FLD32(val, 0, 4)
#define LCD_CFG_HCLK_ENABLE   BSP_BIT32(5)
#define LCD_CFG_MODE_SELECT(val)   BSP_FLD32(val, 6, 7)
#define LCD_CFG_DISPLAY_TYPE   BSP_BIT32(8)
LCD Horizontal Timing Register
#define LCD_TIMH_PPL(val)   BSP_FLD32(val, 2, 7)
#define LCD_TIMH_PPL_GET(reg)   BSP_FLD32GET(reg, 2, 7)
#define LCD_TIMH_HSW(val)   BSP_FLD32(val, 8, 15)
#define LCD_TIMH_HSW_GET(reg)   BSP_FLD32GET(reg, 8, 15)
#define LCD_TIMH_HFP(val)   BSP_FLD32(val, 16, 23)
#define LCD_TIMH_HFP_GET(reg)   BSP_FLD32GET(reg, 16, 23)
#define LCD_TIMH_HBP(val)   BSP_FLD32(val, 24, 31)
#define LCD_TIMH_HBP_GET(reg)   BSP_FLD32GET(reg, 24, 31)
LCD Vertical Timing Register
#define LCD_TIMV_LPP(val)   BSP_FLD32(val, 0, 9)
#define LCD_TIMV_LPP_GET(reg)   BSP_FLD32GET(reg, 0, 9)
#define LCD_TIMV_VSW(val)   BSP_FLD32(val, 10, 15)
#define LCD_TIMV_VSW_GET(reg)   BSP_FLD32GET(reg, 10, 15)
#define LCD_TIMV_VFP(val)   BSP_FLD32(val, 16, 23)
#define LCD_TIMV_VFP_GET(reg)   BSP_FLD32GET(reg, 16, 23)
#define LCD_TIMV_VBP(val)   BSP_FLD32(val, 24, 31)
#define LCD_TIMV_VBP_GET(reg)   BSP_FLD32GET(reg, 24, 31)
LCD Clock and Signal Polarity Register
#define LCD_POL_PCD_LO(val)   BSP_FLD32(val, 0, 4)
#define LCD_POL_PCD_LO_GET(reg)   BSP_FLD32GET(reg, 0, 4)
#define LCD_POL_CLKSEL   BSP_BIT32(5)
#define LCD_POL_ACB(val)   BSP_FLD32(val, 6, 10)
#define LCD_POL_ACB_GET(reg)   BSP_FLD32GET(reg, 6, 10)
#define LCD_POL_IVS   BSP_BIT32(11)
#define LCD_POL_IHS   BSP_BIT32(12)
#define LCD_POL_IPC   BSP_BIT32(13)
#define LCD_POL_IOE   BSP_BIT32(14)
#define LCD_POL_CPL(val)   BSP_FLD32(val, 16, 25)
#define LCD_POL_CPL_GET(reg)   BSP_FLD32GET(reg, 16, 25)
#define LCD_POL_BCD   BSP_BIT32(26)
#define LCD_POL_PCD_HI(val)   BSP_FLD32(val, 27, 31)
#define LCD_POL_PCD_HI_GET(reg)   BSP_FLD32GET(reg, 27, 31)
LCD Line End Control Register
#define LCD_LE_LED(val)   BSP_FLD32(val, 0, 6)
#define LCD_LE_LEE   BSP_BIT32(16)
LCD Control Register
#define LCD_CTRL_LCDEN   BSP_BIT32(0)
#define LCD_CTRL_LCDBPP(val)   BSP_FLD32(val, 1, 3)
#define LCD_CTRL_LCDBPP_GET(reg)   BSP_FLD32GET(reg, 1, 3)
#define LCD_CTRL_LCDBW   BSP_BIT32(4)
#define LCD_CTRL_LCDTFT   BSP_BIT32(5)
#define LCD_CTRL_LCDMONO8   BSP_BIT32(6)
#define LCD_CTRL_LCDDUAL   BSP_BIT32(7)
#define LCD_CTRL_BGR   BSP_BIT32(8)
#define LCD_CTRL_BEBO   BSP_BIT32(9)
#define LCD_CTRL_BEPO   BSP_BIT32(10)
#define LCD_CTRL_LCDPWR   BSP_BIT32(11)
#define LCD_CTRL_LCDVCOMP(val)   BSP_FLD32(val, 12, 13)
#define LCD_CTRL_LCDVCOMP_GET(reg)   BSP_FLD32GET(reg, 12, 13)
#define LCD_CTRL_WATERMARK   BSP_BIT32(16)
LCD Interrupt Registers
#define LCD_INT_FUF   BSP_BIT32(1)
#define LCD_INT_LNBU   BSP_BIT32(2)
#define LCD_INT_VCOMP   BSP_BIT32(3)
#define LCD_INT_BER   BSP_BIT32(4)
LCD Color Palette Register
#define LCD_PAL_R(val)   BSP_FLD16(val, 0, 4)
#define LCD_PAL_G(val)   BSP_FLD16(val, 5, 9)
#define LCD_PAL_B(val)   BSP_FLD16(val, 10, 14)
#define LCD_PAL_I   BSP_BIT16(15)
LCD support.
