RTEMS 5.2
Files | Macros
Ethernet Support
Ethernet support. More...
file  lpc-ethernet-config.h
 Ethernet driver configuration.
file  lpc-ethernet.c
 Ethernet driver.
#define LPC_ETH_CONFIG_INTERRUPT   LPC32XX_IRQ_ETHERNET
#define LPC_ETH_CONFIG_REG_BASE   LPC32XX_BASE_ETHERNET
#define LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT   16
#define LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX   INT_MAX
#define LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT   32
#define LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX   INT_MAX
#define LPC_ETH_CONFIG_UNIT_MULTIPLE   8U
#define LPC_ETH_CONFIG_USE_TRANSMIT_DMA
Ethernet support.
